Which Dialogic Card Is Best?
Hi. I'm ready to purchase VoiceGuide's software but need to know which Dialogic card is best for my needs. My thought is to simply start with the D/4PCIUF model but would like to get the OK from some experienced users. The card will be installed in an XP machine and we will be using standard wav files and the text-to-speech option. Is the D/4PCIUF card the best solution for this? Thanks for any info. -Brian
D/4PCIUF is the best option if you do not need to do "Dial and Conference" (tromboned) type call transfers.
If you need to do "Dial and Conference" type call transfers then you should look at a D/4PCIU card.
