Guest art Report post Posted 06/08/2007 09:55 AM 1. When I select any element, do right click and select Delete, element deleted, but then if I do right click on another element, the context menu does not appears. 2. I can't write Russian characters in VBS module. In description - ok, but not in script text. I can't write comments in my code Can you do something with it? Thanx Share this post Link to post
SupportTeam Report post Posted 06/08/2007 10:11 AM 1. When I select any element, do right click and select Delete, element deleted, but then if I do right click on another element, the context menu does not appears. Not seeing this problem on our script designer. Which version script designer are you using? (we just tested with v6.0.3033) 2. I can't write Russian characters in VBS module. In description - ok, but not in script text. I can't write comments in my code Yes. Unicode is not supported everywhere in the current version Script Designer. Share this post Link to post
Guest art Report post Posted 06/08/2007 10:25 AM Not seeing this problem on our script designer. Which version script designer are you using? (we just tested with v6.0.3033) 6.0.3003 Now I use delete button on panel to preserve right click menu. Yes. Unicode is not supported everywhere in the current version Script Designer. It's sadly enough, but I've found a way. I've just substituted parameter in registry for codepages 1250 and 1252 with my russian c_1251.nls file. Share this post Link to post
