Guest DashboardResearch Report post Posted 06/12/2007 02:34 PM hi i am trying out the VoiceGuide Events Catcher example, but since i am using VB.net i have modified the code a bit, i basically translated it to vb.net. The program does not work i am not catching any events, i have attached my code please help. Form1.txt Share this post Link to post
SupportTeam Report post Posted 06/12/2007 11:58 PM Which version of VoiceGuide are you using? Share this post Link to post
Guest DashboardResearch Report post Posted 06/13/2007 07:54 AM Which version of VoiceGuide are you using? its Version 5.02.5012 Share this post Link to post
Guest DashboardResearch Report post Posted 06/14/2007 02:18 PM hi i am trying out the VoiceGuide Events Catcher example, but since i am using VB.net i have modified the code a bit, i basically translated it to vb.net. The program does not work i am not catching any events, i have attached my code please help. Can someone please help me with this, i am trying to get voice guide to trigger events in a vb.net application Share this post Link to post
SupportTeam Report post Posted 06/15/2007 12:55 AM External software programming issues like this one is outside the scope of this support forum. v7 of VoiceGuide will have a Web Services interface and a .NET Remoting interface - so it will be easier to integrate .NET applications with v7 then trying to write .NET apps to receive COM events from v5/v6 versions. (v7 will also retain the COM interface) Share this post Link to post
