Time Out Problem
I'm making outdialing campains and aftrer 6 or 7 rings the systems considers that the call is answered. (always same duration)
It is not a problem of tone detection because before these 6 or 7 rings the system does not detect any anwser and when hook off the set the detection is correct. The system work perfectly until these duration is reached
- Is there any time out that I'm missing some where ?
Tks
MH
We'll need to see the traces to see what is happening on these outgoing calls.
[Log]
VoiceGuide=10
ktTel=10
Please post the traces.
