Strore Pressed Keys For One Called Number
Hi
I would like to do this:
I'm asking 4 questions one after the other.
The next question is not the result of the previous one I'm always asking these 4 question in the same order
I would like to record the anwser "1" or "2" for each of these 4 questions
How can I strore these 4 anwsers for one same called number.?
MH
I mean , do I have tiç use 5 Play module with between them access to DB query to record that Or do I have to use Get number. In that second case how can I record the result in a DB or a text file ?
Tkx
MH
You should use a sequence of Play modules one after another.
Then to obtain a string of what was pressed in these modules just concatenate the Result Variables from the Play modules together.
Eg. if the Play modules are titled "Question 1", "Question 2", "Question 3" and "Question 4" then use the expression to obtain the entered number string:
$RV[Question 1]$RV[Question 2]$RV[Question 3]$RV[Question 4]
Use this expression in your Database SQL string or VBScripts or parameter to a called program etc.
I'm sorry, but I need your help to setup this?.
What do I have to define in the Path for each of the play modules.
If I wnat to use a DB query to store the values in an access DB, could you please give a concret example using the scipt attached. I mean what shoub be the trigger to run the DB query.
It would be nice if you could help me complete this script
Tkx
MH
CCI_IMMO2.vgs
Have a look at attached script. This will get you pretty close.
Looks like you still need to create the actual database into which the data will be saved...
Let us know if you still have any questions.
CCI_IMMO2.vgs
Thnks I 'll try this and let you..
This is what I call efficient Support !!!!!!!!!!! :-)
hi I have tried this, it works, but:
- if a called presses 1 for the first play module and hangs up on the second, no information is kept ..
How can I store the informationeven if he hangs up.
Tkx
MH
I'm trying to send email.
There is an error that I do not understand.
You specified "http://193.252.107.113" as the smtp server address....
That is not a valid stmp server address expression...
