Vb Scripts Running Failed
I tried to use the sample VB scripts 'Write to file'. It will write the infomation to the file. but it always take fail path if I choose 'wait until scripts complete'. thanks for your reply.
From http://www.voiceguide.com/vghelp/html/modVbs.htm :
A "Success" or Result Variable list must be returned to VoiceGuide (either though a Run_ResultReturn COM function or a Result File) in order for it to go down the Success path.
If no result is returned then the "Fail" path is taken after the VBScript completes.
Calls to Script_Gosub(), Script_Goto() and Script_Return() functions result in immediate running of the next module.
