XOLimited Report post Posted 06/22/2007 04:18 AM HI there, I'm having a problem with inserting html into the access file. For some reason, the insert query stops after inserting after only part of the txt: <html> <head> <meta http-equiv="Content-Language" content="en-nz"> <meta http-equiv="Content-Type" content="text/html; charset=windows-1252"> <title>XO Limited</title> <style> <!-- .bold-grey { color:#666666; font-weight:400; And then continues successfully and sends the email with only that part of the HTML. THe field on the access database is set to MEMO so it should not have any problem inserting that amount of data. Also, we're using a VBS script to grab HTML from a txt file and then inserting it into the access database. The HTML has variables in it. WIll voiceguide insert the correct variables automatically, or do we have to run find and replace functions on the txt? Thanks Tim Attached log and full html email 0622vgm.txt HTM.txt Share this post Link to post
SupportTeam Report post Posted 06/22/2007 04:40 AM This is really more of a VBScript and/or MSAccess related question and outside the scope of this support forum. NB. your post was split away from the thread in which it was originally posted as it was off-topic in that other thread (which related to sending HTML Emails). Share this post Link to post
