Voiceguide 6.03003 And Sendmail
I have Voiceguide set up to send mail automatically by connecting to my SMTP server. Voiceguide indicates that the email is sent successfully, but the mail never arrives. The server logs show a good connection to the server and authentication from the Voiceguide machine, and then:
Jun 27 11:36:46 SERVERNAME sendmail[27093]: l5RFajEZ027093: VOICEGUIDECLIENT did not issue MAIL/EXPN/VRFY/ETRN during connection to MTA
So, it appears that Voiceguide is never actually sending the email after making the connection.
This email contains a whole pile of $RVs (which all show correctly in the Voiceguide call log) and has a recorded wave file as an attachment.
Any suggestions?
[Log]
VoiceGuide=10
EmailSender=10
Hi, sorry it took so long to get back to you - the problem was an authentication error, literally just a bad password. Now it works.
So, since Voiceguide was logging it as an authentication error, why was the script taking the "On {success}" branch instead of the "on {fail}" branch in the script logic? As it says in the thread title, I'm running version 6.03003.
Email is sent in the background and some emails may take a while to send, that is why VoiceGuide will not wait for the actual sending of the email. The IVR script needs to go to the next module without keeping the caller waiting. The module takes success path when email has been *queued* to be sent.
Ultimately, you never get a confirmation that an email has been received at the remote end either.
