Guest Jonah Report post Posted 07/07/2007 08:02 PM Where can I get specific information to pass on to my Telecom Guy about the T1 lines that I will have him install to work with VoiceGuide? Share this post Link to post
SupportTeam Report post Posted 07/08/2007 12:18 AM We recommend that the T1 lines be configured as ISDN (not as Robbed Bit). Especially if you will be using the lines for outgoing calls. Different Telco's support different versions of ISDN, but any one of them is fine as the Dialogic card will work with all of them. You just need to set in the Dialogic Configuration Manager which one of the 10 or so ISDN choices is used on this line and the connection will just work. Common choice for ISDN protocol is "NI2", if your Telco supports NI2 then you should ask for them to use that on the T1 line which they will provide. Share this post Link to post
