ktruk Report post Posted 07/13/2007 06:00 PM Hi, if I use the 'inbuilt' $RV[scriptPath] in a VBS module (script1), which is called by a script (script2 - goto script1), which is itself specified as the script in an 'onAnswer' script in a 'Send Message' module, this RV ends up blank. If the same script is called directly, then the RV works. However, if I use the (now obsolete?) '$RV[scriptsPath]' then it works as expected. If I check the logs, then the [scriptPath] is missing and the [scriptsPath] is present (for outdial calls only). Can you check this please? Thanks. Share this post Link to post
SupportTeam Report post Posted 07/14/2007 08:41 AM We'll look in to this and should have a a version which makes $RV[scriptPath] (instead of '$RV[scriptsPath]') available on outgoing calls. Share this post Link to post
ktruk Report post Posted 07/14/2007 12:25 PM ok, thanks. Just a note: would prefer 'as well as' rather than 'instead of' as my now working scripts will break again if you take away the [scriptSpath] RV. Share this post Link to post
SupportTeam Report post Posted 07/16/2007 03:29 AM Attached version should now set $RV[scriptPath] properly. ($RV[scriptsPath] is still available, but we'd recommend stopping using it) VgMulti_6.0.3351.zip Share this post Link to post
ktruk Report post Posted 07/18/2007 06:49 PM Thank you for the fix, just one problem, I need this in v5.2.5xxx code stream as I am not currently using Dialogic cards. (I did mention my current version in the original post). If you can back issue this in v5 I promise to stop using the old RV (!!) is it a deal? ;-) Thanks again - Tim. Share this post Link to post
SupportTeam Report post Posted 07/18/2007 10:37 PM Please update with attached version. VgMulti_5.2.5061.zip Share this post Link to post
