New Scripts Installation
I have just bought a used Dialogic Board D4PCIUF and successfully
installed on my Windows 2003 Standard Server with Service Pack 2.
Also, I have installed VoiceGuide V7.0.0 Trial Version. It has loaded
with default Credit Card Payment script test module.
It run service wihtout problem. The test run with default script seems fine.
I have tried to do some simple test scripts prior to looking into
actual application scripts flow and purchase the VoiceGuide. I can't
load my test script to run.
At script designer, I click on "set and run current script", it
responded as vgmulti.exe could not be found.
I didn't see VG System Manager. However, I noticed config.xml and has
the script parameter. Is there any better to change and load new test
scripts?
Please see answer posted here: http://voiceguide.com/forums/index.php?showtopic=5077
Right now the script needs to be set in Config.xml file and VoiceGuide needs to be restarted for the changes in Config.xml to be read in.
This setting usually only needs to be set once tom point the script you want to use when the system is configured and does not need changing afterwards. Any changes would be made to the script itself using the Script Designer.
