intrakartal Report post Posted 07/20/2007 06:49 PM After I installed VG 7 (using D4PCIUF card) I could not start IVR Service. .NET 3 is installed. Thanks Share this post Link to post
SupportTeam Report post Posted 07/21/2007 12:19 AM Could you please post a copy of VoiceGuide's Trace Logs which are created in VG's \log\ subdirectory, this will allow us to see what happened. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
intrakartal Report post Posted 07/21/2007 07:00 AM You can find the log folder zipped and attched. there is a text in the log files which is turkish "İşletim sistemi 'i çalıştıramıyor. (HRESULT özel durum döndürdü: 0x800700B6)" its basic translation is: Operating System could not start.( HRESULT returns special condition: 0x800700b6) Thanks in advance. Log.zip Share this post Link to post
intrakartal Report post Posted 07/21/2007 07:24 AM Also Event viewer has some logs in it which is: (They are in turkish so I have translated them.) Application: Event Type: Error Event Source: VoiceGuide IVR Event Category: Yok Event ID: 0 Date: 7/21/2007 Time: 10:20:54 AM User: Yok Computer: 2859527FD234424 Açıklama: Hizmet başlatılamıyor. System.ArgumentNullException: Değer null olamaz. ---> .: SmartExceptionsCore.UnhandledException @ 231, offset:264 --- İç özel durum yığını izlemesinin sonu --- konum: ..OnStart(String[] args) konum: System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state) Ek bilgi için http://go.microsoft.com/fwlink/events.asp adresindeki Yardım ve Destek Merkezi'ne bakın. And Voice guide: Olay Türü: Hata Olay Kaynağı: vgIvrService Olay Kategorisi: Yok Olay Kimliği: 0 Tarih: 7/21/2007 Saat: 10:20:52 AM Kullanıcı: Yok Bilgisayar: 2859527FD234424 Açıklama: StartVgEngine EngineStart returned error:EngineStart references list System.BadImageFormatException: İşletim sistemi 'i çalıştıramıyor. (HRESULT özel durum döndürdü: 0x800700B6) konum: System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) konum: System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) konum: System.Reflection.Assembly.Load(AssemblyName assemblyRef) konum: vgEngine.EngineControl.EngineStart(String sParamsXml_file, String sParamsXml, String sIniFile, String sAppPath) Ek bilgi için http://go.microsoft.com/fwlink/events.asp adresindeki Yardım ve Destek Merkezi'ne bakın. Share this post Link to post
intrakartal Report post Posted 07/21/2007 08:03 AM Sorry before I finish my translation, I accidently post it Also Event viewer has some logs in it which is: (They are in turkish so I have translated them.) Application: Event Type: Error Event Source: VoiceGuide IVR Event Category: None Event ID: 0 Date: 7/21/2007 Time: 10:20:54 AM User: None Computer : 2859527FD234424 Explanation: Service could not start. System.ArgumentNullException: Value can not be null. ---> .: SmartExceptionsCore.UnhandledException @ 231, offset:264 --- İç özel durum yığını izlemesinin sonu --- (Believe me this sentence is imposible to translate but it should be: "End of inner exception stack trace" Position: ..OnStart(String[] args) Position: System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state) And Voice guide: Event Type: Error Event Source: vgIvrService Event Category: None Event ID: 0 Date: 7/21/2007 Time: 10:20:52 AM User: Yok Computer : 2859527FD234424 Explanation: StartVgEngine EngineStart returned error:EngineStart references list System.BadImageFormatException: Operating System Could not start. (HRESULT returns a special condition: 0x800700B6) Position: System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) Position: System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) Position: System.Reflection.Assembly.Load(AssemblyName assemblyRef) Position: vgEngine.EngineControl.EngineStart(String sParamsXml_file, String sParamsXml, String sIniFile, String sAppPath) Share this post Link to post
SupportTeam Report post Posted 07/22/2007 12:09 AM Which version of Dialogic System Release drivers is used on this system? Is the Dialogic service started before installing VoiceGuide? Do the test applications provided with the Dialogic System Release (eg: Voice Horoscope) work? Share this post Link to post
intrakartal Report post Posted 07/23/2007 09:59 AM SR5.1.1 SP1 with D/4PCI-U point release patch. The board is started via Dialogic Configurator. Test programs works fine. Share this post Link to post
SupportTeam Report post Posted 07/23/2007 12:31 PM Can you try installing SR6.0 to see if the system starts when SR6.0 is used? Can we access this machine using PCAnywhere or logmein.com? If that's not possible then can you use the DependencyWalker tool on the ktTelDialogic*.dll files to see which DLL is missing on this system which prevents the Dialogic driver files from being loaded. Dependency Walker can be downloaded from: http://www.dependencywalker.com/ Here is direct link to current version: http://www.dependencywalker.com/depends22_x86.zip Share this post Link to post
intrakartal Report post Posted 07/23/2007 01:59 PM Can you try installing SR6.0 to see if the system starts when SR6.0 is used? Can we access this machine using PCAnywhere or logmein.com? If that's not possible then can you use the DependencyWalker tool on the ktTelDialogic*.dll files to see which DLL is missing on this system which prevents the Dialogic driver files from being loaded. Dependency Walker can be downloaded from: http://www.dependencywalker.com/ Here is direct link to current version: http://www.dependencywalker.com/depends22_x86.zip Share this post Link to post
intrakartal Report post Posted 07/23/2007 02:31 PM Can you try installing SR6.0 to see if the system starts when SR6.0 is used? Can we access this machine using PCAnywhere or logmein.com? If that's not possible then can you use the DependencyWalker tool on the ktTelDialogic*.dll files to see which DLL is missing on this system which prevents the Dialogic driver files from being loaded. Dependency Walker can be downloaded from: http://www.dependencywalker.com/ Here is direct link to current version: http://www.dependencywalker.com/depends22_x86.zip Dear Sirs, You can access using VNC, if it's OK, pls send me an email address to send you connection details. We downloaded dependencywalker, both kteldialogichmp30.dll and kteldialogicsr60.dll gives error: "Error: At least one module has an unresolved import due to a missing export function in an implicitly dependent module. Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module." Another point, we purchased dialogic card from authorised reseller,no sw arrived with the card, as you will see from link you gave (recommended hardware), SR6.0 is not free, you have to purchase an agreement to download it. If it is not so, pls. give us a valid link to download it free. In other words, latest free version for dialogic 4dpci card is version 5.1, so we cannot install 6.0 version. Thanks in advance, Share this post Link to post
SupportTeam Report post Posted 07/23/2007 09:54 PM You can access using VNC, if it's OK, pls send me an email address to send you connection details. support@voiceguide.com Please reference this thread in the email - wither by title or by direct link. Share this post Link to post
