Trouble Running Command.com
Version used: Voice Guide 4.9.0 -trial version
Machine Configuration: Pentium III 800 Mhz with Windows 2000 SP3
The Run Program module is not writing out the data that the caller has entered into a file.
C:\WINNT\system32\command.com /C echo $RV[NIR] > C:\Progra~1\VoiceGuide\Scripts\Helpdesk\output.txt
Rest everything works, here is the trace file:
89022 8 tapie linedevstate 2048 0 0
89032 8 tapie callstate OFFERING 66394 0 4
89042 8 tapie callinfo CALLEDID
89042 8 tapie callinfo ORIGIN
89042 8 tapie ring 0
95041 8 tapie ring 2
95041 8 Answer the call
95051 8 lineAnswer(66394) => 66445
95582 8 tapie callstate CONNECTED 66394,1,0
95582 8 WorkingModeTAPI=
95582 8 WorkingModeScript=
95642 8 Inband detection not enabled
95642 8 tapi Reply 66445 0
95642 8 [Welcome Message] Number Input
95642 8 [Welcome Message] Playing (C:\Program Files\VoiceGuide\Scripts\Helpdesk\A1.wav)
95662 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Helpdesk\A1.wav]
96843 8 tapie monitordigits 53 2
96843 8 LsGetNbrsPlayWelcMsg [5]
96893 8 PlaySoundStop ok
96893 8 [Welcome Message] Number Input 5
97144 8 tapie monitordigits 35 2
97144 8 LsGetNbrsRxDigits [#]
97144 8 [AT&T Wireless] Number Input
97144 8 [AT&T Wireless] Playing (C:\Program Files\VoiceGuide\Scripts\Helpdesk\A11.wav)
97164 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Helpdesk\A11.wav]
97705 8 tapie monitordigits 50 2
97705 8 LsGetNbrsPlayWelcMsg [2]
97755 8 PlaySoundStop ok
97765 8 [AT&T Wireless] Number Input 2
98065 8 tapie monitordigits 35 2
98065 8 LsGetNbrsRxDigits [#]
98065 8 [security Level] Number Input
98065 8 [security Level] Playing (C:\Program Files\VoiceGuide\Scripts\Helpdesk\A117.wav)
98095 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\Helpdesk\A117.wav]
98626 8 tapie monitordigits 49 2
98626 8 LsGetNbrsPlayWelcMsg [1]
98686 8 PlaySoundStop ok
98686 8 [security Level] Number Input 1
98956 8 tapie monitordigits 35 2
98956 8 LsGetNbrsRxDigits [#]
98956 8 [Record Incident] Recording
98976 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voicedlgc\beep1.wav]
99177 8 wb(59895600)
99227 8 Play End line[8] (id=598956)
99227 8 LsRecPlayBeep EV_PLAY_FINISHED
99247 8 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Helpdesk\0814102230_8_.wav] ok
99247 8 RecFile[C:\Program Files\VoiceGuide\Scripts\Helpdesk\0814102230_8_.wav]
99968 8 tapie monitordigits 52 2
99968 8 LsRecRecording [4]
00669 8 tapie monitordigits 35 2
00669 8 LsRecRecording [#]
00719 8 RecSoundStopTruncBytes ok
00729 8 [NIR] Evaluate [Cstr($RV_MONTH)&Cstr($RV_DATE)&Cstr($RV_HOUR)&Cstr($RV_MINUTE)&Cstr($RV_SECOND)&Cstr($RV[security Level])]
00729 8 RVreplace start: [Cstr($RV_MONTH)&Cstr($RV_DATE)&Cstr($RV_HOUR)&Cstr($RV_MINUTE)&Cstr($RV_SECOND)&Cstr($RV[security Level])]
00729 8 RVreplace end: [Cstr(8)&Cstr(14)&Cstr(10)&Cstr(22)&Cstr(31)&Cstr(1)]
00729 8 .Eval(Cstr(8)&Cstr(14)&Cstr(10)&Cstr(22)&Cstr(31)&Cstr(1))
00729 8 Eval Expr result:[8141022311]
00739 8 RVreplace start: [$RV[NIR]]
00739 8 RVreplace end: [8141022311]
00739 8 [Replay NIR] Say numbers: 8141022311 as Digits
00739 8 fn PlaySoundStartNumbers C:\Program Files\VoiceGuide\Scripts\Helpdesk\PayYouArePaying.wav, , 8141022311, Digits
00739 8 twcal PlaySayNumber C:\Program Files\VoiceGuide\Scripts\Helpdesk\PayYouArePaying.wav, , 8141022311, , 1
00789 8 PlaySoundStartNumbers ok
09962 8 wb(60074910)
10022 8 Play End line[8] (id=600749)
10022 8 LsSayNbrPlay EV_PLAY_FINISHED
20017 8 LsSayNbrPlay EV_TIMEOUT_HANGUP
20017 8 PlaySoundStop ok
20017 8 HangupCall called from []
20027 8 Hanging up call...
20037 8 PlaySoundStop ok
20037 8 fnHangupCall end
20087 8 tapie linedevstate 2048 0 0
20087 8 tapie callstate IDLE 66394 0 0
20097 8 WorkingMode@Idle=
20147 8 set EV_TIMEOUT_TIMETOREINITLINE 2
20147 8 tapi Reply 66514 0
21048 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
21048 8 ReinitTelephony due to IDLE start
21048 8 tapic lineDeallocateCall(MainCall:66394) 0
21339 8 lineOpen(8) => 0
21339 8 Waiting for a call...
21349 8 lineOpen(8)LineHandle=65540
Any pointers would be very helpful
What is the name of the Run Program module?
The trace does not show any Run Program modules called...
Please post the script used and we can see why the Run Program module is not called at all...
BTW: v5.0 also has the following RVs:
$RV_DD
Takes on a 2 digit value between "01" and "31", depending on what day of the month it is. Can be used in Evaluate Expression modules to allow you to switch to different areas on the script depending on what day of the month it is.
$RV_MM
Takes on a 2 digit value between "01" and "12", depending on what month it is. Can be used in Evaluate Expression modules to allow you to switch to different areas on the script depending on the current month.
$RV_YY
Takes on a 2 digit value of current year (eg: "03"). Can be used in Evaluate Expression modules to allow you to switch to different areas on the script depending on the current year.
$RV_HH
Takes on a 2 digit value between "00" and "23", depending on the current hour of the day. Can be used in Evaluate Expression modules to allow you to switch to different areas on the script depending on the time of day.
$RV_NN
Takes on a 2 digit value between "00" and "59", depending on the current minute of the hour. Can be used in Evaluate Expression modules to allow you to switch to different areas on the script depending on the time of day.
$RV_SS
Takes on a value between "00" and "59", depending on the current second of the hour. Can be used in Evaluate Expression modules to allow you to switch to different areas on the script depending on the time of day.
Thanks, I will try that.
Also I placed a purchase on the software today. Any pointers where I could get the version 5.0? The beta version available on katalinatech seem to be corrupted upon download.
The download is OK - many people are using it...
I'd suggest downloading again...
