Dialing With Modem Tapi
Hello,je voudrais appeler plusieurs n°s avec mon ligne simple.
J'utilise une modem simple et 1 ligne.
je voudrais appeler une apres l'autre des millier n°s de tel.
planifier entre 7h00 du matin au 19h00
de lundi au vendredi.
je veut que les telephones appeler ,affiche mon n°
je veut laissez sonner 5 fois au max et jouer une .wav file de 5 sec apres decrochage.
racrocher et appeler le prochain.
est-ce que il y a une script qui raproche mes demandes
ou doit je creé ça?
Pour etre honnet j'ai passer des heures a chercher mais cette merveilleuse outil,est trop compliqué pour moi.
donc si un de vous "wizkids" could please help me??
Je vous ecrit de la Nouvelle caledonie et ici on est encore tres en retard.......
Babelfish translation :
Hello, I would like to call several n°s with my single circuit line. I use a simple modem and 1 line. I would like to invite after the other of the n°s thousand tel. to plan between 7h00 morning with the 19h00 of Monday to Friday. I wants that the telephones to call, posts my n° I wants let sound 5 times at the max and play a wav files of 5 dryness after decrochage. racrocher and call the next one. is there a script which raproche my requests or must I creé that? To be honnet I have to pass the hours has to seek but this marvellous tool, is too complicated for me thus if one of you "wizkids" could please help me?? I you ecrit of the News caledonie and here one is still very late.......
To make outgoing calls you will need to use a Dialogic card. Please see: http://www.voiceguide.com/suppRecomHardware.htm
Please also see: http://www.voiceguide.com/vgDialer.htm
:unsure: HI ,thanks for prompt reply,and sorry that i wrote in french,i'm using a SONY vaio laptop computer,with internal modem,if i want to make outgoing calls i need a dialogic card you just told me.in the list of card recommended there are only listed dialogic inbuild cards ,could you pls suggest a model that can b used with laptops. Thanks in advance :rolleyes:
Dialogic card require a PCI or PCIx slots. You will need a standalone computer to use a Dialogic card.
Outgoing calls using voice modems are possible, but as modem cannot detect when the call is answered the system will play a message asking recipient of the call to "press 1 to accept the call". This is why Dialogic cards are used for systems which deliver outbound messages. Dialogic cads can detect when the outgoing call has been answered.
