Problem To Configure D/41epci
Some help, please!
Dialogic card: D/41EPCI
Windows XP SP2
SR5.1.1.
The D/41EPCI card is not detected. Instead I get an "Other PCI Bridge Device”
In Universal Dialogic Diagnostics Utility I get:
WSB0010: Warning No Springware Board(s) found - check system configuration
Do I have to use SR5.1.1 and SP1
Or are D/41EPCI works with Windows XP SP2 and SR6.02
Or is Windows 2000/2003 can solve the problem.
As you see, I’m totally confused . Help, please
Tanks in advance
Regards,
E.P.
The Windows XP SP2 + SR5.1.1 + SP1 drivers combination should work.
Is the card displayed in the Dialogic Configuration Manager app?
There should be "Search for cards" or "Discover cards" command in one of the menu options in the Dialogic Configuration Manager, try selecting those options and see if the Dialogic Configuration Manager can find the D/41EPCI.
