EPierre Report post Posted 09/08/2007 11:29 PM Some help, please! Dialogic card: D/41EPCI Windows XP SP2 SR5.1.1. The D/41EPCI card is not detected. Instead I get an "Other PCI Bridge Device” In Universal Dialogic Diagnostics Utility I get: WSB0010: Warning No Springware Board(s) found - check system configuration Do I have to use SR5.1.1 and SP1 Or are D/41EPCI works with Windows XP SP2 and SR6.02 Or is Windows 2000/2003 can solve the problem. As you see, I’m totally confused . Help, please Tanks in advance Regards, E.P. Share this post Link to post
SupportTeam Report post Posted 09/09/2007 12:32 AM The Windows XP SP2 + SR5.1.1 + SP1 drivers combination should work. Is the card displayed in the Dialogic Configuration Manager app? There should be "Search for cards" or "Discover cards" command in one of the menu options in the Dialogic Configuration Manager, try selecting those options and see if the Dialogic Configuration Manager can find the D/41EPCI. Share this post Link to post
