$rv_cidnumber
hi
Need help, I want to to run a script that says when $RV_CIDNUMBER = some number do something if not do something else.
rings before answering inbound call is set on 2
Popup callerID when number is recieved is selected
here is the code:
If $RV_CIDNUMBER = "" Then
msgbox "Unknown"
Else
CallerID = $RV_CIDNUMBER
End if
:unsure:
The VBScript should have quotes around the $RV_CIDNUMBER, like this:
If "$RV_CIDNUMBER" = "" Then
'msgbox "Unknown"
CallerID = "Unknown"
Else
CallerID = "$RV_CIDNUMBER"
End if
Note that in v7 of VoiceGuide the MsgBoxes are not displayed on the screen, as v7 runs as a Windows Service. Only in v5 and v6 will the MsgBoxes be displayed (if they are ran as a normal program and not as a Windows Service)
Another approach would be to use an Evaluate Expression module to test and branch based on the $RV_CIDNUMBER value.
Hie
Thank you for the feedback, My script is now working the only problem is that i don't seem to be getting the $rv_cidnumber its always equal to nothing.
I have tried it with ring counts = 2 and with ring count = 2 and it still says $rv_cidnumber = ""
What can i do to ensure that i recieve the $rv_cidnumber(caller's number). I need this to search in my database and direct the caller to the right script.
Appreciate your help :unsure:
Is the CallerID information supplied by your telephone company on that line?
Are you using a Dialogic card on this system?
Can you post the ktTel layer traces capturing an incoming call?
Hi
The telephone company i am using supplies the telephone number, i know this because it reflects the number on my mobile.
i am using Dialogic card system
i am not too sure what you mean by "kTel layer traces", how do i access these
Thank you for your help.
But does the phone company send CallerID on the Analog line plugged into the Dialogic card?
Could you please post a copy of VoiceGuide's Trace Logs which captures the incoming call, this will allow us to see what happened.
[Log]
ktTel=10
Then restart VG and make a test call.
Please post the traces.
Hi
I have attached the ktTel trace layer, i am not getting the $rv_cidnumber
thank you for your help
0911vgm.zip
Trace shows that the Dialogic card did not detect any CallerID information being sent.
Easiest way to confirm whether CallerID is actually sent or not is to attach a CallerID monitoring device to the Analog line and see if it displays the CallerID when the call arrives.
Also we can see from the trace that you are using v5.x of VoiceGuide with a Dialogic card.
We'd strongly recommend that you update this system to VoiceGuide v6. (same registration code will work with v6 as was supplied with v5).
:lol:
Thank you for the help, the steps u told me work, the only problem was my hardware.
