Guest TheyCalled Paul Report post Posted 09/11/2007 06:18 AM Hi, I have two systems one running V6 the other running v7. To debug a scrip I wrote in on the V6 machine and it was working, but on v7 no such luck. It is very important that I pass a value called CALLID around the system strResultVariables= "[CALLID]{"& SID & "}" & "[PHONE]{"& Phone & "}" & "{"& Email & "}" 'msgbox strResultVariables vg.Admin_TraceLogAdd iLineId, 5, strResultVariables 'make sure the returned data does not contain any commas strResultVariables = replace(strResultVariables, ",", "") vg.Run_ResultReturn $RV_LINEID, strResultVariables Set vg = Nothing To debug in V7 I used TTS and had it play $RV[CALLID], and $RV[PHONE] - nothing came up. This was perfect in V6. What is the proper syntax for V7? The rest of the script until this point works very well. Thank you. Paul Share this post Link to post
SupportTeam Report post Posted 09/11/2007 07:29 AM We just ran a test on Run_ResultReturn function and it returned RV's back to VoiceGuide fine. I attach a small script which asks called for a number, modifies that number in a VBScript, returns it to VoiceGuide via a Run_ResultReturn RV parameter, and then VoiceGuide speaks back the modified number. If the Run_ResultReturn RVs still do not work for you please post the script you are using and a trace capturing the entire call and we'll have a look at what is happening. RvTest_trace.txt Rvtest.vgs Share this post Link to post
Guest TheyCalled Paul Report post Posted 09/14/2007 06:41 AM On my system, it prompts for digits. I enter 7 of them, followed by the # and the system hangs up. If I have it validate the numbers, I hear the voice of voiceguide and the digits but it wont go the next step. How do you know that it really created and saved the value. Could I have a bad version of VG7?0913_ktTts.zip Share this post Link to post
