Vg7 - Hash While Recording
VG7
Dialogic D/4PCIU
Have you had any issues with using the Hash key to terminate recording in VG7. Hash is set as a valid path to advance to the next module. The log files tell me that VG has recognised the Hash hey but Line Status Monitor doesn’t show the recognition and VoiceGuide will not advance to the next module. I used Line Status Monitor to end the call. The WAV files created from the last 3 tests of the recording function are all listed a 1kb and I can not play them with Windows Media Player as …. The file is already in use. Close other programs that might be using this file and try again.
I stopped VG Service and tried again, but they were still 1kb in size and therefore nothing to play.
You can see below that I pressed hash at 18:02 and 20 seconds (180220.843). Its just that the path was not taken. Also, the beep before recording all though it says below “call beep=True” does not play.
180159.578 17 22 rv replace end: [c:\ghs\A_20070914180159_OrderName.wav]
180159.578 17 22 rv add [Order Name Rec]{c:\ghs\A_20070914180159_OrderName.wav}
180159.578 17 22 RecSoundStart [c:\ghs\A_20070914180159_OrderName.wav] call beep=True
180159.578 17 22 state [Order Name Rec] Recording c:\ghs\A_20070914180159_OrderName.wav
180159.593 17 22 RecSoundStart [c:\ghs\A_20070914180159_OrderName.wav] ok
180159.593 17 22 timer set 60 EV_TIMEOUT_GOTOMODULE
180159.625 17 22 db oledb query completed.
180220.843 9 22 ev dtmf # (22,35,0)
180220.843 9 22 ScriptEventCode #, code=35, state=1201
180220.843 9 22 LsRecRecording #,#
180220.843 9 22 rv rec length: Order Name Rec_RecLen100ms = 211.65625
180220.843 9 22 rv add [Order Name Rec_RecLen100ms]{211.65625}
180220.843 9 22 rv add [Order Name Rec_EndRecCause]{#}
180226.312 15 sockStatusLink_OnLineReceived [<request><type>hangup</type><port>11</port></request>] iLineDevicesControlled=14
I am currently Flood Controlled but will post a message when it lets me back in.
Which release version of VoiceGuide is used on this system?
We just downloaded the current version form our WWW and the recording was stopped and paths were taken fine when the # key was pressed. Trace extract of trace from our test system below:
153230.656 9 3 StartLoadedVgs at 9/17/2007 3:32:30 PM 7.0.2811.43195
153230.656 9 3 StartLoadedVgs LineState.iVgsIdx=1
153230.656 9 3 rvns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\}
153230.656 9 3 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\}
153230.656 9 3 set sScriptToRunOnHangup=[] in StartLoadedVgs
153230.656 9 3 rv add [$RV_STARTTIME]{9/17/2007 3:32:30 PM}
153230.656 9 3 rv add [$RV_DEVICEID]{3}
153230.656 9 3 rv add [DlgcVoice]{dxxxB1C3}
153230.656 9 3 rv add [DlgcNetwork]{dxxxB1C3}
153230.656 9 3 rv add [$RV_CIDNAME]{}
153230.656 9 3 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
153230.656 9 3 rv add [$RV_CIDNUMBER]{}
153230.656 9 3 RunModule vgm=2
153230.656 9 3 timer clear (force=False)
153230.656 9 3 fn RunModule start [Record,[Rec],2]
153230.656 9 3 state [Rec] Recording
153230.656 9 3 rv add [Rec]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment917153230_3_.wav}
153230.656 9 3 RecSoundStart [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment917153230_3_.wav] call beep=True
153230.656 9 3 state [Rec] Recording C:\Program Files\VoiceGuide\Scripts\Credit Card Payment917153230_3_.wav
153230.687 9 3 RecSoundStart [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment917153230_3_.wav] ok
153230.687 9 3 timer set 30 EV_TIMEOUT_GOTOMODULE
153230.687 9 3 ev Dialogic 134,TDX_CST,7423,0,0,DE_LCON,,
153230.687 9 3 ScriptEventCode TDX_CST, code=134, state=1201
153230.687 9 3 LsRecRecording EV_UNKNOWN_134,TDX_CST
153230.687 9 3 path {TDX_CST} not found
153237.421 9 3 ev dtmf # (3,35,0)
153237.421 9 3 ScriptEventCode #, code=35, state=1201
153237.421 9 3 LsRecRecording #,#
153237.453 9 3 rv rec length: Rec_RecLen100ms = 66.65625
153237.453 9 3 rv add [Rec_RecLen100ms]{66.65625}
153237.453 9 3 rv add [Rec_EndRecCause]{#}
153237.453 9 3 ev Dialogic 130,TDX_RECORD,0,0,0,TM_USRSTOP,,
153237.453 9 3 ScriptEventCode TDX_RECORD, code=130, state=1201
153237.453 9 3 LsRecRecording EV_UNKNOWN_130,TDX_RECORD
153237.453 9 3 path {TDX_RECORD} not found
153237.453 9 3 ScriptEventCode EV_REC_FINISHED, code=8003, state=1201
153237.453 9 3 LsRecRecording EV_REC_FINISHED,EV_REC_FINISHED
153237.453 9 3 path {EV_REC_FINISHED} not found
153237.453 9 3 rec complete event arrived. going to previously selected next module.
153237.453 9 3 RunModule vgm=1
153237.453 9 3 timer clear (force=False)
153237.453 9 3 fn RunModule start [Play,[Play 13],1]
153237.453 9 3 state [Play 13] Playing
153237.453 9 3 PrepareAndPlayWavAndTts start iModuleIdx=1, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs=
153237.453 9 3 rv replace start: [$RV[Rec]]
153237.453 9 3 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\}[$RV_STARTTIME]{9/17/2007 3:32:30 PM}[$RV_DEVICEID]{3}[DlgcVoice]{dxxxB1C3}[DlgcNetwork]{dxxxB1C3}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\}[$RV_CIDNUMBER]{}[Rec]{C:\Program Files\VoiceGuide\Scripts\Credit Card Payment917153230_3_.wav}[Rec_RecLen100ms]{66.65625}[Rec_EndRecCause]{#}
153237.453 9 3 rv replace end: [C:\Program Files\VoiceGuide\Scripts\Credit Card Payment917153230_3_.wav]
153237.453 9 3 PrepareAndPlayWavAndTTS sPlayFile=C:\Program Files\VoiceGuide\Scripts\Credit Card Payment917153230_3_.wav
153237.453 9 3 state [Play 13] Playing wav(C:\Program Files\VoiceGuide\Scripts\Credit Card Payment917153230_3_.wav)
153237.468 9 3 play start ok, lPlayId=431140
153243.265 9 3 ev PlayEnd 3 431140
153243.265 9 3 play end id=431140, (current ID)
153243.265 9 3 ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
153243.265 9 3 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
