Wrong Calling Id
Hi everybody,
It's my first message !
I have a D/240 PCI T1 dialogic board. It works fine except for one thing : when I call by example to my cellular 555-4545, the caller id phone number is wrong (the phone number displayed is the phone number from Intel, New Jersey). How can I specify to send 555-4545 to show the good number on my cellular ? What can I do for this ? I hope that it's clear.
Thank you very much !
Are you using VoiceGuide software?
Could you please post a copy of VoiceGuide's Trace Logs which captures the outgoing call, this will allow us to see what happened.
[Log]
VoiceGuide=10
ktTel=10
Then restart VG and make a test call.
Hum ! I'm not using VoiceGuide. What I want is to have information on dialogic function to set the ID before to call. Anyone have an idea ? Which function can I use to do this ?
Thank you !
