Config.xml question
Dear Sir
What's the problem in this--
<?xml version="1.0"?>
<VoiceGuideConfig>
<Devices_Dialogic>
<Channels>
<Channel>
<Name>dxxxB1C1</Name>
<NetworkIf>dxxxB1C1</NetworkIf>
<Protocol>pdk_na_an_io</Protocol>
<RingsBeforeAnswer>0</RingsBeforeAnswer>
<script>F:\Tele Banking System\Tele Banking_Main.vgs</Script>
<ConfigLine></ConfigLine>
<PopupCallerId>0</PopupCallerId>
<RV></RV>
</Channel>
<Channel>
<Name>dxxxB1C2</Name>
<NetworkIf>dxxxB1C2</NetworkIf>
<RV></RV>
</Channel>
<Channel>
<Name>dxxxB1C3</Name>
<NetworkIf>dxxxB1C3</NetworkIf>
<RV></RV>
</Channel>
<Channel>
<Name>dxxxB1C4</Name>
<NetworkIf>dxxxB1C4</NetworkIf>
<RV></RV>
</Channel>
</Channels>
<Parameters_DxBd>
<Notes>
DXBD_ (voice board) parameters
Parameters specified here will be set for every DX (voice)
board found to be started by the DCM in the system.
</Notes>
<Parameter>
<Description>Flash time during dialing (10ms units)</Description>
<Key>DXBD_FLASHTM</Key>
<Value>10</Value>
<Default>10</Default>
</Parameter>
<NotUsedByDefault>
<Notes>
MF param setting causes long delays on some boards.
Remove NotUsedByDefault tags if the MF param setting is desired.
</Notes>
<Parameter>
<Description>MF Interdigit Delay (10 ms units)</Description>
<Key>DXBD_MFDELAY</Key>
<Value>6</Value>
<Default>6</Default>
</Parameter>
<Parameter>
<Description>MF Length of LKP Tone Maximum value: 15 (10 ms units)</Description>
<Key>DXBD_MFLKPTONE</Key>
<Value>10</Value>
</Parameter>
<Parameter>
<Description>Minimum MF On. Added to the standard MF tone duration before the tone is detected. (10 ms units)
The minimum detection duration is 65 ms for KP tones and 40 ms for all other tones.</Description>
<Key>DXBD_MFMINON</Key>
<Value>0</Value>
<Default>0</Default>
</Parameter>
<Parameter>
<Description>MF Minimum Tone Duration (10 ms units)</Description>
<Key>DXBD_MFTONE</Key>
<Value>6</Value>
</Parameter>
</NotUsedByDefault>
<Parameter>
<Description>Minimum Loop Current off time before it is reported</Description>
<Key>DXBD_MINLCOFF</Key>
<Value>50</Value>
<Default>50</Default>
</Parameter>
<Parameter>
<Description>Minimum offhook time</Description>
<Key>DXBD_MINOFFHKTM</Key>
<Value>250</Value>
<Default>250</Default>
</Parameter>
<Parameter>
<Description>Minimum Silence Off</Description>
<Key>DXBD_MINSLOFF</Key>
<Value>2</Value>
<Default>2</Default>
</Parameter>
<Parameter>
<Description>Minimum Silence On</Description>
<Key>DXBD_MINSLON</Key>
<Value>1</Value>
<Default>1</Default>
</Parameter>
<Parameter>
<Description>Minimum DTI Off - minimum time required between rings-received events</Description>
<Key>DXBD_MINTIOFF</Key>
<Value>5</Value>
<Default>5</Default>
</Parameter>
<Parameter>
<Description>Minimum DTI On - minimum time required for rings received event</Description>
<Key>DXBD_MINTION</Key>
<Value>5</Value>
</Parameter>
<Parameter>
<Description>Offhook Delay - period after offhook, during which no events are generated
e.g., no DTMF digits will be detected during this period.</Description>
<Key>DXBD_OFFHDLY</Key>
<Value>50</Value>
</Parameter>
<Parameter>
<Description>Pause Time. Delay caused by a comma in the dialing string (10ms units)</Description>
<Key>DXBD_PAUSETM</Key>
<Value>100</Value>
<Default>100</Default>
</Parameter>
<Parameter>
<Description>Silence and Non-silence Debounce</Description>
<Key>DXBD_S_BNC</Key>
<Value>4</Value>
<Default>4</Default>
</Parameter>
<Parameter>
<Description>DTMF Interdigit Delay. Time between digits in DTMF dialing (10ms units)</Description>
<Key>DXBD_T_IDD</Key>
<Value>15</Value>
</Parameter>
<Parameter>
<Description>DTMF length (duration) for dialing (10ms units)</Description>
<Key>DXBD_TTDATA</Key>
<Value>10</Value>
</Parameter>
<Parameter>
<Description>Silence on and off debounce time (10ms units)</Description>
<Notes>debunce length should be really small so that
we can easily tell when the transition happens</Notes>
<Value>4</Value>
</Parameter>
</Parameters_DxBd>
</Devices_Dialogic>
<Notes>
CTI Devices
</Notes>
<Devices_CTI>
<CtiLink>
<CommsLink>
<Target></Target>
<Notes></Notes>
<IP></IP>
<Port></Port>
<Params></Params>
</CommsLink>
<MonitoredDevices>
<Ext></Ext>
<Ext></Ext>
</MonitoredDevices>
</CtiLink>
</Devices_CTI>
</VoiceGuideConfig>
The Config.xml looks fine (for a 4 line analog system).
What is the actual problem that you are experiencing?
Dear Sir,
Now I face a problem
As per example :
My Numeric Field contans : 9524
I want to say with sound : Nine Thousand Five Hundred Twenty four
How can this possible for sound file and what change in 'lib_num2wav' file ?
All the best.
Reply plz
From
Bank Asia Ltd.
Please post questions on a new topic in a new thread - in order to keep unrelated questions separate and under appropriately described headings.
Please post a full description of your question: What you are trying to achieve and what is the actual problem that you are having, along with related VoiceGuide scripts which you are currently using and relevant VoiceGuide traces. Please start a new thread for this new question.
Dear Sir
Plz reply. Sound files error in 1024 lines.
091835.39 0 ---------------------------------------------------
091835.41 0 VoiceGuide for Dialogic
091835.42 0 v6.0.3243
091835.42 0 ---------------------------------------------------
091835.42 0 rv global loaded >>><<<
091835.44 0 cti Inband Signaling Config file not specified
091837.39 0 init ApiMode=[DialogicGC]
091837.42 0 vm loading VMB data begin
091837.42 0 vm loading VMB data - about to delete old entries
091837.44 0 vm loading VMB data - sorting/ordering
091837.44 0 vm loading VMB data end
091837.45 0 dial DbConnectString_ADO is blank
091837.48 0 init DB Workspaces
091837.50 0 init Voicemail LoadIniSettings
091837.52 0 init VmEmailBody_MainGlobalTemplate loaded from C:\Program Files\VoiceGuide\system\vm\EmailForwardTemplate_body.txt
091837.53 0 init temp dir exists [C:\Program Files\VoiceGuide\temp\]
091837.53 0 init read Config.xml start
091837.55 0 dxxxB1C1 dxxxB1C1 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1
091837.55 0 dxxxB1C2 dxxxB1C2 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1
091837.56 0 dxxxB1C3 dxxxB1C3 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1
091837.56 0 dxxxB1C4 dxxxB1C4 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1
091837.56 0 init read Config.xml end
091837.58 0 init LineOpenDialogic dxxxB1C1 => [1]
091837.58 1 iIvrDev=1
091837.63 0 init distinct ring definitions found:0
091837.63 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig)
091837.64 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
091837.64 MemStructVgs_ClearVgs [1]
091837.66 load end
091837.66 1 state Waiting for a call...
091837.66 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
091837.67 1 event TDX_SETHOOK, iCode=135 state=0
091837.67 1 event callstate IDLE 1 1,0,0
091837.67 1 WorkingMode@Idle=
091837.69 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
091837.69 1 timer clear
091837.69 1 LineState(iLineId).iVgsIdx = 0
091837.69 1 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
091837.70 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091837.70 1 timer set ignored - waiting for line re-init to occur first
091837.72 0 init LineOpenDialogic dxxxB1C2 => [2]
091837.72 2 iIvrDev=2
091837.75 0 init distinct ring definitions found:0
091837.75 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig)
091837.77 2 state Waiting for a call...
091837.77 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
091837.77 2 event TDX_SETHOOK, iCode=135 state=0
091837.78 2 event callstate IDLE 2 1,0,0
091837.78 2 WorkingMode@Idle=
091837.78 2 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
091837.80 2 timer clear
091837.80 2 LineState(iLineId).iVgsIdx = 0
091837.80 2 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
091837.81 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
091837.81 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0
091837.81 1 init atidle reinit : start
091837.81 1 init atidle reinit iConferenceOtherLegLid=-1
091837.83 1 init atidle reinit : reset all LineState variables
091837.83 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091837.83 1 state Waiting for a call...
091837.84 2 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091837.84 2 timer set ignored - waiting for line re-init to occur first
091837.86 0 init LineOpenDialogic dxxxB1C3 => [3]
091837.86 3 iIvrDev=3
091837.89 0 init distinct ring definitions found:0
091837.91 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig)
091837.91 3 state Waiting for a call...
091837.91 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
091837.92 3 event TDX_SETHOOK, iCode=135 state=0
091837.92 3 event callstate IDLE 3 1,0,0
091837.92 3 WorkingMode@Idle=
091837.94 3 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
091837.94 3 timer clear
091837.94 3 LineState(iLineId).iVgsIdx = 0
091837.95 3 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
091837.95 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
091837.95 2 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0
091837.97 2 init atidle reinit : start
091837.97 2 init atidle reinit iConferenceOtherLegLid=-1
091837.97 2 init atidle reinit : reset all LineState variables
091837.98 2 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091837.98 2 state Waiting for a call...
091837.98 3 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091838.00 3 timer set ignored - waiting for line re-init to occur first
091838.00 0 init LineOpenDialogic dxxxB1C4 => [4]
091838.02 4 iIvrDev=4
091838.05 0 init distinct ring definitions found:0
091838.05 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig)
091838.06 4 state Waiting for a call...
091838.06 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
091838.06 4 event TDX_SETHOOK, iCode=135 state=0
091838.08 4 event callstate IDLE 4 1,0,0
091838.08 4 WorkingMode@Idle=
091838.08 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
091838.09 4 timer clear
091838.09 4 LineState(iLineId).iVgsIdx = 0
091838.09 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
091838.11 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
091838.11 3 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0
091838.11 3 init atidle reinit : start
091838.13 3 init atidle reinit iConferenceOtherLegLid=-1
091838.13 3 init atidle reinit : reset all LineState variables
091838.13 3 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091838.14 3 state Waiting for a call...
091838.14 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091838.14 4 timer set ignored - waiting for line re-init to occur first
091838.16 0 init lineids in use: 0-4
091838.16 0 init route channels start
091838.20 0 init route channels => []
091838.22 0 init no dti channels opened. Not opening signaling channel.
091838.22 0 cti //devicesCTI/ctiLink config.xml section not used in this version
091838.22 0 init read Config.xml //devicesSysManagers/StatusLink start
091838.23 0 tcpsl config.xml does not have //devicesSysManagers/StatusLink section (status link wil use the default port of 14710)
091838.23 0 tcpsl open //devicesSysManagers/StatusLink to listen on port 14710
091838.25 0 init read Config.xml //devicesSysManagers/StatusLink end
091838.25 0 init iLineDevicesControlled=4
091838.25 0 init main form load end
091838.27 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
091838.27 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0
091838.28 4 init atidle reinit : start
091838.30 4 init atidle reinit iConferenceOtherLegLid=-1
091838.30 4 init atidle reinit : reset all LineState variables
091838.31 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091838.31 4 state Waiting for a call...
091840.19 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091840.19 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0
091840.20 1 setting iDialoutReadyToDialout = 1
091840.33 2 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091840.33 2 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0
091840.34 2 setting iDialoutReadyToDialout = 1
091840.45 3 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091840.45 3 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0
091840.47 3 setting iDialoutReadyToDialout = 1
091840.58 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
091840.58 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0
091840.59 4 setting iDialoutReadyToDialout = 1
091933.34 0 sys cleanup Start
091933.34 0 sys cleanup End
092135.86 4 event callstate OFFERING 4 2,0,0
092135.88 4 script interpretor: VgMulti v6.0.3243
092135.88 4 fired OFFERING event to listeners
092135.89 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
092135.91 4 cid CallerID vars set (in 'offering' event) [,,]
092135.91 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
092135.92 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
092135.92 4 tw ring 1
092135.94 4 ring time since last ring event (sec): 0.00
092135.95 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
092135.95 4 should answer as number of rings reached
092135.97 4 rv clear all
092135.98 4 init LineState ResetAtStartOfNewCall.
092135.98 4 answering the call (,,,0)
092136.00 4 timer clear
092136.02 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
092136.03 4 event TDX_CST, iCode=134 state=6001
092136.03 4 LsModuleTransition : 134, [TDX_CST]
092136.64 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
092136.66 4 event TDX_SETHOOK, iCode=135 state=6001
092136.67 4 LsModuleTransition : 135, [TDX_SETHOOK]
092136.67 4 event callstate CONNECTED 4 256,0,0
092136.69 4 LineEvCallState_Connected hDevice=4 params=256,0,0
092136.70 4 WorkingModes tapi= script= LineState().iState=6001
092136.72 4 Inband detection not enabled
092136.72 4 StartLoadedVgs at 01/10/2007 9:21:36 AM (VgMulti v6.0.3243)
092136.73 4 set LineState().iVgsIdx=1
092136.75 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
092136.75 4 init StartLoadedVgs_InitLineState start
092136.77 4 rv add [$RV_STARTTIME]{01/10/2007 9:21:36 AM}
092136.78 4 rv add [$RV_DEVICEID]{4}
092136.78 4 rv add [DlgcNetworkResource]{dxxxB1C4}
092136.80 4 rv add [DlgcVoiceResource]{dxxxB1C4}
092136.81 4 rv add [$RV_CIDNAME]{}
092136.81 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
092136.83 4 rvns add [scriptsPath]{G:\TeleBanking System\}
092136.83 4 rv add [$RV_CIDNUMBER]{}
092136.84 4 fn RunModule start [Play,[Get Language],1,,]
092136.84 4 tw DialogicEvent 134,TDX_CST,65535,0,0,DE_LCON,,
092136.84 4 event TDX_CST, iCode=134 state=6001
092136.86 4 LsModuleTransition : 134, [TDX_CST]
092136.88 4 timer clear
092136.88 4 Play Module start
092136.88 4 state [Get Language] Playing
092136.89 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
092136.89 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
092136.95 4 tw wav->vox convert end 320968,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
092136.97 4 play start ok, lPlayId=321031
092139.75 4 tw dtmf 1 (4,49,49)
092139.77 4 event 1, iCode=49 state=1100
092139.77 4 LsPlayMsg 1,1
092139.77 4 rv add [scriptEnd_Time]{01/10/2007 9:21:39 AM}
092139.78 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
092139.78 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
092139.81 4 rv add [scriptStart_Time]{01/10/2007 9:21:39 AM}
092139.81 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
092139.83 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
092139.83 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
092139.84 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
092139.84 MemStructVgs_ClearVgs [2]
092139.91 load end
092139.92 4 loaded [G:\TeleBanking System\Tele Banking_Ban.vgs] into:2
092139.92 4 rvns add [scriptsPath]{G:\TeleBanking System\}
092139.94 4 play PlayStop ok
092139.95 4 rv add [Get Language]{1}
092139.95 4 fn RunModule start [Evaluate,[Get Bangla],25,,]
092139.97 4 tw PlayEnd 4 321031
092139.97 4 play end id=321031, (current ID)
092139.97 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
092139.98 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
092139.98 4 tw DialogicEvent 129,TDX_PLAY,321031,0,0,,,
092140.00 4 event TDX_PLAY, iCode=129 state=6001
092140.00 4 LsModuleTransition : 129, [TDX_PLAY]
092140.02 4 timer clear
092140.03 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
092140.05 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
092140.06 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
092140.06 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
092140.08 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
092140.08 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
092140.09 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
092140.09 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
092140.09 4 matching path not found
092140.11 4 next module is
  1. (idx=26)
092140.11 4 matching path was found
092140.13 4 fn RunModule start [Play,
  1. ,26,,]
092140.13 4 timer clear
092140.14 4 Play Module start
092140.14 4 state
  1. Playing
092140.14 4 state
  1. Playing (Bangla Voice\Service List.wav)
092140.16 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
092140.20 4 tw wav->vox convert end 324234,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
092140.22 4 play start ok, lPlayId=324281
092153.36 4 tw PlayEnd 4 324281
092153.36 4 play end id=324281, (current ID)
092153.38 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
092153.38 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092153.39 4 path {EV_PLAY_FINISHED} not found
092153.39 4 timer set 7 EV_TIMEOUT_REPLAYMSG
092153.41 4 tw DialogicEvent 129,TDX_PLAY,324281,0,0,,,
092153.41 4 event TDX_PLAY, iCode=129 state=1101
092153.41 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
092153.42 4 path {TDX_PLAY} not found
092154.31 4 tw dtmf 1 (4,49,49)
092154.33 4 event 1, iCode=49 state=1101
092154.33 4 LsPlayMsgFinished 1,1
092154.34 4 next module is [Get Acc No] (idx=4)
092154.34 4 rv add
  1. {1}
092154.36 4 fn RunModule start [Get Numbers,[Get Acc No],4,,]
092154.36 4 timer clear
092154.36 4 state [Get Acc No] Number Input
092154.38 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
092154.38 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
092154.42 4 tw wav->vox convert end 338453,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
092154.44 4 play start ok, lPlayId=338500
092158.25 4 tw PlayEnd 4 338500
092158.27 4 play end id=338500, (current ID)
092158.27 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
092158.28 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092158.28 4 path {EV_PLAY_FINISHED} not found
092158.28 4 timer set 17 EV_TIMEOUT_REPLAYMSG
092158.30 4 tw DialogicEvent 129,TDX_PLAY,338500,0,0,,,
092158.30 4 event TDX_PLAY, iCode=129 state=1301
092158.31 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
092158.31 4 path {TDX_PLAY} not found
092200.48 4 tw dtmf 0 (4,48,48)
092200.50 4 event 0, iCode=48 state=1301
092200.50 4 LsGetNbrsRxDigits 0,0
092200.52 4 state [Get Acc No] Number Input 0
092200.52 4 path {0} not found
092200.52 4 timer set 6 EV_TIMEOUT_ENTERDATA
092201.05 4 tw dtmf 1 (4,49,49)
092201.05 4 event 1, iCode=49 state=1301
092201.05 4 LsGetNbrsRxDigits 1,1
092201.06 4 state [Get Acc No] Number Input 01
092201.06 4 path {01} not found
092201.08 4 timer set 6 EV_TIMEOUT_ENTERDATA
092201.58 4 tw dtmf 7 (4,55,55)
092201.59 4 event 7, iCode=55 state=1301
092201.59 4 LsGetNbrsRxDigits 7,7
092201.59 4 state [Get Acc No] Number Input 017
092201.61 4 path {017} not found
092201.61 4 timer set 6 EV_TIMEOUT_ENTERDATA
092202.22 4 tw dtmf 3 (4,51,51)
092202.22 4 event 3, iCode=51 state=1301
092202.23 4 LsGetNbrsRxDigits 3,3
092202.23 4 state [Get Acc No] Number Input 0173
092202.25 4 path {0173} not found
092202.25 4 timer set 6 EV_TIMEOUT_ENTERDATA
092202.56 4 tw dtmf 4 (4,52,52)
092202.58 4 event 4, iCode=52 state=1301
092202.58 4 LsGetNbrsRxDigits 4,4
092202.58 4 state [Get Acc No] Number Input 01734
092202.59 4 path {01734} not found
092202.59 4 timer set 6 EV_TIMEOUT_ENTERDATA
092202.86 4 tw dtmf 5 (4,53,53)
092202.88 4 event 5, iCode=53 state=1301
092202.88 4 LsGetNbrsRxDigits 5,5
092202.89 4 state [Get Acc No] Number Input 017345
092202.89 4 path {017345} not found
092202.91 4 timer set 6 EV_TIMEOUT_ENTERDATA
092203.14 4 tw dtmf 2 (4,50,50)
092203.14 4 event 2, iCode=50 state=1301
092203.16 4 LsGetNbrsRxDigits 2,2
092203.16 4 state [Get Acc No] Number Input 0173452
092203.17 4 path {0173452} not found
092203.17 4 timer set 6 EV_TIMEOUT_ENTERDATA
092203.42 4 tw dtmf 1 (4,49,49)
092203.44 4 event 1, iCode=49 state=1301
092203.44 4 LsGetNbrsRxDigits 1,1
092203.45 4 state [Get Acc No] Number Input 01734521
092203.45 4 path {01734521} not found
092203.47 4 timer set 6 EV_TIMEOUT_ENTERDATA
092203.67 4 tw dtmf 1 (4,49,49)
092203.67 4 event 1, iCode=49 state=1301
092203.69 4 LsGetNbrsRxDigits 1,1
092203.69 4 state [Get Acc No] Number Input 017345211
092203.69 4 path {017345211} not found
092203.70 4 timer set 6 EV_TIMEOUT_ENTERDATA
092210.19 4 timer fired EV_TIMEOUT_ENTERDATA
092210.19 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
092210.19 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
092210.20 4 path {EV_TIMEOUT_ENTERDATA} not found
092210.20 4 timer clear
092210.22 4 rv add [Get Acc No]{017345211}
092210.22 4 len(017345211) min=11, max=14, replays=0/1
092210.23 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
092210.23 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
092210.27 4 tw wav->vox convert end 354312,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
092210.28 4 play start ok, lPlayId=354343
092214.09 4 tw PlayEnd 4 354343
092214.11 4 play end id=354343, (current ID)
092214.11 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
092214.11 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092214.13 4 path {EV_PLAY_FINISHED} not found
092214.13 4 timer set 10 EV_TIMEOUT_HANGUP
092214.14 4 timer set 6 EV_TIMEOUT_ENTERDATA
092214.14 4 tw DialogicEvent 129,TDX_PLAY,354343,0,0,,,
092214.16 4 event TDX_PLAY, iCode=129 state=1301
092214.16 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
092214.17 4 path {TDX_PLAY} not found
092215.00 4 tw dtmf 0 (4,48,48)
092215.00 4 event 0, iCode=48 state=1301
092215.02 4 LsGetNbrsRxDigits 0,0
092215.02 4 state [Get Acc No] Number Input 0
092215.03 4 path {0} not found
092215.03 4 timer set 6 EV_TIMEOUT_ENTERDATA
092215.42 4 tw dtmf 1 (4,49,49)
092215.44 4 event 1, iCode=49 state=1301
092215.44 4 LsGetNbrsRxDigits 1,1
092215.45 4 state [Get Acc No] Number Input 01
092215.45 4 path {01} not found
092215.47 4 timer set 6 EV_TIMEOUT_ENTERDATA
092215.73 4 tw dtmf 7 (4,55,55)
092215.75 4 event 7, iCode=55 state=1301
092215.75 4 LsGetNbrsRxDigits 7,7
092215.77 4 state [Get Acc No] Number Input 017
092215.77 4 path {017} not found
092215.78 4 timer set 6 EV_TIMEOUT_ENTERDATA
092216.16 4 tw dtmf 3 (4,51,51)
092216.17 4 event 3, iCode=51 state=1301
092216.17 4 LsGetNbrsRxDigits 3,3
092216.19 4 state [Get Acc No] Number Input 0173
092216.19 4 path {0173} not found
092216.19 4 timer set 6 EV_TIMEOUT_ENTERDATA
092216.67 4 tw dtmf 4 (4,52,52)
092216.69 4 event 4, iCode=52 state=1301
092216.69 4 LsGetNbrsRxDigits 4,4
092216.70 4 state [Get Acc No] Number Input 01734
092216.70 4 path {01734} not found
092216.72 4 timer set 6 EV_TIMEOUT_ENTERDATA
092217.11 4 tw dtmf 0 (4,48,48)
092217.11 4 event 0, iCode=48 state=1301
092217.13 4 LsGetNbrsRxDigits 0,0
092217.13 4 state [Get Acc No] Number Input 017340
092217.14 4 path {017340} not found
092217.14 4 timer set 6 EV_TIMEOUT_ENTERDATA
092217.33 4 tw dtmf 0 (4,48,48)
092217.34 4 event 0, iCode=48 state=1301
092217.34 4 LsGetNbrsRxDigits 0,0
092217.36 4 state [Get Acc No] Number Input 0173400
092217.36 4 path {0173400} not found
092217.38 4 timer set 6 EV_TIMEOUT_ENTERDATA
092217.58 4 tw dtmf 0 (4,48,48)
092217.58 4 event 0, iCode=48 state=1301
092217.59 4 LsGetNbrsRxDigits 0,0
092217.59 4 state [Get Acc No] Number Input 01734000
092217.61 4 path {01734000} not found
092217.61 4 timer set 6 EV_TIMEOUT_ENTERDATA
092218.08 4 tw dtmf 2 (4,50,50)
092218.09 4 event 2, iCode=50 state=1301
092218.09 4 LsGetNbrsRxDigits 2,2
092218.11 4 state [Get Acc No] Number Input 017340002
092218.11 4 path {017340002} not found
092218.11 4 timer set 6 EV_TIMEOUT_ENTERDATA
092218.41 4 tw dtmf 4 (4,52,52)
092218.41 4 event 4, iCode=52 state=1301
092218.42 4 LsGetNbrsRxDigits 4,4
092218.42 4 state [Get Acc No] Number Input 0173400024
092218.44 4 path {0173400024} not found
092218.44 4 timer set 6 EV_TIMEOUT_ENTERDATA
092218.70 4 tw dtmf 5 (4,53,53)
092218.72 4 event 5, iCode=53 state=1301
092218.72 4 LsGetNbrsRxDigits 5,5
092218.72 4 state [Get Acc No] Number Input 01734000245
092218.73 4 path {01734000245} not found
092218.73 4 timer set 6 EV_TIMEOUT_ENTERDATA
092225.20 4 timer fired EV_TIMEOUT_ENTERDATA
092225.20 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
092225.22 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
092225.22 4 path {EV_TIMEOUT_ENTERDATA} not found
092225.22 4 timer clear
092225.23 4 rv add [Get Acc No]{01734000245}
092225.23 4 path {01734000245} not found
092225.25 4 next module is [Varify A/C] (idx=44)
092225.25 4 rvns add [Get Acc No_PathTaken]{success}
092225.27 4 fn RunModule start [Database Query,[Varify A/C],44,,]
092225.27 4 timer clear
092225.28 4 state [Varify A/C] DB Query
092225.28 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
092225.67 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
092225.69 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:21:36 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:21:39 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:21:39 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
  1. {1}[Get Acc No]{017345211}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}
092225.69 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
092225.72 4 db [Varify A/C] row count=1
092225.72 4 rv add [Varify A/C_RowCount]{1}
092225.73 4 db get RecordsetGetRowsMax
092225.73 4 db get 999 records. (row count=1)
092225.75 4 db update RVs
092225.75 4 db about to close dbDbqDatabase
092225.77 4 db going down path [True]
092225.77 4 next module is [Get PIN No] (idx=5)
092225.78 4 fn RunModule start [Get Numbers,[Get PIN No],5,,]
092225.78 4 timer clear
092225.80 4 state [Get PIN No] Number Input
092225.80 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
092225.81 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
092225.86 4 tw wav->vox convert end 369890,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
092225.88 4 play start ok, lPlayId=369937
092229.16 4 tw dtmf 3 (4,51,51)
092229.16 4 event 3, iCode=51 state=1300
092229.17 4 LsGetNbrsPlayWelcMsg 3,3
092229.19 4 play PlayStop ok
092229.20 4 state [Get PIN No] Number Input 3
092229.20 4 path {3} not found
092229.22 4 timer set 6 EV_TIMEOUT_ENTERDATA
092229.22 4 tw PlayEnd 4 369937
092229.23 4 play end id=369937, (current ID)
092229.23 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
092229.25 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
092229.25 4 path {EV_PLAY_FINISHED} not found
092229.27 4 awaiting further dtmf input
092229.27 4 tw DialogicEvent 129,TDX_PLAY,369937,0,0,,,
092229.28 4 event TDX_PLAY, iCode=129 state=1301
092229.28 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
092229.28 4 path {TDX_PLAY} not found
092229.58 4 tw dtmf 8 (4,56,56)
092229.58 4 event 8, iCode=56 state=1301
092229.59 4 LsGetNbrsRxDigits 8,8
092229.59 4 state [Get PIN No] Number Input 38
092229.61 4 path {38} not found
092229.61 4 timer set 6 EV_TIMEOUT_ENTERDATA
092230.00 4 tw dtmf 0 (4,48,48)
092230.02 4 event 0, iCode=48 state=1301
092230.02 4 LsGetNbrsRxDigits 0,0
092230.03 4 state [Get PIN No] Number Input 380
092230.03 4 path {380} not found
092230.05 4 timer set 6 EV_TIMEOUT_ENTERDATA
092230.39 4 tw dtmf 4 (4,52,52)
092230.41 4 event 4, iCode=52 state=1301
092230.41 4 LsGetNbrsRxDigits 4,4
092230.42 4 state [Get PIN No] Number Input 3804
092230.42 4 path {3804} not found
092230.42 4 timer set 6 EV_TIMEOUT_ENTERDATA
092230.44 4 timer clear
092230.44 4 rv add [Get PIN No]{3804}
092230.45 4 path {3804} not found
092230.45 4 next module is [Varify A/C No] (idx=29)
092230.47 4 rvns add [Get PIN No_PathTaken]{success}
092230.47 4 fn RunModule start [Database Query,[Varify A/C No],29,,]
092230.48 4 timer clear
092230.48 4 state [Varify A/C No] DB Query
092230.50 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
092230.53 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
092230.53 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:21:36 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{017345211}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}
092230.55 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
092230.58 4 db [Varify A/C No] row count=1
092230.58 4 rv add [Varify A/C No_RowCount]{1}
092230.59 4 db get RecordsetGetRowsMax
092230.59 4 db get 999 records. (row count=1)
092230.61 4 db update RVs
092230.63 4 db about to close dbDbqDatabase
092230.64 4 db going down path [True]
092230.64 4 next module is
  1. (idx=6)
092230.66 4 fn RunModule start [Play,
  1. ,6,,]
092230.66 4 timer clear
092230.66 4 Play Module start
092230.67 4 state
  1. Playing
092230.67 4 state
  1. Playing (Bangla Voice\Acc List.wav)
092230.69 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
092230.73 4 tw wav->vox convert end 374765,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
092230.75 4 play start ok, lPlayId=374812
092237.41 4 tw dtmf 1 (4,49,49)
092237.42 4 event 1, iCode=49 state=1100
092237.42 4 LsPlayMsg 1,1
092237.44 4 next module is [Varify Balance] (idx=7)
092237.45 4 play PlayStop ok
092237.47 4 rv add
  1. {1}
092237.47 4 fn RunModule start [Database Query,[Varify Balance],7,,]
092237.48 4 tw PlayEnd 4 374812
092237.48 4 play end id=374812, (current ID)
092237.50 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
092237.50 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
092237.52 4 tw DialogicEvent 129,TDX_PLAY,374812,0,0,,,
092237.52 4 event TDX_PLAY, iCode=129 state=6001
092237.53 4 LsModuleTransition : 129, [TDX_PLAY]
092237.53 4 timer clear
092237.55 4 state [Varify Balance] DB Query
092237.55 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
092237.58 4 rv replace start: [sELECT TRUNC(curbal) curbal FROM stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND acstat<>'CLS']
092237.59 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:21:36 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{017345211}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}[Varify A/C No_RowCount]{1}[Varify A/C No_1_1]{LX4VNZ41KDX7}
    1. {1}
092237.59 4 db About to execute a Retrieve type operation [sELECT TRUNC(curbal) curbal FROM stfacmas WHERE actnum=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND acstat<>'CLS]
092237.61 4 db [Varify Balance] row count=1
092237.63 4 rv add [Varify Balance_RowCount]{1}
092237.63 4 db get RecordsetGetRowsMax
092237.64 4 db get 999 records. (row count=1)
092237.64 4 db update RVs
092237.66 4 db about to close dbDbqDatabase
092237.66 4 db going down path [True]
092237.67 4 next module is [say Balance] (idx=40)
092237.67 4 fn RunModule start [say Numbers,[say Balance],40,,]
092237.69 4 timer clear
092237.69 4 rv replace start: [$RV[Varify Balance_1_1]]
092237.70 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:21:36 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
    1. {1}[Varify Balance_RowCount]{1}[Varify Balance_1_1]{60579}
092237.70 4 rv replace end: [60579]
092237.72 4 state [say Balance] Say numbers: 60579 as Number
092237.72 4 fn PlaySoundStartNumbers [bangla Voice\Acc Bal.wav],[],[60579],Number
092237.75 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
092237.75 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
092237.77 4 rv add [Hangup Time]{01/10/2007 9:22:37 AM}
092237.77 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
092237.78 4 HangupCall_Common hCall=4
092237.78 4 rec RecSoundStop ok
092237.80 4 play PlayStop ok
092237.80 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
092237.81 4 fnHangupCall end
092237.86 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092237.86 4 event TDX_SETHOOK, iCode=135 state=900
092237.88 4 LsAwaitingCalls EV_UNKNOWN_135
092237.88 4 event callstate IDLE 4 1,0,0
092237.89 4 WorkingMode@Idle=
092237.89 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
092237.91 4 timer clear
092237.91 4 rec RecSoundStop ok
092237.92 4 play PlayStop ok
092237.92 4 rv add [CallEndTime]{01/10/2007 9:22:37 AM}
092237.95 4 on-hangup script:[]
092237.95 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
092237.97 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
092237.97 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
092237.98 4 init atidle reinit : start
092237.98 4 init atidle reinit iConferenceOtherLegLid=-1
092238.00 4 init atidle reinit : reset all LineState variables
092238.00 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
092238.02 4 state Waiting for a call...
092240.20 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
092240.20 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
092240.22 4 setting iDialoutReadyToDialout = 1
092651.27 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
092651.27 MemStructVgs_ClearVgs [3]
092651.34 load end
092651.36 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
092651.36 0 Erasing Script (new loaded) Id 2
092651.38 0 VgsScriptFree [2]
092651.38 MemStructVgs_ClearVgs [2]
092652.39 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
092652.39 MemStructVgs_ClearVgs [2]
092652.47 load end
092652.48 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
092652.50 0 Erasing Script (new loaded) Id 3
092652.50 0 VgsScriptFree [3]
092652.52 MemStructVgs_ClearVgs [3]
092703.52 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
092703.53 MemStructVgs_ClearVgs [3]
092703.61 load end
092703.61 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
092703.63 0 Erasing Script (new loaded) Id 2
092703.63 0 VgsScriptFree [2]
092703.64 MemStructVgs_ClearVgs [2]
092712.17 4 event callstate OFFERING 4 2,0,0
092712.17 4 script interpretor: VgMulti v6.0.3243
092712.19 4 fired OFFERING event to listeners
092712.19 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
092712.20 4 cid CallerID vars set (in 'offering' event) [,,]
092712.20 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
092712.22 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
092712.22 4 tw ring 1
092712.23 4 ring time since last ring event (sec): 0.00
092712.23 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
092712.25 4 should answer as number of rings reached
092712.25 4 rv clear all
092712.27 4 init LineState ResetAtStartOfNewCall.
092712.27 4 answering the call (,,,0)
092712.28 4 timer clear
092712.30 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
092712.30 4 event TDX_CST, iCode=134 state=6001
092712.31 4 LsModuleTransition : 134, [TDX_CST]
092712.92 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
092712.94 4 event TDX_SETHOOK, iCode=135 state=6001
092712.94 4 LsModuleTransition : 135, [TDX_SETHOOK]
092712.95 4 event callstate CONNECTED 4 256,0,0
092712.95 4 LineEvCallState_Connected hDevice=4 params=256,0,0
092712.97 4 WorkingModes tapi= script= LineState().iState=6001
092712.97 4 Inband detection not enabled
092712.98 4 StartLoadedVgs at 01/10/2007 9:27:12 AM (VgMulti v6.0.3243)
092712.98 4 set LineState().iVgsIdx=1
092713.00 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
092713.00 4 init StartLoadedVgs_InitLineState start
092713.02 4 rv add [$RV_STARTTIME]{01/10/2007 9:27:12 AM}
092713.03 4 rv add [$RV_DEVICEID]{4}
092713.03 4 rv add [DlgcNetworkResource]{dxxxB1C4}
092713.05 4 rv add [DlgcVoiceResource]{dxxxB1C4}
092713.05 4 rv add [$RV_CIDNAME]{}
092713.06 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
092713.06 4 rvns add [scriptsPath]{G:\TeleBanking System\}
092713.08 4 rv add [$RV_CIDNUMBER]{}
092713.08 4 fn RunModule start [Play,[Get Language],1,,]
092713.09 4 tw DialogicEvent 134,TDX_CST,27507,0,0,DE_LCON,,
092713.09 4 event TDX_CST, iCode=134 state=6001
092713.11 4 LsModuleTransition : 134, [TDX_CST]
092713.11 4 timer clear
092713.13 4 Play Module start
092713.13 4 state [Get Language] Playing
092713.14 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
092713.14 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
092713.17 4 tw wav->vox convert end 657218,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
092713.20 4 play start ok, lPlayId=657265
092714.56 4 tw dtmf 1 (4,49,49)
092714.58 4 event 1, iCode=49 state=1100
092714.58 4 LsPlayMsg 1,1
092714.59 4 rv add [scriptEnd_Time]{01/10/2007 9:27:14 AM}
092714.59 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
092714.61 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
092714.64 4 rv add [scriptStart_Time]{01/10/2007 9:27:14 AM}
092714.64 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
092714.66 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
092714.67 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
092714.67 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3
092714.69 4 rvns add [scriptsPath]{G:\TeleBanking System\}
092714.70 4 play PlayStop ok
092714.70 4 rv add [Get Language]{1}
092714.72 4 fn RunModule start [Evaluate,[Get Bangla],64,,]
092714.72 4 tw PlayEnd 4 657265
092714.73 4 play end id=657265, (current ID)
092714.73 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
092714.75 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
092714.75 4 tw DialogicEvent 129,TDX_PLAY,657265,0,0,,,
092714.77 4 event TDX_PLAY, iCode=129 state=6001
092714.77 4 LsModuleTransition : 129, [TDX_PLAY]
092714.78 4 timer clear
092714.80 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
092714.80 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
092714.81 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
092714.81 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
092714.83 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
092714.83 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
092714.84 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
092714.84 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
092714.86 4 matching path not found
092714.86 4 next module is
  1. (idx=63)
092714.88 4 matching path was found
092714.88 4 fn RunModule start [Play,
  1. ,63,,]
092714.89 4 timer clear
092714.91 4 Play Module start
092714.91 4 state
  1. Playing
092714.92 4 state
092714.92 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
092714.95 4 tw wav->vox convert end 659000,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
092714.97 4 play start ok, lPlayId=659046
092716.56 4 tw dtmf 1 (4,49,49)
092716.56 4 event 1, iCode=49 state=1100
092716.58 4 LsPlayMsg 1,1
092716.58 4 next module is [Get Acc No] (idx=85)
092716.61 4 play PlayStop ok
092716.61 4 rv add
  1. {1}
092716.63 4 fn RunModule start [Get Numbers,[Get Acc No],85,,]
092716.63 4 tw PlayEnd 4 659046
092716.64 4 play end id=659046, (current ID)
092716.64 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
092716.66 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
092716.67 4 tw DialogicEvent 129,TDX_PLAY,659046,0,0,,,
092716.67 4 event TDX_PLAY, iCode=129 state=6001
092716.69 4 LsModuleTransition : 129, [TDX_PLAY]
092716.69 4 timer clear
092716.70 4 state [Get Acc No] Number Input
092716.70 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
092716.72 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
092716.73 4 tw wav->vox convert end 660796,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
092716.75 4 play start ok, lPlayId=660812
092720.56 4 tw PlayEnd 4 660812
092720.58 4 play end id=660812, (current ID)
092720.58 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
092720.59 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092720.59 4 path {EV_PLAY_FINISHED} not found
092720.61 4 timer set 17 EV_TIMEOUT_REPLAYMSG
092720.61 4 tw DialogicEvent 129,TDX_PLAY,660812,0,0,,,
092720.63 4 event TDX_PLAY, iCode=129 state=1301
092720.64 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
092720.64 4 path {TDX_PLAY} not found
092720.66 4 tw dtmf 0 (4,48,48)
092720.66 4 event 0, iCode=48 state=1301
092720.67 4 LsGetNbrsRxDigits 0,0
092720.67 4 state [Get Acc No] Number Input 0
092720.69 4 path {0} not found
092720.69 4 timer set 6 EV_TIMEOUT_ENTERDATA
092720.88 4 tw dtmf 1 (4,49,49)
092720.89 4 event 1, iCode=49 state=1301
092720.89 4 LsGetNbrsRxDigits 1,1
092720.91 4 state [Get Acc No] Number Input 01
092720.91 4 path {01} not found
092720.92 4 timer set 6 EV_TIMEOUT_ENTERDATA
092721.23 4 tw dtmf 7 (4,55,55)
092721.25 4 event 7, iCode=55 state=1301
092721.25 4 LsGetNbrsRxDigits 7,7
092721.27 4 state [Get Acc No] Number Input 017
092721.27 4 path {017} not found
092721.28 4 timer set 6 EV_TIMEOUT_ENTERDATA
092721.64 4 tw dtmf 3 (4,51,51)
092721.66 4 event 3, iCode=51 state=1301
092721.66 4 LsGetNbrsRxDigits 3,3
092721.67 4 state [Get Acc No] Number Input 0173
092721.69 4 path {0173} not found
092721.69 4 timer set 6 EV_TIMEOUT_ENTERDATA
092722.05 4 tw dtmf 4 (4,52,52)
092722.06 4 event 4, iCode=52 state=1301
092722.08 4 LsGetNbrsRxDigits 4,4
092722.08 4 state [Get Acc No] Number Input 01734
092722.09 4 path {01734} not found
092722.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
092722.33 4 tw dtmf 4 (4,52,52)
092722.34 4 event 4, iCode=52 state=1301
092722.34 4 LsGetNbrsRxDigits 4,4
092722.36 4 state [Get Acc No] Number Input 017344
092722.36 4 path {017344} not found
092722.38 4 timer set 6 EV_TIMEOUT_ENTERDATA
092728.89 4 timer fired EV_TIMEOUT_ENTERDATA
092728.89 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
092728.91 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
092728.91 4 path {EV_TIMEOUT_ENTERDATA} not found
092728.92 4 timer clear
092728.92 4 rv add [Get Acc No]{017344}
092728.94 4 len(017344) min=11, max=14, replays=0/1
092728.95 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
092728.95 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
092728.97 4 tw wav->vox convert end 673031,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
092728.98 4 play start ok, lPlayId=673062
092729.73 4 tw dtmf 1 (4,49,49)
092729.75 4 event 1, iCode=49 state=1300
092729.75 4 LsGetNbrsPlayWelcMsg 1,1
092729.77 4 play PlayStop ok
092729.78 4 state [Get Acc No] Number Input 1
092729.78 4 path {1} not found
092729.80 4 timer set 6 EV_TIMEOUT_ENTERDATA
092729.81 4 tw PlayEnd 4 673062
092729.81 4 play end id=673062, (current ID)
092729.83 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
092729.83 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
092729.84 4 path {EV_PLAY_FINISHED} not found
092729.84 4 awaiting further dtmf input
092729.86 4 tw DialogicEvent 129,TDX_PLAY,673062,0,0,,,
092729.86 4 event TDX_PLAY, iCode=129 state=1301
092729.88 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
092729.88 4 path {TDX_PLAY} not found
092730.05 4 tw dtmf 2 (4,50,50)
092730.05 4 event 2, iCode=50 state=1301
092730.06 4 LsGetNbrsRxDigits 2,2
092730.08 4 state [Get Acc No] Number Input 12
092730.08 4 path {12} not found
092730.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
092736.56 4 timer fired EV_TIMEOUT_ENTERDATA
092736.56 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
092736.58 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
092736.58 4 path {EV_TIMEOUT_ENTERDATA} not found
092736.59 4 timer clear
092736.59 4 rv add [Get Acc No]{12}
092736.61 4 len(12) min=11, max=14, replays=1/1
092736.61 4 next module is [invalid A/C] (idx=62)
092736.63 4 fn RunModule start [Play,[invalid A/C],62,,]
092736.63 4 timer clear
092736.64 4 Play Module start
092736.64 4 state [invalid A/C] Playing
092736.66 4 state [invalid A/C] Playing (Bangla Voice\Inv Acc No.wav)
092736.67 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Inv Acc No.wav
092736.69 4 tw wav->vox convert end 680750,G:\TeleBanking System\Bangla Voice\Inv Acc No.vox,1,0,,
092736.70 4 play start ok, lPlayId=680781
092739.69 4 tw PlayEnd 4 680781
092739.70 4 play end id=680781, (current ID)
092739.72 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
092739.72 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092739.73 4 path {EV_PLAY_FINISHED} not found
092739.73 4 timer set 10 EV_TIMEOUT_HANGUP
092739.75 4 timer set 1 EV_TIMEOUT_GOTOMODULE
092739.75 4 tw DialogicEvent 129,TDX_PLAY,680781,0,0,,,
092739.77 4 event TDX_PLAY, iCode=129 state=1101
092739.77 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
092739.78 4 path {TDX_PLAY} not found
092740.77 4 timer fired EV_TIMEOUT_GOTOMODULE
092740.77 4 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101
092740.78 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
092740.78 4 path {EV_TIMEOUT_GOTOMODULE} not found
092740.80 4 next module is [Get Acc No] (idx=85)
092740.80 4 fn RunModule start [Get Numbers,[Get Acc No],85,,]
092740.81 4 timer clear
092740.81 4 state [Get Acc No] Number Input
092740.83 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
092740.84 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
092740.86 4 tw wav->vox convert end 684921,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
092740.88 4 play start ok, lPlayId=684937
092744.69 4 tw PlayEnd 4 684937
092744.69 4 play end id=684937, (current ID)
092744.70 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
092744.72 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
092744.72 4 path {EV_PLAY_FINISHED} not found
092744.73 4 timer set 17 EV_TIMEOUT_REPLAYMSG
092744.73 4 tw DialogicEvent 129,TDX_PLAY,684937,0,0,,,
092744.75 4 event TDX_PLAY, iCode=129 state=1301
092744.75 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
092744.77 4 path {TDX_PLAY} not found
092744.97 4 tw dtmf 0 (4,48,48)
092744.98 4 event 0, iCode=48 state=1301
092744.98 4 LsGetNbrsRxDigits 0,0
092745.00 4 state [Get Acc No] Number Input 0
092745.02 4 path {0} not found
092745.02 4 timer set 6 EV_TIMEOUT_ENTERDATA
092745.17 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
092745.19 4 event FAX, iCode=134 state=1301
092745.19 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
092745.20 4 path {FAX} not found
092745.22 4 event TDX_CST, iCode=134 state=1301
092745.22 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
092745.23 4 path {TDX_CST} not found
092745.31 4 tw dtmf 1 (4,49,49)
092745.31 4 event 1, iCode=49 state=1301
092745.33 4 LsGetNbrsRxDigits 1,1
092745.33 4 state [Get Acc No] Number Input 01
092745.34 4 path {01} not found
092745.36 4 timer set 6 EV_TIMEOUT_ENTERDATA
092745.64 4 tw dtmf 7 (4,55,55)
092745.64 4 event 7, iCode=55 state=1301
092745.66 4 LsGetNbrsRxDigits 7,7
092745.66 4 state [Get Acc No] Number Input 017
092745.67 4 path {017} not found
092745.67 4 timer set 6 EV_TIMEOUT_ENTERDATA
092746.09 4 tw dtmf 3 (4,51,51)
092746.09 4 event 3, iCode=51 state=1301
092746.11 4 LsGetNbrsRxDigits 3,3
092746.11 4 state [Get Acc No] Number Input 0173
092746.13 4 path {0173} not found
092746.13 4 timer set 6 EV_TIMEOUT_ENTERDATA
092746.58 4 tw dtmf 4 (4,52,52)
092746.59 4 event 4, iCode=52 state=1301
092746.59 4 LsGetNbrsRxDigits 4,4
092746.61 4 state [Get Acc No] Number Input 01734
092746.61 4 path {01734} not found
092746.63 4 timer set 6 EV_TIMEOUT_ENTERDATA
092747.02 4 tw dtmf 0 (4,48,48)
092747.02 4 event 0, iCode=48 state=1301
092747.03 4 LsGetNbrsRxDigits 0,0
092747.05 4 state [Get Acc No] Number Input 017340
092747.05 4 path {017340} not found
092747.06 4 timer set 6 EV_TIMEOUT_ENTERDATA
092747.33 4 tw dtmf 0 (4,48,48)
092747.33 4 event 0, iCode=48 state=1301
092747.34 4 LsGetNbrsRxDigits 0,0
092747.34 4 state [Get Acc No] Number Input 0173400
092747.36 4 path {0173400} not found
092747.38 4 timer set 6 EV_TIMEOUT_ENTERDATA
092747.66 4 tw dtmf 0 (4,48,48)
092747.66 4 event 0, iCode=48 state=1301
092747.67 4 LsGetNbrsRxDigits 0,0
092747.67 4 state [Get Acc No] Number Input 01734000
092747.69 4 path {01734000} not found
092747.69 4 timer set 6 EV_TIMEOUT_ENTERDATA
092748.33 4 tw dtmf 2 (4,50,50)
092748.34 4 event 2, iCode=50 state=1301
092748.36 4 LsGetNbrsRxDigits 2,2
092748.36 4 state [Get Acc No] Number Input 017340002
092748.38 4 path {017340002} not found
092748.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
092748.63 4 tw dtmf 4 (4,52,52)
092748.63 4 event 4, iCode=52 state=1301
092748.64 4 LsGetNbrsRxDigits 4,4
092748.64 4 state [Get Acc No] Number Input 0173400024
092748.66 4 path {0173400024} not found
092748.67 4 timer set 6 EV_TIMEOUT_ENTERDATA
092748.92 4 tw dtmf 5 (4,53,53)
092748.94 4 event 5, iCode=53 state=1301
092748.94 4 LsGetNbrsRxDigits 5,5
092748.95 4 state [Get Acc No] Number Input 01734000245
092748.95 4 path {01734000245} not found
092748.97 4 timer set 6 EV_TIMEOUT_ENTERDATA
092755.42 4 timer fired EV_TIMEOUT_ENTERDATA
092755.42 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
092755.44 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
092755.44 4 path {EV_TIMEOUT_ENTERDATA} not found
092755.45 4 timer clear
092755.45 4 rv add [Get Acc No]{01734000245}
092755.47 4 path {01734000245} not found
092755.47 4 next module is [Varify A/C] (idx=45)
092755.48 4 rvns add [Get Acc No_PathTaken]{success}
092755.50 4 fn RunModule start [Database Query,[Varify A/C],45,,]
092755.50 4 timer clear
092755.52 4 state [Varify A/C] DB Query
092755.52 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
092755.56 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
092755.56 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:27:12 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:27:14 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:27:14 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
  1. {1}[Get Acc No]{017344}[Get Acc No]{12}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}
092755.58 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
092755.59 4 db [Varify A/C] row count=1
092755.59 4 rv add [Varify A/C_RowCount]{1}
092755.61 4 db get RecordsetGetRowsMax
092755.61 4 db get 999 records. (row count=1)
092755.63 4 db update RVs
092755.63 4 db about to close dbDbqDatabase
092755.64 4 db going down path [True]
092755.66 4 next module is [Get PIN No] (idx=84)
092755.66 4 fn RunModule start [Get Numbers,[Get PIN No],84,,]
092755.67 4 timer clear
092755.67 4 state [Get PIN No] Number Input
092755.69 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
092755.69 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
092755.73 4 tw wav->vox convert end 699765,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
092755.75 4 play start ok, lPlayId=699812
092759.03 4 tw dtmf 3 (4,51,51)
092759.05 4 event 3, iCode=51 state=1300
092759.06 4 LsGetNbrsPlayWelcMsg 3,3
092759.08 4 play PlayStop ok
092759.08 4 state [Get PIN No] Number Input 3
092759.09 4 path {3} not found
092759.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
092759.11 4 tw PlayEnd 4 699812
092759.13 4 play end id=699812, (current ID)
092759.13 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
092759.14 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
092759.14 4 path {EV_PLAY_FINISHED} not found
092759.16 4 awaiting further dtmf input
092759.16 4 tw DialogicEvent 129,TDX_PLAY,699812,0,0,,,
092759.17 4 event TDX_PLAY, iCode=129 state=1301
092759.17 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
092759.19 4 path {TDX_PLAY} not found
092759.45 4 tw dtmf 8 (4,56,56)
092759.47 4 event 8, iCode=56 state=1301
092759.47 4 LsGetNbrsRxDigits 8,8
092759.48 4 state [Get PIN No] Number Input 38
092759.50 4 path {38} not found
092759.50 4 timer set 6 EV_TIMEOUT_ENTERDATA
092800.06 4 tw dtmf 0 (4,48,48)
092800.06 4 event 0, iCode=48 state=1301
092800.08 4 LsGetNbrsRxDigits 0,0
092800.08 4 state [Get PIN No] Number Input 380
092800.09 4 path {380} not found
092800.11 4 timer set 6 EV_TIMEOUT_ENTERDATA
092800.42 4 tw dtmf 4 (4,52,52)
092800.42 4 event 4, iCode=52 state=1301
092800.44 4 LsGetNbrsRxDigits 4,4
092800.45 4 state [Get PIN No] Number Input 3804
092800.45 4 path {3804} not found
092800.47 4 timer set 6 EV_TIMEOUT_ENTERDATA
092800.47 4 timer clear
092800.48 4 rv add [Get PIN No]{3804}
092800.48 4 path {3804} not found
092800.50 4 next module is [Varify A/C No] (idx=60)
092800.50 4 rvns add [Get PIN No_PathTaken]{success}
092800.52 4 fn RunModule start [Database Query,[Varify A/C No],60,,]
092800.53 4 timer clear
092800.53 4 state [Varify A/C No] DB Query
092800.55 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
092800.58 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
092800.59 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:27:12 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{017344}[Get Acc No]{12}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}
092800.59 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
092800.61 4 db [Varify A/C No] row count=1
092800.63 4 rv add [Varify A/C No_RowCount]{1}
092800.63 4 db get RecordsetGetRowsMax
092800.64 4 db get 999 records. (row count=1)
092800.66 4 db update RVs
092800.66 4 db about to close dbDbqDatabase
092800.67 4 db going down path [True]
092800.67 4 next module is
  1. (idx=83)
092800.69 4 fn RunModule start [Play,
  1. ,83,,]
092800.70 4 timer clear
092800.70 4 Play Module start
092800.72 4 state
  1. Playing
092800.72 4 state
092800.73 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
092800.77 4 tw wav->vox convert end 704812,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
092800.78 4 play start ok, lPlayId=704843
092802.44 4 tw dtmf 1 (4,49,49)
092802.44 4 event 1, iCode=49 state=1100
092802.45 4 LsPlayMsg 1,1
092802.47 4 next module is [Varify Balance] (idx=82)
092802.48 4 play PlayStop ok
092802.50 4 rv add
  1. {1}
092802.50 4 fn RunModule start [Database Query,[Varify Balance],82,,]
092802.52 4 tw PlayEnd 4 704843
092802.52 4 play end id=704843, (current ID)
092802.53 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
092802.55 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
092802.55 4 tw DialogicEvent 129,TDX_PLAY,704843,0,0,,,
092802.56 4 event TDX_PLAY, iCode=129 state=6001
092802.56 4 LsModuleTransition : 129, [TDX_PLAY]
092802.58 4 timer clear
092802.58 4 state [Varify Balance] DB Query
092802.59 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
092802.63 4 db About to execute a Retrieve type operation [sELECT 200 as curbal FROM dual;]
092802.66 4 OpenRecordset: 3146:ODBC--call failed.
092802.67 4 path {0} not found
092802.67 4 path {} not found
092802.69 4 HangupCall start (Fail/False path not defined)
092802.70 4 rv add [Hangup Time]{01/10/2007 9:28:02 AM}
092802.70 4 state Hanging up call... [Fail/False path not defined]
092802.72 4 HangupCall_Common hCall=4
092802.72 4 rec RecSoundStop ok
092802.73 4 play PlayStop ok
092802.75 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
092802.75 4 fnHangupCall end
092802.80 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
092802.81 4 event TDX_SETHOOK, iCode=135 state=900
092802.81 4 LsAwaitingCalls EV_UNKNOWN_135
092802.83 4 event callstate IDLE 4 1,0,0
092802.83 4 WorkingMode@Idle=
092802.84 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
092802.86 4 timer clear
092802.86 4 rec RecSoundStop ok
092802.88 4 play PlayStop ok
092802.89 4 rv add [CallEndTime]{01/10/2007 9:28:02 AM}
092802.91 4 on-hangup script:[]
092802.92 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
092802.94 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
092802.94 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
092802.95 4 init atidle reinit : start
092802.95 4 init atidle reinit iConferenceOtherLegLid=-1
092802.97 4 init atidle reinit : reset all LineState variables
092802.98 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
092802.98 4 state Waiting for a call...
092805.19 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
092805.19 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
092805.20 4 setting iDialoutReadyToDialout = 1
092919.03 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
092919.03 MemStructVgs_ClearVgs [2]
092919.11 load end
092919.13 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
092919.13 0 Erasing Script (new loaded) Id 3
092919.14 0 VgsScriptFree [3]
092919.16 MemStructVgs_ClearVgs [3]
093121.16 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
093121.16 MemStructVgs_ClearVgs [3]
093121.25 load end
093121.25 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
093121.27 0 Erasing Script (new loaded) Id 2
093121.28 0 VgsScriptFree [2]
093121.28 MemStructVgs_ClearVgs [2]
093227.78 4 event callstate OFFERING 4 2,0,0
093227.80 4 script interpretor: VgMulti v6.0.3243
093227.81 4 fired OFFERING event to listeners
093227.81 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
093227.83 4 cid CallerID vars set (in 'offering' event) [,,]
093227.83 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
093227.84 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
093227.84 4 tw ring 1
093227.86 4 ring time since last ring event (sec): 0.00
093227.88 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
093227.88 4 should answer as number of rings reached
093227.89 4 rv clear all
093227.89 4 init LineState ResetAtStartOfNewCall.
093227.91 4 answering the call (,,,0)
093227.91 4 timer clear
093227.92 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
093227.94 4 event TDX_CST, iCode=134 state=6001
093227.95 4 LsModuleTransition : 134, [TDX_CST]
093228.56 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
093228.56 4 event TDX_SETHOOK, iCode=135 state=6001
093228.58 4 LsModuleTransition : 135, [TDX_SETHOOK]
093228.58 4 event callstate CONNECTED 4 256,0,0
093228.59 4 LineEvCallState_Connected hDevice=4 params=256,0,0
093228.59 4 WorkingModes tapi= script= LineState().iState=6001
093228.61 4 Inband detection not enabled
093228.63 4 StartLoadedVgs at 01/10/2007 9:32:28 AM (VgMulti v6.0.3243)
093228.63 4 set LineState().iVgsIdx=1
093228.64 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
093228.64 4 init StartLoadedVgs_InitLineState start
093228.66 4 rv add [$RV_STARTTIME]{01/10/2007 9:32:28 AM}
093228.67 4 rv add [$RV_DEVICEID]{4}
093228.67 4 rv add [DlgcNetworkResource]{dxxxB1C4}
093228.69 4 rv add [DlgcVoiceResource]{dxxxB1C4}
093228.69 4 rv add [$RV_CIDNAME]{}
093228.70 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
093228.72 4 rvns add [scriptsPath]{G:\TeleBanking System\}
093228.72 4 rv add [$RV_CIDNUMBER]{}
093228.73 4 fn RunModule start [Play,[Get Language],1,,]
093228.73 4 tw DialogicEvent 134,TDX_CST,26576,0,0,DE_LCON,,
093228.75 4 event TDX_CST, iCode=134 state=6001
093228.75 4 LsModuleTransition : 134, [TDX_CST]
093228.77 4 timer clear
093228.78 4 Play Module start
093228.78 4 state [Get Language] Playing
093228.80 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
093228.80 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
093228.84 4 tw wav->vox convert end 972875,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
093228.86 4 play start ok, lPlayId=972921
093229.64 4 tw dtmf 1 (4,49,49)
093229.66 4 event 1, iCode=49 state=1100
093229.66 4 LsPlayMsg 1,1
093229.67 4 rv add [scriptEnd_Time]{01/10/2007 9:32:29 AM}
093229.67 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
093229.69 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
093229.72 4 rv add [scriptStart_Time]{01/10/2007 9:32:29 AM}
093229.73 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
093229.73 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
093229.75 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
093229.75 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3
093229.77 4 rvns add [scriptsPath]{G:\TeleBanking System\}
093229.78 4 play PlayStop ok
093229.80 4 rv add [Get Language]{1}
093229.80 4 fn RunModule start [Evaluate,[Get Bangla],66,,]
093229.81 4 tw PlayEnd 4 972921
093229.83 4 play end id=972921, (current ID)
093229.83 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
093229.84 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
093229.84 4 tw DialogicEvent 129,TDX_PLAY,972921,0,0,,,
093229.86 4 event TDX_PLAY, iCode=129 state=6001
093229.86 4 LsModuleTransition : 129, [TDX_PLAY]
093229.88 4 timer clear
093229.89 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
093229.89 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
093229.91 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
093229.91 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
093229.92 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
093229.92 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
093229.94 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
093229.95 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
093229.95 4 matching path not found
093229.97 4 next module is
  1. (idx=67)
093229.97 4 matching path was found
093229.98 4 fn RunModule start [Play,
  1. ,67,,]
093230.00 4 timer clear
093230.00 4 Play Module start
093230.02 4 state
  1. Playing
093230.02 4 state
093230.03 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
093230.06 4 tw wav->vox convert end 974109,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
093230.08 4 play start ok, lPlayId=974140
093232.86 4 tw dtmf 1 (4,49,49)
093232.86 4 event 1, iCode=49 state=1100
093232.88 4 LsPlayMsg 1,1
093232.89 4 next module is [Get Acc No] (idx=45)
093232.91 4 play PlayStop ok
093232.91 4 rv add
  1. {1}
093232.92 4 fn RunModule start [Get Numbers,[Get Acc No],45,,]
093232.94 4 tw PlayEnd 4 974140
093232.94 4 play end id=974140, (current ID)
093232.95 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
093232.95 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
093232.97 4 tw DialogicEvent 129,TDX_PLAY,974140,0,0,,,
093232.98 4 event TDX_PLAY, iCode=129 state=6001
093232.98 4 LsModuleTransition : 129, [TDX_PLAY]
093233.00 4 timer clear
093233.00 4 state [Get Acc No] Number Input
093233.02 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
093233.02 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
093233.05 4 tw wav->vox convert end 977093,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
093233.08 4 play start ok, lPlayId=977140
093236.89 4 tw PlayEnd 4 977140
093236.89 4 play end id=977140, (current ID)
093236.91 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
093236.92 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
093236.92 4 path {EV_PLAY_FINISHED} not found
093236.94 4 timer set 17 EV_TIMEOUT_REPLAYMSG
093236.94 4 tw DialogicEvent 129,TDX_PLAY,977140,0,0,,,
093236.95 4 event TDX_PLAY, iCode=129 state=1301
093236.95 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
093236.97 4 path {TDX_PLAY} not found
093237.86 4 tw dtmf 0 (4,48,48)
093237.88 4 event 0, iCode=48 state=1301
093237.88 4 LsGetNbrsRxDigits 0,0
093237.89 4 state [Get Acc No] Number Input 0
093237.89 4 path {0} not found
093237.91 4 timer set 6 EV_TIMEOUT_ENTERDATA
093238.17 4 tw dtmf 1 (4,49,49)
093238.19 4 event 1, iCode=49 state=1301
093238.19 4 LsGetNbrsRxDigits 1,1
093238.20 4 state [Get Acc No] Number Input 01
093238.20 4 path {01} not found
093238.22 4 timer set 6 EV_TIMEOUT_ENTERDATA
093238.63 4 tw dtmf 7 (4,55,55)
093238.64 4 event 7, iCode=55 state=1301
093238.64 4 LsGetNbrsRxDigits 7,7
093238.66 4 state [Get Acc No] Number Input 017
093238.66 4 path {017} not found
093238.67 4 timer set 6 EV_TIMEOUT_ENTERDATA
093239.03 4 tw dtmf 3 (4,51,51)
093239.05 4 event 3, iCode=51 state=1301
093239.06 4 LsGetNbrsRxDigits 3,3
093239.06 4 state [Get Acc No] Number Input 0173
093239.08 4 path {0173} not found
093239.08 4 timer set 6 EV_TIMEOUT_ENTERDATA
093239.59 4 tw dtmf 4 (4,52,52)
093239.59 4 event 4, iCode=52 state=1301
093239.61 4 LsGetNbrsRxDigits 4,4
093239.61 4 state [Get Acc No] Number Input 01734
093239.63 4 path {01734} not found
093239.64 4 timer set 6 EV_TIMEOUT_ENTERDATA
093240.27 4 tw dtmf 0 (4,48,48)
093240.27 4 event 0, iCode=48 state=1301
093240.28 4 LsGetNbrsRxDigits 0,0
093240.28 4 state [Get Acc No] Number Input 017340
093240.30 4 path {017340} not found
093240.31 4 timer set 6 EV_TIMEOUT_ENTERDATA
093240.45 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
093240.47 4 event FAX, iCode=134 state=1301
093240.47 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
093240.48 4 path {FAX} not found
093240.48 4 event TDX_CST, iCode=134 state=1301
093240.50 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
093240.52 4 path {TDX_CST} not found
093240.52 4 tw dtmf 0 (4,48,48)
093240.53 4 event 0, iCode=48 state=1301
093240.55 4 LsGetNbrsRxDigits 0,0
093240.55 4 state [Get Acc No] Number Input 0173400
093240.56 4 path {0173400} not found
093240.56 4 timer set 6 EV_TIMEOUT_ENTERDATA
093240.70 4 tw dtmf 0 (4,48,48)
093240.72 4 event 0, iCode=48 state=1301
093240.72 4 LsGetNbrsRxDigits 0,0
093240.73 4 state [Get Acc No] Number Input 01734000
093240.73 4 path {01734000} not found
093240.75 4 timer set 6 EV_TIMEOUT_ENTERDATA
093241.52 4 tw dtmf 2 (4,50,50)
093241.53 4 event 2, iCode=50 state=1301
093241.53 4 LsGetNbrsRxDigits 2,2
093241.55 4 state [Get Acc No] Number Input 017340002
093241.56 4 path {017340002} not found
093241.56 4 timer set 6 EV_TIMEOUT_ENTERDATA
093241.77 4 tw dtmf 4 (4,52,52)
093241.78 4 event 4, iCode=52 state=1301
093241.80 4 LsGetNbrsRxDigits 4,4
093241.80 4 state [Get Acc No] Number Input 0173400024
093241.81 4 path {0173400024} not found
093241.81 4 timer set 6 EV_TIMEOUT_ENTERDATA
093242.05 4 tw dtmf 5 (4,53,53)
093242.06 4 event 5, iCode=53 state=1301
093242.06 4 LsGetNbrsRxDigits 5,5
093242.08 4 state [Get Acc No] Number Input 01734000245
093242.08 4 path {01734000245} not found
093242.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
093243.30 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
093243.31 4 event FAX, iCode=134 state=1301
093243.31 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
093243.33 4 path {FAX} not found
093243.33 4 event TDX_CST, iCode=134 state=1301
093243.34 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
093243.34 4 path {TDX_CST} not found
093248.61 4 timer fired EV_TIMEOUT_ENTERDATA
093248.61 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
093248.63 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
093248.63 4 path {EV_TIMEOUT_ENTERDATA} not found
093248.64 4 timer clear
093248.66 4 rv add [Get Acc No]{01734000245}
093248.66 4 path {01734000245} not found
093248.67 4 next module is [Varify A/C] (idx=85)
093248.67 4 rvns add [Get Acc No_PathTaken]{success}
093248.69 4 fn RunModule start [Database Query,[Varify A/C],85,,]
093248.69 4 timer clear
093248.70 4 state [Varify A/C] DB Query
093248.72 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
093248.75 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
093248.77 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:32:28 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:32:29 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:32:29 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
  1. {1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}
093248.77 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
093248.78 4 db [Varify A/C] row count=1
093248.80 4 rv add [Varify A/C_RowCount]{1}
093248.81 4 db get RecordsetGetRowsMax
093248.81 4 db get 999 records. (row count=1)
093248.83 4 db update RVs
093248.83 4 db about to close dbDbqDatabase
093248.84 4 db going down path [True]
093248.86 4 next module is [Get PIN No] (idx=46)
093248.86 4 fn RunModule start [Get Numbers,[Get PIN No],46,,]
093248.88 4 timer clear
093248.88 4 state [Get PIN No] Number Input
093248.89 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
093248.89 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
093248.95 4 tw wav->vox convert end 992968,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
093248.97 4 play start ok, lPlayId=993031
093251.92 4 tw dtmf 3 (4,51,51)
093251.94 4 event 3, iCode=51 state=1300
093251.94 4 LsGetNbrsPlayWelcMsg 3,3
093251.95 4 play PlayStop ok
093251.97 4 state [Get PIN No] Number Input 3
093251.98 4 path {3} not found
093251.98 4 timer set 6 EV_TIMEOUT_ENTERDATA
093252.00 4 tw PlayEnd 4 993031
093252.00 4 play end id=993031, (current ID)
093252.02 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
093252.03 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
093252.03 4 path {EV_PLAY_FINISHED} not found
093252.05 4 awaiting further dtmf input
093252.05 4 tw DialogicEvent 129,TDX_PLAY,993031,0,0,,,
093252.06 4 event TDX_PLAY, iCode=129 state=1301
093252.06 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
093252.08 4 path {TDX_PLAY} not found
093252.45 4 tw dtmf 8 (4,56,56)
093252.45 4 event 8, iCode=56 state=1301
093252.47 4 LsGetNbrsRxDigits 8,8
093252.48 4 state [Get PIN No] Number Input 38
093252.48 4 path {38} not found
093252.50 4 timer set 6 EV_TIMEOUT_ENTERDATA
093253.42 4 tw dtmf 0 (4,48,48)
093253.44 4 event 0, iCode=48 state=1301
093253.44 4 LsGetNbrsRxDigits 0,0
093253.45 4 state [Get PIN No] Number Input 380
093253.45 4 path {380} not found
093253.47 4 timer set 6 EV_TIMEOUT_ENTERDATA
093254.00 4 tw dtmf 4 (4,52,52)
093254.02 4 event 4, iCode=52 state=1301
093254.02 4 LsGetNbrsRxDigits 4,4
093254.03 4 state [Get PIN No] Number Input 3804
093254.03 4 path {3804} not found
093254.05 4 timer set 6 EV_TIMEOUT_ENTERDATA
093254.05 4 timer clear
093254.06 4 rv add [Get PIN No]{3804}
093254.08 4 path {3804} not found
093254.08 4 next module is [Varify A/C No] (idx=70)
093254.09 4 rvns add [Get PIN No_PathTaken]{success}
093254.09 4 fn RunModule start [Database Query,[Varify A/C No],70,,]
093254.11 4 timer clear
093254.13 4 state [Varify A/C No] DB Query
093254.14 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
093254.17 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
093254.19 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:32:28 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}
093254.19 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
093254.20 4 db [Varify A/C No] row count=1
093254.22 4 rv add [Varify A/C No_RowCount]{1}
093254.22 4 db get RecordsetGetRowsMax
093254.23 4 db get 999 records. (row count=1)
093254.25 4 db update RVs
093254.25 4 db about to close dbDbqDatabase
093254.27 4 db going down path [True]
093254.28 4 next module is
  1. (idx=47)
093254.28 4 fn RunModule start [Play,
  1. ,47,,]
093254.30 4 timer clear
093254.30 4 Play Module start
093254.31 4 state
  1. Playing
093254.31 4 state
093254.33 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
093254.38 4 tw wav->vox convert end 998406,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
093254.41 4 play start ok, lPlayId=998468
093255.89 4 tw dtmf 1 (4,49,49)
093255.89 4 event 1, iCode=49 state=1100
093255.91 4 LsPlayMsg 1,1
093255.91 4 next module is [Varify Balance] (idx=48)
093255.94 4 play PlayStop ok
093255.94 4 rv add
  1. {1}
093255.95 4 fn RunModule start [Database Query,[Varify Balance],48,,]
093255.95 4 tw PlayEnd 4 998468
093255.97 4 play end id=998468, (current ID)
093255.98 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
093255.98 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
093256.00 4 tw DialogicEvent 129,TDX_PLAY,998468,0,0,,,
093256.00 4 event TDX_PLAY, iCode=129 state=6001
093256.02 4 LsModuleTransition : 129, [TDX_PLAY]
093256.03 4 timer clear
093256.03 4 state [Varify Balance] DB Query
093256.05 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
093256.08 4 rv replace start: [sELECT TRUNC(curbal) curbal FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND acstat<>'CLS']
093256.09 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:32:28 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}[Varify A/C No_RowCount]{1}[Varify A/C No_1_1]{LX4VNZ41KDX7}
    1. {1}
093256.09 4 db About to execute a Retrieve type operation [sELECT TRUNC(curbal) curbal FROM stlbas.stfacmas WHERE actnum=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND acstat<>'CLS]
093256.11 4 db [Varify Balance] row count=1
093256.13 4 rv add [Varify Balance_RowCount]{1}
093256.13 4 db get RecordsetGetRowsMax
093256.14 4 db get 999 records. (row count=1)
093256.16 4 db update RVs
093256.16 4 db about to close dbDbqDatabase
093256.17 4 db going down path [True]
093256.19 4 next module is [say Balance] (idx=81)
093256.19 4 fn RunModule start [say Numbers,[say Balance],81,,]
093256.20 4 timer clear
093256.22 4 rv replace start: [$RV[Varify Balance_1_1]]
093256.22 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:32:28 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
093256.23 4 rv replace end: [60579]
093256.25 4 state [say Balance] Say numbers: 60579 as Number
093256.25 4 fn PlaySoundStartNumbers [bangla Voice\Acc Bal.wav],[],[60579],Number
093256.28 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
093256.28 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
093256.30 4 rv add [Hangup Time]{01/10/2007 9:32:56 AM}
093256.31 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
093256.31 4 HangupCall_Common hCall=4
093256.33 4 rec RecSoundStop ok
093256.34 4 play PlayStop ok
093256.34 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
093256.36 4 fnHangupCall end
093256.41 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
093256.41 4 event TDX_SETHOOK, iCode=135 state=900
093256.42 4 LsAwaitingCalls EV_UNKNOWN_135
093256.42 4 event callstate IDLE 4 1,0,0
093256.44 4 WorkingMode@Idle=
093256.44 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
093256.45 4 timer clear
093256.47 4 rec RecSoundStop ok
093256.47 4 play PlayStop ok
093256.48 4 rv add [CallEndTime]{01/10/2007 9:32:56 AM}
093256.52 4 on-hangup script:[]
093256.53 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
093256.53 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
093256.55 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
093256.55 4 init atidle reinit : start
093256.56 4 init atidle reinit iConferenceOtherLegLid=-1
093256.58 4 init atidle reinit : reset all LineState variables
093256.58 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
093256.59 4 state Waiting for a call...
093258.78 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
093258.78 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
093258.80 4 setting iDialoutReadyToDialout = 1
093339.41 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
093339.42 MemStructVgs_ClearVgs [2]
093339.52 load end
093339.53 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
093339.55 0 Erasing Script (new loaded) Id 3
093339.56 0 VgsScriptFree [3]
093339.58 MemStructVgs_ClearVgs [3]
093912.92 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
093912.92 MemStructVgs_ClearVgs [3]
093913.00 load end
093913.02 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
093913.03 0 Erasing Script (new loaded) Id 2
093913.05 0 VgsScriptFree [2]
093913.05 MemStructVgs_ClearVgs [2]
093920.06 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
093920.08 MemStructVgs_ClearVgs [2]
093920.16 load end
093920.16 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
093920.17 0 Erasing Script (new loaded) Id 3
093920.17 0 VgsScriptFree [3]
093920.19 MemStructVgs_ClearVgs [3]
093939.27 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
093939.27 MemStructVgs_ClearVgs [3]
093939.34 load end
093939.36 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
093939.38 0 Erasing Script (new loaded) Id 2
093939.38 0 VgsScriptFree [2]
093939.39 MemStructVgs_ClearVgs [2]
093955.41 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
093955.41 MemStructVgs_ClearVgs [2]
093955.48 load end
093955.50 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
093955.52 0 Erasing Script (new loaded) Id 3
093955.52 0 VgsScriptFree [3]
093955.53 MemStructVgs_ClearVgs [3]
094003.94 4 event callstate OFFERING 4 2,0,0
094003.94 4 script interpretor: VgMulti v6.0.3243
094003.95 4 fired OFFERING event to listeners
094003.97 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
094003.97 4 cid CallerID vars set (in 'offering' event) [,,]
094003.98 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
094003.98 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
094004.00 4 tw ring 1
094004.02 4 ring time since last ring event (sec): 0.00
094004.02 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
094004.03 4 should answer as number of rings reached
094004.03 4 rv clear all
094004.05 4 init LineState ResetAtStartOfNewCall.
094004.06 4 answering the call (,,,0)
094004.06 4 timer clear
094004.08 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
094004.09 4 event TDX_CST, iCode=134 state=6001
094004.09 4 LsModuleTransition : 134, [TDX_CST]
094004.70 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
094004.72 4 event TDX_SETHOOK, iCode=135 state=6001
094004.73 4 LsModuleTransition : 135, [TDX_SETHOOK]
094004.73 4 event callstate CONNECTED 4 256,0,0
094004.75 4 LineEvCallState_Connected hDevice=4 params=256,0,0
094004.77 4 WorkingModes tapi= script= LineState().iState=6001
094004.77 4 Inband detection not enabled
094004.78 4 StartLoadedVgs at 01/10/2007 9:40:04 AM (VgMulti v6.0.3243)
094004.80 4 set LineState().iVgsIdx=1
094004.80 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
094004.81 4 init StartLoadedVgs_InitLineState start
094004.81 4 rv add [$RV_STARTTIME]{01/10/2007 9:40:04 AM}
094004.83 4 rv add [$RV_DEVICEID]{4}
094004.84 4 rv add [DlgcNetworkResource]{dxxxB1C4}
094004.84 4 rv add [DlgcVoiceResource]{dxxxB1C4}
094004.86 4 rv add [$RV_CIDNAME]{}
094004.86 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
094004.88 4 rvns add [scriptsPath]{G:\TeleBanking System\}
094004.89 4 rv add [$RV_CIDNUMBER]{}
094004.89 4 fn RunModule start [Play,[Get Language],1,,]
094004.91 4 tw DialogicEvent 134,TDX_CST,42831,0,0,DE_LCON,,
094004.91 4 event TDX_CST, iCode=134 state=6001
094004.92 4 LsModuleTransition : 134, [TDX_CST]
094004.94 4 timer clear
094004.94 4 Play Module start
094004.95 4 state [Get Language] Playing
094004.97 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
094004.97 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
094005.02 4 tw wav->vox convert end 429046,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
094005.03 4 play start ok, lPlayId=429093
094007.05 4 tw dtmf 1 (4,49,49)
094007.06 4 event 1, iCode=49 state=1100
094007.06 4 LsPlayMsg 1,1
094007.08 4 rv add [scriptEnd_Time]{01/10/2007 9:40:07 AM}
094007.08 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
094007.09 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
094007.13 4 rv add [scriptStart_Time]{01/10/2007 9:40:07 AM}
094007.14 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
094007.14 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
094007.16 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
094007.17 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=2
094007.17 4 rvns add [scriptsPath]{G:\TeleBanking System\}
094007.19 4 play PlayStop ok
094007.20 4 rv add [Get Language]{1}
094007.20 4 fn RunModule start [Evaluate,[Get Bangla],24,,]
094007.22 4 tw PlayEnd 4 429093
094007.23 4 play end id=429093, (current ID)
094007.23 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
094007.25 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
094007.25 4 tw DialogicEvent 129,TDX_PLAY,429093,0,0,,,
094007.27 4 event TDX_PLAY, iCode=129 state=6001
094007.28 4 LsModuleTransition : 129, [TDX_PLAY]
094007.28 4 timer clear
094007.30 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
094007.30 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
094007.31 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
094007.33 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
094007.33 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
094007.34 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
094007.34 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
094007.36 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
094007.36 4 matching path not found
094007.38 4 next module is
  1. (idx=23)
094007.39 4 matching path was found
094007.39 4 fn RunModule start [Play,
  1. ,23,,]
094007.42 4 timer clear
094007.42 4 Play Module start
094007.44 4 state
  1. Playing
094007.44 4 state
  1. Playing (Bangla Voice\Service List.wav)
094007.45 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
094007.50 4 tw wav->vox convert end 431531,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
094007.52 4 play start ok, lPlayId=431578
094010.72 4 tw dtmf 1 (4,49,49)
094010.73 4 event 1, iCode=49 state=1100
094010.73 4 LsPlayMsg 1,1
094010.75 4 next module is [Get Acc No] (idx=87)
094010.77 4 play PlayStop ok
094010.78 4 rv add
  1. {1}
094010.78 4 fn RunModule start [Get Numbers,[Get Acc No],87,,]
094010.80 4 tw PlayEnd 4 431578
094010.81 4 play end id=431578, (current ID)
094010.81 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
094010.83 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
094010.84 4 tw DialogicEvent 129,TDX_PLAY,431578,0,0,,,
094010.84 4 event TDX_PLAY, iCode=129 state=6001
094010.86 4 LsModuleTransition : 129, [TDX_PLAY]
094010.86 4 timer clear
094010.88 4 state [Get Acc No] Number Input
094010.89 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
094010.89 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
094010.95 4 tw wav->vox convert end 434968,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
094010.97 4 play start ok, lPlayId=435031
094014.78 4 tw PlayEnd 4 435031
094014.80 4 play end id=435031, (current ID)
094014.81 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
094014.81 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
094014.83 4 path {EV_PLAY_FINISHED} not found
094014.83 4 timer set 17 EV_TIMEOUT_REPLAYMSG
094014.84 4 tw DialogicEvent 129,TDX_PLAY,435031,0,0,,,
094014.86 4 event TDX_PLAY, iCode=129 state=1301
094014.86 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
094014.88 4 path {TDX_PLAY} not found
094015.03 4 tw dtmf 0 (4,48,48)
094015.05 4 event 0, iCode=48 state=1301
094015.06 4 LsGetNbrsRxDigits 0,0
094015.06 4 state [Get Acc No] Number Input 0
094015.08 4 path {0} not found
094015.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
094015.45 4 tw dtmf 1 (4,49,49)
094015.45 4 event 1, iCode=49 state=1301
094015.47 4 LsGetNbrsRxDigits 1,1
094015.47 4 state [Get Acc No] Number Input 01
094015.48 4 path {01} not found
094015.50 4 timer set 6 EV_TIMEOUT_ENTERDATA
094015.81 4 tw dtmf 7 (4,55,55)
094015.81 4 event 7, iCode=55 state=1301
094015.83 4 LsGetNbrsRxDigits 7,7
094015.83 4 state [Get Acc No] Number Input 017
094015.84 4 path {017} not found
094015.86 4 timer set 6 EV_TIMEOUT_ENTERDATA
094016.28 4 tw dtmf 3 (4,51,51)
094016.28 4 event 3, iCode=51 state=1301
094016.30 4 LsGetNbrsRxDigits 3,3
094016.30 4 state [Get Acc No] Number Input 0173
094016.31 4 path {0173} not found
094016.33 4 timer set 6 EV_TIMEOUT_ENTERDATA
094016.69 4 tw dtmf 4 (4,52,52)
094016.69 4 event 4, iCode=52 state=1301
094016.70 4 LsGetNbrsRxDigits 4,4
094016.70 4 state [Get Acc No] Number Input 01734
094016.72 4 path {01734} not found
094016.73 4 timer set 6 EV_TIMEOUT_ENTERDATA
094017.13 4 tw dtmf 0 (4,48,48)
094017.14 4 event 0, iCode=48 state=1301
094017.14 4 LsGetNbrsRxDigits 0,0
094017.16 4 state [Get Acc No] Number Input 017340
094017.16 4 path {017340} not found
094017.17 4 timer set 6 EV_TIMEOUT_ENTERDATA
094017.39 4 tw dtmf 0 (4,48,48)
094017.41 4 event 0, iCode=48 state=1301
094017.41 4 LsGetNbrsRxDigits 0,0
094017.42 4 state [Get Acc No] Number Input 0173400
094017.42 4 path {0173400} not found
094017.44 4 timer set 6 EV_TIMEOUT_ENTERDATA
094017.64 4 tw dtmf 0 (4,48,48)
094017.66 4 event 0, iCode=48 state=1301
094017.66 4 LsGetNbrsRxDigits 0,0
094017.67 4 state [Get Acc No] Number Input 01734000
094017.67 4 path {01734000} not found
094017.69 4 timer set 6 EV_TIMEOUT_ENTERDATA
094018.17 4 tw dtmf 2 (4,50,50)
094018.19 4 event 2, iCode=50 state=1301
094018.19 4 LsGetNbrsRxDigits 2,2
094018.20 4 state [Get Acc No] Number Input 017340002
094018.20 4 path {017340002} not found
094018.22 4 timer set 6 EV_TIMEOUT_ENTERDATA
094018.78 4 tw dtmf 5 (4,53,53)
094018.80 4 event 5, iCode=53 state=1301
094018.80 4 LsGetNbrsRxDigits 5,5
094018.81 4 state [Get Acc No] Number Input 0173400025
094018.83 4 path {0173400025} not found
094018.83 4 timer set 6 EV_TIMEOUT_ENTERDATA
094025.30 4 timer fired EV_TIMEOUT_ENTERDATA
094025.30 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
094025.31 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
094025.31 4 path {EV_TIMEOUT_ENTERDATA} not found
094025.33 4 timer clear
094025.34 4 rv add [Get Acc No]{0173400025}
094025.34 4 len(0173400025) min=11, max=14, replays=0/1
094025.36 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
094025.36 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
094025.42 4 tw wav->vox convert end 449437,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
094025.45 4 play start ok, lPlayId=449515
094029.27 4 tw PlayEnd 4 449515
094029.27 4 play end id=449515, (current ID)
094029.28 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
094029.28 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
094029.30 4 path {EV_PLAY_FINISHED} not found
094029.31 4 timer set 10 EV_TIMEOUT_HANGUP
094029.31 4 timer set 6 EV_TIMEOUT_ENTERDATA
094029.33 4 tw DialogicEvent 129,TDX_PLAY,449515,0,0,,,
094029.33 4 event TDX_PLAY, iCode=129 state=1301
094029.34 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
094029.36 4 path {TDX_PLAY} not found
094029.64 4 tw dtmf 0 (4,48,48)
094029.66 4 event 0, iCode=48 state=1301
094029.66 4 LsGetNbrsRxDigits 0,0
094029.67 4 state [Get Acc No] Number Input 0
094029.67 4 path {0} not found
094029.69 4 timer set 6 EV_TIMEOUT_ENTERDATA
094030.00 4 tw dtmf 1 (4,49,49)
094030.02 4 event 1, iCode=49 state=1301
094030.02 4 LsGetNbrsRxDigits 1,1
094030.03 4 state [Get Acc No] Number Input 01
094030.05 4 path {01} not found
094030.05 4 timer set 6 EV_TIMEOUT_ENTERDATA
094030.34 4 tw dtmf 7 (4,55,55)
094030.36 4 event 7, iCode=55 state=1301
094030.38 4 LsGetNbrsRxDigits 7,7
094030.38 4 state [Get Acc No] Number Input 017
094030.39 4 path {017} not found
094030.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
094030.81 4 tw dtmf 3 (4,51,51)
094030.81 4 event 3, iCode=51 state=1301
094030.83 4 LsGetNbrsRxDigits 3,3
094030.84 4 state [Get Acc No] Number Input 0173
094030.84 4 path {0173} not found
094030.86 4 timer set 6 EV_TIMEOUT_ENTERDATA
094031.05 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
094031.06 4 event FAX, iCode=134 state=1301
094031.06 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
094031.08 4 path {FAX} not found
094031.08 4 event TDX_CST, iCode=134 state=1301
094031.09 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
094031.11 4 path {TDX_CST} not found
094031.22 4 tw dtmf 4 (4,52,52)
094031.22 4 event 4, iCode=52 state=1301
094031.23 4 LsGetNbrsRxDigits 4,4
094031.25 4 state [Get Acc No] Number Input 01734
094031.25 4 path {01734} not found
094031.27 4 timer set 6 EV_TIMEOUT_ENTERDATA
094031.67 4 tw dtmf 0 (4,48,48)
094031.69 4 event 0, iCode=48 state=1301
094031.69 4 LsGetNbrsRxDigits 0,0
094031.70 4 state [Get Acc No] Number Input 017340
094031.70 4 path {017340} not found
094031.72 4 timer set 6 EV_TIMEOUT_ENTERDATA
094031.95 4 tw dtmf 0 (4,48,48)
094031.95 4 event 0, iCode=48 state=1301
094031.97 4 LsGetNbrsRxDigits 0,0
094031.97 4 state [Get Acc No] Number Input 0173400
094031.98 4 path {0173400} not found
094032.00 4 timer set 6 EV_TIMEOUT_ENTERDATA
094032.19 4 tw dtmf 0 (4,48,48)
094032.20 4 event 0, iCode=48 state=1301
094032.20 4 LsGetNbrsRxDigits 0,0
094032.22 4 state [Get Acc No] Number Input 01734000
094032.22 4 path {01734000} not found
094032.23 4 timer set 6 EV_TIMEOUT_ENTERDATA
094032.67 4 tw dtmf 2 (4,50,50)
094032.67 4 event 2, iCode=50 state=1301
094032.69 4 LsGetNbrsRxDigits 2,2
094032.69 4 state [Get Acc No] Number Input 017340002
094032.70 4 path {017340002} not found
094032.72 4 timer set 6 EV_TIMEOUT_ENTERDATA
094032.89 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
094032.91 4 event FAX, iCode=134 state=1301
094032.92 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
094032.92 4 path {FAX} not found
094032.94 4 event TDX_CST, iCode=134 state=1301
094032.94 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
094032.95 4 path {TDX_CST} not found
094033.00 4 tw dtmf 4 (4,52,52)
094033.02 4 event 4, iCode=52 state=1301
094033.02 4 LsGetNbrsRxDigits 4,4
094033.03 4 state [Get Acc No] Number Input 0173400024
094033.05 4 path {0173400024} not found
094033.05 4 timer set 6 EV_TIMEOUT_ENTERDATA
094033.42 4 tw dtmf 5 (4,53,53)
094033.44 4 event 5, iCode=53 state=1301
094033.44 4 LsGetNbrsRxDigits 5,5
094033.45 4 state [Get Acc No] Number Input 01734000245
094033.45 4 path {01734000245} not found
094033.47 4 timer set 6 EV_TIMEOUT_ENTERDATA
094039.94 4 timer fired EV_TIMEOUT_ENTERDATA
094039.94 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
094039.95 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
094039.95 4 path {EV_TIMEOUT_ENTERDATA} not found
094039.97 4 timer clear
094039.97 4 rv add [Get Acc No]{01734000245}
094039.98 4 path {01734000245} not found
094040.00 4 next module is [Varify A/C] (idx=5)
094040.00 4 rvns add [Get Acc No_PathTaken]{success}
094040.02 4 fn RunModule start [Database Query,[Varify A/C],5,,]
094040.02 4 timer clear
094040.03 4 state [Varify A/C] DB Query
094040.05 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
094040.08 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
094040.09 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:40:04 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:40:07 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:40:07 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
  1. {1}[Get Acc No]{0173400025}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}
094040.11 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
094040.13 4 db [Varify A/C] row count=1
094040.13 4 rv add [Varify A/C_RowCount]{1}
094040.14 4 db get RecordsetGetRowsMax
094040.14 4 db get 999 records. (row count=1)
094040.16 4 db update RVs
094040.17 4 db about to close dbDbqDatabase
094040.17 4 db going down path [True]
094040.19 4 next module is [Get PIN No] (idx=44)
094040.19 4 fn RunModule start [Get Numbers,[Get PIN No],44,,]
094040.20 4 timer clear
094040.22 4 state [Get PIN No] Number Input
094040.22 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
094040.23 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
094040.25 4 tw wav->vox convert end 464312,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
094040.28 4 play start ok, lPlayId=464343
094042.11 4 tw dtmf 3 (4,51,51)
094042.13 4 event 3, iCode=51 state=1300
094042.13 4 LsGetNbrsPlayWelcMsg 3,3
094042.14 4 play PlayStop ok
094042.16 4 state [Get PIN No] Number Input 3
094042.17 4 path {3} not found
094042.17 4 timer set 6 EV_TIMEOUT_ENTERDATA
094042.19 4 tw PlayEnd 4 464343
094042.19 4 play end id=464343, (current ID)
094042.20 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
094042.22 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
094042.22 4 path {EV_PLAY_FINISHED} not found
094042.23 4 awaiting further dtmf input
094042.23 4 tw DialogicEvent 129,TDX_PLAY,464343,0,0,,,
094042.25 4 event TDX_PLAY, iCode=129 state=1301
094042.27 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
094042.27 4 path {TDX_PLAY} not found
094042.84 4 tw dtmf 8 (4,56,56)
094042.86 4 event 8, iCode=56 state=1301
094042.86 4 LsGetNbrsRxDigits 8,8
094042.88 4 state [Get PIN No] Number Input 38
094042.88 4 path {38} not found
094042.89 4 timer set 6 EV_TIMEOUT_ENTERDATA
094043.34 4 tw dtmf 0 (4,48,48)
094043.36 4 event 0, iCode=48 state=1301
094043.36 4 LsGetNbrsRxDigits 0,0
094043.38 4 state [Get PIN No] Number Input 380
094043.39 4 path {380} not found
094043.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
094043.58 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
094043.58 4 event FAX, iCode=134 state=1301
094043.59 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
094043.61 4 path {FAX} not found
094043.61 4 event TDX_CST, iCode=134 state=1301
094043.63 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
094043.63 4 path {TDX_CST} not found
094043.75 4 tw dtmf 4 (4,52,52)
094043.75 4 event 4, iCode=52 state=1301
094043.77 4 LsGetNbrsRxDigits 4,4
094043.78 4 state [Get PIN No] Number Input 3804
094043.78 4 path {3804} not found
094043.80 4 timer set 6 EV_TIMEOUT_ENTERDATA
094043.80 4 timer clear
094043.81 4 rv add [Get PIN No]{3804}
094043.83 4 path {3804} not found
094043.83 4 next module is [Varify A/C No] (idx=20)
094043.84 4 rvns add [Get PIN No_PathTaken]{success}
094043.84 4 fn RunModule start [Database Query,[Varify A/C No],20,,]
094043.86 4 timer clear
094043.88 4 state [Varify A/C No] DB Query
094043.88 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
094043.92 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
094043.92 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:40:04 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{0173400025}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}
094043.94 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
094043.95 4 db [Varify A/C No] row count=1
094043.95 4 rv add [Varify A/C No_RowCount]{1}
094043.97 4 db get RecordsetGetRowsMax
094043.97 4 db get 999 records. (row count=1)
094043.98 4 db update RVs
094044.00 4 db about to close dbDbqDatabase
094044.00 4 db going down path [True]
094044.02 4 next module is
  1. (idx=43)
094044.03 4 fn RunModule start [Play,
  1. ,43,,]
094044.03 4 timer clear
094044.05 4 Play Module start
094044.05 4 state
  1. Playing
094044.06 4 state
  1. Playing (Bangla Voice\Acc List.wav)
094044.08 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
094044.11 4 tw wav->vox convert end 468156,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
094044.14 4 play start ok, lPlayId=468203
094045.47 4 tw dtmf 1 (4,49,49)
094045.48 4 event 1, iCode=49 state=1100
094045.48 4 LsPlayMsg 1,1
094045.50 4 next module is [say Bal 1] (idx=4)
094045.52 4 play PlayStop ok
094045.53 4 rv add
  1. {1}
094045.55 4 fn RunModule start [say Numbers,[say Bal 1],4,,]
094045.56 4 tw PlayEnd 4 468203
094045.56 4 play end id=468203, (current ID)
094045.58 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
094045.58 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
094045.59 4 tw DialogicEvent 129,TDX_PLAY,468203,0,0,,,
094045.61 4 event TDX_PLAY, iCode=129 state=6001
094045.61 4 LsModuleTransition : 129, [TDX_PLAY]
094045.64 4 timer clear
094045.64 4 state [say Bal 1] Say numbers: 2000 as Number
094045.66 4 fn PlaySoundStartNumbers [],[],[2000],Number
094045.67 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
094045.69 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
094045.69 4 rv add [Hangup Time]{01/10/2007 9:40:45 AM}
094045.70 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
094045.70 4 HangupCall_Common hCall=4
094045.72 4 rec RecSoundStop ok
094045.73 4 play PlayStop ok
094045.73 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
094045.75 4 fnHangupCall end
094045.77 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
094045.77 4 event FAX, iCode=134 state=900
094045.78 4 LsAwaitingCalls EV_UNKNOWN_134
094045.78 4 event TDX_CST, iCode=134 state=900
094045.80 4 LsAwaitingCalls EV_UNKNOWN_134
094045.81 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
094045.81 4 event TDX_SETHOOK, iCode=135 state=900
094045.83 4 LsAwaitingCalls EV_UNKNOWN_135
094045.83 4 event callstate IDLE 4 1,0,0
094045.84 4 WorkingMode@Idle=
094045.86 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
094045.86 4 timer clear
094045.88 4 rec RecSoundStop ok
094045.89 4 play PlayStop ok
094045.89 4 rv add [CallEndTime]{01/10/2007 9:40:45 AM}
094045.92 4 on-hangup script:[]
094045.94 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
094045.94 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
094045.95 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
094045.97 4 init atidle reinit : start
094045.97 4 init atidle reinit iConferenceOtherLegLid=-1
094045.98 4 init atidle reinit : reset all LineState variables
094045.98 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094046.00 4 state Waiting for a call...
094048.20 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094048.20 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
094048.22 4 setting iDialoutReadyToDialout = 1
094159.66 0 btn Exit (4 lines)
094159.67 1 line state = 0
094159.69 2 line state = 0
094159.69 3 line state = 0
094159.70 4 line state = 900
094159.70 1 state Exiting...
094159.72 2 state Exiting...
094159.73 3 state Exiting...
094159.73 4 state Exiting...
094200.81 0 exit closing all channels start
094200.81 0 exit close dxxxB1C1(1)=> []
094200.83 0 exit close dxxxB1C2(2)=> []
094200.84 0 exit close dxxxB1C3(3)=> []
094200.86 0 exit close dxxxB1C4(4)=> []
094200.86 0 exit closing all channels end
094201.80 0 deleting EmailQue.mdb
094201.81 0 EmailQue.mdb was deleted
094201.81 0 ---------------------------------------------------
094201.83 0 Stopping VoiceGuide (Dialogic) start
094201.83 0 v6.0.3243
094201.84 0 Stopping VoiceGuide (Dialogic) end
094201.84 0 ---------------------------------------------------
094206.38 0 ---------------------------------------------------
094206.39 0 VoiceGuide for Dialogic
094206.41 0 v6.0.3243
094206.41 0 ---------------------------------------------------
094206.42 0 rv global loaded >>><<<
094206.44 0 cti Inband Signaling Config file not specified
094208.39 0 init ApiMode=[DialogicGC]
094208.42 0 vm loading VMB data begin
094208.44 0 vm loading VMB data - about to delete old entries
094208.45 0 vm loading VMB data - sorting/ordering
094208.47 0 vm loading VMB data end
094208.47 0 dial DbConnectString_ADO is blank
094208.52 0 init DB Workspaces
094208.55 0 init Voicemail LoadIniSettings
094208.56 0 init VmEmailBody_MainGlobalTemplate loaded from C:\Program Files\VoiceGuide\system\vm\EmailForwardTemplate_body.txt
094208.58 0 init temp dir exists [C:\Program Files\VoiceGuide\temp\]
094208.59 0 init read Config.xml start
094208.61 0 dxxxB1C1 dxxxB1C1 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1
094208.63 0 dxxxB1C2 dxxxB1C2 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1
094208.63 0 dxxxB1C3 dxxxB1C3 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1
094208.64 0 dxxxB1C4 dxxxB1C4 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1
094208.64 0 init read Config.xml end
094208.66 0 init LineOpenDialogic dxxxB1C1 => [1]
094208.67 1 iIvrDev=1
094208.72 0 init distinct ring definitions found:0
094208.72 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig)
094208.73 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
094208.75 MemStructVgs_ClearVgs [1]
094208.75 load end
094208.77 1 state Waiting for a call...
094208.78 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
094208.78 1 event TDX_SETHOOK, iCode=135 state=0
094208.80 1 event callstate IDLE 1 1,0,0
094208.80 1 WorkingMode@Idle=
094208.81 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
094208.83 1 timer clear
094208.83 1 LineState(iLineId).iVgsIdx = 0
094208.84 1 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
094208.84 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094208.86 1 timer set ignored - waiting for line re-init to occur first
094208.88 0 init LineOpenDialogic dxxxB1C2 => [2]
094208.88 2 iIvrDev=2
094208.92 0 init distinct ring definitions found:0
094208.94 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig)
094208.94 2 state Waiting for a call...
094208.95 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
094208.97 2 event TDX_SETHOOK, iCode=135 state=0
094208.97 2 event callstate IDLE 2 1,0,0
094208.98 2 WorkingMode@Idle=
094208.98 2 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
094209.00 2 timer clear
094209.00 2 LineState(iLineId).iVgsIdx = 0
094209.02 2 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
094209.03 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
094209.03 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0
094209.05 1 init atidle reinit : start
094209.06 1 init atidle reinit iConferenceOtherLegLid=-1
094209.06 1 init atidle reinit : reset all LineState variables
094209.08 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094209.08 1 state Waiting for a call...
094209.09 2 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094209.11 2 timer set ignored - waiting for line re-init to occur first
094209.13 0 init LineOpenDialogic dxxxB1C3 => [3]
094209.13 3 iIvrDev=3
094209.17 0 init distinct ring definitions found:0
094209.19 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig)
094209.19 3 state Waiting for a call...
094209.20 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
094209.20 3 event TDX_SETHOOK, iCode=135 state=0
094209.22 3 event callstate IDLE 3 1,0,0
094209.23 3 WorkingMode@Idle=
094209.23 3 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
094209.25 3 timer clear
094209.25 3 LineState(iLineId).iVgsIdx = 0
094209.27 3 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
094209.28 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
094209.28 2 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0
094209.30 2 init atidle reinit : start
094209.30 2 init atidle reinit iConferenceOtherLegLid=-1
094209.31 2 init atidle reinit : reset all LineState variables
094209.33 2 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094209.33 2 state Waiting for a call...
094209.34 3 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094209.34 3 timer set ignored - waiting for line re-init to occur first
094209.36 0 init LineOpenDialogic dxxxB1C4 => [4]
094209.38 4 iIvrDev=4
094209.41 0 init distinct ring definitions found:0
094209.42 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig)
094209.44 4 state Waiting for a call...
094209.44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
094209.45 4 event TDX_SETHOOK, iCode=135 state=0
094209.47 4 event callstate IDLE 4 1,0,0
094209.47 4 WorkingMode@Idle=
094209.48 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
094209.48 4 timer clear
094209.50 4 LineState(iLineId).iVgsIdx = 0
094209.52 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
094209.52 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
094209.53 3 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0
094209.53 3 init atidle reinit : start
094209.55 3 init atidle reinit iConferenceOtherLegLid=-1
094209.56 3 init atidle reinit : reset all LineState variables
094209.56 3 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094209.58 3 state Waiting for a call...
094209.58 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094209.59 4 timer set ignored - waiting for line re-init to occur first
094209.61 0 init lineids in use: 0-4
094209.61 0 init route channels start
094209.66 0 init route channels => []
094209.67 0 init no dti channels opened. Not opening signaling channel.
094209.69 0 cti //devicesCTI/ctiLink config.xml section not used in this version
094209.69 0 init read Config.xml //devicesSysManagers/StatusLink start
094209.70 0 tcpsl config.xml does not have //devicesSysManagers/StatusLink section (status link wil use the default port of 14710)
094209.72 0 tcpsl open //devicesSysManagers/StatusLink to listen on port 14710
094209.72 0 init read Config.xml //devicesSysManagers/StatusLink end
094209.73 0 init iLineDevicesControlled=4
094209.75 0 init main form load end
094209.75 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
094209.77 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0
094209.77 4 init atidle reinit : start
094209.78 4 init atidle reinit iConferenceOtherLegLid=-1
094209.80 4 init atidle reinit : reset all LineState variables
094209.80 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094209.81 4 state Waiting for a call...
094211.67 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094211.67 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0
094211.69 1 setting iDialoutReadyToDialout = 1
094211.80 2 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094211.80 2 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0
094211.81 2 setting iDialoutReadyToDialout = 1
094211.92 3 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094211.92 3 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0
094211.94 3 setting iDialoutReadyToDialout = 1
094212.05 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
094212.05 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0
094212.06 4 setting iDialoutReadyToDialout = 1
094304.03 0 sys cleanup Start
094304.03 0 sys cleanup End
095132.84 4 event callstate OFFERING 4 2,0,0
095132.86 4 script interpretor: VgMulti v6.0.3243
095132.86 4 fired OFFERING event to listeners
095132.88 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
095132.89 4 cid CallerID vars set (in 'offering' event) [,,]
095132.89 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
095132.91 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
095132.91 4 tw ring 1
095132.92 4 ring time since last ring event (sec): 0.00
095132.94 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
095132.94 4 should answer as number of rings reached
095132.95 4 rv clear all
095132.95 4 init LineState ResetAtStartOfNewCall.
095132.97 4 answering the call (,,,0)
095132.98 4 timer clear
095133.00 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
095133.00 4 event TDX_CST, iCode=134 state=6001
095133.02 4 LsModuleTransition : 134, [TDX_CST]
095133.63 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
095133.63 4 event TDX_SETHOOK, iCode=135 state=6001
095133.64 4 LsModuleTransition : 135, [TDX_SETHOOK]
095133.66 4 event callstate CONNECTED 4 256,0,0
095133.66 4 LineEvCallState_Connected hDevice=4 params=256,0,0
095133.67 4 WorkingModes tapi= script= LineState().iState=6001
095133.69 4 Inband detection not enabled
095133.70 4 StartLoadedVgs at 01/10/2007 9:51:33 AM (VgMulti v6.0.3243)
095133.70 4 set LineState().iVgsIdx=1
095133.72 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
095133.72 4 init StartLoadedVgs_InitLineState start
095133.73 4 rv add [$RV_STARTTIME]{01/10/2007 9:51:33 AM}
095133.75 4 rv add [$RV_DEVICEID]{4}
095133.75 4 rv add [DlgcNetworkResource]{dxxxB1C4}
095133.77 4 rv add [DlgcVoiceResource]{dxxxB1C4}
095133.78 4 rv add [$RV_CIDNAME]{}
095133.78 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
095133.80 4 rvns add [scriptsPath]{G:\TeleBanking System\}
095133.80 4 rv add [$RV_CIDNUMBER]{}
095133.81 4 fn RunModule start [Play,[Get Language],1,,]
095133.83 4 tw DialogicEvent 134,TDX_CST,64781,0,0,DE_LCON,,
095133.83 4 event TDX_CST, iCode=134 state=6001
095133.84 4 LsModuleTransition : 134, [TDX_CST]
095133.86 4 timer clear
095133.86 4 Play Module start
095133.88 4 state [Get Language] Playing
095133.88 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
095133.89 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
095133.91 4 tw wav->vox convert end 117968,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
095133.94 4 play start ok, lPlayId=118000
095135.41 4 tw dtmf 1 (4,49,49)
095135.42 4 event 1, iCode=49 state=1100
095135.42 4 LsPlayMsg 1,1
095135.44 4 rv add [scriptEnd_Time]{01/10/2007 9:51:35 AM}
095135.44 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
095135.45 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
095135.48 4 rv add [scriptStart_Time]{01/10/2007 9:51:35 AM}
095135.50 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
095135.50 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
095135.52 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095135.53 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095135.53 MemStructVgs_ClearVgs [2]
095135.61 load end
095135.63 4 loaded [G:\TeleBanking System\Tele Banking_Ban.vgs] into:2
095135.64 4 rvns add [scriptsPath]{G:\TeleBanking System\}
095135.66 4 play PlayStop ok
095135.67 4 rv add [Get Language]{1}
095135.67 4 fn RunModule start [Evaluate,[Get Bangla],25,,]
095135.69 4 tw PlayEnd 4 118000
095135.70 4 play end id=118000, (current ID)
095135.70 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
095135.72 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
095135.72 4 tw DialogicEvent 129,TDX_PLAY,118000,0,0,,,
095135.73 4 event TDX_PLAY, iCode=129 state=6001
095135.75 4 LsModuleTransition : 129, [TDX_PLAY]
095135.75 4 timer clear
095135.77 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
095135.80 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
095135.81 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
095135.81 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
095135.83 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
095135.83 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
095135.84 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
095135.86 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
095135.86 4 matching path not found
095135.88 4 next module is
  1. (idx=26)
095135.89 4 matching path was found
095135.89 4 fn RunModule start [Play,
  1. ,26,,]
095135.91 4 timer clear
095135.91 4 Play Module start
095135.92 4 state
  1. Playing
095135.94 4 state
095135.94 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
095136.00 4 tw wav->vox convert end 120015,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
095136.02 4 play start ok, lPlayId=120078
095136.75 4 tw dtmf 1 (4,49,49)
095136.77 4 event 1, iCode=49 state=1100
095136.77 4 LsPlayMsg 1,1
095136.78 4 next module is [Get Acc No] (idx=4)
095136.80 4 play PlayStop ok
095136.81 4 rv add
  1. {1}
095136.81 4 fn RunModule start [Get Numbers,[Get Acc No],4,,]
095136.83 4 tw PlayEnd 4 120078
095136.83 4 play end id=120078, (current ID)
095136.84 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
095136.86 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
095136.86 4 tw DialogicEvent 129,TDX_PLAY,120078,0,0,,,
095136.88 4 event TDX_PLAY, iCode=129 state=6001
095136.89 4 LsModuleTransition : 129, [TDX_PLAY]
095136.89 4 timer clear
095136.91 4 state [Get Acc No] Number Input
095136.91 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
095136.92 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
095136.95 4 tw wav->vox convert end 121000,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
095136.98 4 play start ok, lPlayId=121046
095140.80 4 tw PlayEnd 4 121046
095140.81 4 play end id=121046, (current ID)
095140.83 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
095140.83 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
095140.84 4 path {EV_PLAY_FINISHED} not found
095140.86 4 timer set 17 EV_TIMEOUT_REPLAYMSG
095140.86 4 tw DialogicEvent 129,TDX_PLAY,121046,0,0,,,
095140.88 4 event TDX_PLAY, iCode=129 state=1301
095140.88 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
095140.89 4 path {TDX_PLAY} not found
095141.16 4 tw dtmf 0 (4,48,48)
095141.17 4 event 0, iCode=48 state=1301
095141.19 4 LsGetNbrsRxDigits 0,0
095141.19 4 state [Get Acc No] Number Input 0
095141.20 4 path {0} not found
095141.22 4 timer set 6 EV_TIMEOUT_ENTERDATA
095141.48 4 tw dtmf 1 (4,49,49)
095141.50 4 event 1, iCode=49 state=1301
095141.50 4 LsGetNbrsRxDigits 1,1
095141.52 4 state [Get Acc No] Number Input 01
095141.53 4 path {01} not found
095141.53 4 timer set 6 EV_TIMEOUT_ENTERDATA
095141.84 4 tw dtmf 7 (4,55,55)
095141.84 4 event 7, iCode=55 state=1301
095141.86 4 LsGetNbrsRxDigits 7,7
095141.86 4 state [Get Acc No] Number Input 017
095141.88 4 path {017} not found
095141.89 4 timer set 6 EV_TIMEOUT_ENTERDATA
095142.30 4 tw dtmf 3 (4,51,51)
095142.31 4 event 3, iCode=51 state=1301
095142.33 4 LsGetNbrsRxDigits 3,3
095142.33 4 state [Get Acc No] Number Input 0173
095142.34 4 path {0173} not found
095142.36 4 timer set 6 EV_TIMEOUT_ENTERDATA
095142.67 4 tw dtmf 4 (4,52,52)
095142.69 4 event 4, iCode=52 state=1301
095142.69 4 LsGetNbrsRxDigits 4,4
095142.70 4 state [Get Acc No] Number Input 01734
095142.72 4 path {01734} not found
095142.72 4 timer set 6 EV_TIMEOUT_ENTERDATA
095143.28 4 tw dtmf 0 (4,48,48)
095143.30 4 event 0, iCode=48 state=1301
095143.31 4 LsGetNbrsRxDigits 0,0
095143.31 4 state [Get Acc No] Number Input 017340
095143.33 4 path {017340} not found
095143.34 4 timer set 6 EV_TIMEOUT_ENTERDATA
095143.48 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
095143.50 4 event FAX, iCode=134 state=1301
095143.52 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
095143.52 4 path {FAX} not found
095143.53 4 event TDX_CST, iCode=134 state=1301
095143.55 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
095143.55 4 path {TDX_CST} not found
095143.56 4 tw dtmf 0 (4,48,48)
095143.56 4 event 0, iCode=48 state=1301
095143.58 4 LsGetNbrsRxDigits 0,0
095143.59 4 state [Get Acc No] Number Input 0173400
095143.59 4 path {0173400} not found
095143.61 4 timer set 6 EV_TIMEOUT_ENTERDATA
095143.75 4 tw dtmf 0 (4,48,48)
095143.75 4 event 0, iCode=48 state=1301
095143.77 4 LsGetNbrsRxDigits 0,0
095143.78 4 state [Get Acc No] Number Input 01734000
095143.78 4 path {01734000} not found
095143.80 4 timer set 6 EV_TIMEOUT_ENTERDATA
095144.20 4 tw dtmf 2 (4,50,50)
095144.20 4 event 2, iCode=50 state=1301
095144.22 4 LsGetNbrsRxDigits 2,2
095144.23 4 state [Get Acc No] Number Input 017340002
095144.23 4 path {017340002} not found
095144.25 4 timer set 6 EV_TIMEOUT_ENTERDATA
095144.52 4 tw dtmf 4 (4,52,52)
095144.52 4 event 4, iCode=52 state=1301
095144.53 4 LsGetNbrsRxDigits 4,4
095144.55 4 state [Get Acc No] Number Input 0173400024
095144.55 4 path {0173400024} not found
095144.56 4 timer set 6 EV_TIMEOUT_ENTERDATA
095144.83 4 tw dtmf 5 (4,53,53)
095144.84 4 event 5, iCode=53 state=1301
095144.86 4 LsGetNbrsRxDigits 5,5
095144.86 4 state [Get Acc No] Number Input 01734000245
095144.88 4 path {01734000245} not found
095144.89 4 timer set 6 EV_TIMEOUT_ENTERDATA
095151.39 4 timer fired EV_TIMEOUT_ENTERDATA
095151.39 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
095151.41 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
095151.41 4 path {EV_TIMEOUT_ENTERDATA} not found
095151.42 4 timer clear
095151.44 4 rv add [Get Acc No]{01734000245}
095151.44 4 path {01734000245} not found
095151.45 4 next module is [Varify A/C] (idx=44)
095151.45 4 rvns add [Get Acc No_PathTaken]{success}
095151.47 4 fn RunModule start [Database Query,[Varify A/C],44,,]
095151.48 4 timer clear
095151.48 4 state [Varify A/C] DB Query
095151.50 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
095151.86 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
095151.86 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:51:33 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:51:35 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:51:35 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
095151.88 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
095151.89 4 db [Varify A/C] row count=1
095151.89 4 rv add [Varify A/C_RowCount]{1}
095151.91 4 db get RecordsetGetRowsMax
095151.92 4 db get 999 records. (row count=1)
095151.92 4 db update RVs
095151.94 4 db about to close dbDbqDatabase
095151.94 4 db going down path [True]
095151.95 4 next module is [Get PIN No] (idx=5)
095151.97 4 fn RunModule start [Get Numbers,[Get PIN No],5,,]
095151.97 4 timer clear
095151.98 4 state [Get PIN No] Number Input
095152.00 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
095152.00 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
095152.05 4 tw wav->vox convert end 136078,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
095152.06 4 play start ok, lPlayId=136125
095155.39 4 tw PlayEnd 4 136125
095155.39 4 play end id=136125, (current ID)
095155.41 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
095155.41 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
095155.42 4 path {EV_PLAY_FINISHED} not found
095155.44 4 timer set 7 EV_TIMEOUT_REPLAYMSG
095155.44 4 tw DialogicEvent 129,TDX_PLAY,136125,0,0,,,
095155.45 4 event TDX_PLAY, iCode=129 state=1301
095155.45 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
095155.47 4 path {TDX_PLAY} not found
095156.00 4 tw dtmf 3 (4,51,51)
095156.00 4 event 3, iCode=51 state=1301
095156.02 4 LsGetNbrsRxDigits 3,3
095156.03 4 state [Get PIN No] Number Input 3
095156.03 4 path {3} not found
095156.05 4 timer set 6 EV_TIMEOUT_ENTERDATA
095156.61 4 tw dtmf 8 (4,56,56)
095156.61 4 event 8, iCode=56 state=1301
095156.63 4 LsGetNbrsRxDigits 8,8
095156.64 4 state [Get PIN No] Number Input 38
095156.64 4 path {38} not found
095156.66 4 timer set 6 EV_TIMEOUT_ENTERDATA
095157.33 4 tw dtmf 0 (4,48,48)
095157.34 4 event 0, iCode=48 state=1301
095157.34 4 LsGetNbrsRxDigits 0,0
095157.36 4 state [Get PIN No] Number Input 380
095157.36 4 path {380} not found
095157.38 4 timer set 6 EV_TIMEOUT_ENTERDATA
095158.09 4 tw dtmf 4 (4,52,52)
095158.11 4 event 4, iCode=52 state=1301
095158.11 4 LsGetNbrsRxDigits 4,4
095158.13 4 state [Get PIN No] Number Input 3804
095158.14 4 path {3804} not found
095158.14 4 timer set 6 EV_TIMEOUT_ENTERDATA
095158.16 4 timer clear
095158.16 4 rv add [Get PIN No]{3804}
095158.17 4 path {3804} not found
095158.19 4 next module is [Varify A/C No] (idx=29)
095158.19 4 rvns add [Get PIN No_PathTaken]{success}
095158.20 4 fn RunModule start [Database Query,[Varify A/C No],29,,]
095158.22 4 timer clear
095158.23 4 state [Varify A/C No] DB Query
095158.23 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
095158.28 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
095158.28 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:51:33 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
095158.30 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
095158.31 4 db [Varify A/C No] row count=1
095158.31 4 rv add [Varify A/C No_RowCount]{1}
095158.33 4 db get RecordsetGetRowsMax
095158.33 4 db get 999 records. (row count=1)
095158.34 4 db update RVs
095158.36 4 db about to close dbDbqDatabase
095158.36 4 db going down path [True]
095158.38 4 next module is
  1. (idx=6)
095158.39 4 fn RunModule start [Play,
  1. ,6,,]
095158.39 4 timer clear
095158.41 4 Play Module start
095158.41 4 state
  1. Playing
095158.42 4 state
095158.44 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
095158.48 4 tw wav->vox convert end 142515,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
095158.52 4 play start ok, lPlayId=142578
095200.70 4 tw dtmf 1 (4,49,49)
095200.70 4 event 1, iCode=49 state=1100
095200.72 4 LsPlayMsg 1,1
095200.73 4 next module is [say Bal 1] (idx=45)
095200.75 4 play PlayStop ok
095200.75 4 rv add
  1. {1}
095200.77 4 fn RunModule start [say Numbers,[say Bal 1],45,,]
095200.78 4 tw PlayEnd 4 142578
095200.78 4 play end id=142578, (current ID)
095200.80 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
095200.80 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
095200.81 4 tw DialogicEvent 129,TDX_PLAY,142578,0,0,,,
095200.83 4 event TDX_PLAY, iCode=129 state=6001
095200.83 4 LsModuleTransition : 129, [TDX_PLAY]
095200.84 4 timer clear
095200.86 4 state [say Bal 1] Say numbers: 100 as Number
095200.86 4 fn PlaySoundStartNumbers [C:\Program Files\VoiceGuide\system\Bangla Voice\Acc Bal.wav],[],[100],Number
095200.88 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
095200.88 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
095200.89 4 rv add [Hangup Time]{01/10/2007 9:52:00 AM}
095200.91 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
095200.91 4 HangupCall_Common hCall=4
095200.92 4 rec RecSoundStop ok
095200.94 4 play PlayStop ok
095200.94 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
095200.95 4 fnHangupCall end
095201.00 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
095201.00 4 event TDX_SETHOOK, iCode=135 state=900
095201.02 4 LsAwaitingCalls EV_UNKNOWN_135
095201.02 4 event callstate IDLE 4 1,0,0
095201.03 4 WorkingMode@Idle=
095201.05 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
095201.05 4 timer clear
095201.06 4 rec RecSoundStop ok
095201.08 4 play PlayStop ok
095201.08 4 rv add [CallEndTime]{01/10/2007 9:52:01 AM}
095201.11 4 on-hangup script:[]
095201.13 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
095201.13 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
095201.14 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
095201.14 4 init atidle reinit : start
095201.16 4 init atidle reinit iConferenceOtherLegLid=-1
095201.17 4 init atidle reinit : reset all LineState variables
095201.17 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
095201.19 4 state Waiting for a call...
095203.38 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
095203.38 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
095203.39 4 setting iDialoutReadyToDialout = 1
095234.27 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095234.27 MemStructVgs_ClearVgs [3]
095234.34 load end
095234.36 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
095234.38 0 Erasing Script (new loaded) Id 2
095234.38 0 VgsScriptFree [2]
095234.39 MemStructVgs_ClearVgs [2]
095237.41 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095237.41 MemStructVgs_ClearVgs [2]
095237.48 load end
095237.48 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
095237.50 0 Erasing Script (new loaded) Id 3
095237.52 0 VgsScriptFree [3]
095237.52 MemStructVgs_ClearVgs [3]
095320.55 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095320.55 MemStructVgs_ClearVgs [3]
095320.63 load end
095320.64 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
095320.64 0 Erasing Script (new loaded) Id 2
095320.66 0 VgsScriptFree [2]
095320.66 MemStructVgs_ClearVgs [2]
095335.69 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095335.69 MemStructVgs_ClearVgs [2]
095335.77 load end
095335.77 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
095335.78 0 Erasing Script (new loaded) Id 3
095335.80 0 VgsScriptFree [3]
095335.80 MemStructVgs_ClearVgs [3]
095423.81 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095423.81 MemStructVgs_ClearVgs [3]
095423.89 load end
095423.91 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
095423.91 0 Erasing Script (new loaded) Id 2
095423.92 0 VgsScriptFree [2]
095423.94 MemStructVgs_ClearVgs [2]
095555.23 0 vm loading VMB data begin
095555.23 0 vm loading VMB data - about to delete old entries
095555.25 0 vm loading VMB data - sorting/ordering
095555.27 0 vm loading VMB data end
095555.27 0 Loaded new voicemail configuration file (XML)
095708.33 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095708.33 MemStructVgs_ClearVgs [2]
095708.41 load end
095708.42 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
095708.44 0 Erasing Script (new loaded) Id 3
095708.44 0 VgsScriptFree [3]
095708.45 MemStructVgs_ClearVgs [3]
095725.45 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095725.45 MemStructVgs_ClearVgs [3]
095725.53 load end
095725.55 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
095725.56 0 Erasing Script (new loaded) Id 2
095725.56 0 VgsScriptFree [2]
095725.58 MemStructVgs_ClearVgs [2]
095809.61 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095809.61 MemStructVgs_ClearVgs [2]
095809.69 load end
095809.70 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
095809.70 0 Erasing Script (new loaded) Id 3
095809.72 0 VgsScriptFree [3]
095809.73 MemStructVgs_ClearVgs [3]
095825.73 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095825.73 MemStructVgs_ClearVgs [3]
095825.81 load end
095825.83 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
095825.84 0 Erasing Script (new loaded) Id 2
095825.84 0 VgsScriptFree [2]
095825.86 MemStructVgs_ClearVgs [2]
095838.86 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095838.86 MemStructVgs_ClearVgs [2]
095838.94 load end
095838.95 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
095838.95 0 Erasing Script (new loaded) Id 3
095838.97 0 VgsScriptFree [3]
095838.97 MemStructVgs_ClearVgs [3]
095856.98 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095856.98 MemStructVgs_ClearVgs [3]
095857.06 load end
095857.08 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
095857.09 0 Erasing Script (new loaded) Id 2
095857.09 0 VgsScriptFree [2]
095857.11 MemStructVgs_ClearVgs [2]
095905.13 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095905.13 MemStructVgs_ClearVgs [2]
095905.20 load end
095905.22 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
095905.23 0 Erasing Script (new loaded) Id 3
095905.23 0 VgsScriptFree [3]
095905.25 MemStructVgs_ClearVgs [3]
095910.25 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095910.25 MemStructVgs_ClearVgs [3]
095910.33 load end
095910.34 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
095910.36 0 Erasing Script (new loaded) Id 2
095910.36 0 VgsScriptFree [2]
095910.38 MemStructVgs_ClearVgs [2]
095914.38 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095914.38 MemStructVgs_ClearVgs [2]
095914.45 load end
095914.47 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs
095914.48 0 Erasing Script (new loaded) Id 3
095914.48 0 VgsScriptFree [3]
095914.50 MemStructVgs_ClearVgs [3]
095940.97 4 event callstate OFFERING 4 2,0,0
095940.98 4 script interpretor: VgMulti v6.0.3243
095941.00 4 fired OFFERING event to listeners
095941.00 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
095941.02 4 cid CallerID vars set (in 'offering' event) [,,]
095941.02 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
095941.03 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
095941.05 4 tw ring 1
095941.05 4 ring time since last ring event (sec): 0.00
095941.06 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
095941.06 4 should answer as number of rings reached
095941.08 4 rv clear all
095941.09 4 init LineState ResetAtStartOfNewCall.
095941.09 4 answering the call (,,,0)
095941.11 4 timer clear
095941.13 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
095941.13 4 event TDX_CST, iCode=134 state=6001
095941.14 4 LsModuleTransition : 134, [TDX_CST]
095941.75 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
095941.77 4 event TDX_SETHOOK, iCode=135 state=6001
095941.77 4 LsModuleTransition : 135, [TDX_SETHOOK]
095941.78 4 event callstate CONNECTED 4 256,0,0
095941.78 4 LineEvCallState_Connected hDevice=4 params=256,0,0
095941.80 4 WorkingModes tapi= script= LineState().iState=6001
095941.81 4 Inband detection not enabled
095941.81 4 StartLoadedVgs at 01/10/2007 9:59:41 AM (VgMulti v6.0.3243)
095941.83 4 set LineState().iVgsIdx=1
095941.84 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
095941.84 4 init StartLoadedVgs_InitLineState start
095941.86 4 rv add [$RV_STARTTIME]{01/10/2007 9:59:41 AM}
095941.86 4 rv add [$RV_DEVICEID]{4}
095941.88 4 rv add [DlgcNetworkResource]{dxxxB1C4}
095941.89 4 rv add [DlgcVoiceResource]{dxxxB1C4}
095941.89 4 rv add [$RV_CIDNAME]{}
095941.91 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
095941.92 4 rvns add [scriptsPath]{G:\TeleBanking System\}
095941.92 4 rv add [$RV_CIDNUMBER]{}
095941.94 4 fn RunModule start [Play,[Get Language],1,,]
095941.94 4 tw DialogicEvent 134,TDX_CST,46075,0,0,DE_LCON,,
095941.95 4 event TDX_CST, iCode=134 state=6001
095941.97 4 LsModuleTransition : 134, [TDX_CST]
095941.97 4 timer clear
095941.98 4 Play Module start
095941.98 4 state [Get Language] Playing
095942.00 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
095942.02 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
095942.03 4 tw wav->vox convert end 606093,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
095942.06 4 play start ok, lPlayId=606125
095942.78 4 tw dtmf 1 (4,49,49)
095942.78 4 event 1, iCode=49 state=1100
095942.80 4 LsPlayMsg 1,1
095942.80 4 rv add [scriptEnd_Time]{01/10/2007 9:59:42 AM}
095942.81 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
095942.83 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
095942.86 4 rv add [scriptStart_Time]{01/10/2007 9:59:42 AM}
095942.86 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
095942.88 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
095942.88 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
095942.89 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=2
095942.91 4 rvns add [scriptsPath]{G:\TeleBanking System\}
095942.92 4 play PlayStop ok
095942.92 4 rv add [Get Language]{1}
095942.94 4 fn RunModule start [Evaluate,[Get Bangla],25,,]
095942.95 4 tw PlayEnd 4 606125
095942.95 4 play end id=606125, (current ID)
095942.97 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
095942.97 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
095942.98 4 tw DialogicEvent 129,TDX_PLAY,606125,0,0,,,
095943.00 4 event TDX_PLAY, iCode=129 state=6001
095943.00 4 LsModuleTransition : 129, [TDX_PLAY]
095943.02 4 timer clear
095943.02 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
095943.03 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
095943.05 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
095943.05 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
095943.06 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
095943.06 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
095943.08 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
095943.09 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
095943.09 4 matching path not found
095943.11 4 next module is
  1. (idx=24)
095943.11 4 matching path was found
095943.13 4 fn RunModule start [Play,
  1. ,24,,]
095943.14 4 timer clear
095943.14 4 Play Module start
095943.16 4 state
  1. Playing
095943.16 4 state
095943.17 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
095943.20 4 tw wav->vox convert end 607250,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
095943.22 4 play start ok, lPlayId=607296
095944.83 4 tw dtmf 1 (4,49,49)
095944.84 4 event 1, iCode=49 state=1100
095944.84 4 LsPlayMsg 1,1
095944.86 4 next module is [Get Acc No] (idx=87)
095944.88 4 play PlayStop ok
095944.89 4 rv add
  1. {1}
095944.89 4 fn RunModule start [Get Numbers,[Get Acc No],87,,]
095944.91 4 tw PlayEnd 4 607296
095944.92 4 play end id=607296, (current ID)
095944.92 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
095944.94 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
095944.94 4 tw DialogicEvent 129,TDX_PLAY,607296,0,0,,,
095944.95 4 event TDX_PLAY, iCode=129 state=6001
095944.97 4 LsModuleTransition : 129, [TDX_PLAY]
095944.97 4 timer clear
095944.98 4 state [Get Acc No] Number Input
095944.98 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
095945.00 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
095945.03 4 tw wav->vox convert end 609078,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
095945.06 4 play start ok, lPlayId=609125
095947.44 4 tw dtmf 0 (4,48,48)
095947.45 4 event 0, iCode=48 state=1300
095947.47 4 LsGetNbrsPlayWelcMsg 0,0
095947.48 4 play PlayStop ok
095947.48 4 state [Get Acc No] Number Input 0
095947.50 4 path {0} not found
095947.52 4 timer set 6 EV_TIMEOUT_ENTERDATA
095947.52 4 tw PlayEnd 4 609125
095947.53 4 play end id=609125, (current ID)
095947.53 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
095947.55 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
095947.56 4 path {EV_PLAY_FINISHED} not found
095947.56 4 awaiting further dtmf input
095947.58 4 tw DialogicEvent 129,TDX_PLAY,609125,0,0,,,
095947.58 4 event TDX_PLAY, iCode=129 state=1301
095947.59 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
095947.61 4 path {TDX_PLAY} not found
095947.64 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
095947.64 4 event FAX, iCode=134 state=1301
095947.66 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
095947.66 4 path {FAX} not found
095947.67 4 event TDX_CST, iCode=134 state=1301
095947.69 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
095947.69 4 path {TDX_CST} not found
095948.02 4 tw dtmf 1 (4,49,49)
095948.03 4 event 1, iCode=49 state=1301
095948.03 4 LsGetNbrsRxDigits 1,1
095948.05 4 state [Get Acc No] Number Input 01
095948.06 4 path {01} not found
095948.06 4 timer set 6 EV_TIMEOUT_ENTERDATA
095948.52 4 tw dtmf 7 (4,55,55)
095948.53 4 event 7, iCode=55 state=1301
095948.55 4 LsGetNbrsRxDigits 7,7
095948.55 4 state [Get Acc No] Number Input 017
095948.56 4 path {017} not found
095948.56 4 timer set 6 EV_TIMEOUT_ENTERDATA
095949.05 4 tw dtmf 3 (4,51,51)
095949.06 4 event 3, iCode=51 state=1301
095949.06 4 LsGetNbrsRxDigits 3,3
095949.08 4 state [Get Acc No] Number Input 0173
095949.09 4 path {0173} not found
095949.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
095949.58 4 tw dtmf 4 (4,52,52)
095949.59 4 event 4, iCode=52 state=1301
095949.59 4 LsGetNbrsRxDigits 4,4
095949.61 4 state [Get Acc No] Number Input 01734
095949.61 4 path {01734} not found
095949.63 4 timer set 6 EV_TIMEOUT_ENTERDATA
095950.09 4 tw dtmf 0 (4,48,48)
095950.11 4 event 0, iCode=48 state=1301
095950.11 4 LsGetNbrsRxDigits 0,0
095950.13 4 state [Get Acc No] Number Input 017340
095950.13 4 path {017340} not found
095950.14 4 timer set 6 EV_TIMEOUT_ENTERDATA
095950.42 4 tw dtmf 0 (4,48,48)
095950.42 4 event 0, iCode=48 state=1301
095950.44 4 LsGetNbrsRxDigits 0,0
095950.45 4 state [Get Acc No] Number Input 0173400
095950.45 4 path {0173400} not found
095950.47 4 timer set 6 EV_TIMEOUT_ENTERDATA
095950.75 4 tw dtmf 0 (4,48,48)
095950.75 4 event 0, iCode=48 state=1301
095950.77 4 LsGetNbrsRxDigits 0,0
095950.77 4 state [Get Acc No] Number Input 01734000
095950.78 4 path {01734000} not found
095950.80 4 timer set 6 EV_TIMEOUT_ENTERDATA
095951.25 4 tw dtmf 2 (4,50,50)
095951.25 4 event 2, iCode=50 state=1301
095951.27 4 LsGetNbrsRxDigits 2,2
095951.28 4 state [Get Acc No] Number Input 017340002
095951.28 4 path {017340002} not found
095951.30 4 timer set 6 EV_TIMEOUT_ENTERDATA
095951.63 4 tw dtmf 4 (4,52,52)
095951.64 4 event 4, iCode=52 state=1301
095951.66 4 LsGetNbrsRxDigits 4,4
095951.66 4 state [Get Acc No] Number Input 0173400024
095951.67 4 path {0173400024} not found
095951.67 4 timer set 6 EV_TIMEOUT_ENTERDATA
095951.95 4 tw dtmf 5 (4,53,53)
095951.97 4 event 5, iCode=53 state=1301
095951.97 4 LsGetNbrsRxDigits 5,5
095951.98 4 state [Get Acc No] Number Input 01734000245
095952.00 4 path {01734000245} not found
095952.00 4 timer set 6 EV_TIMEOUT_ENTERDATA
095958.47 4 timer fired EV_TIMEOUT_ENTERDATA
095958.47 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
095958.48 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
095958.50 4 path {EV_TIMEOUT_ENTERDATA} not found
095958.50 4 timer clear
095958.52 4 rv add [Get Acc No]{01734000245}
095958.52 4 path {01734000245} not found
095958.53 4 next module is [Varify A/C] (idx=6)
095958.55 4 rvns add [Get Acc No_PathTaken]{success}
095958.55 4 fn RunModule start [Database Query,[Varify A/C],6,,]
095958.56 4 timer clear
095958.56 4 state [Varify A/C] DB Query
095958.58 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
095958.63 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
095958.63 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:59:41 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:59:42 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:59:42 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
  1. {1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}
095958.64 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
095958.66 4 db [Varify A/C] row count=1
095958.66 4 rv add [Varify A/C_RowCount]{1}
095958.67 4 db get RecordsetGetRowsMax
095958.69 4 db get 999 records. (row count=1)
095958.69 4 db update RVs
095958.70 4 db about to close dbDbqDatabase
095958.70 4 db going down path [True]
095958.72 4 next module is [Get PIN No] (idx=45)
095958.73 4 fn RunModule start [Get Numbers,[Get PIN No],45,,]
095958.75 4 timer clear
095958.77 4 state [Get PIN No] Number Input
095958.77 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
095958.78 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
095958.80 4 tw wav->vox convert end 622859,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
095958.81 4 play start ok, lPlayId=622890
100002.14 4 tw PlayEnd 4 622890
100002.16 4 play end id=622890, (current ID)
100002.16 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
100002.17 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100002.19 4 path {EV_PLAY_FINISHED} not found
100002.19 4 timer set 7 EV_TIMEOUT_REPLAYMSG
100002.20 4 tw DialogicEvent 129,TDX_PLAY,622890,0,0,,,
100002.20 4 event TDX_PLAY, iCode=129 state=1301
100002.22 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
100002.23 4 path {TDX_PLAY} not found
100002.23 4 tw dtmf 3 (4,51,51)
100002.25 4 event 3, iCode=51 state=1301
100002.25 4 LsGetNbrsRxDigits 3,3
100002.27 4 state [Get PIN No] Number Input 3
100002.28 4 path {3} not found
100002.28 4 timer set 6 EV_TIMEOUT_ENTERDATA
100002.92 4 tw dtmf 8 (4,56,56)
100002.94 4 event 8, iCode=56 state=1301
100002.94 4 LsGetNbrsRxDigits 8,8
100002.95 4 state [Get PIN No] Number Input 38
100002.95 4 path {38} not found
100002.97 4 timer set 6 EV_TIMEOUT_ENTERDATA
100003.30 4 tw dtmf 0 (4,48,48)
100003.30 4 event 0, iCode=48 state=1301
100003.31 4 LsGetNbrsRxDigits 0,0
100003.33 4 state [Get PIN No] Number Input 380
100003.33 4 path {380} not found
100003.34 4 timer set 6 EV_TIMEOUT_ENTERDATA
100003.50 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100003.52 4 event FAX, iCode=134 state=1301
100003.52 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100003.53 4 path {FAX} not found
100003.53 4 event TDX_CST, iCode=134 state=1301
100003.55 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100003.56 4 path {TDX_CST} not found
100003.70 4 tw dtmf 4 (4,52,52)
100003.72 4 event 4, iCode=52 state=1301
100003.72 4 LsGetNbrsRxDigits 4,4
100003.73 4 state [Get PIN No] Number Input 3804
100003.73 4 path {3804} not found
100003.75 4 timer set 6 EV_TIMEOUT_ENTERDATA
100003.77 4 timer clear
100003.77 4 rv add [Get PIN No]{3804}
100003.78 4 path {3804} not found
100003.78 4 next module is [Varify A/C No] (idx=21)
100003.80 4 rvns add [Get PIN No_PathTaken]{success}
100003.81 4 fn RunModule start [Database Query,[Varify A/C No],21,,]
100003.83 4 timer clear
100003.83 4 state [Varify A/C No] DB Query
100003.84 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
100003.88 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
100003.89 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:59:41 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}
100003.91 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
100003.91 4 db [Varify A/C No] row count=1
100003.92 4 rv add [Varify A/C No_RowCount]{1}
100003.94 4 db get RecordsetGetRowsMax
100003.94 4 db get 999 records. (row count=1)
100003.95 4 db update RVs
100003.95 4 db about to close dbDbqDatabase
100003.97 4 db going down path [True]
100003.98 4 next module is
  1. (idx=44)
100003.98 4 fn RunModule start [Play,
  1. ,44,,]
100004.00 4 timer clear
100004.02 4 Play Module start
100004.02 4 state
  1. Playing
100004.03 4 state
100004.03 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
100004.08 4 tw wav->vox convert end 628109,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
100004.11 4 play start ok, lPlayId=628171
100010.64 4 tw dtmf 1 (4,49,49)
100010.66 4 event 1, iCode=49 state=1100
100010.66 4 LsPlayMsg 1,1
100010.67 4 next module is [say Bal 1] (idx=5)
100010.69 4 play PlayStop ok
100010.70 4 rv add
  1. {1}
100010.70 4 fn RunModule start [Play,[say Bal 1],5,,]
100010.72 4 tw PlayEnd 4 628171
100010.72 4 play end id=628171, (current ID)
100010.73 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100010.75 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100010.75 4 tw DialogicEvent 129,TDX_PLAY,628171,0,0,,,
100010.77 4 event TDX_PLAY, iCode=129 state=6001
100010.78 4 LsModuleTransition : 129, [TDX_PLAY]
100010.80 4 timer clear
100010.80 4 Play Module start
100010.81 4 state [say Bal 1] Playing
100010.81 4 state [say Bal 1] Playing (Bangla Voice\15 digit Credit Card No.wav)
100010.83 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\15 digit Credit Card No.wav
100010.86 4 tw wav->vox convert end 634906,G:\TeleBanking System\Bangla Voice\15 digit Credit Card No.vox,1,0,,
100010.88 4 play start ok, lPlayId=634953
100015.55 4 tw PlayEnd 4 634953
100015.56 4 play end id=634953, (current ID)
100015.56 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
100015.58 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100015.58 4 path {EV_PLAY_FINISHED} not found
100015.59 4 timer set 5 EV_TIMEOUT_REPLAYMSG
100015.61 4 tw DialogicEvent 129,TDX_PLAY,634953,0,0,,,
100015.61 4 event TDX_PLAY, iCode=129 state=1101
100015.63 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
100015.63 4 path {TDX_PLAY} not found
100019.14 4 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,DISCONNECT_TAPI2,
100019.14 4 event DISCONNECT_TAPI2, iCode=134 state=1101
100019.16 4 LsPlayMsgFinished EV_UNKNOWN_134,DISCONNECT_TAPI2
100019.16 4 path {DISCONNECT_TAPI2} not found
100019.17 4 HangupCall start (Default Handler 20: DISCONNECT_TAPI2)
100019.19 4 rv add [Hangup Time]{01/10/2007 10:00:19 AM}
100019.19 4 state Hanging up call... [Default Handler 20: DISCONNECT_TAPI2]
100019.20 4 HangupCall_Common hCall=4
100019.22 4 rec RecSoundStop ok
100019.22 4 play PlayStop ok
100019.23 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
100019.23 4 fnHangupCall end
100019.25 4 event TDX_CST, iCode=134 state=900
100019.27 4 LsAwaitingCalls EV_UNKNOWN_134
100019.28 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
100019.30 4 event TDX_SETHOOK, iCode=135 state=900
100019.30 4 LsAwaitingCalls EV_UNKNOWN_135
100019.31 4 event callstate IDLE 4 1,0,0
100019.33 4 WorkingMode@Idle=
100019.33 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
100019.34 4 timer clear
100019.34 4 rec RecSoundStop ok
100019.36 4 play PlayStop ok
100019.38 4 rv add [CallEndTime]{01/10/2007 10:00:19 AM}
100019.41 4 on-hangup script:[]
100019.41 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
100019.42 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
100019.44 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
100019.44 4 init atidle reinit : start
100019.45 4 init atidle reinit iConferenceOtherLegLid=-1
100019.45 4 init atidle reinit : reset all LineState variables
100019.47 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100019.48 4 state Waiting for a call...
100021.67 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100021.67 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
100021.69 4 setting iDialoutReadyToDialout = 1
100141.13 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100141.13 MemStructVgs_ClearVgs [3]
100141.22 load end
100141.22 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
100141.23 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100141.23 MemStructVgs_ClearVgs [4]
100141.31 load end
100141.33 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
100141.34 0 Erasing Script (new loaded) Id 2
100141.36 0 VgsScriptFree [2]
100141.38 MemStructVgs_ClearVgs [2]
100141.38 0 Erasing Script (new loaded) Id 3
100141.39 0 VgsScriptFree [3]
100141.41 MemStructVgs_ClearVgs [3]
100149.41 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100149.41 MemStructVgs_ClearVgs [3]
100149.48 load end
100149.50 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
100149.52 0 Erasing Script (new loaded) Id 4
100149.52 0 VgsScriptFree [4]
100149.53 MemStructVgs_ClearVgs [4]
100205.53 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100205.55 MemStructVgs_ClearVgs [4]
100205.63 load end
100205.63 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
100205.64 0 Erasing Script (new loaded) Id 3
100205.66 0 VgsScriptFree [3]
100205.66 MemStructVgs_ClearVgs [3]
100215.66 4 event callstate OFFERING 4 2,0,0
100215.67 4 script interpretor: VgMulti v6.0.3243
100215.67 4 fired OFFERING event to listeners
100215.69 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
100215.69 4 cid CallerID vars set (in 'offering' event) [,,]
100215.70 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
100215.72 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
100215.72 4 tw ring 1
100215.73 4 ring time since last ring event (sec): 0.00
100215.73 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
100215.75 4 should answer as number of rings reached
100215.77 4 rv clear all
100215.77 4 init LineState ResetAtStartOfNewCall.
100215.78 4 answering the call (,,,0)
100215.78 4 timer clear
100215.80 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
100215.81 4 event TDX_CST, iCode=134 state=6001
100215.83 4 LsModuleTransition : 134, [TDX_CST]
100216.44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
100216.44 4 event TDX_SETHOOK, iCode=135 state=6001
100216.45 4 LsModuleTransition : 135, [TDX_SETHOOK]
100216.47 4 event callstate CONNECTED 4 256,0,0
100216.47 4 LineEvCallState_Connected hDevice=4 params=256,0,0
100216.48 4 WorkingModes tapi= script= LineState().iState=6001
100216.48 4 Inband detection not enabled
100216.50 4 StartLoadedVgs at 01/10/2007 10:02:16 AM (VgMulti v6.0.3243)
100216.52 4 set LineState().iVgsIdx=1
100216.52 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
100216.53 4 init StartLoadedVgs_InitLineState start
100216.53 4 rv add [$RV_STARTTIME]{01/10/2007 10:02:16 AM}
100216.55 4 rv add [$RV_DEVICEID]{4}
100216.56 4 rv add [DlgcNetworkResource]{dxxxB1C4}
100216.56 4 rv add [DlgcVoiceResource]{dxxxB1C4}
100216.58 4 rv add [$RV_CIDNAME]{}
100216.58 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
100216.59 4 rvns add [scriptsPath]{G:\TeleBanking System\}
100216.61 4 rv add [$RV_CIDNUMBER]{}
100216.61 4 fn RunModule start [Play,[Get Language],1,,]
100216.63 4 tw DialogicEvent 134,TDX_CST,11714,0,0,DE_LCON,,
100216.64 4 event TDX_CST, iCode=134 state=6001
100216.64 4 LsModuleTransition : 134, [TDX_CST]
100216.66 4 timer clear
100216.66 4 Play Module start
100216.67 4 state [Get Language] Playing
100216.69 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
100216.69 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
100216.75 4 tw wav->vox convert end 760765,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
100216.77 4 play start ok, lPlayId=760843
100217.61 4 tw dtmf 1 (4,49,49)
100217.63 4 event 1, iCode=49 state=1100
100217.63 4 LsPlayMsg 1,1
100217.64 4 rv add [scriptEnd_Time]{01/10/2007 10:02:17 AM}
100217.66 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
100217.66 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
100217.69 4 rv add [scriptStart_Time]{01/10/2007 10:02:17 AM}
100217.70 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
100217.72 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
100217.72 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100217.73 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4
100217.73 4 rvns add [scriptsPath]{G:\TeleBanking System\}
100217.75 4 play PlayStop ok
100217.77 4 rv add [Get Language]{1}
100217.78 4 fn RunModule start [Evaluate,[Get Bangla],108,,]
100217.78 4 tw PlayEnd 4 760843
100217.80 4 play end id=760843, (current ID)
100217.81 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100217.81 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100217.83 4 tw DialogicEvent 129,TDX_PLAY,760843,0,0,,,
100217.83 4 event TDX_PLAY, iCode=129 state=6001
100217.84 4 LsModuleTransition : 129, [TDX_PLAY]
100217.86 4 timer clear
100217.88 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
100217.88 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
100217.89 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
100217.91 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100217.91 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100217.92 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
100217.94 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
100217.94 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
100217.95 4 matching path not found
100217.95 4 next module is
  1. (idx=107)
100217.97 4 matching path was found
100217.98 4 fn RunModule start [Play,
  1. ,107,,]
100217.98 4 timer clear
100218.00 4 Play Module start
100218.00 4 state
  1. Playing
100218.02 4 state
  1. Playing (Bangla Voice\Service List.wav)
100218.03 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
100218.06 4 tw wav->vox convert end 762109,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
100218.09 4 play start ok, lPlayId=762156
100219.36 4 tw dtmf 1 (4,49,49)
100219.38 4 event 1, iCode=49 state=1100
100219.39 4 LsPlayMsg 1,1
100219.39 4 next module is [Get Acc No] (idx=129)
100219.41 4 play PlayStop ok
100219.42 4 rv add
  1. {1}
100219.44 4 fn RunModule start [Get Numbers,[Get Acc No],129,,]
100219.44 4 tw PlayEnd 4 762156
100219.45 4 play end id=762156, (current ID)
100219.45 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100219.47 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100219.48 4 tw DialogicEvent 129,TDX_PLAY,762156,0,0,,,
100219.48 4 event TDX_PLAY, iCode=129 state=6001
100219.50 4 LsModuleTransition : 129, [TDX_PLAY]
100219.50 4 timer clear
100219.52 4 state [Get Acc No] Number Input
100219.53 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
100219.53 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
100219.59 4 tw wav->vox convert end 763609,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
100219.61 4 play start ok, lPlayId=763687
100223.44 4 tw PlayEnd 4 763687
100223.44 4 play end id=763687, (current ID)
100223.45 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
100223.45 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100223.47 4 path {EV_PLAY_FINISHED} not found
100223.48 4 timer set 17 EV_TIMEOUT_REPLAYMSG
100223.48 4 tw DialogicEvent 129,TDX_PLAY,763687,0,0,,,
100223.50 4 event TDX_PLAY, iCode=129 state=1301
100223.52 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
100223.52 4 path {TDX_PLAY} not found
100223.53 4 tw dtmf 0 (4,48,48)
100223.53 4 event 0, iCode=48 state=1301
100223.55 4 LsGetNbrsRxDigits 0,0
100223.56 4 state [Get Acc No] Number Input 0
100223.56 4 path {0} not found
100223.58 4 timer set 6 EV_TIMEOUT_ENTERDATA
100223.70 4 tw dtmf 1 (4,49,49)
100223.72 4 event 1, iCode=49 state=1301
100223.73 4 LsGetNbrsRxDigits 1,1
100223.73 4 state [Get Acc No] Number Input 01
100223.75 4 path {01} not found
100223.75 4 timer set 6 EV_TIMEOUT_ENTERDATA
100224.05 4 tw dtmf 7 (4,55,55)
100224.05 4 event 7, iCode=55 state=1301
100224.06 4 LsGetNbrsRxDigits 7,7
100224.08 4 state [Get Acc No] Number Input 017
100224.08 4 path {017} not found
100224.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
100224.88 4 tw dtmf 3 (4,51,51)
100224.88 4 event 3, iCode=51 state=1301
100224.89 4 LsGetNbrsRxDigits 3,3
100224.91 4 state [Get Acc No] Number Input 0173
100224.91 4 path {0173} not found
100224.92 4 timer set 6 EV_TIMEOUT_ENTERDATA
100225.34 4 tw dtmf 4 (4,52,52)
100225.34 4 event 4, iCode=52 state=1301
100225.36 4 LsGetNbrsRxDigits 4,4
100225.38 4 state [Get Acc No] Number Input 01734
100225.38 4 path {01734} not found
100225.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
100225.56 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100225.56 4 event FAX, iCode=134 state=1301
100225.58 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100225.58 4 path {FAX} not found
100225.59 4 event TDX_CST, iCode=134 state=1301
100225.61 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100225.61 4 path {TDX_CST} not found
100225.75 4 tw dtmf 0 (4,48,48)
100225.75 4 event 0, iCode=48 state=1301
100225.77 4 LsGetNbrsRxDigits 0,0
100225.78 4 state [Get Acc No] Number Input 017340
100225.78 4 path {017340} not found
100225.80 4 timer set 6 EV_TIMEOUT_ENTERDATA
100226.02 4 tw dtmf 0 (4,48,48)
100226.02 4 event 0, iCode=48 state=1301
100226.03 4 LsGetNbrsRxDigits 0,0
100226.05 4 state [Get Acc No] Number Input 0173400
100226.05 4 path {0173400} not found
100226.06 4 timer set 6 EV_TIMEOUT_ENTERDATA
100226.25 4 tw dtmf 0 (4,48,48)
100226.27 4 event 0, iCode=48 state=1301
100226.28 4 LsGetNbrsRxDigits 0,0
100226.28 4 state [Get Acc No] Number Input 01734000
100226.30 4 path {01734000} not found
100226.30 4 timer set 6 EV_TIMEOUT_ENTERDATA
100226.75 4 tw dtmf 2 (4,50,50)
100226.77 4 event 2, iCode=50 state=1301
100226.78 4 LsGetNbrsRxDigits 2,2
100226.78 4 state [Get Acc No] Number Input 017340002
100226.80 4 path {017340002} not found
100226.83 4 timer set 6 EV_TIMEOUT_ENTERDATA
100227.06 4 tw dtmf 4 (4,52,52)
100227.06 4 event 4, iCode=52 state=1301
100227.08 4 LsGetNbrsRxDigits 4,4
100227.08 4 state [Get Acc No] Number Input 0173400024
100227.09 4 path {0173400024} not found
100227.11 4 timer set 6 EV_TIMEOUT_ENTERDATA
100227.38 4 tw dtmf 5 (4,53,53)
100227.38 4 event 5, iCode=53 state=1301
100227.39 4 LsGetNbrsRxDigits 5,5
100227.39 4 state [Get Acc No] Number Input 01734000245
100227.41 4 path {01734000245} not found
100227.42 4 timer set 6 EV_TIMEOUT_ENTERDATA
100233.89 4 timer fired EV_TIMEOUT_ENTERDATA
100233.89 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
100233.91 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
100233.91 4 path {EV_TIMEOUT_ENTERDATA} not found
100233.92 4 timer clear
100233.94 4 rv add [Get Acc No]{01734000245}
100233.94 4 path {01734000245} not found
100233.95 4 next module is [Varify A/C] (idx=89)
100233.97 4 rvns add [Get Acc No_PathTaken]{success}
100233.97 4 fn RunModule start [Database Query,[Varify A/C],89,,]
100233.98 4 timer clear
100233.98 4 state [Varify A/C] DB Query
100234.00 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
100234.05 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
100234.06 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:02:16 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:02:17 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:02:17 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100234.08 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
100234.08 4 db [Varify A/C] row count=1
100234.09 4 rv add [Varify A/C_RowCount]{1}
100234.11 4 db get RecordsetGetRowsMax
100234.11 4 db get 999 records. (row count=1)
100234.13 4 db update RVs
100234.14 4 db about to close dbDbqDatabase
100234.14 4 db going down path [True]
100234.16 4 next module is [Get PIN No] (idx=128)
100234.16 4 fn RunModule start [Get Numbers,[Get PIN No],128,,]
100234.17 4 timer clear
100234.19 4 state [Get PIN No] Number Input
100234.19 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
100234.20 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
100234.22 4 tw wav->vox convert end 778281,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
100234.25 4 play start ok, lPlayId=778312
100237.56 4 tw PlayEnd 4 778312
100237.58 4 play end id=778312, (current ID)
100237.59 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
100237.59 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100237.61 4 path {EV_PLAY_FINISHED} not found
100237.63 4 timer set 7 EV_TIMEOUT_REPLAYMSG
100237.63 4 tw DialogicEvent 129,TDX_PLAY,778312,0,0,,,
100237.64 4 event TDX_PLAY, iCode=129 state=1301
100237.64 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
100237.66 4 path {TDX_PLAY} not found
100238.03 4 tw dtmf 3 (4,51,51)
100238.05 4 event 3, iCode=51 state=1301
100238.06 4 LsGetNbrsRxDigits 3,3
100238.06 4 state [Get PIN No] Number Input 3
100238.08 4 path {3} not found
100238.08 4 timer set 6 EV_TIMEOUT_ENTERDATA
100239.17 4 tw dtmf 8 (4,56,56)
100239.19 4 event 8, iCode=56 state=1301
100239.19 4 LsGetNbrsRxDigits 8,8
100239.20 4 state [Get PIN No] Number Input 38
100239.22 4 path {38} not found
100239.22 4 timer set 6 EV_TIMEOUT_ENTERDATA
100239.41 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100239.41 4 event FAX, iCode=134 state=1301
100239.42 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100239.44 4 path {FAX} not found
100239.44 4 event TDX_CST, iCode=134 state=1301
100239.45 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100239.47 4 path {TDX_CST} not found
100239.63 4 tw dtmf 0 (4,48,48)
100239.63 4 event 0, iCode=48 state=1301
100239.64 4 LsGetNbrsRxDigits 0,0
100239.66 4 state [Get PIN No] Number Input 380
100239.66 4 path {380} not found
100239.67 4 timer set 6 EV_TIMEOUT_ENTERDATA
100240.05 4 tw dtmf 4 (4,52,52)
100240.06 4 event 4, iCode=52 state=1301
100240.08 4 LsGetNbrsRxDigits 4,4
100240.08 4 state [Get PIN No] Number Input 3804
100240.09 4 path {3804} not found
100240.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
100240.11 4 timer clear
100240.13 4 rv add [Get PIN No]{3804}
100240.13 4 path {3804} not found
100240.14 4 next module is [Varify A/C No] (idx=104)
100240.14 4 rvns add [Get PIN No_PathTaken]{success}
100240.16 4 fn RunModule start [Database Query,[Varify A/C No],104,,]
100240.17 4 timer clear
100240.17 4 state [Varify A/C No] DB Query
100240.19 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
100240.22 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
100240.23 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:02:16 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
100240.25 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
100240.25 4 db [Varify A/C No] row count=1
100240.27 4 rv add [Varify A/C No_RowCount]{1}
100240.28 4 db get RecordsetGetRowsMax
100240.28 4 db get 999 records. (row count=1)
100240.30 4 db update RVs
100240.30 4 db about to close dbDbqDatabase
100240.31 4 db going down path [True]
100240.33 4 next module is
  1. (idx=127)
100240.33 4 fn RunModule start [Play,
  1. ,127,,]
100240.34 4 timer clear
100240.36 4 Play Module start
100240.36 4 state
  1. Playing
100240.38 4 state
  1. Playing (Bangla Voice\Acc List.wav)
100240.39 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
100240.42 4 tw wav->vox convert end 784468,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
100240.44 4 play start ok, lPlayId=784500
100244.42 4 tw dtmf 1 (4,49,49)
100244.44 4 event 1, iCode=49 state=1100
100244.44 4 LsPlayMsg 1,1
100244.45 4 next module is [say Bal 1] (idx=88)
100244.47 4 play PlayStop ok
100244.48 4 rv add
  1. {1}
100244.48 4 fn RunModule start [say Numbers,[say Bal 1],88,,]
100244.50 4 tw PlayEnd 4 784500
100244.50 4 play end id=784500, (current ID)
100244.52 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100244.53 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100244.53 4 tw DialogicEvent 129,TDX_PLAY,784500,0,0,,,
100244.55 4 event TDX_PLAY, iCode=129 state=6001
100244.56 4 LsModuleTransition : 129, [TDX_PLAY]
100244.56 4 timer clear
100244.58 4 state [say Bal 1] Say numbers: as
100244.58 4 fn PlaySoundStartNumbers [bangla Voice\16 digit Credit Card No.wav],[],[],
100244.59 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
100244.61 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
100244.61 4 rv add [Hangup Time]{01/10/2007 10:02:44 AM}
100244.63 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
100244.63 4 HangupCall_Common hCall=4
100244.64 4 rec RecSoundStop ok
100244.66 4 play PlayStop ok
100244.66 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
100244.67 4 fnHangupCall end
100244.72 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
100244.72 4 event TDX_SETHOOK, iCode=135 state=900
100244.73 4 LsAwaitingCalls EV_UNKNOWN_135
100244.75 4 event callstate IDLE 4 1,0,0
100244.75 4 WorkingMode@Idle=
100244.77 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
100244.77 4 timer clear
100244.78 4 rec RecSoundStop ok
100244.80 4 play PlayStop ok
100244.81 4 rv add [CallEndTime]{01/10/2007 10:02:44 AM}
100244.86 4 on-hangup script:[]
100244.86 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
100244.88 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
100244.88 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
100244.89 4 init atidle reinit : start
100244.91 4 init atidle reinit iConferenceOtherLegLid=-1
100244.91 4 init atidle reinit : reset all LineState variables
100244.92 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100244.92 4 state Waiting for a call...
100247.13 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100247.13 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
100247.14 4 setting iDialoutReadyToDialout = 1
100319.95 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100319.95 MemStructVgs_ClearVgs [3]
100320.05 load end
100320.05 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
100320.06 0 Erasing Script (new loaded) Id 4
100320.08 0 VgsScriptFree [4]
100320.08 MemStructVgs_ClearVgs [4]
100351.09 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100351.11 MemStructVgs_ClearVgs [4]
100351.19 load end
100351.19 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
100351.20 0 Erasing Script (new loaded) Id 3
100351.22 0 VgsScriptFree [3]
100351.22 MemStructVgs_ClearVgs [3]
100404.23 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100404.23 MemStructVgs_ClearVgs [3]
100404.33 load end
100404.33 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
100404.34 0 Erasing Script (new loaded) Id 4
100404.36 0 VgsScriptFree [4]
100404.36 MemStructVgs_ClearVgs [4]
100414.17 4 event callstate OFFERING 4 2,0,0
100414.17 4 script interpretor: VgMulti v6.0.3243
100414.19 4 fired OFFERING event to listeners
100414.19 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
100414.20 4 cid CallerID vars set (in 'offering' event) [,,]
100414.22 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
100414.22 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
100414.23 4 tw ring 1
100414.23 4 ring time since last ring event (sec): 0.00
100414.25 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
100414.27 4 should answer as number of rings reached
100414.27 4 rv clear all
100414.28 4 init LineState ResetAtStartOfNewCall.
100414.30 4 answering the call (,,,0)
100414.30 4 timer clear
100414.31 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
100414.33 4 event TDX_CST, iCode=134 state=6001
100414.33 4 LsModuleTransition : 134, [TDX_CST]
100414.94 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
100414.95 4 event TDX_SETHOOK, iCode=135 state=6001
100414.97 4 LsModuleTransition : 135, [TDX_SETHOOK]
100414.97 4 event callstate CONNECTED 4 256,0,0
100414.98 4 LineEvCallState_Connected hDevice=4 params=256,0,0
100414.98 4 WorkingModes tapi= script= LineState().iState=6001
100415.00 4 Inband detection not enabled
100415.02 4 StartLoadedVgs at 01/10/2007 10:04:15 AM (VgMulti v6.0.3243)
100415.02 4 set LineState().iVgsIdx=1
100415.03 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
100415.05 4 init StartLoadedVgs_InitLineState start
100415.05 4 rv add [$RV_STARTTIME]{01/10/2007 10:04:15 AM}
100415.06 4 rv add [$RV_DEVICEID]{4}
100415.06 4 rv add [DlgcNetworkResource]{dxxxB1C4}
100415.08 4 rv add [DlgcVoiceResource]{dxxxB1C4}
100415.09 4 rv add [$RV_CIDNAME]{}
100415.09 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
100415.11 4 rvns add [scriptsPath]{G:\TeleBanking System\}
100415.13 4 rv add [$RV_CIDNUMBER]{}
100415.13 4 fn RunModule start [Play,[Get Language],1,,]
100415.14 4 tw DialogicEvent 134,TDX_CST,9022,0,0,DE_LCON,,
100415.14 4 event TDX_CST, iCode=134 state=6001
100415.16 4 LsModuleTransition : 134, [TDX_CST]
100415.17 4 timer clear
100415.19 4 Play Module start
100415.19 4 state [Get Language] Playing
100415.20 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
100415.22 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
100415.22 4 tw wav->vox convert end 879296,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
100415.25 4 play start ok, lPlayId=879312
100415.92 4 tw dtmf 1 (4,49,49)
100415.94 4 event 1, iCode=49 state=1100
100415.94 4 LsPlayMsg 1,1
100415.95 4 rv add [scriptEnd_Time]{01/10/2007 10:04:15 AM}
100415.95 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
100415.97 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
100416.00 4 rv add [scriptStart_Time]{01/10/2007 10:04:15 AM}
100416.02 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
100416.02 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
100416.03 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100416.03 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3
100416.05 4 rvns add [scriptsPath]{G:\TeleBanking System\}
100416.06 4 play PlayStop ok
100416.08 4 rv add [Get Language]{1}
100416.08 4 fn RunModule start [Evaluate,[Get Bangla],66,,]
100416.09 4 tw PlayEnd 4 879312
100416.11 4 play end id=879312, (current ID)
100416.11 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100416.13 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100416.13 4 tw DialogicEvent 129,TDX_PLAY,879312,0,0,,,
100416.14 4 event TDX_PLAY, iCode=129 state=6001
100416.16 4 LsModuleTransition : 129, [TDX_PLAY]
100416.16 4 timer clear
100416.17 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
100416.19 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
100416.19 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
100416.20 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100416.20 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100416.22 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
100416.23 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
100416.23 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
100416.25 4 matching path not found
100416.25 4 next module is
  1. (idx=67)
100416.27 4 matching path was found
100416.28 4 fn RunModule start [Play,
  1. ,67,,]
100416.30 4 timer clear
100416.31 4 Play Module start
100416.31 4 state
  1. Playing
100416.33 4 state
100416.33 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
100416.39 4 tw wav->vox convert end 880406,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
100416.41 4 play start ok, lPlayId=880484
100417.13 4 tw dtmf 1 (4,49,49)
100417.13 4 event 1, iCode=49 state=1100
100417.14 4 LsPlayMsg 1,1
100417.16 4 next module is [Get Acc No] (idx=4)
100417.17 4 play PlayStop ok
100417.17 4 rv add
  1. {1}
100417.19 4 fn RunModule start [Get Numbers,[Get Acc No],4,,]
100417.20 4 tw PlayEnd 4 880484
100417.20 4 play end id=880484, (current ID)
100417.22 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100417.23 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100417.23 4 tw DialogicEvent 129,TDX_PLAY,880484,0,0,,,
100417.25 4 event TDX_PLAY, iCode=129 state=6001
100417.25 4 LsModuleTransition : 129, [TDX_PLAY]
100417.27 4 timer clear
100417.28 4 state [Get Acc No] Number Input
100417.28 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
100417.30 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
100417.31 4 tw wav->vox convert end 881375,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
100417.33 4 play start ok, lPlayId=881390
100421.14 4 tw PlayEnd 4 881390
100421.16 4 play end id=881390, (current ID)
100421.16 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
100421.17 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100421.17 4 path {EV_PLAY_FINISHED} not found
100421.19 4 timer set 17 EV_TIMEOUT_REPLAYMSG
100421.20 4 tw DialogicEvent 129,TDX_PLAY,881390,0,0,,,
100421.20 4 event TDX_PLAY, iCode=129 state=1301
100421.22 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
100421.23 4 path {TDX_PLAY} not found
100421.91 4 tw dtmf 0 (4,48,48)
100421.92 4 event 0, iCode=48 state=1301
100421.92 4 LsGetNbrsRxDigits 0,0
100421.94 4 state [Get Acc No] Number Input 0
100421.95 4 path {0} not found
100421.95 4 timer set 6 EV_TIMEOUT_ENTERDATA
100422.13 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100422.14 4 event FAX, iCode=134 state=1301
100422.14 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100422.16 4 path {FAX} not found
100422.16 4 event TDX_CST, iCode=134 state=1301
100422.17 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100422.19 4 path {TDX_CST} not found
100422.36 4 tw dtmf 1 (4,49,49)
100422.36 4 event 1, iCode=49 state=1301
100422.38 4 LsGetNbrsRxDigits 1,1
100422.38 4 state [Get Acc No] Number Input 01
100422.39 4 path {01} not found
100422.41 4 timer set 6 EV_TIMEOUT_ENTERDATA
100422.72 4 tw dtmf 7 (4,55,55)
100422.73 4 event 7, iCode=55 state=1301
100422.75 4 LsGetNbrsRxDigits 7,7
100422.75 4 state [Get Acc No] Number Input 017
100422.77 4 path {017} not found
100422.77 4 timer set 6 EV_TIMEOUT_ENTERDATA
100423.19 4 tw dtmf 3 (4,51,51)
100423.20 4 event 3, iCode=51 state=1301
100423.22 4 LsGetNbrsRxDigits 3,3
100423.22 4 state [Get Acc No] Number Input 0173
100423.23 4 path {0173} not found
100423.23 4 timer set 6 EV_TIMEOUT_ENTERDATA
100423.42 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100423.44 4 event FAX, iCode=134 state=1301
100423.44 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100423.45 4 path {FAX} not found
100423.45 4 event TDX_CST, iCode=134 state=1301
100423.47 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100423.48 4 path {TDX_CST} not found
100423.59 4 tw dtmf 4 (4,52,52)
100423.61 4 event 4, iCode=52 state=1301
100423.63 4 LsGetNbrsRxDigits 4,4
100423.63 4 state [Get Acc No] Number Input 01734
100423.64 4 path {01734} not found
100423.66 4 timer set 6 EV_TIMEOUT_ENTERDATA
100423.81 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100423.83 4 event FAX, iCode=134 state=1301
100423.84 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100423.84 4 path {FAX} not found
100423.86 4 event TDX_CST, iCode=134 state=1301
100423.86 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100423.88 4 path {TDX_CST} not found
100424.02 4 tw dtmf 0 (4,48,48)
100424.02 4 event 0, iCode=48 state=1301
100424.03 4 LsGetNbrsRxDigits 0,0
100424.03 4 state [Get Acc No] Number Input 017340
100424.05 4 path {017340} not found
100424.06 4 timer set 6 EV_TIMEOUT_ENTERDATA
100424.34 4 tw dtmf 0 (4,48,48)
100424.36 4 event 0, iCode=48 state=1301
100424.36 4 LsGetNbrsRxDigits 0,0
100424.38 4 state [Get Acc No] Number Input 0173400
100424.39 4 path {0173400} not found
100424.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
100424.59 4 tw dtmf 0 (4,48,48)
100424.61 4 event 0, iCode=48 state=1301
100424.61 4 LsGetNbrsRxDigits 0,0
100424.63 4 state [Get Acc No] Number Input 01734000
100424.64 4 path {01734000} not found
100424.64 4 timer set 6 EV_TIMEOUT_ENTERDATA
100425.11 4 tw dtmf 2 (4,50,50)
100425.13 4 event 2, iCode=50 state=1301
100425.13 4 LsGetNbrsRxDigits 2,2
100425.14 4 state [Get Acc No] Number Input 017340002
100425.16 4 path {017340002} not found
100425.16 4 timer set 6 EV_TIMEOUT_ENTERDATA
100425.47 4 tw dtmf 4 (4,52,52)
100425.47 4 event 4, iCode=52 state=1301
100425.48 4 LsGetNbrsRxDigits 4,4
100425.48 4 state [Get Acc No] Number Input 0173400024
100425.50 4 path {0173400024} not found
100425.52 4 timer set 6 EV_TIMEOUT_ENTERDATA
100425.75 4 tw dtmf 5 (4,53,53)
100425.77 4 event 5, iCode=53 state=1301
100425.77 4 LsGetNbrsRxDigits 5,5
100425.78 4 state [Get Acc No] Number Input 01734000245
100425.78 4 path {01734000245} not found
100425.80 4 timer set 6 EV_TIMEOUT_ENTERDATA
100432.31 4 timer fired EV_TIMEOUT_ENTERDATA
100432.31 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
100432.33 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
100432.33 4 path {EV_TIMEOUT_ENTERDATA} not found
100432.34 4 timer clear
100432.36 4 rv add [Get Acc No]{01734000245}
100432.36 4 path {01734000245} not found
100432.38 4 next module is [Varify A/C] (idx=85)
100432.39 4 rvns add [Get Acc No_PathTaken]{success}
100432.39 4 fn RunModule start [Database Query,[Varify A/C],85,,]
100432.41 4 timer clear
100432.42 4 state [Varify A/C] DB Query
100432.44 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
100432.47 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
100432.48 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:04:15 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:04:15 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:04:15 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100432.48 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
100432.50 4 db [Varify A/C] row count=1
100432.52 4 rv add [Varify A/C_RowCount]{1}
100432.52 4 db get RecordsetGetRowsMax
100432.53 4 db get 999 records. (row count=1)
100432.55 4 db update RVs
100432.55 4 db about to close dbDbqDatabase
100432.56 4 db going down path [True]
100432.56 4 next module is [Get PIN No] (idx=46)
100432.58 4 fn RunModule start [Get Numbers,[Get PIN No],46,,]
100432.59 4 timer clear
100432.59 4 state [Get PIN No] Number Input
100432.61 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
100432.63 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
100432.64 4 tw wav->vox convert end 896703,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
100432.66 4 play start ok, lPlayId=896734
100435.98 4 tw PlayEnd 4 896734
100436.00 4 play end id=896734, (current ID)
100436.00 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
100436.02 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100436.03 4 path {EV_PLAY_FINISHED} not found
100436.03 4 timer set 7 EV_TIMEOUT_REPLAYMSG
100436.05 4 tw DialogicEvent 129,TDX_PLAY,896734,0,0,,,
100436.05 4 event TDX_PLAY, iCode=129 state=1301
100436.06 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
100436.08 4 path {TDX_PLAY} not found
100436.08 4 tw dtmf 3 (4,51,51)
100436.09 4 event 3, iCode=51 state=1301
100436.09 4 LsGetNbrsRxDigits 3,3
100436.11 4 state [Get PIN No] Number Input 3
100436.13 4 path {3} not found
100436.13 4 timer set 6 EV_TIMEOUT_ENTERDATA
100437.50 4 tw dtmf 8 (4,56,56)
100437.50 4 event 8, iCode=56 state=1301
100437.52 4 LsGetNbrsRxDigits 8,8
100437.53 4 state [Get PIN No] Number Input 38
100437.53 4 path {38} not found
100437.55 4 timer set 6 EV_TIMEOUT_ENTERDATA
100437.86 4 tw dtmf 0 (4,48,48)
100437.86 4 event 0, iCode=48 state=1301
100437.88 4 LsGetNbrsRxDigits 0,0
100437.89 4 state [Get PIN No] Number Input 380
100437.89 4 path {380} not found
100437.91 4 timer set 6 EV_TIMEOUT_ENTERDATA
100438.34 4 tw dtmf 4 (4,52,52)
100438.34 4 event 4, iCode=52 state=1301
100438.36 4 LsGetNbrsRxDigits 4,4
100438.36 4 state [Get PIN No] Number Input 3804
100438.38 4 path {3804} not found
100438.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
100438.39 4 timer clear
100438.41 4 rv add [Get PIN No]{3804}
100438.41 4 path {3804} not found
100438.42 4 next module is [Varify A/C No] (idx=70)
100438.44 4 rvns add [Get PIN No_PathTaken]{success}
100438.44 4 fn RunModule start [Database Query,[Varify A/C No],70,,]
100438.47 4 timer clear
100438.47 4 state [Varify A/C No] DB Query
100438.48 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
100438.52 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
100438.53 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:04:15 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
100438.53 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
100438.55 4 db [Varify A/C No] row count=1
100438.56 4 rv add [Varify A/C No_RowCount]{1}
100438.56 4 db get RecordsetGetRowsMax
100438.58 4 db get 999 records. (row count=1)
100438.59 4 db update RVs
100438.59 4 db about to close dbDbqDatabase
100438.61 4 db going down path [True]
100438.63 4 next module is
  1. (idx=47)
100438.63 4 fn RunModule start [Play,
  1. ,47,,]
100438.64 4 timer clear
100438.66 4 Play Module start
100438.66 4 state
  1. Playing
100438.67 4 state
100438.67 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
100438.73 4 tw wav->vox convert end 902750,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
100438.75 4 play start ok, lPlayId=902828
100441.03 4 tw dtmf 1 (4,49,49)
100441.05 4 event 1, iCode=49 state=1100
100441.06 4 LsPlayMsg 1,1
100441.06 4 next module is [say Bal 1] (idx=86)
100441.08 4 play PlayStop ok
100441.09 4 rv add
  1. {1}
100441.11 4 fn RunModule start [say Numbers,[say Bal 1],86,,]
100441.11 4 tw PlayEnd 4 902828
100441.13 4 play end id=902828, (current ID)
100441.14 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100441.14 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100441.16 4 tw DialogicEvent 129,TDX_PLAY,902828,0,0,,,
100441.16 4 event TDX_PLAY, iCode=129 state=6001
100441.17 4 LsModuleTransition : 129, [TDX_PLAY]
100441.19 4 timer clear
100441.19 4 state [say Bal 1] Say numbers: 200 as Number
100441.20 4 fn PlaySoundStartNumbers [C:\Program Files\VoiceGuide\system\Bangla Voice\16 digit Credit Card No.wav],[],[200],Number
100441.20 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
100441.22 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
100441.23 4 rv add [Hangup Time]{01/10/2007 10:04:41 AM}
100441.23 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
100441.25 4 HangupCall_Common hCall=4
100441.27 4 rec RecSoundStop ok
100441.27 4 play PlayStop ok
100441.28 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
100441.28 4 fnHangupCall end
100441.33 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
100441.34 4 event TDX_SETHOOK, iCode=135 state=900
100441.36 4 LsAwaitingCalls EV_UNKNOWN_135
100441.36 4 event callstate IDLE 4 1,0,0
100441.38 4 WorkingMode@Idle=
100441.38 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
100441.39 4 timer clear
100441.41 4 rec RecSoundStop ok
100441.41 4 play PlayStop ok
100441.42 4 rv add [CallEndTime]{01/10/2007 10:04:41 AM}
100441.45 4 on-hangup script:[]
100441.47 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
100441.47 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
100441.48 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
100441.48 4 init atidle reinit : start
100441.50 4 init atidle reinit iConferenceOtherLegLid=-1
100441.52 4 init atidle reinit : reset all LineState variables
100441.52 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100441.53 4 state Waiting for a call...
100443.73 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100443.73 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
100443.75 4 setting iDialoutReadyToDialout = 1
100549.69 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100549.69 MemStructVgs_ClearVgs [4]
100549.78 load end
100549.80 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
100549.80 0 Erasing Script (new loaded) Id 3
100549.81 0 VgsScriptFree [3]
100549.83 MemStructVgs_ClearVgs [3]
100553.83 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100553.84 MemStructVgs_ClearVgs [3]
100553.91 load end
100553.92 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
100553.94 0 Erasing Script (new loaded) Id 4
100553.94 0 VgsScriptFree [4]
100553.95 MemStructVgs_ClearVgs [4]
100605.97 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100605.98 MemStructVgs_ClearVgs [4]
100606.06 load end
100606.08 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
100606.08 0 Erasing Script (new loaded) Id 3
100606.09 0 VgsScriptFree [3]
100606.11 MemStructVgs_ClearVgs [3]
100615.02 4 event callstate OFFERING 4 2,0,0
100615.02 4 script interpretor: VgMulti v6.0.3243
100615.03 4 fired OFFERING event to listeners
100615.03 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
100615.05 4 cid CallerID vars set (in 'offering' event) [,,]
100615.06 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
100615.06 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
100615.08 4 tw ring 1
100615.09 4 ring time since last ring event (sec): 0.00
100615.09 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
100615.11 4 should answer as number of rings reached
100615.11 4 rv clear all
100615.13 4 init LineState ResetAtStartOfNewCall.
100615.14 4 answering the call (,,,0)
100615.14 4 timer clear
100615.16 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
100615.17 4 event TDX_CST, iCode=134 state=6001
100615.17 4 LsModuleTransition : 134, [TDX_CST]
100615.80 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
100615.80 4 event TDX_SETHOOK, iCode=135 state=6001
100615.81 4 LsModuleTransition : 135, [TDX_SETHOOK]
100615.81 4 event callstate CONNECTED 4 256,0,0
100615.83 4 LineEvCallState_Connected hDevice=4 params=256,0,0
100615.84 4 WorkingModes tapi= script= LineState().iState=6001
100615.84 4 Inband detection not enabled
100615.86 4 StartLoadedVgs at 01/10/2007 10:06:15 AM (VgMulti v6.0.3243)
100615.88 4 set LineState().iVgsIdx=1
100615.88 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
100615.89 4 init StartLoadedVgs_InitLineState start
100615.91 4 rv add [$RV_STARTTIME]{01/10/2007 10:06:15 AM}
100615.91 4 rv add [$RV_DEVICEID]{4}
100615.92 4 rv add [DlgcNetworkResource]{dxxxB1C4}
100615.92 4 rv add [DlgcVoiceResource]{dxxxB1C4}
100615.94 4 rv add [$RV_CIDNAME]{}
100615.95 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
100615.95 4 rvns add [scriptsPath]{G:\TeleBanking System\}
100615.97 4 rv add [$RV_CIDNUMBER]{}
100615.98 4 fn RunModule start [Play,[Get Language],1,,]
100615.98 4 tw DialogicEvent 134,TDX_CST,9446,0,0,DE_LCON,,
100616.00 4 event TDX_CST, iCode=134 state=6001
100616.00 4 LsModuleTransition : 134, [TDX_CST]
100616.02 4 timer clear
100616.03 4 Play Module start
100616.03 4 state [Get Language] Playing
100616.05 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
100616.06 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
100616.08 4 tw wav->vox convert end 140,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
100616.11 4 play start ok, lPlayId=171
100617.70 4 tw dtmf 1 (4,49,49)
100617.72 4 event 1, iCode=49 state=1100
100617.73 4 LsPlayMsg 1,1
100617.73 4 rv add [scriptEnd_Time]{01/10/2007 10:06:17 AM}
100617.75 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
100617.77 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
100617.80 4 rv add [scriptStart_Time]{01/10/2007 10:06:17 AM}
100617.80 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
100617.81 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
100617.83 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100617.83 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4
100617.84 4 rvns add [scriptsPath]{G:\TeleBanking System\}
100617.86 4 play PlayStop ok
100617.88 4 rv add [Get Language]{1}
100617.89 4 fn RunModule start [Evaluate,[Get Bangla],109,,]
100617.89 4 tw PlayEnd 4 171
100617.91 4 play end id=171, (current ID)
100617.92 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100617.92 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100617.94 4 tw DialogicEvent 129,TDX_PLAY,171,0,0,,,
100617.94 4 event TDX_PLAY, iCode=129 state=6001
100617.95 4 LsModuleTransition : 129, [TDX_PLAY]
100617.97 4 timer clear
100617.97 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
100617.98 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
100618.00 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
100618.00 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100618.02 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100618.02 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
100618.03 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
100618.05 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
100618.05 4 matching path not found
100618.06 4 next module is
  1. (idx=110)
100618.08 4 matching path was found
100618.08 4 fn RunModule start [Play,
  1. ,110,,]
100618.09 4 timer clear
100618.09 4 Play Module start
100618.11 4 state
  1. Playing
100618.13 4 state
100618.13 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
100618.17 4 tw wav->vox convert end 2203,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
100618.19 4 play start ok, lPlayId=2265
100619.20 4 tw dtmf 1 (4,49,49)
100619.22 4 event 1, iCode=49 state=1100
100619.23 4 LsPlayMsg 1,1
100619.23 4 next module is [Get Acc No] (idx=88)
100619.25 4 play PlayStop ok
100619.27 4 rv add
  1. {1}
100619.28 4 fn RunModule start [Get Numbers,[Get Acc No],88,,]
100619.28 4 tw PlayEnd 4 2265
100619.30 4 play end id=2265, (current ID)
100619.31 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100619.31 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100619.33 4 tw DialogicEvent 129,TDX_PLAY,2265,0,0,,,
100619.33 4 event TDX_PLAY, iCode=129 state=6001
100619.34 4 LsModuleTransition : 129, [TDX_PLAY]
100619.36 4 timer clear
100619.38 4 state [Get Acc No] Number Input
100619.39 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
100619.39 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
100619.44 4 tw wav->vox convert end 3468,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
100619.47 4 play start ok, lPlayId=3531
100622.17 4 tw dtmf 0 (4,48,48)
100622.19 4 event 0, iCode=48 state=1300
100622.19 4 LsGetNbrsPlayWelcMsg 0,0
100622.20 4 play PlayStop ok
100622.22 4 state [Get Acc No] Number Input 0
100622.23 4 path {0} not found
100622.23 4 timer set 6 EV_TIMEOUT_ENTERDATA
100622.25 4 tw PlayEnd 4 3531
100622.27 4 play end id=3531, (current ID)
100622.27 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
100622.28 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
100622.28 4 path {EV_PLAY_FINISHED} not found
100622.30 4 awaiting further dtmf input
100622.31 4 tw DialogicEvent 129,TDX_PLAY,3531,0,0,,,
100622.31 4 event TDX_PLAY, iCode=129 state=1301
100622.33 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
100622.34 4 path {TDX_PLAY} not found
100622.52 4 tw dtmf 1 (4,49,49)
100622.52 4 event 1, iCode=49 state=1301
100622.53 4 LsGetNbrsRxDigits 1,1
100622.53 4 state [Get Acc No] Number Input 01
100622.55 4 path {01} not found
100622.56 4 timer set 6 EV_TIMEOUT_ENTERDATA
100622.95 4 tw dtmf 7 (4,55,55)
100622.97 4 event 7, iCode=55 state=1301
100622.97 4 LsGetNbrsRxDigits 7,7
100622.98 4 state [Get Acc No] Number Input 017
100623.00 4 path {017} not found
100623.00 4 timer set 6 EV_TIMEOUT_ENTERDATA
100623.44 4 tw dtmf 3 (4,51,51)
100623.44 4 event 3, iCode=51 state=1301
100623.45 4 LsGetNbrsRxDigits 3,3
100623.47 4 state [Get Acc No] Number Input 0173
100623.47 4 path {0173} not found
100623.48 4 timer set 6 EV_TIMEOUT_ENTERDATA
100623.88 4 tw dtmf 4 (4,52,52)
100623.89 4 event 4, iCode=52 state=1301
100623.89 4 LsGetNbrsRxDigits 4,4
100623.91 4 state [Get Acc No] Number Input 01734
100623.92 4 path {01734} not found
100623.92 4 timer set 6 EV_TIMEOUT_ENTERDATA
100624.34 4 tw dtmf 0 (4,48,48)
100624.36 4 event 0, iCode=48 state=1301
100624.36 4 LsGetNbrsRxDigits 0,0
100624.38 4 state [Get Acc No] Number Input 017340
100624.39 4 path {017340} not found
100624.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
100624.67 4 tw dtmf 0 (4,48,48)
100624.69 4 event 0, iCode=48 state=1301
100624.69 4 LsGetNbrsRxDigits 0,0
100624.70 4 state [Get Acc No] Number Input 0173400
100624.70 4 path {0173400} not found
100624.72 4 timer set 6 EV_TIMEOUT_ENTERDATA
100624.98 4 tw dtmf 0 (4,48,48)
100624.98 4 event 0, iCode=48 state=1301
100625.00 4 LsGetNbrsRxDigits 0,0
100625.02 4 state [Get Acc No] Number Input 01734000
100625.02 4 path {01734000} not found
100625.03 4 timer set 6 EV_TIMEOUT_ENTERDATA
100625.50 4 tw dtmf 2 (4,50,50)
100625.50 4 event 2, iCode=50 state=1301
100625.52 4 LsGetNbrsRxDigits 2,2
100625.53 4 state [Get Acc No] Number Input 017340002
100625.53 4 path {017340002} not found
100625.55 4 timer set 6 EV_TIMEOUT_ENTERDATA
100625.72 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100625.73 4 event FAX, iCode=134 state=1301
100625.75 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100625.75 4 path {FAX} not found
100625.77 4 event TDX_CST, iCode=134 state=1301
100625.78 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100625.78 4 path {TDX_CST} not found
100625.98 4 tw dtmf 4 (4,52,52)
100626.02 4 event 4, iCode=52 state=1301
100626.02 4 LsGetNbrsRxDigits 4,4
100626.03 4 state [Get Acc No] Number Input 0173400024
100626.03 4 path {0173400024} not found
100626.05 4 timer set 6 EV_TIMEOUT_ENTERDATA
100626.59 4 tw dtmf 5 (4,53,53)
100626.59 4 event 5, iCode=53 state=1301
100626.61 4 LsGetNbrsRxDigits 5,5
100626.63 4 state [Get Acc No] Number Input 01734000245
100626.63 4 path {01734000245} not found
100626.64 4 timer set 6 EV_TIMEOUT_ENTERDATA
100633.11 4 timer fired EV_TIMEOUT_ENTERDATA
100633.11 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
100633.13 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
100633.13 4 path {EV_TIMEOUT_ENTERDATA} not found
100633.14 4 timer clear
100633.16 4 rv add [Get Acc No]{01734000245}
100633.16 4 path {01734000245} not found
100633.17 4 next module is [Varify A/C] (idx=128)
100633.19 4 rvns add [Get Acc No_PathTaken]{success}
100633.19 4 fn RunModule start [Database Query,[Varify A/C],128,,]
100633.20 4 timer clear
100633.20 4 state [Varify A/C] DB Query
100633.22 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
100633.27 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
100633.27 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:06:15 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:06:17 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:06:17 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100633.28 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
100633.30 4 db [Varify A/C] row count=1
100633.30 4 rv add [Varify A/C_RowCount]{1}
100633.31 4 db get RecordsetGetRowsMax
100633.33 4 db get 999 records. (row count=1)
100633.33 4 db update RVs
100633.34 4 db about to close dbDbqDatabase
100633.36 4 db going down path [True]
100633.36 4 next module is [Get PIN No] (idx=89)
100633.38 4 fn RunModule start [Get Numbers,[Get PIN No],89,,]
100633.39 4 timer clear
100633.39 4 state [Get PIN No] Number Input
100633.41 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
100633.42 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
100633.45 4 tw wav->vox convert end 17500,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
100633.48 4 play start ok, lPlayId=17546
100636.02 4 tw dtmf 3 (4,51,51)
100636.03 4 event 3, iCode=51 state=1300
100636.05 4 LsGetNbrsPlayWelcMsg 3,3
100636.06 4 play PlayStop ok
100636.06 4 state [Get PIN No] Number Input 3
100636.08 4 path {3} not found
100636.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
100636.09 4 tw PlayEnd 4 17546
100636.11 4 play end id=17546, (current ID)
100636.11 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
100636.13 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
100636.14 4 path {EV_PLAY_FINISHED} not found
100636.14 4 awaiting further dtmf input
100636.16 4 tw DialogicEvent 129,TDX_PLAY,17546,0,0,,,
100636.17 4 event TDX_PLAY, iCode=129 state=1301
100636.17 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
100636.19 4 path {TDX_PLAY} not found
100636.58 4 tw dtmf 8 (4,56,56)
100636.59 4 event 8, iCode=56 state=1301
100636.61 4 LsGetNbrsRxDigits 8,8
100636.61 4 state [Get PIN No] Number Input 38
100636.63 4 path {38} not found
100636.64 4 timer set 6 EV_TIMEOUT_ENTERDATA
100637.20 4 tw dtmf 0 (4,48,48)
100637.20 4 event 0, iCode=48 state=1301
100637.22 4 LsGetNbrsRxDigits 0,0
100637.23 4 state [Get PIN No] Number Input 380
100637.23 4 path {380} not found
100637.25 4 timer set 6 EV_TIMEOUT_ENTERDATA
100637.66 4 tw dtmf 4 (4,52,52)
100637.66 4 event 4, iCode=52 state=1301
100637.67 4 LsGetNbrsRxDigits 4,4
100637.69 4 state [Get PIN No] Number Input 3804
100637.69 4 path {3804} not found
100637.70 4 timer set 6 EV_TIMEOUT_ENTERDATA
100637.72 4 timer clear
100637.72 4 rv add [Get PIN No]{3804}
100637.73 4 path {3804} not found
100637.73 4 next module is [Varify A/C No] (idx=113)
100637.75 4 rvns add [Get PIN No_PathTaken]{success}
100637.77 4 fn RunModule start [Database Query,[Varify A/C No],113,,]
100637.77 4 timer clear
100637.78 4 state [Varify A/C No] DB Query
100637.80 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
100637.83 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
100637.83 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:06:15 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
100637.84 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
100637.86 4 db [Varify A/C No] row count=1
100637.88 4 rv add [Varify A/C No_RowCount]{1}
100637.88 4 db get RecordsetGetRowsMax
100637.89 4 db get 999 records. (row count=1)
100637.91 4 db update RVs
100637.91 4 db about to close dbDbqDatabase
100637.92 4 db going down path [True]
100637.94 4 next module is
  1. (idx=90)
100637.94 4 fn RunModule start [Play,
  1. ,90,,]
100637.95 4 timer clear
100637.95 4 Play Module start
100637.97 4 state
  1. Playing
100637.98 4 state
100637.98 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
100638.03 4 tw wav->vox convert end 22062,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
100638.05 4 play start ok, lPlayId=22109
100644.00 4 tw dtmf 1 (4,49,49)
100644.02 4 event 1, iCode=49 state=1100
100644.02 4 LsPlayMsg 1,1
100644.03 4 next module is [say Bal 1] (idx=129)
100644.05 4 play PlayStop ok
100644.06 4 rv add
  1. {1}
100644.06 4 fn RunModule start [Play,[say Bal 1],129,,]
100644.08 4 tw PlayEnd 4 22109
100644.09 4 play end id=22109, (current ID)
100644.09 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100644.11 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100644.13 4 tw DialogicEvent 129,TDX_PLAY,22109,0,0,,,
100644.13 4 event TDX_PLAY, iCode=129 state=6001
100644.14 4 LsModuleTransition : 129, [TDX_PLAY]
100644.14 4 timer clear
100644.16 4 Play Module start
100644.17 4 state [say Bal 1] Playing
100644.17 4 state [say Bal 1] Playing (C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav)
100644.19 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav
100644.22 4 tw wav->vox convert end 28265,C:\Program Files\VoiceGuide\system\Bangla Voice\7.vox,1,0,,
100644.25 4 play start ok, lPlayId=28312
100644.81 4 tw PlayEnd 4 28312
100644.81 4 play end id=28312, (current ID)
100644.83 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
100644.83 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100644.84 4 path {EV_PLAY_FINISHED} not found
100644.86 4 timer set 5 EV_TIMEOUT_REPLAYMSG
100644.86 4 tw DialogicEvent 129,TDX_PLAY,28312,0,0,,,
100644.88 4 event TDX_PLAY, iCode=129 state=1101
100644.89 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
100644.89 4 path {TDX_PLAY} not found
100648.39 0 btn Hangup on line 1
100648.41 1 event EV_TIMEOUT_HANGUP, iCode=9001 state=0
100650.27 4 timer fired EV_TIMEOUT_REPLAYMSG
100650.27 4 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101
100650.28 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
100650.28 4 path {EV_TIMEOUT_REPLAYMSG} not found
100650.30 4 state [say Bal 1] Playing (C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav)
100650.31 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav
100650.31 4 tw wav->vox convert end 34390,C:\Program Files\VoiceGuide\system\Bangla Voice\7.vox,1,0,,
100650.34 4 play start ok, lPlayId=34406
100650.91 4 tw PlayEnd 4 34406
100650.91 4 play end id=34406, (current ID)
100650.92 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
100650.94 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100650.94 4 path {EV_PLAY_FINISHED} not found
100650.95 4 timer set 5 EV_TIMEOUT_REPLAYMSG
100650.95 4 tw DialogicEvent 129,TDX_PLAY,34406,0,0,,,
100650.97 4 event TDX_PLAY, iCode=129 state=1101
100650.98 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
100650.98 4 path {TDX_PLAY} not found
100654.61 0 btn Hangup on line 1
100654.63 1 event EV_TIMEOUT_HANGUP, iCode=9001 state=0
100656.36 4 timer fired EV_TIMEOUT_REPLAYMSG
100656.36 4 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101
100656.38 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
100656.38 4 path {EV_TIMEOUT_REPLAYMSG} not found
100656.39 4 state [say Bal 1] Playing (C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav)
100656.41 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav
100656.41 4 tw wav->vox convert end 40484,C:\Program Files\VoiceGuide\system\Bangla Voice\7.vox,1,0,,
100656.44 4 play start ok, lPlayId=40500
100656.45 4 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,DISCONNECT_TAPI2,
100656.45 4 event DISCONNECT_TAPI2, iCode=134 state=1100
100656.47 4 LsPlayMsg EV_UNKNOWN_134,DISCONNECT_TAPI2
100656.48 4 path {DISCONNECT_TAPI2} not found
100656.48 4 HangupCall start (Default Handler 20: DISCONNECT_TAPI2)
100656.50 4 rv add [Hangup Time]{01/10/2007 10:06:56 AM}
100656.50 4 state Hanging up call... [Default Handler 20: DISCONNECT_TAPI2]
100656.52 4 HangupCall_Common hCall=4
100656.55 4 rec RecSoundStop ok
100656.55 4 play PlayStop ok
100656.56 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
100656.58 4 fnHangupCall end
100656.58 4 event TDX_CST, iCode=134 state=900
100656.59 4 LsAwaitingCalls EV_UNKNOWN_134
100656.61 4 tw PlayEnd 4 40500
100656.61 4 play end id=40500, (current ID)
100656.63 4 event EV_PLAY_FINISHED, iCode=8001 state=900
100656.63 4 LsAwaitingCalls EV_PLAY_FINISHED
100656.64 4 tw DialogicEvent 129,TDX_PLAY,40500,0,0,,,
100656.66 4 event TDX_PLAY, iCode=129 state=900
100656.66 4 LsAwaitingCalls EV_UNKNOWN_129
100656.67 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
100656.69 4 event TDX_SETHOOK, iCode=135 state=900
100656.69 4 LsAwaitingCalls EV_UNKNOWN_135
100656.70 4 event callstate IDLE 4 1,0,0
100656.70 4 WorkingMode@Idle=
100656.72 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
100656.73 4 timer clear
100656.73 4 rec RecSoundStop ok
100656.75 4 play PlayStop ok
100656.77 4 rv add [CallEndTime]{01/10/2007 10:06:56 AM}
100656.80 4 on-hangup script:[]
100656.81 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
100656.81 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
100656.83 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
100656.83 4 init atidle reinit : start
100656.84 4 init atidle reinit iConferenceOtherLegLid=-1
100656.86 4 init atidle reinit : reset all LineState variables
100656.86 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100656.88 4 state Waiting for a call...
100659.64 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100659.64 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
100659.66 4 setting iDialoutReadyToDialout = 1
100741.77 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100741.78 MemStructVgs_ClearVgs [3]
100741.86 load end
100741.86 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
100741.88 0 Erasing Script (new loaded) Id 4
100741.89 0 VgsScriptFree [4]
100741.89 MemStructVgs_ClearVgs [4]
100749.91 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100749.91 MemStructVgs_ClearVgs [4]
100749.98 load end
100750.00 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
100750.00 0 Erasing Script (new loaded) Id 3
100750.02 0 VgsScriptFree [3]
100750.03 MemStructVgs_ClearVgs [3]
100808.03 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100808.05 MemStructVgs_ClearVgs [3]
100808.11 load end
100808.13 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
100808.14 0 Erasing Script (new loaded) Id 4
100808.14 0 VgsScriptFree [4]
100808.16 MemStructVgs_ClearVgs [4]
100819.17 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100819.19 MemStructVgs_ClearVgs [4]
100819.27 load end
100819.27 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
100819.28 0 Erasing Script (new loaded) Id 3
100819.30 0 VgsScriptFree [3]
100819.30 MemStructVgs_ClearVgs [3]
100828.31 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100828.31 MemStructVgs_ClearVgs [3]
100828.39 load end
100828.41 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
100828.41 0 Erasing Script (new loaded) Id 4
100828.42 0 VgsScriptFree [4]
100828.42 MemStructVgs_ClearVgs [4]
100837.08 4 event callstate OFFERING 4 2,0,0
100837.08 4 script interpretor: VgMulti v6.0.3243
100837.09 4 fired OFFERING event to listeners
100837.11 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
100837.11 4 cid CallerID vars set (in 'offering' event) [,,]
100837.13 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
100837.13 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
100837.14 4 tw ring 1
100837.16 4 ring time since last ring event (sec): 0.00
100837.16 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
100837.17 4 should answer as number of rings reached
100837.19 4 rv clear all
100837.19 4 init LineState ResetAtStartOfNewCall.
100837.20 4 answering the call (,,,0)
100837.22 4 timer clear
100837.22 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
100837.23 4 event TDX_CST, iCode=134 state=6001
100837.25 4 LsModuleTransition : 134, [TDX_CST]
100837.86 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
100837.86 4 event TDX_SETHOOK, iCode=135 state=6001
100837.88 4 LsModuleTransition : 135, [TDX_SETHOOK]
100837.89 4 event callstate CONNECTED 4 256,0,0
100837.89 4 LineEvCallState_Connected hDevice=4 params=256,0,0
100837.91 4 WorkingModes tapi= script= LineState().iState=6001
100837.92 4 Inband detection not enabled
100837.94 4 StartLoadedVgs at 01/10/2007 10:08:37 AM (VgMulti v6.0.3243)
100837.94 4 set LineState().iVgsIdx=1
100837.95 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
100837.97 4 init StartLoadedVgs_InitLineState start
100837.97 4 rv add [$RV_STARTTIME]{01/10/2007 10:08:37 AM}
100837.98 4 rv add [$RV_DEVICEID]{4}
100837.98 4 rv add [DlgcNetworkResource]{dxxxB1C4}
100838.00 4 rv add [DlgcVoiceResource]{dxxxB1C4}
100838.02 4 rv add [$RV_CIDNAME]{}
100838.02 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
100838.03 4 rvns add [scriptsPath]{G:\TeleBanking System\}
100838.05 4 rv add [$RV_CIDNUMBER]{}
100838.05 4 fn RunModule start [Play,[Get Language],1,,]
100838.06 4 tw DialogicEvent 134,TDX_CST,10123,0,0,DE_LCON,,
100838.08 4 event TDX_CST, iCode=134 state=6001
100838.08 4 LsModuleTransition : 134, [TDX_CST]
100838.09 4 timer clear
100838.11 4 Play Module start
100838.13 4 state [Get Language] Playing
100838.13 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
100838.14 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
100838.19 4 tw wav->vox convert end 142218,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
100838.20 4 play start ok, lPlayId=142281
100838.86 4 tw dtmf 1 (4,49,49)
100838.86 4 event 1, iCode=49 state=1100
100838.88 4 LsPlayMsg 1,1
100838.89 4 rv add [scriptEnd_Time]{01/10/2007 10:08:38 AM}
100838.89 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
100838.91 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
100838.94 4 rv add [scriptStart_Time]{01/10/2007 10:08:38 AM}
100838.95 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
100838.95 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
100838.97 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100838.98 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3
100838.98 4 rvns add [scriptsPath]{G:\TeleBanking System\}
100839.02 4 play PlayStop ok
100839.02 4 rv add [Get Language]{1}
100839.03 4 fn RunModule start [Evaluate,[Get Bangla],65,,]
100839.05 4 tw PlayEnd 4 142281
100839.05 4 play end id=142281, (current ID)
100839.06 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100839.08 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100839.08 4 tw DialogicEvent 129,TDX_PLAY,142281,0,0,,,
100839.09 4 event TDX_PLAY, iCode=129 state=6001
100839.09 4 LsModuleTransition : 129, [TDX_PLAY]
100839.13 4 timer clear
100839.13 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
100839.14 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
100839.16 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
100839.16 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100839.17 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
100839.19 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
100839.19 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
100839.20 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
100839.22 4 matching path not found
100839.22 4 next module is
  1. (idx=66)
100839.23 4 matching path was found
100839.25 4 fn RunModule start [Play,
  1. ,66,,]
100839.25 4 timer clear
100839.27 4 Play Module start
100839.28 4 state
  1. Playing
100839.28 4 state
  1. Playing (Bangla Voice\Service List.wav)
100839.30 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
100839.31 4 tw wav->vox convert end 143375,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
100839.33 4 play start ok, lPlayId=143406
100840.05 4 tw dtmf 1 (4,49,49)
100840.06 4 event 1, iCode=49 state=1100
100840.08 4 LsPlayMsg 1,1
100840.08 4 next module is [Get Acc No] (idx=86)
100840.11 4 play PlayStop ok
100840.11 4 rv add
  1. {1}
100840.13 4 fn RunModule start [Get Numbers,[Get Acc No],86,,]
100840.14 4 tw PlayEnd 4 143406
100840.14 4 play end id=143406, (current ID)
100840.16 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
100840.16 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
100840.17 4 tw DialogicEvent 129,TDX_PLAY,143406,0,0,,,
100840.19 4 event TDX_PLAY, iCode=129 state=6001
100840.19 4 LsModuleTransition : 129, [TDX_PLAY]
100840.22 4 timer clear
100840.22 4 state [Get Acc No] Number Input
100840.23 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
100840.25 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
100840.28 4 tw wav->vox convert end 144328,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
100840.30 4 play start ok, lPlayId=144375
100842.25 4 tw dtmf 0 (4,48,48)
100842.27 4 event 0, iCode=48 state=1300
100842.27 4 LsGetNbrsPlayWelcMsg 0,0
100842.30 4 play PlayStop ok
100842.31 4 state [Get Acc No] Number Input 0
100842.31 4 path {0} not found
100842.33 4 timer set 6 EV_TIMEOUT_ENTERDATA
100842.34 4 tw PlayEnd 4 144375
100842.34 4 play end id=144375, (current ID)
100842.36 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
100842.38 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
100842.38 4 path {EV_PLAY_FINISHED} not found
100842.39 4 awaiting further dtmf input
100842.41 4 tw DialogicEvent 129,TDX_PLAY,144375,0,0,,,
100842.41 4 event TDX_PLAY, iCode=129 state=1301
100842.42 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
100842.44 4 path {TDX_PLAY} not found
100842.44 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100842.45 4 event FAX, iCode=134 state=1301
100842.47 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100842.47 4 path {FAX} not found
100842.48 4 event TDX_CST, iCode=134 state=1301
100842.50 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100842.50 4 path {TDX_CST} not found
100842.63 4 tw dtmf 1 (4,49,49)
100842.64 4 event 1, iCode=49 state=1301
100842.64 4 LsGetNbrsRxDigits 1,1
100842.66 4 state [Get Acc No] Number Input 01
100842.66 4 path {01} not found
100842.67 4 timer set 6 EV_TIMEOUT_ENTERDATA
100843.00 4 tw dtmf 7 (4,55,55)
100843.02 4 event 7, iCode=55 state=1301
100843.03 4 LsGetNbrsRxDigits 7,7
100843.03 4 state [Get Acc No] Number Input 017
100843.05 4 path {017} not found
100843.06 4 timer set 6 EV_TIMEOUT_ENTERDATA
100843.53 4 tw dtmf 3 (4,51,51)
100843.55 4 event 3, iCode=51 state=1301
100843.56 4 LsGetNbrsRxDigits 3,3
100843.56 4 state [Get Acc No] Number Input 0173
100843.58 4 path {0173} not found
100843.58 4 timer set 6 EV_TIMEOUT_ENTERDATA
100844.03 4 tw dtmf 4 (4,52,52)
100844.05 4 event 4, iCode=52 state=1301
100844.06 4 LsGetNbrsRxDigits 4,4
100844.06 4 state [Get Acc No] Number Input 01734
100844.08 4 path {01734} not found
100844.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
100844.52 4 tw dtmf 0 (4,48,48)
100844.53 4 event 0, iCode=48 state=1301
100844.53 4 LsGetNbrsRxDigits 0,0
100844.55 4 state [Get Acc No] Number Input 017340
100844.56 4 path {017340} not found
100844.58 4 timer set 6 EV_TIMEOUT_ENTERDATA
100844.81 4 tw dtmf 0 (4,48,48)
100844.81 4 event 0, iCode=48 state=1301
100844.83 4 LsGetNbrsRxDigits 0,0
100844.84 4 state [Get Acc No] Number Input 0173400
100844.84 4 path {0173400} not found
100844.86 4 timer set 6 EV_TIMEOUT_ENTERDATA
100845.02 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100845.03 4 event FAX, iCode=134 state=1301
100845.05 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100845.05 4 path {FAX} not found
100845.06 4 event TDX_CST, iCode=134 state=1301
100845.08 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100845.08 4 path {TDX_CST} not found
100845.23 4 tw dtmf 0 (4,48,48)
100845.25 4 event 0, iCode=48 state=1301
100845.27 4 LsGetNbrsRxDigits 0,0
100845.27 4 state [Get Acc No] Number Input 01734000
100845.28 4 path {01734000} not found
100845.30 4 timer set 6 EV_TIMEOUT_ENTERDATA
100845.73 4 tw dtmf 2 (4,50,50)
100845.73 4 event 2, iCode=50 state=1301
100845.75 4 LsGetNbrsRxDigits 2,2
100845.77 4 state [Get Acc No] Number Input 017340002
100845.77 4 path {017340002} not found
100845.78 4 timer set 6 EV_TIMEOUT_ENTERDATA
100846.11 4 tw dtmf 4 (4,52,52)
100846.11 4 event 4, iCode=52 state=1301
100846.13 4 LsGetNbrsRxDigits 4,4
100846.14 4 state [Get Acc No] Number Input 0173400024
100846.14 4 path {0173400024} not found
100846.16 4 timer set 6 EV_TIMEOUT_ENTERDATA
100846.45 4 tw dtmf 5 (4,53,53)
100846.47 4 event 5, iCode=53 state=1301
100846.47 4 LsGetNbrsRxDigits 5,5
100846.48 4 state [Get Acc No] Number Input 01734000245
100846.48 4 path {01734000245} not found
100846.50 4 timer set 6 EV_TIMEOUT_ENTERDATA
100852.97 4 timer fired EV_TIMEOUT_ENTERDATA
100852.97 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
100852.98 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
100853.00 4 path {EV_TIMEOUT_ENTERDATA} not found
100853.00 4 timer clear
100853.02 4 rv add [Get Acc No]{01734000245}
100853.03 4 path {01734000245} not found
100853.03 4 next module is [Varify A/C] (idx=84)
100853.05 4 rvns add [Get Acc No_PathTaken]{success}
100853.06 4 fn RunModule start [Database Query,[Varify A/C],84,,]
100853.06 4 timer clear
100853.08 4 state [Varify A/C] DB Query
100853.09 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
100853.13 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
100853.14 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:08:37 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:08:38 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:08:38 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
  1. {1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}
100853.14 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
100853.16 4 db [Varify A/C] row count=1
100853.17 4 rv add [Varify A/C_RowCount]{1}
100853.19 4 db get RecordsetGetRowsMax
100853.19 4 db get 999 records. (row count=1)
100853.20 4 db update RVs
100853.22 4 db about to close dbDbqDatabase
100853.22 4 db going down path [True]
100853.23 4 next module is [Get PIN No] (idx=4)
100853.25 4 fn RunModule start [Get Numbers,[Get PIN No],4,,]
100853.27 4 timer clear
100853.28 4 state [Get PIN No] Number Input
100853.28 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
100853.30 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
100853.33 4 tw wav->vox convert end 157375,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
100853.34 4 play start ok, lPlayId=157421
100855.69 4 tw dtmf 3 (4,51,51)
100855.70 4 event 3, iCode=51 state=1300
100855.72 4 LsGetNbrsPlayWelcMsg 3,3
100855.73 4 play PlayStop ok
100855.75 4 state [Get PIN No] Number Input 3
100855.77 4 path {3} not found
100855.77 4 timer set 6 EV_TIMEOUT_ENTERDATA
100855.78 4 tw PlayEnd 4 157421
100855.80 4 play end id=157421, (current ID)
100855.80 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
100855.81 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
100855.83 4 path {EV_PLAY_FINISHED} not found
100855.83 4 awaiting further dtmf input
100855.84 4 tw DialogicEvent 129,TDX_PLAY,157421,0,0,,,
100855.84 4 event TDX_PLAY, iCode=129 state=1301
100855.86 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
100855.88 4 path {TDX_PLAY} not found
100856.11 4 tw dtmf 8 (4,56,56)
100856.13 4 event 8, iCode=56 state=1301
100856.13 4 LsGetNbrsRxDigits 8,8
100856.14 4 state [Get PIN No] Number Input 38
100856.16 4 path {38} not found
100856.16 4 timer set 6 EV_TIMEOUT_ENTERDATA
100856.50 4 tw dtmf 0 (4,48,48)
100856.50 4 event 0, iCode=48 state=1301
100856.52 4 LsGetNbrsRxDigits 0,0
100856.53 4 state [Get PIN No] Number Input 380
100856.53 4 path {380} not found
100856.55 4 timer set 6 EV_TIMEOUT_ENTERDATA
100856.72 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
100856.72 4 event FAX, iCode=134 state=1301
100856.73 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
100856.73 4 path {FAX} not found
100856.75 4 event TDX_CST, iCode=134 state=1301
100856.77 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
100856.77 4 path {TDX_CST} not found
100856.91 4 tw dtmf 4 (4,52,52)
100856.92 4 event 4, iCode=52 state=1301
100856.94 4 LsGetNbrsRxDigits 4,4
100856.94 4 state [Get PIN No] Number Input 3804
100856.95 4 path {3804} not found
100856.97 4 timer set 6 EV_TIMEOUT_ENTERDATA
100856.97 4 timer clear
100856.98 4 rv add [Get PIN No]{3804}
100857.00 4 path {3804} not found
100857.00 4 next module is [Varify A/C No] (idx=69)
100857.02 4 rvns add [Get PIN No_PathTaken]{success}
100857.03 4 fn RunModule start [Database Query,[Varify A/C No],69,,]
100857.03 4 timer clear
100857.05 4 state [Varify A/C No] DB Query
100857.06 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
100857.09 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
100857.11 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:08:37 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}
100857.11 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
100857.13 4 db [Varify A/C No] row count=1
100857.14 4 rv add [Varify A/C No_RowCount]{1}
100857.16 4 db get RecordsetGetRowsMax
100857.16 4 db get 999 records. (row count=1)
100857.17 4 db update RVs
100857.19 4 db about to close dbDbqDatabase
100857.20 4 db going down path [True]
100857.20 4 next module is
  1. (idx=46)
100857.22 4 fn RunModule start [Play,
  1. ,46,,]
100857.22 4 timer clear
100857.23 4 Play Module start
100857.25 4 state
  1. Playing
100857.25 4 state
  1. Playing (Bangla Voice\Acc List.wav)
100857.27 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
100857.30 4 tw wav->vox convert end 161343,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
100857.31 4 play start ok, lPlayId=161375
100909.94 4 tw PlayEnd 4 161375
100909.94 4 play end id=161375, (current ID)
100909.95 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
100909.97 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100909.97 4 path {EV_PLAY_FINISHED} not found
100909.98 4 timer set 7 EV_TIMEOUT_REPLAYMSG
100910.00 4 tw DialogicEvent 129,TDX_PLAY,161375,0,0,,,
100910.00 4 event TDX_PLAY, iCode=129 state=1101
100910.02 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
100910.03 4 path {TDX_PLAY} not found
100910.56 4 tw dtmf 1 (4,49,49)
100910.56 4 event 1, iCode=49 state=1101
100910.58 4 LsPlayMsgFinished 1,1
100910.59 4 next module is [say Bal 1] (idx=85)
100910.59 4 rv add
  1. {1}
100910.61 4 fn RunModule start [say Numbers,[say Bal 1],85,,]
100910.63 4 timer clear
100910.63 4 state [say Bal 1] Say numbers: 7 as Number
100910.64 4 fn PlaySoundStartNumbers [],[],[7],Number
100910.66 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
100910.66 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
100910.67 4 rv add [Hangup Time]{01/10/2007 10:09:10 AM}
100910.69 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
100910.69 4 HangupCall_Common hCall=4
100910.70 4 rec RecSoundStop ok
100910.72 4 play PlayStop ok
100910.72 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
100910.73 4 fnHangupCall end
100910.78 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
100910.80 4 event TDX_SETHOOK, iCode=135 state=900
100910.80 4 LsAwaitingCalls EV_UNKNOWN_135
100910.81 4 event callstate IDLE 4 1,0,0
100910.83 4 WorkingMode@Idle=
100910.83 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
100910.84 4 timer clear
100910.86 4 rec RecSoundStop ok
100910.86 4 play PlayStop ok
100910.88 4 rv add [CallEndTime]{01/10/2007 10:09:10 AM}
100910.91 4 on-hangup script:[]
100910.92 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
100910.94 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
100910.94 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
100910.95 4 init atidle reinit : start
100910.95 4 init atidle reinit iConferenceOtherLegLid=-1
100910.97 4 init atidle reinit : reset all LineState variables
100910.98 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100910.98 4 state Waiting for a call...
100913.19 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
100913.19 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
100913.20 4 setting iDialoutReadyToDialout = 1
100921.58 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
100921.59 MemStructVgs_ClearVgs [4]
100921.59 load end
100921.61 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Main.vgs
100921.63 0 Erasing Script (new loaded) Id 1
100921.64 0 VgsScriptFree [1]
100921.66 MemStructVgs_ClearVgs [1]
100934.66 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
100934.67 MemStructVgs_ClearVgs [1]
100934.73 load end
100934.75 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs
100934.77 0 Erasing Script (new loaded) Id 3
100934.77 0 VgsScriptFree [3]
100934.78 MemStructVgs_ClearVgs [3]
101304.22 0 sys cleanup Start
101304.22 0 sys cleanup End
101356.81 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
101356.81 MemStructVgs_ClearVgs [3]
101356.91 load end
101356.91 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
101356.92 0 Erasing Script (new loaded) Id 1
101356.94 0 VgsScriptFree [1]
101356.94 MemStructVgs_ClearVgs [1]
101404.97 4 event callstate OFFERING 4 2,0,0
101404.98 4 script interpretor: VgMulti v6.0.3243
101405.00 4 fired OFFERING event to listeners
101405.00 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
101405.02 4 cid CallerID vars set (in 'offering' event) [,,]
101405.03 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
101405.03 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
101405.05 4 tw ring 1
101405.06 4 ring time since last ring event (sec): 0.00
101405.06 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
101405.08 4 should answer as number of rings reached
101405.08 4 rv clear all
101405.09 4 init LineState ResetAtStartOfNewCall.
101405.11 4 answering the call (,,,0)
101405.11 4 timer clear
101405.13 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
101405.14 4 event TDX_CST, iCode=134 state=6001
101405.16 4 LsModuleTransition : 134, [TDX_CST]
101405.75 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
101405.77 4 event TDX_SETHOOK, iCode=135 state=6001
101405.78 4 LsModuleTransition : 135, [TDX_SETHOOK]
101405.78 4 event callstate CONNECTED 4 256,0,0
101405.80 4 LineEvCallState_Connected hDevice=4 params=256,0,0
101405.81 4 WorkingModes tapi= script= LineState().iState=6001
101405.81 4 Inband detection not enabled
101405.83 4 StartLoadedVgs at 01/10/2007 10:14:05 AM (VgMulti v6.0.3243)
101405.84 4 set LineState().iVgsIdx=4
101405.84 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
101405.86 4 init StartLoadedVgs_InitLineState start
101405.88 4 rv add [$RV_STARTTIME]{01/10/2007 10:14:05 AM}
101405.88 4 rv add [$RV_DEVICEID]{4}
101405.89 4 rv add [DlgcNetworkResource]{dxxxB1C4}
101405.89 4 rv add [DlgcVoiceResource]{dxxxB1C4}
101405.91 4 rv add [$RV_CIDNAME]{}
101405.92 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
101405.92 4 rvns add [scriptsPath]{G:\TeleBanking System\}
101405.94 4 rv add [$RV_CIDNUMBER]{}
101405.95 4 fn RunModule start [Play,[Get Language],129,,]
101405.95 4 tw DialogicEvent 134,TDX_CST,29497,0,0,DE_LCON,,
101405.97 4 event TDX_CST, iCode=134 state=6001
101405.98 4 LsModuleTransition : 134, [TDX_CST]
101405.98 4 timer clear
101406.00 4 Play Module start
101406.00 4 state [Get Language] Playing
101406.02 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
101406.03 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
101406.08 4 tw wav->vox convert end 470109,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
101406.11 4 play start ok, lPlayId=470171
101408.00 4 tw dtmf 1 (4,49,49)
101408.00 4 event 1, iCode=49 state=1100
101408.02 4 LsPlayMsg 1,1
101408.03 4 rv add [scriptEnd_Time]{01/10/2007 10:14:08 AM}
101408.03 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
101408.05 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
101408.08 4 rv add [scriptStart_Time]{01/10/2007 10:14:08 AM}
101408.08 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
101408.09 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
101408.11 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
101408.11 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3
101408.13 4 rvns add [scriptsPath]{G:\TeleBanking System\}
101408.16 4 play PlayStop ok
101408.16 4 rv add [Get Language]{1}
101408.17 4 fn RunModule start [Evaluate,[Get Bangla],64,,]
101408.17 4 tw PlayEnd 4 470171
101408.19 4 play end id=470171, (current ID)
101408.20 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
101408.20 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
101408.22 4 tw DialogicEvent 129,TDX_PLAY,470171,0,0,,,
101408.23 4 event TDX_PLAY, iCode=129 state=6001
101408.23 4 LsModuleTransition : 129, [TDX_PLAY]
101408.25 4 timer clear
101408.27 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
101408.27 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
101408.28 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
101408.30 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
101408.30 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
101408.31 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
101408.31 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
101408.33 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
101408.34 4 matching path not found
101408.34 4 next module is
  1. (idx=63)
101408.36 4 matching path was found
101408.38 4 fn RunModule start [Play,
  1. ,63,,]
101408.38 4 timer clear
101408.39 4 Play Module start
101408.41 4 state
  1. Playing
101408.41 4 state
101408.42 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
101408.47 4 tw wav->vox convert end 472500,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
101408.48 4 play start ok, lPlayId=472546
101411.28 4 tw dtmf 1 (4,49,49)
101411.30 4 event 1, iCode=49 state=1100
101411.30 4 LsPlayMsg 1,1
101411.31 4 next module is [Get Acc No] (idx=85)
101411.33 4 play PlayStop ok
101411.34 4 rv add
  1. {1}
101411.34 4 fn RunModule start [Get Numbers,[Get Acc No],85,,]
101411.36 4 tw PlayEnd 4 472546
101411.38 4 play end id=472546, (current ID)
101411.38 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
101411.39 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
101411.41 4 tw DialogicEvent 129,TDX_PLAY,472546,0,0,,,
101411.41 4 event TDX_PLAY, iCode=129 state=6001
101411.42 4 LsModuleTransition : 129, [TDX_PLAY]
101411.44 4 timer clear
101411.44 4 state [Get Acc No] Number Input
101411.45 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
101411.45 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
101411.52 4 tw wav->vox convert end 475531,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
101411.53 4 play start ok, lPlayId=475609
101415.34 4 tw dtmf 0 (4,48,48)
101415.34 4 event 0, iCode=48 state=1300
101415.36 4 LsGetNbrsPlayWelcMsg 0,0
101415.38 4 play PlayStop ok
101415.38 4 state [Get Acc No] Number Input 0
101415.39 4 path {0} not found
101415.41 4 timer set 6 EV_TIMEOUT_ENTERDATA
101415.41 4 tw PlayEnd 4 475609
101415.42 4 play end id=475609, (current ID)
101415.42 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
101415.44 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
101415.45 4 path {EV_PLAY_FINISHED} not found
101415.45 4 awaiting further dtmf input
101415.47 4 tw DialogicEvent 129,TDX_PLAY,475609,0,0,,,
101415.48 4 event TDX_PLAY, iCode=129 state=1301
101415.48 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
101415.50 4 path {TDX_PLAY} not found
101415.75 4 tw dtmf 1 (4,49,49)
101415.75 4 event 1, iCode=49 state=1301
101415.77 4 LsGetNbrsRxDigits 1,1
101415.78 4 state [Get Acc No] Number Input 01
101415.78 4 path {01} not found
101415.80 4 timer set 6 EV_TIMEOUT_ENTERDATA
101416.17 4 tw dtmf 7 (4,55,55)
101416.19 4 event 7, iCode=55 state=1301
101416.20 4 LsGetNbrsRxDigits 7,7
101416.20 4 state [Get Acc No] Number Input 017
101416.22 4 path {017} not found
101416.22 4 timer set 6 EV_TIMEOUT_ENTERDATA
101416.75 4 tw dtmf 3 (4,51,51)
101416.77 4 event 3, iCode=51 state=1301
101416.77 4 LsGetNbrsRxDigits 3,3
101416.78 4 state [Get Acc No] Number Input 0173
101416.80 4 path {0173} not found
101416.80 4 timer set 6 EV_TIMEOUT_ENTERDATA
101417.27 4 tw dtmf 4 (4,52,52)
101417.28 4 event 4, iCode=52 state=1301
101417.28 4 LsGetNbrsRxDigits 4,4
101417.30 4 state [Get Acc No] Number Input 01734
101417.31 4 path {01734} not found
101417.31 4 timer set 6 EV_TIMEOUT_ENTERDATA
101417.77 4 tw dtmf 0 (4,48,48)
101417.77 4 event 0, iCode=48 state=1301
101417.78 4 LsGetNbrsRxDigits 0,0
101417.80 4 state [Get Acc No] Number Input 017340
101417.80 4 path {017340} not found
101417.81 4 timer set 6 EV_TIMEOUT_ENTERDATA
101418.14 4 tw dtmf 0 (4,48,48)
101418.16 4 event 0, iCode=48 state=1301
101418.17 4 LsGetNbrsRxDigits 0,0
101418.17 4 state [Get Acc No] Number Input 0173400
101418.19 4 path {0173400} not found
101418.19 4 timer set 6 EV_TIMEOUT_ENTERDATA
101418.45 4 tw dtmf 0 (4,48,48)
101418.47 4 event 0, iCode=48 state=1301
101418.47 4 LsGetNbrsRxDigits 0,0
101418.48 4 state [Get Acc No] Number Input 01734000
101418.50 4 path {01734000} not found
101418.50 4 timer set 6 EV_TIMEOUT_ENTERDATA
101418.97 4 tw dtmf 2 (4,50,50)
101418.98 4 event 2, iCode=50 state=1301
101419.00 4 LsGetNbrsRxDigits 2,2
101419.02 4 state [Get Acc No] Number Input 017340002
101419.02 4 path {017340002} not found
101419.03 4 timer set 6 EV_TIMEOUT_ENTERDATA
101419.41 4 tw dtmf 4 (4,52,52)
101419.42 4 event 4, iCode=52 state=1301
101419.42 4 LsGetNbrsRxDigits 4,4
101419.44 4 state [Get Acc No] Number Input 0173400024
101419.45 4 path {0173400024} not found
101419.45 4 timer set 6 EV_TIMEOUT_ENTERDATA
101419.69 4 tw dtmf 5 (4,53,53)
101419.70 4 event 5, iCode=53 state=1301
101419.72 4 LsGetNbrsRxDigits 5,5
101419.72 4 state [Get Acc No] Number Input 01734000245
101419.73 4 path {01734000245} not found
101419.75 4 timer set 6 EV_TIMEOUT_ENTERDATA
101426.20 4 timer fired EV_TIMEOUT_ENTERDATA
101426.20 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
101426.22 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
101426.23 4 path {EV_TIMEOUT_ENTERDATA} not found
101426.23 4 timer clear
101426.25 4 rv add [Get Acc No]{01734000245}
101426.25 4 path {01734000245} not found
101426.27 4 next module is [Varify A/C] (idx=4)
101426.28 4 rvns add [Get Acc No_PathTaken]{success}
101426.28 4 fn RunModule start [Database Query,[Varify A/C],4,,]
101426.30 4 timer clear
101426.31 4 state [Varify A/C] DB Query
101426.31 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
101426.36 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
101426.38 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:14:05 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:14:08 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:14:08 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
101426.38 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
101426.39 4 db [Varify A/C] row count=1
101426.41 4 rv add [Varify A/C_RowCount]{1}
101426.41 4 db get RecordsetGetRowsMax
101426.42 4 db get 999 records. (row count=1)
101426.44 4 db update RVs
101426.44 4 db about to close dbDbqDatabase
101426.45 4 db going down path [True]
101426.47 4 next module is [Get PIN No] (idx=84)
101426.47 4 fn RunModule start [Get Numbers,[Get PIN No],84,,]
101426.48 4 timer clear
101426.50 4 state [Get PIN No] Number Input
101426.50 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
101426.52 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
101426.55 4 tw wav->vox convert end 490593,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
101426.56 4 play start ok, lPlayId=490640
101429.17 4 tw dtmf 3 (4,51,51)
101429.19 4 event 3, iCode=51 state=1300
101429.19 4 LsGetNbrsPlayWelcMsg 3,3
101429.22 4 play PlayStop ok
101429.23 4 state [Get PIN No] Number Input 3
101429.23 4 path {3} not found
101429.25 4 timer set 6 EV_TIMEOUT_ENTERDATA
101429.27 4 tw PlayEnd 4 490640
101429.27 4 play end id=490640, (current ID)
101429.28 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
101429.30 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
101429.30 4 path {EV_PLAY_FINISHED} not found
101429.31 4 awaiting further dtmf input
101429.31 4 tw DialogicEvent 129,TDX_PLAY,490640,0,0,,,
101429.33 4 event TDX_PLAY, iCode=129 state=1301
101429.34 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
101429.34 4 path {TDX_PLAY} not found
101429.67 4 tw dtmf 8 (4,56,56)
101429.69 4 event 8, iCode=56 state=1301
101429.70 4 LsGetNbrsRxDigits 8,8
101429.70 4 state [Get PIN No] Number Input 38
101429.72 4 path {38} not found
101429.73 4 timer set 6 EV_TIMEOUT_ENTERDATA
101430.11 4 tw dtmf 0 (4,48,48)
101430.13 4 event 0, iCode=48 state=1301
101430.13 4 LsGetNbrsRxDigits 0,0
101430.14 4 state [Get PIN No] Number Input 380
101430.16 4 path {380} not found
101430.16 4 timer set 6 EV_TIMEOUT_ENTERDATA
101430.34 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
101430.34 4 event FAX, iCode=134 state=1301
101430.36 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
101430.36 4 path {FAX} not found
101430.38 4 event TDX_CST, iCode=134 state=1301
101430.39 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
101430.41 4 path {TDX_CST} not found
101430.55 4 tw dtmf 4 (4,52,52)
101430.55 4 event 4, iCode=52 state=1301
101430.56 4 LsGetNbrsRxDigits 4,4
101430.56 4 state [Get PIN No] Number Input 3804
101430.58 4 path {3804} not found
101430.59 4 timer set 6 EV_TIMEOUT_ENTERDATA
101430.59 4 timer clear
101430.61 4 rv add [Get PIN No]{3804}
101430.63 4 path {3804} not found
101430.63 4 next module is [Varify A/C No] (idx=60)
101430.64 4 rvns add [Get PIN No_PathTaken]{success}
101430.66 4 fn RunModule start [Database Query,[Varify A/C No],60,,]
101430.66 4 timer clear
101430.67 4 state [Varify A/C No] DB Query
101430.69 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
101430.72 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
101430.73 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:14:05 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
101430.75 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
101430.77 4 db [Varify A/C No] row count=1
101430.77 4 rv add [Varify A/C No_RowCount]{1}
101430.78 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
101430.80 4 event FAX, iCode=134 state=1400
101430.80 4 LsDbQuery EV_UNKNOWN_134
101430.81 4 event TDX_CST, iCode=134 state=1400
101430.83 4 LsDbQuery EV_UNKNOWN_134
101430.84 4 db get RecordsetGetRowsMax
101430.84 4 db get 999 records. (row count=1)
101430.86 4 db update RVs
101430.88 4 db about to close dbDbqDatabase
101430.88 4 db going down path [True]
101430.89 4 next module is
  1. (idx=83)
101430.91 4 fn RunModule start [Play,
  1. ,83,,]
101430.91 4 timer clear
101430.92 4 Play Module start
101430.94 4 state
  1. Playing
101430.94 4 state
101430.95 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
101430.97 4 tw wav->vox convert end 495031,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
101430.98 4 play start ok, lPlayId=495046
101432.89 4 tw dtmf 1 (4,49,49)
101432.91 4 event 1, iCode=49 state=1100
101432.91 4 LsPlayMsg 1,1
101432.92 4 next module is [say Bal 1] (idx=86)
101432.94 4 play PlayStop ok
101432.95 4 rv add
  1. {1}
101432.97 4 fn RunModule start [say Numbers,[say Bal 1],86,,]
101432.97 4 tw PlayEnd 4 495046
101432.98 4 play end id=495046, (current ID)
101433.00 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
101433.00 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
101433.02 4 tw DialogicEvent 129,TDX_PLAY,495046,0,0,,,
101433.02 4 event TDX_PLAY, iCode=129 state=6001
101433.03 4 LsModuleTransition : 129, [TDX_PLAY]
101433.05 4 timer clear
101433.05 4 state [say Bal 1] Say numbers: 7 as Number
101433.06 4 fn PlaySoundStartNumbers [],[],[7],Number
101433.08 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
101433.08 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
101433.09 4 rv add [Hangup Time]{01/10/2007 10:14:33 AM}
101433.11 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
101433.11 4 HangupCall_Common hCall=4
101433.13 4 rec RecSoundStop ok
101433.14 4 play PlayStop ok
101433.14 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
101433.16 4 fnHangupCall end
101433.20 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
101433.20 4 event TDX_SETHOOK, iCode=135 state=900
101433.22 4 LsAwaitingCalls EV_UNKNOWN_135
101433.23 4 event callstate IDLE 4 1,0,0
101433.23 4 WorkingMode@Idle=
101433.25 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
101433.25 4 timer clear
101433.27 4 rec RecSoundStop ok
101433.28 4 play PlayStop ok
101433.28 4 rv add [CallEndTime]{01/10/2007 10:14:33 AM}
101433.33 4 on-hangup script:[]
101433.33 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
101433.34 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
101433.36 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
101433.36 4 init atidle reinit : start
101433.38 4 init atidle reinit iConferenceOtherLegLid=-1
101433.38 4 init atidle reinit : reset all LineState variables
101433.39 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
101433.41 4 state Waiting for a call...
101435.59 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
101435.59 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
101435.61 4 setting iDialoutReadyToDialout = 1
101539.39 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
101539.39 MemStructVgs_ClearVgs [1]
101539.47 load end
101539.52 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs
101539.53 0 Erasing Script (new loaded) Id 3
101539.55 0 VgsScriptFree [3]
101539.55 MemStructVgs_ClearVgs [3]
101614.56 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
101614.58 MemStructVgs_ClearVgs [3]
101614.67 load end
101614.69 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
101614.70 0 Erasing Script (new loaded) Id 1
101614.70 0 VgsScriptFree [1]
101614.72 MemStructVgs_ClearVgs [1]
101842.22 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
101842.22 MemStructVgs_ClearVgs [1]
101842.30 load end
101842.31 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs
101842.33 0 Erasing Script (new loaded) Id 3
101842.33 0 VgsScriptFree [3]
101842.34 MemStructVgs_ClearVgs [3]
101952.36 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
101952.36 MemStructVgs_ClearVgs [3]
101952.44 load end
101952.45 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
101952.47 0 Erasing Script (new loaded) Id 1
101952.47 0 VgsScriptFree [1]
101952.48 MemStructVgs_ClearVgs [1]
102020.50 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
102020.50 MemStructVgs_ClearVgs [1]
102020.59 load end
102020.61 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs
102020.63 0 Erasing Script (new loaded) Id 3
102020.64 0 VgsScriptFree [3]
102020.66 MemStructVgs_ClearVgs [3]
102029.48 4 event callstate OFFERING 4 2,0,0
102029.50 4 script interpretor: VgMulti v6.0.3243
102029.50 4 fired OFFERING event to listeners
102029.52 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
102029.52 4 cid CallerID vars set (in 'offering' event) [,,]
102029.53 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
102029.55 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
102029.55 4 tw ring 1
102029.56 4 ring time since last ring event (sec): 0.00
102029.58 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
102029.58 4 should answer as number of rings reached
102029.59 4 rv clear all
102029.61 4 init LineState ResetAtStartOfNewCall.
102029.61 4 answering the call (,,,0)
102029.63 4 timer clear
102029.64 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
102029.66 4 event TDX_CST, iCode=134 state=6001
102029.66 4 LsModuleTransition : 134, [TDX_CST]
102030.27 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
102030.28 4 event TDX_SETHOOK, iCode=135 state=6001
102030.30 4 LsModuleTransition : 135, [TDX_SETHOOK]
102030.30 4 event callstate CONNECTED 4 256,0,0
102030.31 4 LineEvCallState_Connected hDevice=4 params=256,0,0
102030.33 4 WorkingModes tapi= script= LineState().iState=6001
102030.33 4 Inband detection not enabled
102030.34 4 StartLoadedVgs at 01/10/2007 10:20:30 AM (VgMulti v6.0.3243)
102030.36 4 set LineState().iVgsIdx=4
102030.36 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
102030.38 4 init StartLoadedVgs_InitLineState start
102030.39 4 rv add [$RV_STARTTIME]{01/10/2007 10:20:30 AM}
102030.39 4 rv add [$RV_DEVICEID]{4}
102030.41 4 rv add [DlgcNetworkResource]{dxxxB1C4}
102030.41 4 rv add [DlgcVoiceResource]{dxxxB1C4}
102030.42 4 rv add [$RV_CIDNAME]{}
102030.44 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
102030.44 4 rvns add [scriptsPath]{G:\TeleBanking System\}
102030.45 4 rv add [$RV_CIDNUMBER]{}
102030.47 4 fn RunModule start [Play,[Get Language],129,,]
102030.48 4 tw DialogicEvent 134,TDX_CST,35707,0,0,DE_LCON,,
102030.48 4 event TDX_CST, iCode=134 state=6001
102030.50 4 LsModuleTransition : 134, [TDX_CST]
102030.52 4 timer clear
102030.53 4 Play Module start
102030.55 4 state [Get Language] Playing
102030.55 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
102030.56 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
102030.61 4 tw wav->vox convert end 854640,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
102030.64 4 play start ok, lPlayId=854703
102031.52 4 tw dtmf 1 (4,49,49)
102031.53 4 event 1, iCode=49 state=1100
102031.53 4 LsPlayMsg 1,1
102031.55 4 rv add [scriptEnd_Time]{01/10/2007 10:20:31 AM}
102031.56 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
102031.56 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
102031.61 4 rv add [scriptStart_Time]{01/10/2007 10:20:31 AM}
102031.61 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
102031.63 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
102031.64 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
102031.64 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=1
102031.66 4 rvns add [scriptsPath]{G:\TeleBanking System\}
102031.69 4 play PlayStop ok
102031.70 4 rv add [Get Language]{1}
102031.70 4 fn RunModule start [Evaluate,[Get Bangla],109,,]
102031.72 4 tw PlayEnd 4 854703
102031.73 4 play end id=854703, (current ID)
102031.73 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
102031.75 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
102031.77 4 tw DialogicEvent 129,TDX_PLAY,854703,0,0,,,
102031.77 4 event TDX_PLAY, iCode=129 state=6001
102031.78 4 LsModuleTransition : 129, [TDX_PLAY]
102031.80 4 timer clear
102031.80 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
102031.81 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
102031.83 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
102031.83 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
102031.84 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
102031.86 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
102031.88 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
102031.88 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
102031.89 4 matching path not found
102031.89 4 next module is
  1. (idx=110)
102031.91 4 matching path was found
102031.92 4 fn RunModule start [Play,
  1. ,110,,]
102031.92 4 timer clear
102031.94 4 Play Module start
102031.95 4 state
  1. Playing
102031.95 4 state
102031.97 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
102031.98 4 tw wav->vox convert end 856046,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
102032.02 4 play start ok, lPlayId=856078
102033.31 4 tw dtmf 1 (4,49,49)
102033.33 4 event 1, iCode=49 state=1100
102033.34 4 LsPlayMsg 1,1
102033.34 4 next module is [Get Acc No] (idx=88)
102033.36 4 play PlayStop ok
102033.38 4 rv add
  1. {1}
102033.39 4 fn RunModule start [Get Numbers,[Get Acc No],88,,]
102033.39 4 tw PlayEnd 4 856078
102033.41 4 play end id=856078, (current ID)
102033.42 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
102033.42 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
102033.44 4 tw DialogicEvent 129,TDX_PLAY,856078,0,0,,,
102033.45 4 event TDX_PLAY, iCode=129 state=6001
102033.45 4 LsModuleTransition : 129, [TDX_PLAY]
102033.47 4 timer clear
102033.47 4 state [Get Acc No] Number Input
102033.48 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
102033.50 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
102033.52 4 tw wav->vox convert end 857578,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
102033.53 4 play start ok, lPlayId=857609
102037.34 4 tw PlayEnd 4 857609
102037.36 4 play end id=857609, (current ID)
102037.38 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
102037.38 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
102037.39 4 path {EV_PLAY_FINISHED} not found
102037.39 4 timer set 17 EV_TIMEOUT_REPLAYMSG
102037.41 4 tw DialogicEvent 129,TDX_PLAY,857609,0,0,,,
102037.42 4 event TDX_PLAY, iCode=129 state=1301
102037.42 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
102037.44 4 path {TDX_PLAY} not found
102037.45 4 tw dtmf 0 (4,48,48)
102037.45 4 event 0, iCode=48 state=1301
102037.47 4 LsGetNbrsRxDigits 0,0
102037.48 4 state [Get Acc No] Number Input 0
102037.48 4 path {0} not found
102037.50 4 timer set 6 EV_TIMEOUT_ENTERDATA
102037.64 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
102037.66 4 event FAX, iCode=134 state=1301
102037.67 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
102037.69 4 path {FAX} not found
102037.70 4 event TDX_CST, iCode=134 state=1301
102037.72 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
102037.72 4 path {TDX_CST} not found
102037.88 4 tw dtmf 1 (4,49,49)
102037.89 4 event 1, iCode=49 state=1301
102037.91 4 LsGetNbrsRxDigits 1,1
102037.91 4 state [Get Acc No] Number Input 01
102037.92 4 path {01} not found
102037.94 4 timer set 6 EV_TIMEOUT_ENTERDATA
102038.11 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
102038.11 4 event FAX, iCode=134 state=1301
102038.13 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
102038.14 4 path {FAX} not found
102038.14 4 event TDX_CST, iCode=134 state=1301
102038.16 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
102038.17 4 path {TDX_CST} not found
102038.31 4 tw dtmf 7 (4,55,55)
102038.31 4 event 7, iCode=55 state=1301
102038.33 4 LsGetNbrsRxDigits 7,7
102038.34 4 state [Get Acc No] Number Input 017
102038.36 4 path {017} not found
102038.36 4 timer set 6 EV_TIMEOUT_ENTERDATA
102038.83 4 tw dtmf 3 (4,51,51)
102038.84 4 event 3, iCode=51 state=1301
102038.86 4 LsGetNbrsRxDigits 3,3
102038.88 4 state [Get Acc No] Number Input 0173
102038.88 4 path {0173} not found
102038.89 4 timer set 6 EV_TIMEOUT_ENTERDATA
102039.41 4 tw dtmf 4 (4,52,52)
102039.41 4 event 4, iCode=52 state=1301
102039.42 4 LsGetNbrsRxDigits 4,4
102039.44 4 state [Get Acc No] Number Input 01734
102039.44 4 path {01734} not found
102039.45 4 timer set 6 EV_TIMEOUT_ENTERDATA
102039.95 4 tw dtmf 0 (4,48,48)
102039.97 4 event 0, iCode=48 state=1301
102039.97 4 LsGetNbrsRxDigits 0,0
102039.98 4 state [Get Acc No] Number Input 017340
102040.00 4 path {017340} not found
102040.00 4 timer set 6 EV_TIMEOUT_ENTERDATA
102040.33 4 tw dtmf 0 (4,48,48)
102040.34 4 event 0, iCode=48 state=1301
102040.36 4 LsGetNbrsRxDigits 0,0
102040.36 4 state [Get Acc No] Number Input 0173400
102040.38 4 path {0173400} not found
102040.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
102040.64 4 tw dtmf 0 (4,48,48)
102040.66 4 event 0, iCode=48 state=1301
102040.67 4 LsGetNbrsRxDigits 0,0
102040.67 4 state [Get Acc No] Number Input 01734000
102040.69 4 path {01734000} not found
102040.70 4 timer set 6 EV_TIMEOUT_ENTERDATA
102041.17 4 tw dtmf 2 (4,50,50)
102041.19 4 event 2, iCode=50 state=1301
102041.20 4 LsGetNbrsRxDigits 2,2
102041.20 4 state [Get Acc No] Number Input 017340002
102041.22 4 path {017340002} not found
102041.23 4 timer set 6 EV_TIMEOUT_ENTERDATA
102041.52 4 tw dtmf 4 (4,52,52)
102041.59 4 event 4, iCode=52 state=1301
102041.59 4 LsGetNbrsRxDigits 4,4
102041.61 4 state [Get Acc No] Number Input 0173400024
102041.63 4 path {0173400024} not found
102041.63 4 timer set 6 EV_TIMEOUT_ENTERDATA
102041.75 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
102041.77 4 event FAX, iCode=134 state=1301
102041.77 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
102041.78 4 path {FAX} not found
102041.80 4 event TDX_CST, iCode=134 state=1301
102041.80 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
102041.81 4 path {TDX_CST} not found
102041.89 4 tw dtmf 5 (4,53,53)
102041.91 4 event 5, iCode=53 state=1301
102041.92 4 LsGetNbrsRxDigits 5,5
102041.92 4 state [Get Acc No] Number Input 01734000245
102041.94 4 path {01734000245} not found
102041.95 4 timer set 6 EV_TIMEOUT_ENTERDATA
102048.42 4 timer fired EV_TIMEOUT_ENTERDATA
102048.42 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
102048.44 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
102048.45 4 path {EV_TIMEOUT_ENTERDATA} not found
102048.45 4 timer clear
102048.47 4 rv add [Get Acc No]{01734000245}
102048.48 4 path {01734000245} not found
102048.48 4 next module is [Varify A/C] (idx=2)
102048.50 4 rvns add [Get Acc No_PathTaken]{success}
102048.52 4 fn RunModule start [Database Query,[Varify A/C],2,,]
102048.52 4 timer clear
102048.53 4 state [Varify A/C] DB Query
102048.55 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
102048.58 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
102048.59 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:20:30 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:20:31 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:20:31 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
102048.61 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
102048.61 4 db [Varify A/C] row count=1
102048.63 4 rv add [Varify A/C_RowCount]{1}
102048.64 4 db get RecordsetGetRowsMax
102048.64 4 db get 999 records. (row count=1)
102048.66 4 db update RVs
102048.67 4 db about to close dbDbqDatabase
102048.69 4 db going down path [True]
102048.69 4 next module is [Get PIN No] (idx=89)
102048.70 4 fn RunModule start [Get Numbers,[Get PIN No],89,,]
102048.72 4 timer clear
102048.72 4 state [Get PIN No] Number Input
102048.73 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
102048.75 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
102048.80 4 tw wav->vox convert end 872828,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
102048.83 4 play start ok, lPlayId=872890
102052.16 4 tw PlayEnd 4 872890
102052.17 4 play end id=872890, (current ID)
102052.17 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
102052.19 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
102052.20 4 path {EV_PLAY_FINISHED} not found
102052.20 4 timer set 7 EV_TIMEOUT_REPLAYMSG
102052.22 4 tw DialogicEvent 129,TDX_PLAY,872890,0,0,,,
102052.23 4 event TDX_PLAY, iCode=129 state=1301
102052.23 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
102052.25 4 path {TDX_PLAY} not found
102053.05 4 tw dtmf 3 (4,51,51)
102053.05 4 event 3, iCode=51 state=1301
102053.06 4 LsGetNbrsRxDigits 3,3
102053.08 4 state [Get PIN No] Number Input 3
102053.08 4 path {3} not found
102053.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
102053.73 4 tw dtmf 8 (4,56,56)
102053.75 4 event 8, iCode=56 state=1301
102053.77 4 LsGetNbrsRxDigits 8,8
102053.77 4 state [Get PIN No] Number Input 38
102053.78 4 path {38} not found
102053.80 4 timer set 6 EV_TIMEOUT_ENTERDATA
102054.14 4 tw dtmf 0 (4,48,48)
102054.16 4 event 0, iCode=48 state=1301
102054.17 4 LsGetNbrsRxDigits 0,0
102054.19 4 state [Get PIN No] Number Input 380
102054.19 4 path {380} not found
102054.20 4 timer set 6 EV_TIMEOUT_ENTERDATA
102054.50 4 tw dtmf 4 (4,52,52)
102054.52 4 event 4, iCode=52 state=1301
102054.53 4 LsGetNbrsRxDigits 4,4
102054.53 4 state [Get PIN No] Number Input 3804
102054.55 4 path {3804} not found
102054.56 4 timer set 6 EV_TIMEOUT_ENTERDATA
102054.56 4 timer clear
102054.58 4 rv add [Get PIN No]{3804}
102054.59 4 path {3804} not found
102054.59 4 next module is [Varify A/C No] (idx=113)
102054.61 4 rvns add [Get PIN No_PathTaken]{success}
102054.63 4 fn RunModule start [Database Query,[Varify A/C No],113,,]
102054.63 4 timer clear
102054.64 4 state [Varify A/C No] DB Query
102054.66 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
102054.69 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
102054.70 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:20:30 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
102054.72 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
102054.72 4 db [Varify A/C No] row count=1
102054.73 4 rv add [Varify A/C No_RowCount]{1}
102054.75 4 db get RecordsetGetRowsMax
102054.75 4 db get 999 records. (row count=1)
102054.77 4 db update RVs
102054.78 4 db about to close dbDbqDatabase
102054.80 4 db going down path [True]
102054.80 4 next module is
  1. (idx=90)
102054.81 4 fn RunModule start [Play,
  1. ,90,,]
102054.83 4 timer clear
102054.83 4 Play Module start
102054.84 4 state
  1. Playing
102054.86 4 state
102054.86 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
102054.89 4 tw wav->vox convert end 878937,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
102054.92 4 play start ok, lPlayId=878984
102056.42 4 tw dtmf 1 (4,49,49)
102056.44 4 event 1, iCode=49 state=1100
102056.45 4 LsPlayMsg 1,1
102056.45 4 next module is [say Bal 1] (idx=3)
102056.47 4 play PlayStop ok
102056.48 4 rv add
  1. {1}
102056.50 4 fn RunModule start [say Numbers,[say Bal 1],3,,]
102056.50 4 tw PlayEnd 4 878984
102056.52 4 play end id=878984, (current ID)
102056.53 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
102056.53 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
102056.55 4 tw DialogicEvent 129,TDX_PLAY,878984,0,0,,,
102056.56 4 event TDX_PLAY, iCode=129 state=6001
102056.56 4 LsModuleTransition : 129, [TDX_PLAY]
102056.58 4 timer clear
102056.59 4 state [say Bal 1] Say numbers: 01/02/2007 as Date - DDMMYYYY
102056.61 4 fn PlaySoundStartNumbers [],[],[01/02/2007],Date - DDMMYYYY
102056.63 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
102056.64 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
102056.64 4 rv add [Hangup Time]{01/10/2007 10:20:56 AM}
102056.66 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
102056.67 4 HangupCall_Common hCall=4
102056.67 4 rec RecSoundStop ok
102056.69 4 play PlayStop ok
102056.70 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
102056.70 4 fnHangupCall end
102056.72 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
102056.73 4 event FAX, iCode=134 state=900
102056.73 4 LsAwaitingCalls EV_UNKNOWN_134
102056.75 4 event TDX_CST, iCode=134 state=900
102056.77 4 LsAwaitingCalls EV_UNKNOWN_134
102056.77 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
102056.78 4 event TDX_SETHOOK, iCode=135 state=900
102056.80 4 LsAwaitingCalls EV_UNKNOWN_135
102056.80 4 event callstate IDLE 4 1,0,0
102056.81 4 WorkingMode@Idle=
102056.83 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
102056.83 4 timer clear
102056.84 4 rec RecSoundStop ok
102056.86 4 play PlayStop ok
102056.88 4 rv add [CallEndTime]{01/10/2007 10:20:56 AM}
102056.91 4 on-hangup script:[]
102056.92 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
102056.92 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
102056.94 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
102056.95 4 init atidle reinit : start
102056.95 4 init atidle reinit iConferenceOtherLegLid=-1
102056.97 4 init atidle reinit : reset all LineState variables
102056.98 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
102056.98 4 state Waiting for a call...
102059.19 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
102059.19 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
102059.20 4 setting iDialoutReadyToDialout = 1
102205.00 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
102205.02 MemStructVgs_ClearVgs [3]
102205.02 load end
102205.03 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
102205.05 0 Erasing Script (new loaded) Id 4
102205.05 0 VgsScriptFree [4]
102205.06 MemStructVgs_ClearVgs [4]
102207.08 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
102207.08 MemStructVgs_ClearVgs [4]
102207.09 load end
102207.11 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Main.vgs
102207.13 0 Erasing Script (new loaded) Id 3
102207.13 0 VgsScriptFree [3]
102207.14 MemStructVgs_ClearVgs [3]
102216.16 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
102216.16 MemStructVgs_ClearVgs [3]
102216.17 load end
102216.19 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
102216.19 0 Erasing Script (new loaded) Id 4
102216.20 0 VgsScriptFree [4]
102216.22 MemStructVgs_ClearVgs [4]
102555.61 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
102555.61 MemStructVgs_ClearVgs [4]
102555.70 load end
102555.72 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
102555.73 0 Erasing Script (new loaded) Id 1
102555.75 0 VgsScriptFree [1]
102555.75 MemStructVgs_ClearVgs [1]
103953.97 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
103953.97 MemStructVgs_ClearVgs [1]
103954.05 load end
103954.06 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs
103954.06 0 Erasing Script (new loaded) Id 4
103954.08 0 VgsScriptFree [4]
103954.09 MemStructVgs_ClearVgs [4]
103957.09 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
103957.09 MemStructVgs_ClearVgs [4]
103957.17 load end
103957.19 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
103957.20 0 Erasing Script (new loaded) Id 1
103957.20 0 VgsScriptFree [1]
103957.22 MemStructVgs_ClearVgs [1]
104131.23 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104131.25 MemStructVgs_ClearVgs [1]
104131.33 load end
104131.34 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs
104131.36 0 Erasing Script (new loaded) Id 4
104131.36 0 VgsScriptFree [4]
104131.38 MemStructVgs_ClearVgs [4]
104304.23 0 sys cleanup Start
104304.23 0 sys cleanup End
104323.39 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104323.39 MemStructVgs_ClearVgs [4]
104323.47 load end
104323.48 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
104323.50 0 Erasing Script (new loaded) Id 1
104323.50 0 VgsScriptFree [1]
104323.52 MemStructVgs_ClearVgs [1]
104332.34 4 event callstate OFFERING 4 2,0,0
104332.36 4 script interpretor: VgMulti v6.0.3243
104332.36 4 fired OFFERING event to listeners
104332.38 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
104332.39 4 cid CallerID vars set (in 'offering' event) [,,]
104332.39 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
104332.41 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
104332.42 4 tw ring 1
104332.42 4 ring time since last ring event (sec): 0.00
104332.44 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
104332.45 4 should answer as number of rings reached
104332.45 4 rv clear all
104332.47 4 init LineState ResetAtStartOfNewCall.
104332.48 4 answering the call (,,,0)
104332.48 4 timer clear
104332.50 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
104332.52 4 event TDX_CST, iCode=134 state=6001
104332.53 4 LsModuleTransition : 134, [TDX_CST]
104333.14 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
104333.14 4 event TDX_SETHOOK, iCode=135 state=6001
104333.16 4 LsModuleTransition : 135, [TDX_SETHOOK]
104333.17 4 event callstate CONNECTED 4 256,0,0
104333.17 4 LineEvCallState_Connected hDevice=4 params=256,0,0
104333.19 4 WorkingModes tapi= script= LineState().iState=6001
104333.20 4 Inband detection not enabled
104333.20 4 StartLoadedVgs at 01/10/2007 10:43:33 AM (VgMulti v6.0.3243)
104333.22 4 set LineState().iVgsIdx=3
104333.23 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
104333.23 4 init StartLoadedVgs_InitLineState start
104333.25 4 rv add [$RV_STARTTIME]{01/10/2007 10:43:33 AM}
104333.25 4 rv add [$RV_DEVICEID]{4}
104333.27 4 rv add [DlgcNetworkResource]{dxxxB1C4}
104333.28 4 rv add [DlgcVoiceResource]{dxxxB1C4}
104333.28 4 rv add [$RV_CIDNAME]{}
104333.30 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
104333.31 4 rvns add [scriptsPath]{G:\TeleBanking System\}
104333.31 4 rv add [$RV_CIDNUMBER]{}
104333.33 4 fn RunModule start [Play,[Get Language],46,,]
104333.34 4 tw DialogicEvent 134,TDX_CST,65535,0,0,DE_LCON,,
104333.34 4 event TDX_CST, iCode=134 state=6001
104333.36 4 LsModuleTransition : 134, [TDX_CST]
104333.38 4 timer clear
104333.39 4 Play Module start
104333.39 4 state [Get Language] Playing
104333.41 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
104333.42 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
104333.45 4 tw wav->vox convert end 237500,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
104333.47 4 play start ok, lPlayId=237546
104334.78 4 tw dtmf 1 (4,49,49)
104334.80 4 event 1, iCode=49 state=1100
104334.81 4 LsPlayMsg 1,1
104334.81 4 rv add [scriptEnd_Time]{01/10/2007 10:43:34 AM}
104334.83 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
104334.84 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
104334.88 4 rv add [scriptStart_Time]{01/10/2007 10:43:34 AM}
104334.88 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
104334.89 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
104334.91 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104334.91 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4
104334.92 4 rvns add [scriptsPath]{G:\TeleBanking System\}
104334.94 4 play PlayStop ok
104334.95 4 rv add [Get Language]{1}
104334.97 4 fn RunModule start [Evaluate,[Get Bangla],65,,]
104334.97 4 tw PlayEnd 4 237546
104334.98 4 play end id=237546, (current ID)
104335.00 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
104335.00 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
104335.02 4 tw DialogicEvent 129,TDX_PLAY,237546,0,0,,,
104335.03 4 event TDX_PLAY, iCode=129 state=6001
104335.03 4 LsModuleTransition : 129, [TDX_PLAY]
104335.05 4 timer clear
104335.05 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
104335.06 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
104335.08 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
104335.08 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
104335.09 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
104335.11 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
104335.11 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
104335.13 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
104335.14 4 matching path not found
104335.14 4 next module is
  1. (idx=66)
104335.16 4 matching path was found
104335.16 4 fn RunModule start [Play,
  1. ,66,,]
104335.17 4 timer clear
104335.19 4 Play Module start
104335.19 4 state
  1. Playing
104335.20 4 state
  1. Playing (Bangla Voice\Service List.wav)
104335.22 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
104335.23 4 tw wav->vox convert end 239296,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
104335.25 4 play start ok, lPlayId=239312
104336.03 4 tw dtmf 1 (4,49,49)
104336.03 4 event 1, iCode=49 state=1100
104336.05 4 LsPlayMsg 1,1
104336.05 4 next module is [Get Acc No] (idx=129)
104336.08 4 play PlayStop ok
104336.08 4 rv add
  1. {1}
104336.09 4 fn RunModule start [Get Numbers,[Get Acc No],129,,]
104336.11 4 tw PlayEnd 4 239312
104336.11 4 play end id=239312, (current ID)
104336.13 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
104336.14 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
104336.14 4 tw DialogicEvent 129,TDX_PLAY,239312,0,0,,,
104336.16 4 event TDX_PLAY, iCode=129 state=6001
104336.16 4 LsModuleTransition : 129, [TDX_PLAY]
104336.17 4 timer clear
104336.19 4 state [Get Acc No] Number Input
104336.19 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
104336.20 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
104336.25 4 tw wav->vox convert end 240281,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
104336.27 4 play start ok, lPlayId=240328
104339.48 4 tw dtmf 0 (4,48,48)
104339.50 4 event 0, iCode=48 state=1300
104339.52 4 LsGetNbrsPlayWelcMsg 0,0
104339.53 4 play PlayStop ok
104339.53 4 state [Get Acc No] Number Input 0
104339.55 4 path {0} not found
104339.56 4 timer set 6 EV_TIMEOUT_ENTERDATA
104339.56 4 tw PlayEnd 4 240328
104339.58 4 play end id=240328, (current ID)
104339.59 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
104339.59 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
104339.61 4 path {EV_PLAY_FINISHED} not found
104339.63 4 awaiting further dtmf input
104339.63 4 tw DialogicEvent 129,TDX_PLAY,240328,0,0,,,
104339.64 4 event TDX_PLAY, iCode=129 state=1301
104339.64 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
104339.66 4 path {TDX_PLAY} not found
104340.31 4 tw dtmf 1 (4,49,49)
104340.31 4 event 1, iCode=49 state=1301
104340.33 4 LsGetNbrsRxDigits 1,1
104340.34 4 state [Get Acc No] Number Input 01
104340.34 4 path {01} not found
104340.36 4 timer set 6 EV_TIMEOUT_ENTERDATA
104341.59 4 tw dtmf 7 (4,55,55)
104341.61 4 event 7, iCode=55 state=1301
104341.61 4 LsGetNbrsRxDigits 7,7
104341.63 4 state [Get Acc No] Number Input 017
104341.63 4 path {017} not found
104341.64 4 timer set 6 EV_TIMEOUT_ENTERDATA
104341.81 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
104341.83 4 event FAX, iCode=134 state=1301
104341.84 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
104341.84 4 path {FAX} not found
104341.86 4 event TDX_CST, iCode=134 state=1301
104341.88 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
104341.88 4 path {TDX_CST} not found
104342.03 4 tw dtmf 3 (4,51,51)
104342.05 4 event 3, iCode=51 state=1301
104342.06 4 LsGetNbrsRxDigits 3,3
104342.06 4 state [Get Acc No] Number Input 0173
104342.08 4 path {0173} not found
104342.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
104342.61 4 tw dtmf 4 (4,52,52)
104342.63 4 event 4, iCode=52 state=1301
104342.63 4 LsGetNbrsRxDigits 4,4
104342.64 4 state [Get Acc No] Number Input 01734
104342.66 4 path {01734} not found
104342.66 4 timer set 6 EV_TIMEOUT_ENTERDATA
104343.05 4 tw dtmf 0 (4,48,48)
104343.05 4 event 0, iCode=48 state=1301
104343.06 4 LsGetNbrsRxDigits 0,0
104343.08 4 state [Get Acc No] Number Input 017340
104343.08 4 path {017340} not found
104343.09 4 timer set 6 EV_TIMEOUT_ENTERDATA
104343.38 4 tw dtmf 0 (4,48,48)
104343.39 4 event 0, iCode=48 state=1301
104343.41 4 LsGetNbrsRxDigits 0,0
104343.41 4 state [Get Acc No] Number Input 0173400
104343.42 4 path {0173400} not found
104343.44 4 timer set 6 EV_TIMEOUT_ENTERDATA
104343.58 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
104343.59 4 event FAX, iCode=134 state=1301
104343.61 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
104343.61 4 path {FAX} not found
104343.63 4 event TDX_CST, iCode=134 state=1301
104343.64 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
104343.64 4 path {TDX_CST} not found
104343.77 4 tw dtmf 0 (4,48,48)
104343.78 4 event 0, iCode=48 state=1301
104343.78 4 LsGetNbrsRxDigits 0,0
104343.80 4 state [Get Acc No] Number Input 01734000
104343.80 4 path {01734000} not found
104343.81 4 timer set 6 EV_TIMEOUT_ENTERDATA
104343.98 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
104343.98 4 event FAX, iCode=134 state=1301
104344.00 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
104344.02 4 path {FAX} not found
104344.02 4 event TDX_CST, iCode=134 state=1301
104344.03 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
104344.05 4 path {TDX_CST} not found
104344.20 4 tw dtmf 2 (4,50,50)
104344.22 4 event 2, iCode=50 state=1301
104344.23 4 LsGetNbrsRxDigits 2,2
104344.23 4 state [Get Acc No] Number Input 017340002
104344.25 4 path {017340002} not found
104344.25 4 timer set 6 EV_TIMEOUT_ENTERDATA
104344.56 4 tw dtmf 4 (4,52,52)
104344.58 4 event 4, iCode=52 state=1301
104344.59 4 LsGetNbrsRxDigits 4,4
104344.59 4 state [Get Acc No] Number Input 0173400024
104344.61 4 path {0173400024} not found
104344.63 4 timer set 6 EV_TIMEOUT_ENTERDATA
104344.88 4 tw dtmf 5 (4,53,53)
104344.88 4 event 5, iCode=53 state=1301
104344.89 4 LsGetNbrsRxDigits 5,5
104344.89 4 state [Get Acc No] Number Input 01734000245
104344.91 4 path {01734000245} not found
104344.92 4 timer set 6 EV_TIMEOUT_ENTERDATA
104351.42 4 timer fired EV_TIMEOUT_ENTERDATA
104351.42 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
104351.44 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
104351.44 4 path {EV_TIMEOUT_ENTERDATA} not found
104351.45 4 timer clear
104351.47 4 rv add [Get Acc No]{01734000245}
104351.47 4 path {01734000245} not found
104351.48 4 next module is [Varify A/C] (idx=84)
104351.50 4 rvns add [Get Acc No_PathTaken]{success}
104351.50 4 fn RunModule start [Database Query,[Varify A/C],84,,]
104351.52 4 timer clear
104351.53 4 state [Varify A/C] DB Query
104351.53 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
104351.58 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
104351.58 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:43:33 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:43:34 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:43:34 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
104351.59 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
104351.61 4 db [Varify A/C] row count=1
104351.63 4 rv add [Varify A/C_RowCount]{1}
104351.63 4 db get RecordsetGetRowsMax
104351.64 4 db get 999 records. (row count=1)
104351.64 4 db update RVs
104351.66 4 db about to close dbDbqDatabase
104351.67 4 db going down path [True]
104351.67 4 next module is [Get PIN No] (idx=128)
104351.69 4 fn RunModule start [Get Numbers,[Get PIN No],128,,]
104351.70 4 timer clear
104351.70 4 state [Get PIN No] Number Input
104351.72 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
104351.73 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
104351.78 4 tw wav->vox convert end 255812,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
104351.81 4 play start ok, lPlayId=255875
104355.13 4 tw PlayEnd 4 255875
104355.14 4 play end id=255875, (current ID)
104355.14 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
104355.16 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104355.17 4 path {EV_PLAY_FINISHED} not found
104355.17 4 timer set 7 EV_TIMEOUT_REPLAYMSG
104355.19 4 tw DialogicEvent 129,TDX_PLAY,255875,0,0,,,
104355.20 4 event TDX_PLAY, iCode=129 state=1301
104355.20 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
104355.22 4 path {TDX_PLAY} not found
104355.42 4 tw dtmf 3 (4,51,51)
104355.42 4 event 3, iCode=51 state=1301
104355.44 4 LsGetNbrsRxDigits 3,3
104355.45 4 state [Get PIN No] Number Input 3
104355.45 4 path {3} not found
104355.47 4 timer set 6 EV_TIMEOUT_ENTERDATA
104356.22 4 tw dtmf 8 (4,56,56)
104356.23 4 event 8, iCode=56 state=1301
104356.23 4 LsGetNbrsRxDigits 8,8
104356.25 4 state [Get PIN No] Number Input 38
104356.27 4 path {38} not found
104356.27 4 timer set 6 EV_TIMEOUT_ENTERDATA
104356.70 4 tw dtmf 0 (4,48,48)
104356.70 4 event 0, iCode=48 state=1301
104356.72 4 LsGetNbrsRxDigits 0,0
104356.73 4 state [Get PIN No] Number Input 380
104356.73 4 path {380} not found
104356.75 4 timer set 6 EV_TIMEOUT_ENTERDATA
104357.09 4 tw dtmf 4 (4,52,52)
104357.11 4 event 4, iCode=52 state=1301
104357.11 4 LsGetNbrsRxDigits 4,4
104357.13 4 state [Get PIN No] Number Input 3804
104357.14 4 path {3804} not found
104357.14 4 timer set 6 EV_TIMEOUT_ENTERDATA
104357.16 4 timer clear
104357.17 4 rv add [Get PIN No]{3804}
104357.17 4 path {3804} not found
104357.19 4 next module is [Varify A/C No] (idx=69)
104357.20 4 rvns add [Get PIN No_PathTaken]{success}
104357.20 4 fn RunModule start [Database Query,[Varify A/C No],69,,]
104357.22 4 timer clear
104357.22 4 state [Varify A/C No] DB Query
104357.23 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
104357.27 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
104357.28 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:43:33 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}
104357.30 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
104357.30 4 db [Varify A/C No] row count=1
104357.31 4 rv add [Varify A/C No_RowCount]{1}
104357.33 4 db get RecordsetGetRowsMax
104357.33 4 db get 999 records. (row count=1)
104357.34 4 db update RVs
104357.36 4 db about to close dbDbqDatabase
104357.36 4 db going down path [True]
104357.38 4 next module is
  1. (idx=127)
104357.39 4 fn RunModule start [Play,
  1. ,127,,]
104357.41 4 timer clear
104357.42 4 Play Module start
104357.42 4 state
  1. Playing
104357.44 4 state
  1. Playing (Bangla Voice\Acc List.wav)
104357.44 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
104357.47 4 tw wav->vox convert end 261515,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
104357.50 4 play start ok, lPlayId=261562
104410.13 4 tw PlayEnd 4 261562
104410.14 4 play end id=261562, (current ID)
104410.14 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
104410.16 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104410.17 4 path {EV_PLAY_FINISHED} not found
104410.17 4 timer set 7 EV_TIMEOUT_REPLAYMSG
104410.19 4 tw DialogicEvent 129,TDX_PLAY,261562,0,0,,,
104410.20 4 event TDX_PLAY, iCode=129 state=1101
104410.20 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
104410.22 4 path {TDX_PLAY} not found
104410.23 4 tw dtmf 1 (4,49,49)
104410.23 4 event 1, iCode=49 state=1101
104410.25 4 LsPlayMsgFinished 1,1
104410.25 4 next module is [say Bal 1] (idx=85)
104410.27 4 rv add
  1. {1}
104410.28 4 fn RunModule start [say Numbers,[say Bal 1],85,,]
104410.28 4 timer clear
104410.30 4 state [say Bal 1] Say numbers: 01/02/2007 as Date - DDMMYYYY
104410.31 4 fn PlaySoundStartNumbers [],[],[01/02/2007],Date - DDMMYYYY
104410.31 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
104410.33 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
104410.34 4 rv add [Hangup Time]{01/10/2007 10:44:10 AM}
104410.34 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
104410.36 4 HangupCall_Common hCall=4
104410.36 4 rec RecSoundStop ok
104410.38 4 play PlayStop ok
104410.39 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104410.41 4 fnHangupCall end
104410.44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
104410.45 4 event TDX_SETHOOK, iCode=135 state=900
104410.47 4 LsAwaitingCalls EV_UNKNOWN_135
104410.47 4 event callstate IDLE 4 1,0,0
104410.48 4 WorkingMode@Idle=
104410.50 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
104410.50 4 timer clear
104410.52 4 rec RecSoundStop ok
104410.53 4 play PlayStop ok
104410.53 4 rv add [CallEndTime]{01/10/2007 10:44:10 AM}
104410.56 4 on-hangup script:[]
104410.58 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
104410.58 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
104410.59 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
104410.61 4 init atidle reinit : start
104410.61 4 init atidle reinit iConferenceOtherLegLid=-1
104410.63 4 init atidle reinit : reset all LineState variables
104410.64 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
104410.64 4 state Waiting for a call...
104412.84 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
104412.84 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
104412.86 4 setting iDialoutReadyToDialout = 1
104449.72 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
104449.72 MemStructVgs_ClearVgs [1]
104449.73 load end
104449.75 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
104449.77 0 Erasing Script (new loaded) Id 3
104449.77 0 VgsScriptFree [3]
104449.78 MemStructVgs_ClearVgs [3]
104532.80 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104532.80 MemStructVgs_ClearVgs [3]
104532.89 load end
104532.89 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
104532.91 0 Erasing Script (new loaded) Id 4
104532.92 0 VgsScriptFree [4]
104532.92 MemStructVgs_ClearVgs [4]
104542.94 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104542.94 MemStructVgs_ClearVgs [4]
104543.02 load end
104543.03 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
104543.05 0 Erasing Script (new loaded) Id 3
104543.05 0 VgsScriptFree [3]
104543.06 MemStructVgs_ClearVgs [3]
104554.08 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104554.08 MemStructVgs_ClearVgs [3]
104554.16 load end
104554.17 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
104554.19 0 Erasing Script (new loaded) Id 4
104554.19 0 VgsScriptFree [4]
104554.20 MemStructVgs_ClearVgs [4]
104604.22 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104604.22 MemStructVgs_ClearVgs [4]
104604.30 load end
104604.31 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
104604.33 0 Erasing Script (new loaded) Id 3
104604.33 0 VgsScriptFree [3]
104604.34 MemStructVgs_ClearVgs [3]
104612.36 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104612.36 MemStructVgs_ClearVgs [3]
104612.44 load end
104612.45 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
104612.47 0 Erasing Script (new loaded) Id 4
104612.48 0 VgsScriptFree [4]
104612.48 MemStructVgs_ClearVgs [4]
104634.50 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104634.50 MemStructVgs_ClearVgs [4]
104634.58 load end
104634.59 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
104634.61 0 Erasing Script (new loaded) Id 3
104634.63 0 VgsScriptFree [3]
104634.63 MemStructVgs_ClearVgs [3]
104643.64 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104643.64 MemStructVgs_ClearVgs [3]
104643.72 load end
104643.73 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
104643.73 0 Erasing Script (new loaded) Id 4
104643.75 0 VgsScriptFree [4]
104643.77 MemStructVgs_ClearVgs [4]
104644.77 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104644.77 MemStructVgs_ClearVgs [4]
104644.84 load end
104644.86 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
104644.88 0 Erasing Script (new loaded) Id 3
104644.88 0 VgsScriptFree [3]
104644.89 MemStructVgs_ClearVgs [3]
104647.91 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104647.91 MemStructVgs_ClearVgs [3]
104647.98 load end
104648.00 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs
104648.02 0 Erasing Script (new loaded) Id 4
104648.02 0 VgsScriptFree [4]
104648.03 MemStructVgs_ClearVgs [4]
104703.05 load start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104703.06 MemStructVgs_ClearVgs [4]
104703.16 load end
104703.17 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs
104703.19 0 Erasing Script (new loaded) Id 3
104703.22 0 VgsScriptFree [3]
104703.23 MemStructVgs_ClearVgs [3]
104752.89 4 event callstate OFFERING 4 2,0,0
104752.91 4 script interpretor: VgMulti v6.0.3243
104752.91 4 fired OFFERING event to listeners
104752.92 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
104752.94 4 cid CallerID vars set (in 'offering' event) [,,]
104752.94 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
104752.95 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
104752.97 4 tw ring 1
104752.97 4 ring time since last ring event (sec): 0.00
104752.98 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
104753.00 4 should answer as number of rings reached
104753.00 4 rv clear all
104753.02 4 init LineState ResetAtStartOfNewCall.
104753.02 4 answering the call (,,,0)
104753.03 4 timer clear
104753.05 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
104753.06 4 event TDX_CST, iCode=134 state=6001
104753.06 4 LsModuleTransition : 134, [TDX_CST]
104753.67 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
104753.69 4 event TDX_SETHOOK, iCode=135 state=6001
104753.70 4 LsModuleTransition : 135, [TDX_SETHOOK]
104753.70 4 event callstate CONNECTED 4 256,0,0
104753.72 4 LineEvCallState_Connected hDevice=4 params=256,0,0
104753.73 4 WorkingModes tapi= script= LineState().iState=6001
104753.73 4 Inband detection not enabled
104753.75 4 StartLoadedVgs at 01/10/2007 10:47:53 AM (VgMulti v6.0.3243)
104753.77 4 set LineState().iVgsIdx=1
104753.77 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
104753.78 4 init StartLoadedVgs_InitLineState start
104753.80 4 rv add [$RV_STARTTIME]{01/10/2007 10:47:53 AM}
104753.80 4 rv add [$RV_DEVICEID]{4}
104753.81 4 rv add [DlgcNetworkResource]{dxxxB1C4}
104753.81 4 rv add [DlgcVoiceResource]{dxxxB1C4}
104753.83 4 rv add [$RV_CIDNAME]{}
104753.84 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
104753.84 4 rvns add [scriptsPath]{G:\TeleBanking System\}
104753.86 4 rv add [$RV_CIDNUMBER]{}
104753.88 4 fn RunModule start [Play,[Get Language],3,,]
104753.88 4 tw DialogicEvent 134,TDX_CST,22324,0,0,DE_LCON,,
104753.89 4 event TDX_CST, iCode=134 state=6001
104753.89 4 LsModuleTransition : 134, [TDX_CST]
104753.91 4 timer clear
104753.92 4 Play Module start
104753.92 4 state [Get Language] Playing
104753.94 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
104753.95 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
104753.97 4 tw wav->vox convert end 498031,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
104754.00 4 play start ok, lPlayId=498062
104754.70 4 tw dtmf 1 (4,49,49)
104754.72 4 event 1, iCode=49 state=1100
104754.73 4 LsPlayMsg 1,1
104754.73 4 rv add [scriptEnd_Time]{01/10/2007 10:47:54 AM}
104754.75 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
104754.77 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
104754.80 4 rv add [scriptStart_Time]{01/10/2007 10:47:54 AM}
104754.80 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
104754.81 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
104754.83 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
104754.83 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4
104754.84 4 rvns add [scriptsPath]{G:\TeleBanking System\}
104754.86 4 play PlayStop ok
104754.88 4 rv add [Get Language]{1}
104754.89 4 fn RunModule start [Evaluate,[Get Bangla],64,,]
104754.89 4 tw PlayEnd 4 498062
104754.91 4 play end id=498062, (current ID)
104754.92 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
104754.92 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
104754.94 4 tw DialogicEvent 129,TDX_PLAY,498062,0,0,,,
104754.95 4 event TDX_PLAY, iCode=129 state=6001
104754.95 4 LsModuleTransition : 129, [TDX_PLAY]
104754.97 4 timer clear
104754.97 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
104754.98 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
104755.00 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
104755.00 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
104755.02 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
104755.03 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
104755.03 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
104755.05 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
104755.05 4 matching path not found
104755.06 4 next module is
  1. (idx=63)
104755.08 4 matching path was found
104755.08 4 fn RunModule start [Play,
  1. ,63,,]
104755.09 4 timer clear
104755.11 4 Play Module start
104755.11 4 state
  1. Playing
104755.13 4 state
104755.14 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
104755.19 4 tw wav->vox convert end 499218,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
104755.22 4 play start ok, lPlayId=499281
104756.31 4 tw dtmf 1 (4,49,49)
104756.33 4 event 1, iCode=49 state=1100
104756.34 4 LsPlayMsg 1,1
104756.36 4 next module is [Get Acc No] (idx=85)
104756.39 4 play PlayStop ok
104756.41 4 rv add
  1. {1}
104756.41 4 fn RunModule start [Get Numbers,[Get Acc No],85,,]
104756.42 4 tw PlayEnd 4 499281
104756.44 4 play end id=499281, (current ID)
104756.44 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
104756.45 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
104756.45 4 tw DialogicEvent 129,TDX_PLAY,499281,0,0,,,
104756.47 4 event TDX_PLAY, iCode=129 state=6001
104756.48 4 LsModuleTransition : 129, [TDX_PLAY]
104756.48 4 timer clear
104756.50 4 state [Get Acc No] Number Input
104756.52 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
104756.52 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
104756.56 4 tw wav->vox convert end 500593,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
104756.58 4 play start ok, lPlayId=500656
104800.39 4 tw dtmf 0 (4,48,48)
104800.39 4 event 0, iCode=48 state=1300
104800.41 4 LsGetNbrsPlayWelcMsg 0,0
104800.42 4 play PlayStop ok
104800.42 4 state [Get Acc No] Number Input 0
104800.44 4 path {0} not found
104800.45 4 timer set 6 EV_TIMEOUT_ENTERDATA
104800.45 4 tw PlayEnd 4 500656
104800.47 4 play end id=500656, (current ID)
104800.48 4 event EV_PLAY_FINISHED, iCode=8001 state=1301
104800.48 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED
104800.50 4 path {EV_PLAY_FINISHED} not found
104800.52 4 awaiting further dtmf input
104800.52 4 tw DialogicEvent 129,TDX_PLAY,500656,0,0,,,
104800.53 4 event TDX_PLAY, iCode=129 state=1301
104800.53 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
104800.55 4 path {TDX_PLAY} not found
104800.70 4 tw dtmf 1 (4,49,49)
104800.72 4 event 1, iCode=49 state=1301
104800.73 4 LsGetNbrsRxDigits 1,1
104800.73 4 state [Get Acc No] Number Input 01
104800.75 4 path {01} not found
104800.77 4 timer set 6 EV_TIMEOUT_ENTERDATA
104801.13 4 tw dtmf 7 (4,55,55)
104801.14 4 event 7, iCode=55 state=1301
104801.16 4 LsGetNbrsRxDigits 7,7
104801.16 4 state [Get Acc No] Number Input 017
104801.17 4 path {017} not found
104801.17 4 timer set 6 EV_TIMEOUT_ENTERDATA
104801.63 4 tw dtmf 3 (4,51,51)
104801.63 4 event 3, iCode=51 state=1301
104801.64 4 LsGetNbrsRxDigits 3,3
104801.66 4 state [Get Acc No] Number Input 0173
104801.66 4 path {0173} not found
104801.67 4 timer set 6 EV_TIMEOUT_ENTERDATA
104802.05 4 tw dtmf 4 (4,52,52)
104802.06 4 event 4, iCode=52 state=1301
104802.08 4 LsGetNbrsRxDigits 4,4
104802.08 4 state [Get Acc No] Number Input 01734
104802.09 4 path {01734} not found
104802.11 4 timer set 6 EV_TIMEOUT_ENTERDATA
104802.52 4 tw dtmf 0 (4,48,48)
104802.53 4 event 0, iCode=48 state=1301
104802.55 4 LsGetNbrsRxDigits 0,0
104802.55 4 state [Get Acc No] Number Input 017340
104802.56 4 path {017340} not found
104802.58 4 timer set 6 EV_TIMEOUT_ENTERDATA
104802.88 4 tw dtmf 0 (4,48,48)
104802.88 4 event 0, iCode=48 state=1301
104802.89 4 LsGetNbrsRxDigits 0,0
104802.91 4 state [Get Acc No] Number Input 0173400
104802.91 4 path {0173400} not found
104802.92 4 timer set 6 EV_TIMEOUT_ENTERDATA
104803.16 4 tw dtmf 0 (4,48,48)
104803.17 4 event 0, iCode=48 state=1301
104803.17 4 LsGetNbrsRxDigits 0,0
104803.19 4 state [Get Acc No] Number Input 01734000
104803.20 4 path {01734000} not found
104803.20 4 timer set 6 EV_TIMEOUT_ENTERDATA
104803.66 4 tw dtmf 2 (4,50,50)
104803.66 4 event 2, iCode=50 state=1301
104803.67 4 LsGetNbrsRxDigits 2,2
104803.67 4 state [Get Acc No] Number Input 017340002
104803.69 4 path {017340002} not found
104803.70 4 timer set 6 EV_TIMEOUT_ENTERDATA
104804.34 4 tw dtmf 5 (4,53,53)
104804.36 4 event 5, iCode=53 state=1301
104804.36 4 LsGetNbrsRxDigits 5,5
104804.38 4 state [Get Acc No] Number Input 0173400025
104804.39 4 path {0173400025} not found
104804.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
104810.86 4 timer fired EV_TIMEOUT_ENTERDATA
104810.86 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
104810.88 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
104810.88 4 path {EV_TIMEOUT_ENTERDATA} not found
104810.89 4 timer clear
104810.91 4 rv add [Get Acc No]{0173400025}
104810.91 4 len(0173400025) min=11, max=14, replays=0/1
104810.92 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav)
104810.94 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav
104810.98 4 tw wav->vox convert end 515015,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,,
104811.00 4 play start ok, lPlayId=515078
104814.83 4 tw PlayEnd 4 515078
104814.83 4 play end id=515078, (current ID)
104814.84 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
104814.84 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104814.86 4 path {EV_PLAY_FINISHED} not found
104814.88 4 timer set 10 EV_TIMEOUT_HANGUP
104814.88 4 timer set 6 EV_TIMEOUT_ENTERDATA
104814.89 4 tw DialogicEvent 129,TDX_PLAY,515078,0,0,,,
104814.91 4 event TDX_PLAY, iCode=129 state=1301
104814.91 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
104814.92 4 path {TDX_PLAY} not found
104816.02 4 tw dtmf 0 (4,48,48)
104816.03 4 event 0, iCode=48 state=1301
104816.05 4 LsGetNbrsRxDigits 0,0
104816.05 4 state [Get Acc No] Number Input 0
104816.06 4 path {0} not found
104816.08 4 timer set 6 EV_TIMEOUT_ENTERDATA
104816.23 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
104816.25 4 event FAX, iCode=134 state=1301
104816.27 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
104816.27 4 path {FAX} not found
104816.28 4 event TDX_CST, iCode=134 state=1301
104816.28 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
104816.30 4 path {TDX_CST} not found
104816.53 4 tw dtmf 1 (4,49,49)
104816.53 4 event 1, iCode=49 state=1301
104816.55 4 LsGetNbrsRxDigits 1,1
104816.56 4 state [Get Acc No] Number Input 01
104816.56 4 path {01} not found
104816.58 4 timer set 6 EV_TIMEOUT_ENTERDATA
104816.97 4 tw dtmf 7 (4,55,55)
104816.98 4 event 7, iCode=55 state=1301
104816.98 4 LsGetNbrsRxDigits 7,7
104817.00 4 state [Get Acc No] Number Input 017
104817.02 4 path {017} not found
104817.02 4 timer set 6 EV_TIMEOUT_ENTERDATA
104817.48 4 tw dtmf 3 (4,51,51)
104817.50 4 event 3, iCode=51 state=1301
104817.50 4 LsGetNbrsRxDigits 3,3
104817.52 4 state [Get Acc No] Number Input 0173
104817.53 4 path {0173} not found
104817.53 4 timer set 6 EV_TIMEOUT_ENTERDATA
104817.91 4 tw dtmf 4 (4,52,52)
104817.92 4 event 4, iCode=52 state=1301
104817.92 4 LsGetNbrsRxDigits 4,4
104817.94 4 state [Get Acc No] Number Input 01734
104817.95 4 path {01734} not found
104817.95 4 timer set 6 EV_TIMEOUT_ENTERDATA
104818.13 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX,
104818.13 4 event FAX, iCode=134 state=1301
104818.14 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX
104818.16 4 path {FAX} not found
104818.16 4 event TDX_CST, iCode=134 state=1301
104818.17 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST
104818.19 4 path {TDX_CST} not found
104818.34 4 tw dtmf 0 (4,48,48)
104818.36 4 event 0, iCode=48 state=1301
104818.38 4 LsGetNbrsRxDigits 0,0
104818.38 4 state [Get Acc No] Number Input 017340
104818.39 4 path {017340} not found
104818.41 4 timer set 6 EV_TIMEOUT_ENTERDATA
104818.66 4 tw dtmf 0 (4,48,48)
104818.66 4 event 0, iCode=48 state=1301
104818.67 4 LsGetNbrsRxDigits 0,0
104818.67 4 state [Get Acc No] Number Input 0173400
104818.69 4 path {0173400} not found
104818.70 4 timer set 6 EV_TIMEOUT_ENTERDATA
104818.94 4 tw dtmf 0 (4,48,48)
104818.95 4 event 0, iCode=48 state=1301
104818.95 4 LsGetNbrsRxDigits 0,0
104818.97 4 state [Get Acc No] Number Input 01734000
104818.98 4 path {01734000} not found
104818.98 4 timer set 6 EV_TIMEOUT_ENTERDATA
104819.59 4 tw dtmf 2 (4,50,50)
104819.61 4 event 2, iCode=50 state=1301
104819.63 4 LsGetNbrsRxDigits 2,2
104819.63 4 state [Get Acc No] Number Input 017340002
104819.64 4 path {017340002} not found
104819.64 4 timer set 6 EV_TIMEOUT_ENTERDATA
104819.97 4 tw dtmf 4 (4,52,52)
104819.98 4 event 4, iCode=52 state=1301
104819.98 4 LsGetNbrsRxDigits 4,4
104820.00 4 state [Get Acc No] Number Input 0173400024
104820.02 4 path {0173400024} not found
104820.02 4 timer set 6 EV_TIMEOUT_ENTERDATA
104820.30 4 tw dtmf 5 (4,53,53)
104820.30 4 event 5, iCode=53 state=1301
104820.31 4 LsGetNbrsRxDigits 5,5
104820.33 4 state [Get Acc No] Number Input 01734000245
104820.33 4 path {01734000245} not found
104820.34 4 timer set 6 EV_TIMEOUT_ENTERDATA
104826.81 4 timer fired EV_TIMEOUT_ENTERDATA
104826.81 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301
104826.83 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
104826.84 4 path {EV_TIMEOUT_ENTERDATA} not found
104826.84 4 timer clear
104826.86 4 rv add [Get Acc No]{01734000245}
104826.86 4 path {01734000245} not found
104826.88 4 next module is [Varify A/C] (idx=128)
104826.89 4 rvns add [Get Acc No_PathTaken]{success}
104826.89 4 fn RunModule start [Database Query,[Varify A/C],128,,]
104826.91 4 timer clear
104826.92 4 state [Varify A/C] DB Query
104826.92 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
104826.97 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)]
104826.98 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:47:53 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:47:54 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:47:54 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
  1. {1}[Get Acc No]{0173400025}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}
104826.98 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)]
104827.00 4 db [Varify A/C] row count=1
104827.02 4 rv add [Varify A/C_RowCount]{1}
104827.03 4 db get RecordsetGetRowsMax
104827.03 4 db get 999 records. (row count=1)
104827.05 4 db update RVs
104827.05 4 db about to close dbDbqDatabase
104827.06 4 db going down path [True]
104827.08 4 next module is [Get PIN No] (idx=84)
104827.08 4 fn RunModule start [Get Numbers,[Get PIN No],84,,]
104827.09 4 timer clear
104827.11 4 state [Get PIN No] Number Input
104827.11 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav)
104827.13 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav
104827.19 4 tw wav->vox convert end 531203,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,,
104827.20 4 play start ok, lPlayId=531265
104830.53 4 tw PlayEnd 4 531265
104830.55 4 play end id=531265, (current ID)
104830.55 4 event EV_PLAY_FINISHED, iCode=8001 state=1300
104830.56 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104830.56 4 path {EV_PLAY_FINISHED} not found
104830.58 4 timer set 7 EV_TIMEOUT_REPLAYMSG
104830.59 4 tw DialogicEvent 129,TDX_PLAY,531265,0,0,,,
104830.59 4 event TDX_PLAY, iCode=129 state=1301
104830.61 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY
104830.63 4 path {TDX_PLAY} not found
104830.80 4 tw dtmf 3 (4,51,51)
104830.80 4 event 3, iCode=51 state=1301
104830.81 4 LsGetNbrsRxDigits 3,3
104830.83 4 state [Get PIN No] Number Input 3
104830.83 4 path {3} not found
104830.84 4 timer set 6 EV_TIMEOUT_ENTERDATA
104831.34 4 tw dtmf 8 (4,56,56)
104831.36 4 event 8, iCode=56 state=1301
104831.36 4 LsGetNbrsRxDigits 8,8
104831.38 4 state [Get PIN No] Number Input 38
104831.39 4 path {38} not found
104831.39 4 timer set 6 EV_TIMEOUT_ENTERDATA
104831.73 4 tw dtmf 0 (4,48,48)
104831.73 4 event 0, iCode=48 state=1301
104831.75 4 LsGetNbrsRxDigits 0,0
104831.77 4 state [Get PIN No] Number Input 380
104831.77 4 path {380} not found
104831.78 4 timer set 6 EV_TIMEOUT_ENTERDATA
104832.31 4 tw dtmf 4 (4,52,52)
104832.33 4 event 4, iCode=52 state=1301
104832.34 4 LsGetNbrsRxDigits 4,4
104832.34 4 state [Get PIN No] Number Input 3804
104832.36 4 path {3804} not found
104832.38 4 timer set 6 EV_TIMEOUT_ENTERDATA
104832.38 4 timer clear
104832.39 4 rv add [Get PIN No]{3804}
104832.41 4 path {3804} not found
104832.41 4 next module is [Varify A/C No] (idx=60)
104832.42 4 rvns add [Get PIN No_PathTaken]{success}
104832.42 4 fn RunModule start [Database Query,[Varify A/C No],60,,]
104832.44 4 timer clear
104832.45 4 state [Varify A/C No] DB Query
104832.45 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;]
104832.50 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y']
104832.50 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:47:53 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4}
  1. {1}[Get Acc No]{0173400025}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}
104832.52 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y]
104832.53 4 db [Varify A/C No] row count=1
104832.55 4 rv add [Varify A/C No_RowCount]{1}
104832.55 4 db get RecordsetGetRowsMax
104832.56 4 db get 999 records. (row count=1)
104832.56 4 db update RVs
104832.58 4 db about to close dbDbqDatabase
104832.59 4 db going down path [True]
104832.61 4 next module is
  1. (idx=83)
104832.61 4 fn RunModule start [Play,
  1. ,83,,]
104832.63 4 timer clear
104832.63 4 Play Module start
104832.64 4 state
  1. Playing
104832.66 4 state
104832.66 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav
104832.72 4 tw wav->vox convert end 536734,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,,
104832.75 4 play start ok, lPlayId=536812
104845.38 4 tw PlayEnd 4 536812
104845.39 4 play end id=536812, (current ID)
104845.39 4 event EV_PLAY_FINISHED, iCode=8001 state=1100
104845.41 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
104845.41 4 path {EV_PLAY_FINISHED} not found
104845.42 4 timer set 7 EV_TIMEOUT_REPLAYMSG
104845.44 4 tw DialogicEvent 129,TDX_PLAY,536812,0,0,,,
104845.44 4 event TDX_PLAY, iCode=129 state=1101
104845.45 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
104845.47 4 path {TDX_PLAY} not found
104847.67 4 tw dtmf 1 (4,49,49)
104847.67 4 event 1, iCode=49 state=1101
104847.69 4 LsPlayMsgFinished 1,1
104847.70 4 next module is [say Bal 1] (idx=129)
104847.70 4 rv add
  1. {1}
104847.72 4 fn RunModule start [say Numbers,[say Bal 1],129,,]
104847.72 4 timer clear
104847.73 4 state [say Bal 1] Say numbers: 125 as Number
104847.75 4 fn PlaySoundStartNumbers [C:\Program Files\VoiceGuide\system\Bangla Voice\16 digit Credit Card No.wav],[],[125],Number
104847.75 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
104847.77 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
104847.78 4 rv add [Hangup Time]{01/10/2007 10:48:47 AM}
104847.78 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
104847.80 4 HangupCall_Common hCall=4
104847.81 4 rec RecSoundStop ok
104847.81 4 play PlayStop ok
104847.83 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
104847.84 4 fnHangupCall end
104847.88 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
104847.89 4 event TDX_SETHOOK, iCode=135 state=900
104847.91 4 LsAwaitingCalls EV_UNKNOWN_135
104847.91 4 event callstate IDLE 4 1,0,0
104847.92 4 WorkingMode@Idle=
104847.94 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
104847.94 4 timer clear
104847.95 4 rec RecSoundStop ok
104847.97 4 play PlayStop ok
104847.97 4 rv add [CallEndTime]{01/10/2007 10:48:47 AM}
104848.00 4 on-hangup script:[]
104848.02 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
104848.03 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
104848.03 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
104848.05 4 init atidle reinit : start
104848.05 4 init atidle reinit iConferenceOtherLegLid=-1
104848.06 4 init atidle reinit : reset all LineState variables
104848.08 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
104848.08 4 state Waiting for a call...
104850.28 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
104850.28 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
104850.30 4 setting iDialoutReadyToDialout = 1
105142.83 0 btn Hangup on line 1
105142.84 1 event EV_TIMEOUT_HANGUP, iCode=9001 state=0
105204.95 0 vm loading VMB data begin
105204.97 0 vm loading VMB data - about to delete old entries
105204.98 0 vm loading VMB data - sorting/ordering
105205.00 0 vm loading VMB data end
105205.02 0 Loaded new voicemail configuration file (XML)
105301.33 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105301.34 MemStructVgs_ClearVgs [3]
105301.34 load end
105301.36 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105301.38 0 Erasing Script (new loaded) Id 1
105301.39 0 VgsScriptFree [1]
105301.39 MemStructVgs_ClearVgs [1]
105320.41 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105320.42 MemStructVgs_ClearVgs [1]
105320.42 load end
105320.44 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
105320.45 0 Erasing Script (new loaded) Id 3
105320.47 0 VgsScriptFree [3]
105320.47 MemStructVgs_ClearVgs [3]
105451.50 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105451.52 MemStructVgs_ClearVgs [3]
105451.52 load end
105451.53 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105451.55 0 Erasing Script (new loaded) Id 1
105451.55 0 VgsScriptFree [1]
105451.56 MemStructVgs_ClearVgs [1]
105458.58 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105458.58 MemStructVgs_ClearVgs [1]
105458.59 load end
105458.61 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
105458.63 0 Erasing Script (new loaded) Id 3
105458.63 0 VgsScriptFree [3]
105458.64 MemStructVgs_ClearVgs [3]
105506.08 4 event callstate OFFERING 4 2,0,0
105506.08 4 script interpretor: VgMulti v6.0.3243
105506.09 4 fired OFFERING event to listeners
105506.16 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
105506.16 4 cid CallerID vars set (in 'offering' event) [,,]
105506.17 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
105506.19 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
105506.19 4 tw ring 1
105506.20 4 ring time since last ring event (sec): 0.00
105506.20 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
105506.22 4 should answer as number of rings reached
105506.23 4 rv clear all
105506.23 4 init LineState ResetAtStartOfNewCall.
105506.25 4 answering the call (,,,0)
105506.27 4 timer clear
105506.28 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
105506.28 4 event TDX_CST, iCode=134 state=6001
105506.30 4 LsModuleTransition : 134, [TDX_CST]
105506.91 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
105506.92 4 event TDX_SETHOOK, iCode=135 state=6001
105506.92 4 LsModuleTransition : 135, [TDX_SETHOOK]
105506.94 4 event callstate CONNECTED 4 256,0,0
105506.95 4 LineEvCallState_Connected hDevice=4 params=256,0,0
105506.95 4 WorkingModes tapi= script= LineState().iState=6001
105506.97 4 Inband detection not enabled
105506.98 4 StartLoadedVgs at 01/10/2007 10:55:06 AM (VgMulti v6.0.3243)
105506.98 4 set LineState().iVgsIdx=1
105507.00 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
105507.00 4 init StartLoadedVgs_InitLineState start
105507.02 4 rv add [$RV_STARTTIME]{01/10/2007 10:55:06 AM}
105507.03 4 rv add [$RV_DEVICEID]{4}
105507.03 4 rv add [DlgcNetworkResource]{dxxxB1C4}
105507.05 4 rv add [DlgcVoiceResource]{dxxxB1C4}
105507.06 4 rv add [$RV_CIDNAME]{}
105507.06 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
105507.08 4 rvns add [scriptsPath]{G:\TeleBanking System\}
105507.08 4 rv add [$RV_CIDNUMBER]{}
105507.09 4 fn RunModule start [Play,[Get Language],91,,]
105507.11 4 tw DialogicEvent 134,TDX_CST,37902,0,0,DE_LCON,,
105507.11 4 event TDX_CST, iCode=134 state=6001
105507.13 4 LsModuleTransition : 134, [TDX_CST]
105507.14 4 timer clear
105507.14 4 Play Module start
105507.16 4 state [Get Language] Playing
105507.17 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
105507.17 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
105507.19 4 tw wav->vox convert end 931250,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
105507.22 4 play start ok, lPlayId=931281
105507.80 4 tw dtmf 3 (4,51,51)
105507.80 4 event 3, iCode=51 state=1100
105507.81 4 LsPlayMsg 3,3
105507.83 4 next module is [say Bal 1] (idx=1)
105507.84 4 play PlayStop ok
105507.86 4 rv add [Get Language]{3}
105507.86 4 fn RunModule start [say Numbers,[say Bal 1],1,,]
105507.88 4 tw PlayEnd 4 931281
105507.88 4 play end id=931281, (current ID)
105507.89 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
105507.91 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
105507.91 4 tw DialogicEvent 129,TDX_PLAY,931281,0,0,,,
105507.92 4 event TDX_PLAY, iCode=129 state=6001
105507.94 4 LsModuleTransition : 129, [TDX_PLAY]
105507.94 4 timer clear
105507.95 4 state [say Bal 1] Say numbers: 200 as Number
105507.95 4 fn PlaySoundStartNumbers [],[],[200],Number
105507.97 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
105507.98 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
105507.98 4 rv add [Hangup Time]{01/10/2007 10:55:07 AM}
105508.00 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
105508.02 4 HangupCall_Common hCall=4
105508.02 4 rec RecSoundStop ok
105508.03 4 play PlayStop ok
105508.05 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
105508.05 4 fnHangupCall end
105508.86 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
105508.86 4 event TDX_SETHOOK, iCode=135 state=900
105508.88 4 LsAwaitingCalls EV_UNKNOWN_135
105508.89 4 event callstate IDLE 4 1,0,0
105508.89 4 WorkingMode@Idle=
105508.91 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
105508.92 4 timer clear
105508.92 4 rec RecSoundStop ok
105508.94 4 play PlayStop ok
105508.94 4 rv add [CallEndTime]{01/10/2007 10:55:08 AM}
105508.98 4 on-hangup script:[]
105508.98 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
105509.00 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
105509.00 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
105509.02 4 init atidle reinit : start
105509.03 4 init atidle reinit iConferenceOtherLegLid=-1
105509.03 4 init atidle reinit : reset all LineState variables
105509.05 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
105509.06 4 state Waiting for a call...
105511.25 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
105511.25 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
105511.27 4 setting iDialoutReadyToDialout = 1
105518.75 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105518.75 MemStructVgs_ClearVgs [3]
105518.77 load end
105518.78 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105518.80 0 Erasing Script (new loaded) Id 1
105518.80 0 VgsScriptFree [1]
105518.81 MemStructVgs_ClearVgs [1]
105623.84 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105623.84 MemStructVgs_ClearVgs [1]
105623.86 load end
105623.88 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
105623.89 0 Erasing Script (new loaded) Id 3
105623.89 0 VgsScriptFree [3]
105623.91 MemStructVgs_ClearVgs [3]
105635.92 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105635.94 MemStructVgs_ClearVgs [3]
105635.95 load end
105635.97 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105635.98 0 Erasing Script (new loaded) Id 1
105635.98 0 VgsScriptFree [1]
105636.00 MemStructVgs_ClearVgs [1]
105718.38 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105718.38 MemStructVgs_ClearVgs [1]
105718.39 load end
105718.41 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
105718.42 0 Erasing Script (new loaded) Id 3
105718.44 0 VgsScriptFree [3]
105718.44 MemStructVgs_ClearVgs [3]
105721.45 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105721.47 MemStructVgs_ClearVgs [3]
105721.48 load end
105721.50 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105721.50 0 Erasing Script (new loaded) Id 1
105721.52 0 VgsScriptFree [1]
105721.53 MemStructVgs_ClearVgs [1]
105725.55 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105725.55 MemStructVgs_ClearVgs [1]
105725.56 load end
105725.58 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
105725.59 0 Erasing Script (new loaded) Id 3
105725.59 0 VgsScriptFree [3]
105725.61 MemStructVgs_ClearVgs [3]
105736.78 4 event callstate OFFERING 4 2,0,0
105736.80 4 script interpretor: VgMulti v6.0.3243
105736.80 4 fired OFFERING event to listeners
105736.81 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
105736.83 4 cid CallerID vars set (in 'offering' event) [,,]
105736.83 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
105736.84 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
105736.86 4 tw ring 1
105736.86 4 ring time since last ring event (sec): 0.00
105736.88 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
105736.88 4 should answer as number of rings reached
105736.89 4 rv clear all
105736.91 4 init LineState ResetAtStartOfNewCall.
105736.91 4 answering the call (,,,0)
105736.92 4 timer clear
105736.94 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
105736.94 4 event TDX_CST, iCode=134 state=6001
105736.95 4 LsModuleTransition : 134, [TDX_CST]
105737.56 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
105737.58 4 event TDX_SETHOOK, iCode=135 state=6001
105737.59 4 LsModuleTransition : 135, [TDX_SETHOOK]
105737.59 4 event callstate CONNECTED 4 256,0,0
105737.61 4 LineEvCallState_Connected hDevice=4 params=256,0,0
105737.61 4 WorkingModes tapi= script= LineState().iState=6001
105737.63 4 Inband detection not enabled
105737.64 4 StartLoadedVgs at 01/10/2007 10:57:37 AM (VgMulti v6.0.3243)
105737.64 4 set LineState().iVgsIdx=1
105737.66 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
105737.67 4 init StartLoadedVgs_InitLineState start
105737.67 4 rv add [$RV_STARTTIME]{01/10/2007 10:57:37 AM}
105737.69 4 rv add [$RV_DEVICEID]{4}
105737.70 4 rv add [DlgcNetworkResource]{dxxxB1C4}
105737.70 4 rv add [DlgcVoiceResource]{dxxxB1C4}
105737.72 4 rv add [$RV_CIDNAME]{}
105737.72 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
105737.73 4 rvns add [scriptsPath]{G:\TeleBanking System\}
105737.75 4 rv add [$RV_CIDNUMBER]{}
105737.75 4 fn RunModule start [Play,[Get Language],1,,]
105737.77 4 tw DialogicEvent 134,TDX_CST,14871,0,0,DE_LCON,,
105737.78 4 event TDX_CST, iCode=134 state=6001
105737.78 4 LsModuleTransition : 134, [TDX_CST]
105737.80 4 timer clear
105737.81 4 Play Module start
105737.81 4 state [Get Language] Playing
105737.83 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
105737.83 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
105737.86 4 tw wav->vox convert end 81906,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
105737.88 4 play start ok, lPlayId=81953
105739.64 4 tw dtmf 1 (4,49,49)
105739.66 4 event 1, iCode=49 state=1100
105739.66 4 LsPlayMsg 1,1
105739.67 4 rv add [scriptEnd_Time]{01/10/2007 10:57:39 AM}
105739.69 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}
105739.69 4 rv add [scriptEnd_Goto_Module]{Get Bangla}
105739.72 4 rv add [scriptStart_Time]{01/10/2007 10:57:39 AM}
105739.73 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}
105739.75 4 rv add [scriptStart_CalledFrom_Module]{Get Language}
105739.75 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs]
105739.77 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4
105739.78 4 rvns add [scriptsPath]{G:\TeleBanking System\}
105739.80 4 play PlayStop ok
105739.81 4 rv add [Get Language]{1}
105739.81 4 fn RunModule start [Evaluate,[Get Bangla],64,,]
105739.83 4 tw PlayEnd 4 81953
105739.84 4 play end id=81953, (current ID)
105739.84 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
105739.86 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
105739.86 4 tw DialogicEvent 129,TDX_PLAY,81953,0,0,,,
105739.88 4 event TDX_PLAY, iCode=129 state=6001
105739.89 4 LsModuleTransition : 129, [TDX_PLAY]
105739.89 4 timer clear
105739.91 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
105739.92 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
105739.92 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
105739.94 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}
105739.95 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}
105739.95 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\]
105739.97 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE]
105739.98 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
105739.98 4 matching path not found
105740.00 4 next module is
  1. (idx=63)
105740.00 4 matching path was found
105740.02 4 fn RunModule start [Play,
  1. ,63,,]
105740.03 4 timer clear
105740.03 4 Play Module start
105740.05 4 state
  1. Playing
105740.06 4 state
105740.06 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav
105740.11 4 tw wav->vox convert end 84140,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,,
105740.13 4 play start ok, lPlayId=84187
105745.78 4 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,DISCONNECT_TAPI2,
105745.80 4 event DISCONNECT_TAPI2, iCode=134 state=1100
105745.81 4 LsPlayMsg EV_UNKNOWN_134,DISCONNECT_TAPI2
105745.81 4 path {DISCONNECT_TAPI2} not found
105745.83 4 HangupCall start (Default Handler 20: DISCONNECT_TAPI2)
105745.83 4 rv add [Hangup Time]{01/10/2007 10:57:45 AM}
105745.84 4 state Hanging up call... [Default Handler 20: DISCONNECT_TAPI2]
105745.86 4 HangupCall_Common hCall=4
105745.88 4 rec RecSoundStop ok
105745.89 4 play PlayStop ok
105745.91 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
105745.91 4 fnHangupCall end
105745.92 4 event TDX_CST, iCode=134 state=900
105745.94 4 LsAwaitingCalls EV_UNKNOWN_134
105745.94 4 tw PlayEnd 4 84187
105745.95 4 play end id=84187, (current ID)
105745.97 4 event EV_PLAY_FINISHED, iCode=8001 state=900
105745.97 4 LsAwaitingCalls EV_PLAY_FINISHED
105745.98 4 tw DialogicEvent 129,TDX_PLAY,84187,0,0,,,
105746.00 4 event TDX_PLAY, iCode=129 state=900
105746.00 4 LsAwaitingCalls EV_UNKNOWN_129
105746.02 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
105746.02 4 event TDX_SETHOOK, iCode=135 state=900
105746.03 4 LsAwaitingCalls EV_UNKNOWN_135
105746.05 4 event callstate IDLE 4 1,0,0
105746.05 4 WorkingMode@Idle=
105746.06 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
105746.08 4 timer clear
105746.08 4 rec RecSoundStop ok
105746.09 4 play PlayStop ok
105746.11 4 rv add [CallEndTime]{01/10/2007 10:57:46 AM}
105746.14 4 on-hangup script:[]
105746.14 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
105746.16 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
105746.17 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
105746.17 4 init atidle reinit : start
105746.19 4 init atidle reinit iConferenceOtherLegLid=-1
105746.20 4 init atidle reinit : reset all LineState variables
105746.20 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
105746.22 4 state Waiting for a call...
105748.42 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
105748.42 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
105748.44 4 setting iDialoutReadyToDialout = 1
105749.91 4 event callstate OFFERING 4 2,0,0
105749.92 4 script interpretor: VgMulti v6.0.3243
105749.92 4 fired OFFERING event to listeners
105749.94 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
105749.95 4 cid CallerID vars set (in 'offering' event) [,,]
105749.95 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
105749.97 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
105749.98 4 tw ring 1
105749.98 4 ring time since last ring event (sec): 0.00
105750.00 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
105750.00 4 should answer as number of rings reached
105750.02 4 rv clear all
105750.03 4 init LineState ResetAtStartOfNewCall.
105750.03 4 answering the call (,,,0)
105750.05 4 timer clear
105750.06 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
105750.08 4 event TDX_CST, iCode=134 state=6001
105750.08 4 LsModuleTransition : 134, [TDX_CST]
105750.69 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
105750.70 4 event TDX_SETHOOK, iCode=135 state=6001
105750.70 4 LsModuleTransition : 135, [TDX_SETHOOK]
105750.72 4 event callstate CONNECTED 4 256,0,0
105750.73 4 LineEvCallState_Connected hDevice=4 params=256,0,0
105750.73 4 WorkingModes tapi= script= LineState().iState=6001
105750.75 4 Inband detection not enabled
105750.77 4 StartLoadedVgs at 01/10/2007 10:57:50 AM (VgMulti v6.0.3243)
105750.77 4 set LineState().iVgsIdx=1
105750.78 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
105750.80 4 init StartLoadedVgs_InitLineState start
105750.80 4 rv add [$RV_STARTTIME]{01/10/2007 10:57:50 AM}
105750.81 4 rv add [$RV_DEVICEID]{4}
105750.81 4 rv add [DlgcNetworkResource]{dxxxB1C4}
105750.83 4 rv add [DlgcVoiceResource]{dxxxB1C4}
105750.84 4 rv add [$RV_CIDNAME]{}
105750.84 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
105750.86 4 rvns add [scriptsPath]{G:\TeleBanking System\}
105750.88 4 rv add [$RV_CIDNUMBER]{}
105750.88 4 fn RunModule start [Play,[Get Language],1,,]
105750.89 4 tw DialogicEvent 134,TDX_CST,473,0,0,DE_LCON,,
105750.89 4 event TDX_CST, iCode=134 state=6001
105750.91 4 LsModuleTransition : 134, [TDX_CST]
105750.92 4 timer clear
105750.92 4 Play Module start
105750.94 4 state [Get Language] Playing
105750.95 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
105750.95 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
105750.97 4 tw wav->vox convert end 95031,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
105750.98 4 play start ok, lPlayId=95062
105751.80 4 tw dtmf 3 (4,51,51)
105751.81 4 event 3, iCode=51 state=1100
105751.81 4 LsPlayMsg 3,3
105751.83 4 next module is [GetData] (idx=93)
105751.84 4 play PlayStop ok
105751.86 4 rv add [Get Language]{3}
105751.86 4 fn RunModule start [Evaluate,[GetData],93,,]
105751.88 4 tw PlayEnd 4 95062
105751.89 4 play end id=95062, (current ID)
105751.89 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
105751.91 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
105751.92 4 tw DialogicEvent 129,TDX_PLAY,95062,0,0,,,
105751.92 4 event TDX_PLAY, iCode=129 state=6001
105751.94 4 LsModuleTransition : 129, [TDX_PLAY]
105751.95 4 timer clear
105751.95 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
105751.97 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
105751.98 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
105751.98 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice}
105752.00 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice]
105752.00 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
105752.02 4 matching path not found
105752.03 4 next module is [say Bal 1] (idx=91)
105752.03 4 matching path was found
105752.05 4 fn RunModule start [say Numbers,[say Bal 1],91,,]
105752.06 4 timer clear
105752.06 4 state [say Bal 1] Say numbers: 200 as Number
105752.08 4 fn PlaySoundStartNumbers [],[],[200],Number
105752.09 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
105752.09 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
105752.11 4 rv add [Hangup Time]{01/10/2007 10:57:52 AM}
105752.13 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
105752.13 4 HangupCall_Common hCall=4
105752.14 4 rec RecSoundStop ok
105752.16 4 play PlayStop ok
105752.16 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
105752.17 4 fnHangupCall end
105752.64 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
105752.66 4 event TDX_SETHOOK, iCode=135 state=900
105752.67 4 LsAwaitingCalls EV_UNKNOWN_135
105752.67 4 event callstate IDLE 4 1,0,0
105752.69 4 WorkingMode@Idle=
105752.69 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
105752.70 4 timer clear
105752.72 4 rec RecSoundStop ok
105752.73 4 play PlayStop ok
105752.73 4 rv add [CallEndTime]{01/10/2007 10:57:52 AM}
105752.77 4 on-hangup script:[]
105752.78 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
105752.78 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
105752.80 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
105752.81 4 init atidle reinit : start
105752.81 4 init atidle reinit iConferenceOtherLegLid=-1
105752.83 4 init atidle reinit : reset all LineState variables
105752.84 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
105752.84 4 state Waiting for a call...
105755.05 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
105755.05 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
105755.06 4 setting iDialoutReadyToDialout = 1
105844.23 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105844.23 MemStructVgs_ClearVgs [3]
105844.25 load end
105844.27 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105844.28 0 Erasing Script (new loaded) Id 1
105844.28 0 VgsScriptFree [1]
105844.30 MemStructVgs_ClearVgs [1]
105905.31 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105905.31 MemStructVgs_ClearVgs [1]
105905.33 load end
105905.34 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
105905.36 0 Erasing Script (new loaded) Id 3
105905.36 0 VgsScriptFree [3]
105905.38 MemStructVgs_ClearVgs [3]
105909.38 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105909.38 MemStructVgs_ClearVgs [3]
105909.39 load end
105909.41 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105909.42 0 Erasing Script (new loaded) Id 1
105909.42 0 VgsScriptFree [1]
105909.44 MemStructVgs_ClearVgs [1]
105913.44 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105913.44 MemStructVgs_ClearVgs [1]
105913.45 load end
105913.47 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
105913.48 0 Erasing Script (new loaded) Id 3
105913.48 0 VgsScriptFree [3]
105913.50 MemStructVgs_ClearVgs [3]
105915.52 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105915.52 MemStructVgs_ClearVgs [3]
105915.53 load end
105915.55 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105915.56 0 Erasing Script (new loaded) Id 1
105915.56 0 VgsScriptFree [1]
105915.58 MemStructVgs_ClearVgs [1]
105917.59 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105917.59 MemStructVgs_ClearVgs [1]
105917.61 load end
105917.63 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
105917.64 0 Erasing Script (new loaded) Id 3
105917.64 0 VgsScriptFree [3]
105917.66 MemStructVgs_ClearVgs [3]
105919.67 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105919.67 MemStructVgs_ClearVgs [3]
105919.69 load end
105919.70 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105919.72 0 Erasing Script (new loaded) Id 1
105919.72 0 VgsScriptFree [1]
105919.73 MemStructVgs_ClearVgs [1]
105922.73 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105922.73 MemStructVgs_ClearVgs [1]
105922.75 load end
105922.77 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
105922.77 0 Erasing Script (new loaded) Id 3
105922.78 0 VgsScriptFree [3]
105922.80 MemStructVgs_ClearVgs [3]
105926.80 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
105926.80 MemStructVgs_ClearVgs [3]
105926.81 load end
105926.83 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
105926.84 0 Erasing Script (new loaded) Id 1
105926.86 0 VgsScriptFree [1]
105926.86 MemStructVgs_ClearVgs [1]
110035.50 4 event callstate OFFERING 4 2,0,0
110035.52 4 script interpretor: VgMulti v6.0.3243
110035.52 4 fired OFFERING event to listeners
110035.53 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
110035.53 4 cid CallerID vars set (in 'offering' event) [,,]
110035.55 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
110035.56 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
110035.56 4 tw ring 1
110035.58 4 ring time since last ring event (sec): 0.00
110035.59 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
110035.59 4 should answer as number of rings reached
110035.61 4 rv clear all
110035.63 4 init LineState ResetAtStartOfNewCall.
110035.63 4 answering the call (,,,0)
110035.64 4 timer clear
110035.66 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
110035.67 4 event TDX_CST, iCode=134 state=6001
110035.67 4 LsModuleTransition : 134, [TDX_CST]
110036.28 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
110036.30 4 event TDX_SETHOOK, iCode=135 state=6001
110036.31 4 LsModuleTransition : 135, [TDX_SETHOOK]
110036.31 4 event callstate CONNECTED 4 256,0,0
110036.33 4 LineEvCallState_Connected hDevice=4 params=256,0,0
110036.34 4 WorkingModes tapi= script= LineState().iState=6001
110036.34 4 Inband detection not enabled
110036.36 4 StartLoadedVgs at 01/10/2007 11:00:36 AM (VgMulti v6.0.3243)
110036.38 4 set LineState().iVgsIdx=3
110036.38 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
110036.39 4 init StartLoadedVgs_InitLineState start
110036.41 4 rv add [$RV_STARTTIME]{01/10/2007 11:00:36 AM}
110036.41 4 rv add [$RV_DEVICEID]{4}
110036.42 4 rv add [DlgcNetworkResource]{dxxxB1C4}
110036.42 4 rv add [DlgcVoiceResource]{dxxxB1C4}
110036.44 4 rv add [$RV_CIDNAME]{}
110036.45 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
110036.45 4 rvns add [scriptsPath]{G:\TeleBanking System\}
110036.47 4 rv add [$RV_CIDNUMBER]{}
110036.48 4 fn RunModule start [Play,[Get Language],89,,]
110036.48 4 tw DialogicEvent 134,TDX_CST,16364,0,0,DE_LCON,,
110036.50 4 event TDX_CST, iCode=134 state=6001
110036.52 4 LsModuleTransition : 134, [TDX_CST]
110036.53 4 timer clear
110036.53 4 Play Module start
110036.55 4 state [Get Language] Playing
110036.56 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
110036.56 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
110036.63 4 tw wav->vox convert end 260640,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
110036.64 4 play start ok, lPlayId=260718
110037.47 4 tw dtmf 3 (4,51,51)
110037.48 4 event 3, iCode=51 state=1100
110037.48 4 LsPlayMsg 3,3
110037.50 4 next module is [GetData] (idx=96)
110037.52 4 play PlayStop ok
110037.53 4 rv add [Get Language]{3}
110037.55 4 fn RunModule start [Evaluate,[GetData],96,,]
110037.55 4 tw PlayEnd 4 260718
110037.56 4 play end id=260718, (current ID)
110037.56 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
110037.58 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
110037.59 4 tw DialogicEvent 129,TDX_PLAY,260718,0,0,,,
110037.59 4 event TDX_PLAY, iCode=129 state=6001
110037.61 4 LsModuleTransition : 129, [TDX_PLAY]
110037.63 4 timer clear
110037.64 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
110037.66 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
110037.66 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
110037.67 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice}
110037.67 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice]
110037.69 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
110037.70 4 matching path not found
110037.70 4 next module is [say Bal 1] (idx=94)
110037.72 4 matching path was found
110037.73 4 fn RunModule start [say Numbers,[say Bal 1],94,,]
110037.73 4 timer clear
110037.75 4 state [say Bal 1] Say numbers: 200 as Number
110037.77 4 fn PlaySoundStartNumbers [],[],[200],Number
110037.77 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
110037.78 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
110037.80 4 rv add [Hangup Time]{01/10/2007 11:00:37 AM}
110037.80 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
110037.81 4 HangupCall_Common hCall=4
110037.83 4 rec RecSoundStop ok
110037.83 4 play PlayStop ok
110037.84 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
110037.86 4 fnHangupCall end
110038.23 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
110038.25 4 event TDX_SETHOOK, iCode=135 state=900
110038.25 4 LsAwaitingCalls EV_UNKNOWN_135
110038.27 4 event callstate IDLE 4 1,0,0
110038.27 4 WorkingMode@Idle=
110038.28 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
110038.30 4 timer clear
110038.30 4 rec RecSoundStop ok
110038.31 4 play PlayStop ok
110038.33 4 rv add [CallEndTime]{01/10/2007 11:00:38 AM}
110038.36 4 on-hangup script:[]
110038.38 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
110038.38 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
110038.39 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
110038.41 4 init atidle reinit : start
110038.41 4 init atidle reinit iConferenceOtherLegLid=-1
110038.42 4 init atidle reinit : reset all LineState variables
110038.42 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
110038.44 4 state Waiting for a call...
110040.64 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
110040.64 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
110040.66 4 setting iDialoutReadyToDialout = 1
110145.19 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
110145.19 MemStructVgs_ClearVgs [1]
110145.20 load end
110145.22 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
110145.23 0 Erasing Script (new loaded) Id 3
110145.23 0 VgsScriptFree [3]
110145.25 MemStructVgs_ClearVgs [3]
110205.28 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
110205.28 MemStructVgs_ClearVgs [3]
110205.30 load end
110205.31 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
110205.33 0 Erasing Script (new loaded) Id 1
110205.33 0 VgsScriptFree [1]
110205.34 MemStructVgs_ClearVgs [1]
110212.34 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
110212.34 MemStructVgs_ClearVgs [1]
110212.36 load end
110212.38 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs
110212.39 0 Erasing Script (new loaded) Id 3
110212.41 0 VgsScriptFree [3]
110212.41 MemStructVgs_ClearVgs [3]
110219.69 4 event callstate OFFERING 4 2,0,0
110219.70 4 script interpretor: VgMulti v6.0.3243
110219.72 4 fired OFFERING event to listeners
110219.72 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
110219.73 4 cid CallerID vars set (in 'offering' event) [,,]
110219.75 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
110219.75 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
110219.77 4 tw ring 1
110219.78 4 ring time since last ring event (sec): 0.00
110219.78 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
110219.80 4 should answer as number of rings reached
110219.81 4 rv clear all
110219.81 4 init LineState ResetAtStartOfNewCall.
110219.83 4 answering the call (,,,0)
110219.83 4 timer clear
110219.84 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
110219.86 4 event TDX_CST, iCode=134 state=6001
110219.88 4 LsModuleTransition : 134, [TDX_CST]
110220.48 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
110220.50 4 event TDX_SETHOOK, iCode=135 state=6001
110220.50 4 LsModuleTransition : 135, [TDX_SETHOOK]
110220.52 4 event callstate CONNECTED 4 256,0,0
110220.53 4 LineEvCallState_Connected hDevice=4 params=256,0,0
110220.53 4 WorkingModes tapi= script= LineState().iState=6001
110220.55 4 Inband detection not enabled
110220.56 4 StartLoadedVgs at 01/10/2007 11:02:20 AM (VgMulti v6.0.3243)
110220.56 4 set LineState().iVgsIdx=1
110220.58 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
110220.58 4 init StartLoadedVgs_InitLineState start
110220.59 4 rv add [$RV_STARTTIME]{01/10/2007 11:02:20 AM}
110220.61 4 rv add [$RV_DEVICEID]{4}
110220.61 4 rv add [DlgcNetworkResource]{dxxxB1C4}
110220.63 4 rv add [DlgcVoiceResource]{dxxxB1C4}
110220.64 4 rv add [$RV_CIDNAME]{}
110220.64 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
110220.66 4 rvns add [scriptsPath]{G:\TeleBanking System\}
110220.67 4 rv add [$RV_CIDNUMBER]{}
110220.67 4 fn RunModule start [Play,[Get Language],1,,]
110220.69 4 tw DialogicEvent 134,TDX_CST,10225,0,0,DE_LCON,,
110220.70 4 event TDX_CST, iCode=134 state=6001
110220.70 4 LsModuleTransition : 134, [TDX_CST]
110220.72 4 timer clear
110220.73 4 Play Module start
110220.73 4 state [Get Language] Playing
110220.75 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
110220.77 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
110220.78 4 tw wav->vox convert end 364843,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
110220.80 4 play start ok, lPlayId=364859
110221.98 4 tw dtmf 3 (4,51,51)
110221.98 4 event 3, iCode=51 state=1100
110222.00 4 LsPlayMsg 3,3
110222.02 4 next module is [GetData] (idx=93)
110222.03 4 play PlayStop ok
110222.03 4 rv add [Get Language]{3}
110222.05 4 fn RunModule start [Evaluate,[GetData],93,,]
110222.06 4 tw PlayEnd 4 364859
110222.06 4 play end id=364859, (current ID)
110222.08 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
110222.09 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
110222.09 4 tw DialogicEvent 129,TDX_PLAY,364859,0,0,,,
110222.11 4 event TDX_PLAY, iCode=129 state=6001
110222.13 4 LsModuleTransition : 129, [TDX_PLAY]
110222.14 4 timer clear
110222.14 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
110222.16 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
110222.17 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
110222.17 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice}
110222.19 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice]
110222.20 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
110222.20 4 matching path not found
110222.22 4 next module is [say Bal 1] (idx=91)
110222.23 4 matching path was found
110222.23 4 fn RunModule start [say Numbers,[say Bal 1],91,,]
110222.25 4 timer clear
110222.27 4 state [say Bal 1] Say numbers: ARIF as Digits
110222.27 4 fn PlaySoundStartNumbers [],[],[ARIF],Digits
110222.28 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
110222.30 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
110222.30 4 rv add [Hangup Time]{01/10/2007 11:02:22 AM}
110222.31 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
110222.33 4 HangupCall_Common hCall=4
110222.33 4 rec RecSoundStop ok
110222.34 4 play PlayStop ok
110222.36 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
110222.36 4 fnHangupCall end
110222.44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
110222.44 4 event TDX_SETHOOK, iCode=135 state=900
110222.45 4 LsAwaitingCalls EV_UNKNOWN_135
110222.47 4 event callstate IDLE 4 1,0,0
110222.47 4 WorkingMode@Idle=
110222.48 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
110222.50 4 timer clear
110222.50 4 rec RecSoundStop ok
110222.52 4 play PlayStop ok
110222.53 4 rv add [CallEndTime]{01/10/2007 11:02:22 AM}
110222.56 4 on-hangup script:[]
110222.58 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
110222.58 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
110222.59 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
110222.61 4 init atidle reinit : start
110222.61 4 init atidle reinit iConferenceOtherLegLid=-1
110222.63 4 init atidle reinit : reset all LineState variables
110222.63 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
110222.64 4 state Waiting for a call...
110224.84 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
110224.84 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
110224.86 4 setting iDialoutReadyToDialout = 1
110240.17 4 event callstate OFFERING 4 2,0,0
110240.19 4 script interpretor: VgMulti v6.0.3243
110240.20 4 fired OFFERING event to listeners
110240.20 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
110240.22 4 cid CallerID vars set (in 'offering' event) [,,]
110240.23 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
110240.23 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
110240.25 4 tw ring 1
110240.27 4 ring time since last ring event (sec): 0.00
110240.27 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
110240.28 4 should answer as number of rings reached
110240.30 4 rv clear all
110240.30 4 init LineState ResetAtStartOfNewCall.
110240.31 4 answering the call (,,,0)
110240.33 4 timer clear
110240.34 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
110240.36 4 event TDX_CST, iCode=134 state=6001
110240.36 4 LsModuleTransition : 134, [TDX_CST]
110240.97 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
110240.98 4 event TDX_SETHOOK, iCode=135 state=6001
110240.98 4 LsModuleTransition : 135, [TDX_SETHOOK]
110241.00 4 event callstate CONNECTED 4 256,0,0
110241.02 4 LineEvCallState_Connected hDevice=4 params=256,0,0
110241.02 4 WorkingModes tapi= script= LineState().iState=6001
110241.03 4 Inband detection not enabled
110241.05 4 StartLoadedVgs at 01/10/2007 11:02:41 AM (VgMulti v6.0.3243)
110241.05 4 set LineState().iVgsIdx=1
110241.06 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
110241.08 4 init StartLoadedVgs_InitLineState start
110241.08 4 rv add [$RV_STARTTIME]{01/10/2007 11:02:41 AM}
110241.09 4 rv add [$RV_DEVICEID]{4}
110241.11 4 rv add [DlgcNetworkResource]{dxxxB1C4}
110241.11 4 rv add [DlgcVoiceResource]{dxxxB1C4}
110241.13 4 rv add [$RV_CIDNAME]{}
110241.14 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
110241.14 4 rvns add [scriptsPath]{G:\TeleBanking System\}
110241.16 4 rv add [$RV_CIDNUMBER]{}
110241.16 4 fn RunModule start [Play,[Get Language],1,,]
110241.17 4 tw DialogicEvent 134,TDX_CST,1854,0,0,DE_LCON,,
110241.19 4 event TDX_CST, iCode=134 state=6001
110241.19 4 LsModuleTransition : 134, [TDX_CST]
110241.22 4 timer clear
110241.22 4 Play Module start
110241.23 4 state [Get Language] Playing
110241.25 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
110241.25 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
110241.30 4 tw wav->vox convert end 385328,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
110241.31 4 play start ok, lPlayId=385375
110244.08 4 tw dtmf 3 (4,51,51)
110244.09 4 event 3, iCode=51 state=1100
110244.11 4 LsPlayMsg 3,3
110244.11 4 next module is [GetData] (idx=93)
110244.13 4 play PlayStop ok
110244.14 4 rv add [Get Language]{3}
110244.16 4 fn RunModule start [Evaluate,[GetData],93,,]
110244.16 4 tw PlayEnd 4 385375
110244.17 4 play end id=385375, (current ID)
110244.19 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
110244.19 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
110244.20 4 tw DialogicEvent 129,TDX_PLAY,385375,0,0,,,
110244.22 4 event TDX_PLAY, iCode=129 state=6001
110244.22 4 LsModuleTransition : 129, [TDX_PLAY]
110244.23 4 timer clear
110244.25 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
110244.27 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
110244.27 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
110244.28 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice}
110244.30 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice]
110244.30 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
110244.31 4 matching path not found
110244.33 4 next module is [say Bal 1] (idx=91)
110244.33 4 matching path was found
110244.34 4 fn RunModule start [say Numbers,[say Bal 1],91,,]
110244.36 4 timer clear
110244.36 4 state [say Bal 1] Say numbers: ARIF as Digits
110244.38 4 fn PlaySoundStartNumbers [],[],[ARIF],Digits
110244.39 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide
110244.39 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
110244.41 4 rv add [Hangup Time]{01/10/2007 11:02:44 AM}
110244.42 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
110244.42 4 HangupCall_Common hCall=4
110244.44 4 rec RecSoundStop ok
110244.45 4 play PlayStop ok
110244.45 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
110244.47 4 fnHangupCall end
110244.52 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
110244.52 4 event TDX_SETHOOK, iCode=135 state=900
110244.53 4 LsAwaitingCalls EV_UNKNOWN_135
110244.55 4 event callstate IDLE 4 1,0,0
110244.55 4 WorkingMode@Idle=
110244.56 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
110244.58 4 timer clear
110244.58 4 rec RecSoundStop ok
110244.59 4 play PlayStop ok
110244.61 4 rv add [CallEndTime]{01/10/2007 11:02:44 AM}
110244.64 4 on-hangup script:[]
110244.64 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
110244.66 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
110244.67 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
110244.67 4 init atidle reinit : start
110244.69 4 init atidle reinit iConferenceOtherLegLid=-1
110244.70 4 init atidle reinit : reset all LineState variables
110244.70 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
110244.72 4 state Waiting for a call...
110246.92 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
110246.92 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
110246.94 4 setting iDialoutReadyToDialout = 1
110557.48 load start [G:\TeleBanking System\Tele Banking_Main.vgs]
110557.48 MemStructVgs_ClearVgs [3]
110557.50 load end
110557.52 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs
110557.53 0 Erasing Script (new loaded) Id 1
110557.55 0 VgsScriptFree [1]
110557.56 MemStructVgs_ClearVgs [1]
110604.17 4 event callstate OFFERING 4 2,0,0
110604.19 4 script interpretor: VgMulti v6.0.3243
110604.19 4 fired OFFERING event to listeners
110604.20 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING
110604.22 4 cid CallerID vars set (in 'offering' event) [,,]
110604.22 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
110604.23 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
110604.25 4 tw ring 1
110604.25 4 ring time since last ring event (sec): 0.00
110604.27 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
110604.28 4 should answer as number of rings reached
110604.28 4 rv clear all
110604.30 4 init LineState ResetAtStartOfNewCall.
110604.31 4 answering the call (,,,0)
110604.31 4 timer clear
110604.33 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
110604.34 4 event TDX_CST, iCode=134 state=6001
110604.36 4 LsModuleTransition : 134, [TDX_CST]
110604.97 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
110604.97 4 event TDX_SETHOOK, iCode=135 state=6001
110604.98 4 LsModuleTransition : 135, [TDX_SETHOOK]
110605.00 4 event callstate CONNECTED 4 256,0,0
110605.02 4 LineEvCallState_Connected hDevice=4 params=256,0,0
110605.03 4 WorkingModes tapi= script= LineState().iState=6001
110605.03 4 Inband detection not enabled
110605.05 4 StartLoadedVgs at 01/10/2007 11:06:05 AM (VgMulti v6.0.3243)
110605.06 4 set LineState().iVgsIdx=3
110605.06 4 set sScriptToRunOnHangup=[] in StartLoadedVgs
110605.08 4 init StartLoadedVgs_InitLineState start
110605.09 4 rv add [$RV_STARTTIME]{01/10/2007 11:06:05 AM}
110605.09 4 rv add [$RV_DEVICEID]{4}
110605.11 4 rv add [DlgcNetworkResource]{dxxxB1C4}
110605.13 4 rv add [DlgcVoiceResource]{dxxxB1C4}
110605.13 4 rv add [$RV_CIDNAME]{}
110605.14 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
110605.16 4 rvns add [scriptsPath]{G:\TeleBanking System\}
110605.16 4 rv add [$RV_CIDNUMBER]{}
110605.17 4 fn RunModule start [Play,[Get Language],89,,]
110605.19 4 tw DialogicEvent 134,TDX_CST,20045,0,0,DE_LCON,,
110605.19 4 event TDX_CST, iCode=134 state=6001
110605.20 4 LsModuleTransition : 134, [TDX_CST]
110605.22 4 timer clear
110605.22 4 Play Module start
110605.23 4 state [Get Language] Playing
110605.25 4 state [Get Language] Playing (Bangla Voice\Welcome.wav)
110605.25 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav
110605.28 4 tw wav->vox convert end 589328,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,,
110605.31 4 play start ok, lPlayId=589375
110606.52 4 tw dtmf 3 (4,51,51)
110606.53 4 event 3, iCode=51 state=1100
110606.53 4 LsPlayMsg 3,3
110606.55 4 next module is [GetData] (idx=96)
110606.58 4 play PlayStop ok
110606.58 4 rv add [Get Language]{3}
110606.59 4 fn RunModule start [Evaluate,[GetData],96,,]
110606.64 4 tw PlayEnd 4 589375
110606.66 4 play end id=589375, (current ID)
110606.66 4 event EV_PLAY_FINISHED, iCode=8001 state=6001
110606.67 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED]
110606.69 4 tw DialogicEvent 129,TDX_PLAY,589375,0,0,,,
110606.69 4 event TDX_PLAY, iCode=129 state=6001
110606.70 4 LsModuleTransition : 129, [TDX_PLAY]
110606.72 4 timer clear
110606.73 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"]
110606.73 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")]
110606.75 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}
110606.77 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice}
110606.77 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice]
110606.78 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found
110606.78 4 matching path not found
110606.80 4 next module is [say Bal 1] (idx=94)
110606.81 4 matching path was found
110606.81 4 fn RunModule start [say Numbers,[say Bal 1],94,,]
110606.83 4 timer clear
110606.84 4 state [say Bal 1] Say numbers: 200 as Number
110606.84 4 fn PlaySoundStartNumbers [],[],[200],Number
110606.88 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide110606.89 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040)
110606.89 4 rv add [Hangup Time]{01/10/2007 11:06:06 AM}
110606.91 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040]
110606.92 4 HangupCall_Common hCall=4
110606.92 4 rec RecSoundStop ok
110606.94 4 play PlayStop ok
110606.95 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
110606.95 4 fnHangupCall end
110607.00 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
110607.02 4 event TDX_SETHOOK, iCode=135 state=900
110607.03 4 LsAwaitingCalls EV_UNKNOWN_135
110607.03 4 event callstate IDLE 4 1,0,0
110607.05 4 WorkingMode@Idle=
110607.06 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE
110607.06 4 timer clear
110607.08 4 rec RecSoundStop ok
110607.09 4 play PlayStop ok
110607.09 4 rv add [CallEndTime]{01/10/2007 11:06:07 AM}
110607.14 4 on-hangup script:[]
110607.14 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE
110607.16 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
110607.17 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900
110607.17 4 init atidle reinit : start
110607.19 4 init atidle reinit iConferenceOtherLegLid=-1
110607.20 4 init atidle reinit : reset all LineState variables
110607.20 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT
110607.22 4 state Waiting for a call...
110609.42 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT
110609.42 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900
110609.44 4 setting iDialoutReadyToDialout = 1
Plz reply.
1001vgm.txt
Please do not post long traces as part of message. It makes the post hard to read.
Trace shows that you are using v6.0.3243 of VoiceGuide. Please update to the latest v6 and see if you get better results with this newer version.
