era Report post Posted 09/23/2007 06:07 AM Dear Sir What's the problem in this-- <?xml version="1.0"?> <VoiceGuideConfig> <Devices_Dialogic> <Channels> <Channel> <Name>dxxxB1C1</Name> <NetworkIf>dxxxB1C1</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>0</RingsBeforeAnswer> <script>F:\Tele Banking System\Tele Banking_Main.vgs</Script> <ConfigLine></ConfigLine> <AllowDialOut>1</AllowDialOut> <PopupCallerId>0</PopupCallerId> <RV></RV> </Channel> <Channel> <Name>dxxxB1C2</Name> <NetworkIf>dxxxB1C2</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>0</RingsBeforeAnswer> <script>F:\Tele Banking System\Tele Banking_Main.vgs</Script> <ConfigLine></ConfigLine> <AllowDialOut>1</AllowDialOut> <PopupCallerId>0</PopupCallerId> <RV></RV> </Channel> <Channel> <Name>dxxxB1C3</Name> <NetworkIf>dxxxB1C3</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>0</RingsBeforeAnswer> <script>F:\Tele Banking System\Tele Banking_Main.vgs</Script> <ConfigLine></ConfigLine> <AllowDialOut>1</AllowDialOut> <PopupCallerId>0</PopupCallerId> <RV></RV> </Channel> <Channel> <Name>dxxxB1C4</Name> <NetworkIf>dxxxB1C4</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>0</RingsBeforeAnswer> <script>F:\Tele Banking System\Tele Banking_Main.vgs</Script> <ConfigLine></ConfigLine> <AllowDialOut>1</AllowDialOut> <PopupCallerId>0</PopupCallerId> <RV></RV> </Channel> </Channels> <Parameters_DxBd> <Notes> ******************************************************************************** ************************* ******************************************************************************** ************************* DXBD_ (voice board) parameters Parameters specified here will be set for every DX (voice) board found to be started by the DCM in the system. ******************************************************************************** ************************* ******************************************************************************** ************************* </Notes> <Parameter> <Description>Flash time during dialing (10ms units)</Description> <Key>DXBD_FLASHTM</Key> <Value>10</Value> <Default>10</Default> </Parameter> <NotUsedByDefault> <Notes> MF param setting causes long delays on some boards. Remove NotUsedByDefault tags if the MF param setting is desired. </Notes> <Parameter> <Description>MF Interdigit Delay (10 ms units)</Description> <Key>DXBD_MFDELAY</Key> <Value>6</Value> <Default>6</Default> </Parameter> <Parameter> <Description>MF Length of LKP Tone Maximum value: 15 (10 ms units)</Description> <Key>DXBD_MFLKPTONE</Key> <Value>10</Value> <Default>10</Default> </Parameter> <Parameter> <Description>Minimum MF On. Added to the standard MF tone duration before the tone is detected. (10 ms units) The minimum detection duration is 65 ms for KP tones and 40 ms for all other tones.</Description> <Key>DXBD_MFMINON</Key> <Value>0</Value> <Default>0</Default> </Parameter> <Parameter> <Description>MF Minimum Tone Duration (10 ms units)</Description> <Key>DXBD_MFTONE</Key> <Value>6</Value> <Default>6</Default> </Parameter> </NotUsedByDefault> <Parameter> <Description>Minimum Loop Current off time before it is reported</Description> <Key>DXBD_MINLCOFF</Key> <Value>50</Value> <Default>50</Default> </Parameter> <Parameter> <Description>Minimum offhook time</Description> <Key>DXBD_MINOFFHKTM</Key> <Value>250</Value> <Default>250</Default> </Parameter> <Parameter> <Description>Minimum Silence Off</Description> <Key>DXBD_MINSLOFF</Key> <Value>2</Value> <Default>2</Default> </Parameter> <Parameter> <Description>Minimum Silence On</Description> <Key>DXBD_MINSLON</Key> <Value>1</Value> <Default>1</Default> </Parameter> <Parameter> <Description>Minimum DTI Off - minimum time required between rings-received events</Description> <Key>DXBD_MINTIOFF</Key> <Value>5</Value> <Default>5</Default> </Parameter> <Parameter> <Description>Minimum DTI On - minimum time required for rings received event</Description> <Key>DXBD_MINTION</Key> <Value>5</Value> <Default>5</Default> </Parameter> <Parameter> <Description>Offhook Delay - period after offhook, during which no events are generated e.g., no DTMF digits will be detected during this period.</Description> <Key>DXBD_OFFHDLY</Key> <Value>50</Value> <Default>50</Default> </Parameter> <Parameter> <Description>Pause Time. Delay caused by a comma in the dialing string (10ms units)</Description> <Key>DXBD_PAUSETM</Key> <Value>100</Value> <Default>100</Default> </Parameter> <Parameter> <Description>Silence and Non-silence Debounce</Description> <Key>DXBD_S_BNC</Key> <Value>4</Value> <Default>4</Default> </Parameter> <Parameter> <Description>DTMF Interdigit Delay. Time between digits in DTMF dialing (10ms units)</Description> <Key>DXBD_T_IDD</Key> <Value>15</Value> <Default>10</Default> </Parameter> <Parameter> <Description>DTMF length (duration) for dialing (10ms units)</Description> <Key>DXBD_TTDATA</Key> <Value>10</Value> <Default>10</Default> </Parameter> <Parameter> <Description>Silence on and off debounce time (10ms units)</Description> <Notes>debunce length should be really small so that we can easily tell when the transition happens</Notes> <Key>DXBD_S_BNC</Key> <Value>4</Value> <Default>4</Default> </Parameter> </Parameters_DxBd> </Devices_Dialogic> <Notes> ******************************************************************************** ************************* ******************************************************************************** ************************* CTI Devices ******************************************************************************** ************************* ******************************************************************************** ************************* </Notes> <Devices_CTI> <CtiLink> <CommsLink> <Target></Target> <Notes></Notes> <IP></IP> <Port></Port> <Params></Params> </CommsLink> <MonitoredDevices> <Ext></Ext> <Ext></Ext> </MonitoredDevices> </CtiLink> </Devices_CTI> </VoiceGuideConfig> Share this post Link to post
SupportTeam Report post Posted 09/23/2007 11:13 AM The Config.xml looks fine (for a 4 line analog system). What is the actual problem that you are experiencing? Share this post Link to post
era Report post Posted 09/24/2007 03:57 AM Dear Sir, Now I face a problem As per example : My Numeric Field contans : 9524 I want to say with sound : Nine Thousand Five Hundred Twenty four How can this possible for sound file and what change in 'lib_num2wav' file ? All the best. Reply plz From Bank Asia Ltd. Share this post Link to post
SupportTeam Report post Posted 09/24/2007 05:20 AM Please post questions on a new topic in a new thread - in order to keep unrelated questions separate and under appropriately described headings. Please post a full description of your question: What you are trying to achieve and what is the actual problem that you are having, along with related VoiceGuide scripts which you are currently using and relevant VoiceGuide traces. Please start a new thread for this new question. Share this post Link to post
era Report post Posted 10/01/2007 05:18 AM Dear Sir Plz reply. Sound files error in 1024 lines. 091835.39 0 --------------------------------------------------- 091835.41 0 VoiceGuide for Dialogic 091835.42 0 v6.0.3243 091835.42 0 --------------------------------------------------- 091835.42 0 rv global loaded >>><<< 091835.44 0 cti Inband Signaling Config file not specified 091837.39 0 init ApiMode=[DialogicGC] 091837.42 0 vm loading VMB data begin 091837.42 0 vm loading VMB data - about to delete old entries 091837.44 0 vm loading VMB data - sorting/ordering 091837.44 0 vm loading VMB data end 091837.45 0 dial DbConnectString_ADO is blank 091837.48 0 init DB Workspaces 091837.50 0 init Voicemail LoadIniSettings 091837.52 0 init VmEmailBody_MainGlobalTemplate loaded from C:\Program Files\VoiceGuide\system\vm\EmailForwardTemplate_body.txt 091837.53 0 init temp dir exists [C:\Program Files\VoiceGuide\temp\] 091837.53 0 init read Config.xml start 091837.55 0 dxxxB1C1 dxxxB1C1 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1 091837.55 0 dxxxB1C2 dxxxB1C2 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1 091837.56 0 dxxxB1C3 dxxxB1C3 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1 091837.56 0 dxxxB1C4 dxxxB1C4 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1 091837.56 0 init read Config.xml end 091837.58 0 init LineOpenDialogic dxxxB1C1 => [1] 091837.58 1 iIvrDev=1 091837.63 0 init distinct ring definitions found:0 091837.63 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig) 091837.64 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 091837.64 MemStructVgs_ClearVgs [1] 091837.66 load end 091837.66 1 state Waiting for a call... 091837.66 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 091837.67 1 event TDX_SETHOOK, iCode=135 state=0 091837.67 1 event callstate IDLE 1 1,0,0 091837.67 1 WorkingMode@Idle= 091837.69 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 091837.69 1 timer clear 091837.69 1 LineState(iLineId).iVgsIdx = 0 091837.69 1 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 091837.70 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091837.70 1 timer set ignored - waiting for line re-init to occur first 091837.72 0 init LineOpenDialogic dxxxB1C2 => [2] 091837.72 2 iIvrDev=2 091837.75 0 init distinct ring definitions found:0 091837.75 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig) 091837.77 2 state Waiting for a call... 091837.77 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 091837.77 2 event TDX_SETHOOK, iCode=135 state=0 091837.78 2 event callstate IDLE 2 1,0,0 091837.78 2 WorkingMode@Idle= 091837.78 2 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 091837.80 2 timer clear 091837.80 2 LineState(iLineId).iVgsIdx = 0 091837.80 2 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 091837.81 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 091837.81 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0 091837.81 1 init atidle reinit : start 091837.81 1 init atidle reinit iConferenceOtherLegLid=-1 091837.83 1 init atidle reinit : reset all LineState variables 091837.83 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091837.83 1 state Waiting for a call... 091837.84 2 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091837.84 2 timer set ignored - waiting for line re-init to occur first 091837.86 0 init LineOpenDialogic dxxxB1C3 => [3] 091837.86 3 iIvrDev=3 091837.89 0 init distinct ring definitions found:0 091837.91 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig) 091837.91 3 state Waiting for a call... 091837.91 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 091837.92 3 event TDX_SETHOOK, iCode=135 state=0 091837.92 3 event callstate IDLE 3 1,0,0 091837.92 3 WorkingMode@Idle= 091837.94 3 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 091837.94 3 timer clear 091837.94 3 LineState(iLineId).iVgsIdx = 0 091837.95 3 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 091837.95 2 timer fired EV_TIMEOUT_TIMETOREINITLINE 091837.95 2 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0 091837.97 2 init atidle reinit : start 091837.97 2 init atidle reinit iConferenceOtherLegLid=-1 091837.97 2 init atidle reinit : reset all LineState variables 091837.98 2 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091837.98 2 state Waiting for a call... 091837.98 3 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091838.00 3 timer set ignored - waiting for line re-init to occur first 091838.00 0 init LineOpenDialogic dxxxB1C4 => [4] 091838.02 4 iIvrDev=4 091838.05 0 init distinct ring definitions found:0 091838.05 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig) 091838.06 4 state Waiting for a call... 091838.06 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 091838.06 4 event TDX_SETHOOK, iCode=135 state=0 091838.08 4 event callstate IDLE 4 1,0,0 091838.08 4 WorkingMode@Idle= 091838.08 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 091838.09 4 timer clear 091838.09 4 LineState(iLineId).iVgsIdx = 0 091838.09 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 091838.11 3 timer fired EV_TIMEOUT_TIMETOREINITLINE 091838.11 3 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0 091838.11 3 init atidle reinit : start 091838.13 3 init atidle reinit iConferenceOtherLegLid=-1 091838.13 3 init atidle reinit : reset all LineState variables 091838.13 3 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091838.14 3 state Waiting for a call... 091838.14 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091838.14 4 timer set ignored - waiting for line re-init to occur first 091838.16 0 init lineids in use: 0-4 091838.16 0 init route channels start 091838.20 0 init route channels => [] 091838.22 0 init no dti channels opened. Not opening signaling channel. 091838.22 0 cti //devicesCTI/ctiLink config.xml section not used in this version 091838.22 0 init read Config.xml //devicesSysManagers/StatusLink start 091838.23 0 tcpsl config.xml does not have //devicesSysManagers/StatusLink section (status link wil use the default port of 14710) 091838.23 0 tcpsl open //devicesSysManagers/StatusLink to listen on port 14710 091838.25 0 init read Config.xml //devicesSysManagers/StatusLink end 091838.25 0 init iLineDevicesControlled=4 091838.25 0 init main form load end 091838.27 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 091838.27 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0 091838.28 4 init atidle reinit : start 091838.30 4 init atidle reinit iConferenceOtherLegLid=-1 091838.30 4 init atidle reinit : reset all LineState variables 091838.31 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091838.31 4 state Waiting for a call... 091840.19 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091840.19 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0 091840.20 1 setting iDialoutReadyToDialout = 1 091840.33 2 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091840.33 2 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0 091840.34 2 setting iDialoutReadyToDialout = 1 091840.45 3 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091840.45 3 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0 091840.47 3 setting iDialoutReadyToDialout = 1 091840.58 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 091840.58 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0 091840.59 4 setting iDialoutReadyToDialout = 1 091933.34 0 sys cleanup Start 091933.34 0 sys cleanup End 092135.86 4 event callstate OFFERING 4 2,0,0 092135.88 4 script interpretor: VgMulti v6.0.3243 092135.88 4 fired OFFERING event to listeners 092135.89 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 092135.91 4 cid CallerID vars set (in 'offering' event) [,,] 092135.91 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 092135.92 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 092135.92 4 tw ring 1 092135.94 4 ring time since last ring event (sec): 0.00 092135.95 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 092135.95 4 should answer as number of rings reached 092135.97 4 rv clear all 092135.98 4 init LineState ResetAtStartOfNewCall. 092135.98 4 answering the call (,,,0) 092136.00 4 timer clear 092136.02 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 092136.03 4 event TDX_CST, iCode=134 state=6001 092136.03 4 LsModuleTransition : 134, [TDX_CST] 092136.64 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 092136.66 4 event TDX_SETHOOK, iCode=135 state=6001 092136.67 4 LsModuleTransition : 135, [TDX_SETHOOK] 092136.67 4 event callstate CONNECTED 4 256,0,0 092136.69 4 LineEvCallState_Connected hDevice=4 params=256,0,0 092136.70 4 WorkingModes tapi= script= LineState().iState=6001 092136.72 4 Inband detection not enabled 092136.72 4 StartLoadedVgs at 01/10/2007 9:21:36 AM (VgMulti v6.0.3243) 092136.73 4 set LineState().iVgsIdx=1 092136.75 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 092136.75 4 init StartLoadedVgs_InitLineState start 092136.77 4 rv add [$RV_STARTTIME]{01/10/2007 9:21:36 AM} 092136.78 4 rv add [$RV_DEVICEID]{4} 092136.78 4 rv add [DlgcNetworkResource]{dxxxB1C4} 092136.80 4 rv add [DlgcVoiceResource]{dxxxB1C4} 092136.81 4 rv add [$RV_CIDNAME]{} 092136.81 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 092136.83 4 rvns add [scriptsPath]{G:\TeleBanking System\} 092136.83 4 rv add [$RV_CIDNUMBER]{} 092136.84 4 fn RunModule start [Play,[Get Language],1,,] 092136.84 4 tw DialogicEvent 134,TDX_CST,65535,0,0,DE_LCON,, 092136.84 4 event TDX_CST, iCode=134 state=6001 092136.86 4 LsModuleTransition : 134, [TDX_CST] 092136.88 4 timer clear 092136.88 4 Play Module start 092136.88 4 state [Get Language] Playing 092136.89 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 092136.89 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 092136.95 4 tw wav->vox convert end 320968,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 092136.97 4 play start ok, lPlayId=321031 092139.75 4 tw dtmf 1 (4,49,49) 092139.77 4 event 1, iCode=49 state=1100 092139.77 4 LsPlayMsg 1,1 092139.77 4 rv add [scriptEnd_Time]{01/10/2007 9:21:39 AM} 092139.78 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 092139.78 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 092139.81 4 rv add [scriptStart_Time]{01/10/2007 9:21:39 AM} 092139.81 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 092139.83 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 092139.83 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 092139.84 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 092139.84 MemStructVgs_ClearVgs [2] 092139.91 load end 092139.92 4 loaded [G:\TeleBanking System\Tele Banking_Ban.vgs] into:2 092139.92 4 rvns add [scriptsPath]{G:\TeleBanking System\} 092139.94 4 play PlayStop ok 092139.95 4 rv add [Get Language]{1} 092139.95 4 fn RunModule start [Evaluate,[Get Bangla],25,,] 092139.97 4 tw PlayEnd 4 321031 092139.97 4 play end id=321031, (current ID) 092139.97 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 092139.98 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 092139.98 4 tw DialogicEvent 129,TDX_PLAY,321031,0,0,,, 092140.00 4 event TDX_PLAY, iCode=129 state=6001 092140.00 4 LsModuleTransition : 129, [TDX_PLAY] 092140.02 4 timer clear 092140.03 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 092140.05 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 092140.06 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 092140.06 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 092140.08 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 092140.08 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 092140.09 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 092140.09 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 092140.09 4 matching path not found 092140.11 4 next module is (idx=26) 092140.11 4 matching path was found 092140.13 4 fn RunModule start [Play,,26,,] 092140.13 4 timer clear 092140.14 4 Play Module start 092140.14 4 state Playing 092140.14 4 state Playing (Bangla Voice\Service List.wav) 092140.16 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 092140.20 4 tw wav->vox convert end 324234,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 092140.22 4 play start ok, lPlayId=324281 092153.36 4 tw PlayEnd 4 324281 092153.36 4 play end id=324281, (current ID) 092153.38 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 092153.38 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 092153.39 4 path {EV_PLAY_FINISHED} not found 092153.39 4 timer set 7 EV_TIMEOUT_REPLAYMSG 092153.41 4 tw DialogicEvent 129,TDX_PLAY,324281,0,0,,, 092153.41 4 event TDX_PLAY, iCode=129 state=1101 092153.41 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 092153.42 4 path {TDX_PLAY} not found 092154.31 4 tw dtmf 1 (4,49,49) 092154.33 4 event 1, iCode=49 state=1101 092154.33 4 LsPlayMsgFinished 1,1 092154.34 4 next module is [Get Acc No] (idx=4) 092154.34 4 rv add {1} 092154.36 4 fn RunModule start [Get Numbers,[Get Acc No],4,,] 092154.36 4 timer clear 092154.36 4 state [Get Acc No] Number Input 092154.38 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 092154.38 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 092154.42 4 tw wav->vox convert end 338453,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 092154.44 4 play start ok, lPlayId=338500 092158.25 4 tw PlayEnd 4 338500 092158.27 4 play end id=338500, (current ID) 092158.27 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 092158.28 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 092158.28 4 path {EV_PLAY_FINISHED} not found 092158.28 4 timer set 17 EV_TIMEOUT_REPLAYMSG 092158.30 4 tw DialogicEvent 129,TDX_PLAY,338500,0,0,,, 092158.30 4 event TDX_PLAY, iCode=129 state=1301 092158.31 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 092158.31 4 path {TDX_PLAY} not found 092200.48 4 tw dtmf 0 (4,48,48) 092200.50 4 event 0, iCode=48 state=1301 092200.50 4 LsGetNbrsRxDigits 0,0 092200.52 4 state [Get Acc No] Number Input 0 092200.52 4 path {0} not found 092200.52 4 timer set 6 EV_TIMEOUT_ENTERDATA 092201.05 4 tw dtmf 1 (4,49,49) 092201.05 4 event 1, iCode=49 state=1301 092201.05 4 LsGetNbrsRxDigits 1,1 092201.06 4 state [Get Acc No] Number Input 01 092201.06 4 path {01} not found 092201.08 4 timer set 6 EV_TIMEOUT_ENTERDATA 092201.58 4 tw dtmf 7 (4,55,55) 092201.59 4 event 7, iCode=55 state=1301 092201.59 4 LsGetNbrsRxDigits 7,7 092201.59 4 state [Get Acc No] Number Input 017 092201.61 4 path {017} not found 092201.61 4 timer set 6 EV_TIMEOUT_ENTERDATA 092202.22 4 tw dtmf 3 (4,51,51) 092202.22 4 event 3, iCode=51 state=1301 092202.23 4 LsGetNbrsRxDigits 3,3 092202.23 4 state [Get Acc No] Number Input 0173 092202.25 4 path {0173} not found 092202.25 4 timer set 6 EV_TIMEOUT_ENTERDATA 092202.56 4 tw dtmf 4 (4,52,52) 092202.58 4 event 4, iCode=52 state=1301 092202.58 4 LsGetNbrsRxDigits 4,4 092202.58 4 state [Get Acc No] Number Input 01734 092202.59 4 path {01734} not found 092202.59 4 timer set 6 EV_TIMEOUT_ENTERDATA 092202.86 4 tw dtmf 5 (4,53,53) 092202.88 4 event 5, iCode=53 state=1301 092202.88 4 LsGetNbrsRxDigits 5,5 092202.89 4 state [Get Acc No] Number Input 017345 092202.89 4 path {017345} not found 092202.91 4 timer set 6 EV_TIMEOUT_ENTERDATA 092203.14 4 tw dtmf 2 (4,50,50) 092203.14 4 event 2, iCode=50 state=1301 092203.16 4 LsGetNbrsRxDigits 2,2 092203.16 4 state [Get Acc No] Number Input 0173452 092203.17 4 path {0173452} not found 092203.17 4 timer set 6 EV_TIMEOUT_ENTERDATA 092203.42 4 tw dtmf 1 (4,49,49) 092203.44 4 event 1, iCode=49 state=1301 092203.44 4 LsGetNbrsRxDigits 1,1 092203.45 4 state [Get Acc No] Number Input 01734521 092203.45 4 path {01734521} not found 092203.47 4 timer set 6 EV_TIMEOUT_ENTERDATA 092203.67 4 tw dtmf 1 (4,49,49) 092203.67 4 event 1, iCode=49 state=1301 092203.69 4 LsGetNbrsRxDigits 1,1 092203.69 4 state [Get Acc No] Number Input 017345211 092203.69 4 path {017345211} not found 092203.70 4 timer set 6 EV_TIMEOUT_ENTERDATA 092210.19 4 timer fired EV_TIMEOUT_ENTERDATA 092210.19 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 092210.19 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 092210.20 4 path {EV_TIMEOUT_ENTERDATA} not found 092210.20 4 timer clear 092210.22 4 rv add [Get Acc No]{017345211} 092210.22 4 len(017345211) min=11, max=14, replays=0/1 092210.23 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 092210.23 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 092210.27 4 tw wav->vox convert end 354312,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 092210.28 4 play start ok, lPlayId=354343 092214.09 4 tw PlayEnd 4 354343 092214.11 4 play end id=354343, (current ID) 092214.11 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 092214.11 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 092214.13 4 path {EV_PLAY_FINISHED} not found 092214.13 4 timer set 10 EV_TIMEOUT_HANGUP 092214.14 4 timer set 6 EV_TIMEOUT_ENTERDATA 092214.14 4 tw DialogicEvent 129,TDX_PLAY,354343,0,0,,, 092214.16 4 event TDX_PLAY, iCode=129 state=1301 092214.16 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 092214.17 4 path {TDX_PLAY} not found 092215.00 4 tw dtmf 0 (4,48,48) 092215.00 4 event 0, iCode=48 state=1301 092215.02 4 LsGetNbrsRxDigits 0,0 092215.02 4 state [Get Acc No] Number Input 0 092215.03 4 path {0} not found 092215.03 4 timer set 6 EV_TIMEOUT_ENTERDATA 092215.42 4 tw dtmf 1 (4,49,49) 092215.44 4 event 1, iCode=49 state=1301 092215.44 4 LsGetNbrsRxDigits 1,1 092215.45 4 state [Get Acc No] Number Input 01 092215.45 4 path {01} not found 092215.47 4 timer set 6 EV_TIMEOUT_ENTERDATA 092215.73 4 tw dtmf 7 (4,55,55) 092215.75 4 event 7, iCode=55 state=1301 092215.75 4 LsGetNbrsRxDigits 7,7 092215.77 4 state [Get Acc No] Number Input 017 092215.77 4 path {017} not found 092215.78 4 timer set 6 EV_TIMEOUT_ENTERDATA 092216.16 4 tw dtmf 3 (4,51,51) 092216.17 4 event 3, iCode=51 state=1301 092216.17 4 LsGetNbrsRxDigits 3,3 092216.19 4 state [Get Acc No] Number Input 0173 092216.19 4 path {0173} not found 092216.19 4 timer set 6 EV_TIMEOUT_ENTERDATA 092216.67 4 tw dtmf 4 (4,52,52) 092216.69 4 event 4, iCode=52 state=1301 092216.69 4 LsGetNbrsRxDigits 4,4 092216.70 4 state [Get Acc No] Number Input 01734 092216.70 4 path {01734} not found 092216.72 4 timer set 6 EV_TIMEOUT_ENTERDATA 092217.11 4 tw dtmf 0 (4,48,48) 092217.11 4 event 0, iCode=48 state=1301 092217.13 4 LsGetNbrsRxDigits 0,0 092217.13 4 state [Get Acc No] Number Input 017340 092217.14 4 path {017340} not found 092217.14 4 timer set 6 EV_TIMEOUT_ENTERDATA 092217.33 4 tw dtmf 0 (4,48,48) 092217.34 4 event 0, iCode=48 state=1301 092217.34 4 LsGetNbrsRxDigits 0,0 092217.36 4 state [Get Acc No] Number Input 0173400 092217.36 4 path {0173400} not found 092217.38 4 timer set 6 EV_TIMEOUT_ENTERDATA 092217.58 4 tw dtmf 0 (4,48,48) 092217.58 4 event 0, iCode=48 state=1301 092217.59 4 LsGetNbrsRxDigits 0,0 092217.59 4 state [Get Acc No] Number Input 01734000 092217.61 4 path {01734000} not found 092217.61 4 timer set 6 EV_TIMEOUT_ENTERDATA 092218.08 4 tw dtmf 2 (4,50,50) 092218.09 4 event 2, iCode=50 state=1301 092218.09 4 LsGetNbrsRxDigits 2,2 092218.11 4 state [Get Acc No] Number Input 017340002 092218.11 4 path {017340002} not found 092218.11 4 timer set 6 EV_TIMEOUT_ENTERDATA 092218.41 4 tw dtmf 4 (4,52,52) 092218.41 4 event 4, iCode=52 state=1301 092218.42 4 LsGetNbrsRxDigits 4,4 092218.42 4 state [Get Acc No] Number Input 0173400024 092218.44 4 path {0173400024} not found 092218.44 4 timer set 6 EV_TIMEOUT_ENTERDATA 092218.70 4 tw dtmf 5 (4,53,53) 092218.72 4 event 5, iCode=53 state=1301 092218.72 4 LsGetNbrsRxDigits 5,5 092218.72 4 state [Get Acc No] Number Input 01734000245 092218.73 4 path {01734000245} not found 092218.73 4 timer set 6 EV_TIMEOUT_ENTERDATA 092225.20 4 timer fired EV_TIMEOUT_ENTERDATA 092225.20 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 092225.22 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 092225.22 4 path {EV_TIMEOUT_ENTERDATA} not found 092225.22 4 timer clear 092225.23 4 rv add [Get Acc No]{01734000245} 092225.23 4 path {01734000245} not found 092225.25 4 next module is [Varify A/C] (idx=44) 092225.25 4 rvns add [Get Acc No_PathTaken]{success} 092225.27 4 fn RunModule start [Database Query,[Varify A/C],44,,] 092225.27 4 timer clear 092225.28 4 state [Varify A/C] DB Query 092225.28 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 092225.67 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 092225.69 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:21:36 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:21:39 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:21:39 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{017345211}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 092225.69 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 092225.72 4 db [Varify A/C] row count=1 092225.72 4 rv add [Varify A/C_RowCount]{1} 092225.73 4 db get RecordsetGetRowsMax 092225.73 4 db get 999 records. (row count=1) 092225.75 4 db update RVs 092225.75 4 db about to close dbDbqDatabase 092225.77 4 db going down path [True] 092225.77 4 next module is [Get PIN No] (idx=5) 092225.78 4 fn RunModule start [Get Numbers,[Get PIN No],5,,] 092225.78 4 timer clear 092225.80 4 state [Get PIN No] Number Input 092225.80 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 092225.81 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 092225.86 4 tw wav->vox convert end 369890,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 092225.88 4 play start ok, lPlayId=369937 092229.16 4 tw dtmf 3 (4,51,51) 092229.16 4 event 3, iCode=51 state=1300 092229.17 4 LsGetNbrsPlayWelcMsg 3,3 092229.19 4 play PlayStop ok 092229.20 4 state [Get PIN No] Number Input 3 092229.20 4 path {3} not found 092229.22 4 timer set 6 EV_TIMEOUT_ENTERDATA 092229.22 4 tw PlayEnd 4 369937 092229.23 4 play end id=369937, (current ID) 092229.23 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 092229.25 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 092229.25 4 path {EV_PLAY_FINISHED} not found 092229.27 4 awaiting further dtmf input 092229.27 4 tw DialogicEvent 129,TDX_PLAY,369937,0,0,,, 092229.28 4 event TDX_PLAY, iCode=129 state=1301 092229.28 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 092229.28 4 path {TDX_PLAY} not found 092229.58 4 tw dtmf 8 (4,56,56) 092229.58 4 event 8, iCode=56 state=1301 092229.59 4 LsGetNbrsRxDigits 8,8 092229.59 4 state [Get PIN No] Number Input 38 092229.61 4 path {38} not found 092229.61 4 timer set 6 EV_TIMEOUT_ENTERDATA 092230.00 4 tw dtmf 0 (4,48,48) 092230.02 4 event 0, iCode=48 state=1301 092230.02 4 LsGetNbrsRxDigits 0,0 092230.03 4 state [Get PIN No] Number Input 380 092230.03 4 path {380} not found 092230.05 4 timer set 6 EV_TIMEOUT_ENTERDATA 092230.39 4 tw dtmf 4 (4,52,52) 092230.41 4 event 4, iCode=52 state=1301 092230.41 4 LsGetNbrsRxDigits 4,4 092230.42 4 state [Get PIN No] Number Input 3804 092230.42 4 path {3804} not found 092230.42 4 timer set 6 EV_TIMEOUT_ENTERDATA 092230.44 4 timer clear 092230.44 4 rv add [Get PIN No]{3804} 092230.45 4 path {3804} not found 092230.45 4 next module is [Varify A/C No] (idx=29) 092230.47 4 rvns add [Get PIN No_PathTaken]{success} 092230.47 4 fn RunModule start [Database Query,[Varify A/C No],29,,] 092230.48 4 timer clear 092230.48 4 state [Varify A/C No] DB Query 092230.50 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 092230.53 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 092230.53 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:21:36 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:21:39 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:21:39 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{017345211}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 092230.55 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 092230.58 4 db [Varify A/C No] row count=1 092230.58 4 rv add [Varify A/C No_RowCount]{1} 092230.59 4 db get RecordsetGetRowsMax 092230.59 4 db get 999 records. (row count=1) 092230.61 4 db update RVs 092230.63 4 db about to close dbDbqDatabase 092230.64 4 db going down path [True] 092230.64 4 next module is (idx=6) 092230.66 4 fn RunModule start [Play,,6,,] 092230.66 4 timer clear 092230.66 4 Play Module start 092230.67 4 state Playing 092230.67 4 state Playing (Bangla Voice\Acc List.wav) 092230.69 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 092230.73 4 tw wav->vox convert end 374765,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 092230.75 4 play start ok, lPlayId=374812 092237.41 4 tw dtmf 1 (4,49,49) 092237.42 4 event 1, iCode=49 state=1100 092237.42 4 LsPlayMsg 1,1 092237.44 4 next module is [Varify Balance] (idx=7) 092237.45 4 play PlayStop ok 092237.47 4 rv add {1} 092237.47 4 fn RunModule start [Database Query,[Varify Balance],7,,] 092237.48 4 tw PlayEnd 4 374812 092237.48 4 play end id=374812, (current ID) 092237.50 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 092237.50 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 092237.52 4 tw DialogicEvent 129,TDX_PLAY,374812,0,0,,, 092237.52 4 event TDX_PLAY, iCode=129 state=6001 092237.53 4 LsModuleTransition : 129, [TDX_PLAY] 092237.53 4 timer clear 092237.55 4 state [Varify Balance] DB Query 092237.55 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 092237.58 4 rv replace start: [sELECT TRUNC(curbal) curbal FROM stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND acstat<>'CLS'] 092237.59 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:21:36 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:21:39 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:21:39 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{017345211}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}[Varify A/C No_RowCount]{1}[Varify A/C No_1_1]{LX4VNZ41KDX7}{1} 092237.59 4 db About to execute a Retrieve type operation [sELECT TRUNC(curbal) curbal FROM stfacmas WHERE actnum=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND acstat<>'CLS] 092237.61 4 db [Varify Balance] row count=1 092237.63 4 rv add [Varify Balance_RowCount]{1} 092237.63 4 db get RecordsetGetRowsMax 092237.64 4 db get 999 records. (row count=1) 092237.64 4 db update RVs 092237.66 4 db about to close dbDbqDatabase 092237.66 4 db going down path [True] 092237.67 4 next module is [say Balance] (idx=40) 092237.67 4 fn RunModule start [say Numbers,[say Balance],40,,] 092237.69 4 timer clear 092237.69 4 rv replace start: [$RV[Varify Balance_1_1]] 092237.70 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:21:36 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:21:39 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:21:39 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{017345211}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}[Varify A/C No_RowCount]{1}[Varify A/C No_1_1]{LX4VNZ41KDX7}{1}[Varify Balance_RowCount]{1}[Varify Balance_1_1]{60579} 092237.70 4 rv replace end: [60579] 092237.72 4 state [say Balance] Say numbers: 60579 as Number 092237.72 4 fn PlaySoundStartNumbers [bangla Voice\Acc Bal.wav],[],[60579],Number 092237.75 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 092237.75 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 092237.77 4 rv add [Hangup Time]{01/10/2007 9:22:37 AM} 092237.77 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 092237.78 4 HangupCall_Common hCall=4 092237.78 4 rec RecSoundStop ok 092237.80 4 play PlayStop ok 092237.80 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 092237.81 4 fnHangupCall end 092237.86 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 092237.86 4 event TDX_SETHOOK, iCode=135 state=900 092237.88 4 LsAwaitingCalls EV_UNKNOWN_135 092237.88 4 event callstate IDLE 4 1,0,0 092237.89 4 WorkingMode@Idle= 092237.89 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 092237.91 4 timer clear 092237.91 4 rec RecSoundStop ok 092237.92 4 play PlayStop ok 092237.92 4 rv add [CallEndTime]{01/10/2007 9:22:37 AM} 092237.95 4 on-hangup script:[] 092237.95 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 092237.97 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 092237.97 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 092237.98 4 init atidle reinit : start 092237.98 4 init atidle reinit iConferenceOtherLegLid=-1 092238.00 4 init atidle reinit : reset all LineState variables 092238.00 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 092238.02 4 state Waiting for a call... 092240.20 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 092240.20 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 092240.22 4 setting iDialoutReadyToDialout = 1 092651.27 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 092651.27 MemStructVgs_ClearVgs [3] 092651.34 load end 092651.36 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 092651.36 0 Erasing Script (new loaded) Id 2 092651.38 0 VgsScriptFree [2] 092651.38 MemStructVgs_ClearVgs [2] 092652.39 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 092652.39 MemStructVgs_ClearVgs [2] 092652.47 load end 092652.48 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 092652.50 0 Erasing Script (new loaded) Id 3 092652.50 0 VgsScriptFree [3] 092652.52 MemStructVgs_ClearVgs [3] 092703.52 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 092703.53 MemStructVgs_ClearVgs [3] 092703.61 load end 092703.61 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 092703.63 0 Erasing Script (new loaded) Id 2 092703.63 0 VgsScriptFree [2] 092703.64 MemStructVgs_ClearVgs [2] 092712.17 4 event callstate OFFERING 4 2,0,0 092712.17 4 script interpretor: VgMulti v6.0.3243 092712.19 4 fired OFFERING event to listeners 092712.19 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 092712.20 4 cid CallerID vars set (in 'offering' event) [,,] 092712.20 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 092712.22 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 092712.22 4 tw ring 1 092712.23 4 ring time since last ring event (sec): 0.00 092712.23 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 092712.25 4 should answer as number of rings reached 092712.25 4 rv clear all 092712.27 4 init LineState ResetAtStartOfNewCall. 092712.27 4 answering the call (,,,0) 092712.28 4 timer clear 092712.30 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 092712.30 4 event TDX_CST, iCode=134 state=6001 092712.31 4 LsModuleTransition : 134, [TDX_CST] 092712.92 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 092712.94 4 event TDX_SETHOOK, iCode=135 state=6001 092712.94 4 LsModuleTransition : 135, [TDX_SETHOOK] 092712.95 4 event callstate CONNECTED 4 256,0,0 092712.95 4 LineEvCallState_Connected hDevice=4 params=256,0,0 092712.97 4 WorkingModes tapi= script= LineState().iState=6001 092712.97 4 Inband detection not enabled 092712.98 4 StartLoadedVgs at 01/10/2007 9:27:12 AM (VgMulti v6.0.3243) 092712.98 4 set LineState().iVgsIdx=1 092713.00 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 092713.00 4 init StartLoadedVgs_InitLineState start 092713.02 4 rv add [$RV_STARTTIME]{01/10/2007 9:27:12 AM} 092713.03 4 rv add [$RV_DEVICEID]{4} 092713.03 4 rv add [DlgcNetworkResource]{dxxxB1C4} 092713.05 4 rv add [DlgcVoiceResource]{dxxxB1C4} 092713.05 4 rv add [$RV_CIDNAME]{} 092713.06 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 092713.06 4 rvns add [scriptsPath]{G:\TeleBanking System\} 092713.08 4 rv add [$RV_CIDNUMBER]{} 092713.08 4 fn RunModule start [Play,[Get Language],1,,] 092713.09 4 tw DialogicEvent 134,TDX_CST,27507,0,0,DE_LCON,, 092713.09 4 event TDX_CST, iCode=134 state=6001 092713.11 4 LsModuleTransition : 134, [TDX_CST] 092713.11 4 timer clear 092713.13 4 Play Module start 092713.13 4 state [Get Language] Playing 092713.14 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 092713.14 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 092713.17 4 tw wav->vox convert end 657218,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 092713.20 4 play start ok, lPlayId=657265 092714.56 4 tw dtmf 1 (4,49,49) 092714.58 4 event 1, iCode=49 state=1100 092714.58 4 LsPlayMsg 1,1 092714.59 4 rv add [scriptEnd_Time]{01/10/2007 9:27:14 AM} 092714.59 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 092714.61 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 092714.64 4 rv add [scriptStart_Time]{01/10/2007 9:27:14 AM} 092714.64 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 092714.66 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 092714.67 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 092714.67 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3 092714.69 4 rvns add [scriptsPath]{G:\TeleBanking System\} 092714.70 4 play PlayStop ok 092714.70 4 rv add [Get Language]{1} 092714.72 4 fn RunModule start [Evaluate,[Get Bangla],64,,] 092714.72 4 tw PlayEnd 4 657265 092714.73 4 play end id=657265, (current ID) 092714.73 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 092714.75 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 092714.75 4 tw DialogicEvent 129,TDX_PLAY,657265,0,0,,, 092714.77 4 event TDX_PLAY, iCode=129 state=6001 092714.77 4 LsModuleTransition : 129, [TDX_PLAY] 092714.78 4 timer clear 092714.80 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 092714.80 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 092714.81 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 092714.81 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 092714.83 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 092714.83 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 092714.84 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 092714.84 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 092714.86 4 matching path not found 092714.86 4 next module is (idx=63) 092714.88 4 matching path was found 092714.88 4 fn RunModule start [Play,,63,,] 092714.89 4 timer clear 092714.91 4 Play Module start 092714.91 4 state Playing 092714.92 4 state Playing (Bangla Voice\Service List.wav) 092714.92 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 092714.95 4 tw wav->vox convert end 659000,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 092714.97 4 play start ok, lPlayId=659046 092716.56 4 tw dtmf 1 (4,49,49) 092716.56 4 event 1, iCode=49 state=1100 092716.58 4 LsPlayMsg 1,1 092716.58 4 next module is [Get Acc No] (idx=85) 092716.61 4 play PlayStop ok 092716.61 4 rv add {1} 092716.63 4 fn RunModule start [Get Numbers,[Get Acc No],85,,] 092716.63 4 tw PlayEnd 4 659046 092716.64 4 play end id=659046, (current ID) 092716.64 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 092716.66 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 092716.67 4 tw DialogicEvent 129,TDX_PLAY,659046,0,0,,, 092716.67 4 event TDX_PLAY, iCode=129 state=6001 092716.69 4 LsModuleTransition : 129, [TDX_PLAY] 092716.69 4 timer clear 092716.70 4 state [Get Acc No] Number Input 092716.70 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 092716.72 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 092716.73 4 tw wav->vox convert end 660796,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 092716.75 4 play start ok, lPlayId=660812 092720.56 4 tw PlayEnd 4 660812 092720.58 4 play end id=660812, (current ID) 092720.58 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 092720.59 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 092720.59 4 path {EV_PLAY_FINISHED} not found 092720.61 4 timer set 17 EV_TIMEOUT_REPLAYMSG 092720.61 4 tw DialogicEvent 129,TDX_PLAY,660812,0,0,,, 092720.63 4 event TDX_PLAY, iCode=129 state=1301 092720.64 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 092720.64 4 path {TDX_PLAY} not found 092720.66 4 tw dtmf 0 (4,48,48) 092720.66 4 event 0, iCode=48 state=1301 092720.67 4 LsGetNbrsRxDigits 0,0 092720.67 4 state [Get Acc No] Number Input 0 092720.69 4 path {0} not found 092720.69 4 timer set 6 EV_TIMEOUT_ENTERDATA 092720.88 4 tw dtmf 1 (4,49,49) 092720.89 4 event 1, iCode=49 state=1301 092720.89 4 LsGetNbrsRxDigits 1,1 092720.91 4 state [Get Acc No] Number Input 01 092720.91 4 path {01} not found 092720.92 4 timer set 6 EV_TIMEOUT_ENTERDATA 092721.23 4 tw dtmf 7 (4,55,55) 092721.25 4 event 7, iCode=55 state=1301 092721.25 4 LsGetNbrsRxDigits 7,7 092721.27 4 state [Get Acc No] Number Input 017 092721.27 4 path {017} not found 092721.28 4 timer set 6 EV_TIMEOUT_ENTERDATA 092721.64 4 tw dtmf 3 (4,51,51) 092721.66 4 event 3, iCode=51 state=1301 092721.66 4 LsGetNbrsRxDigits 3,3 092721.67 4 state [Get Acc No] Number Input 0173 092721.69 4 path {0173} not found 092721.69 4 timer set 6 EV_TIMEOUT_ENTERDATA 092722.05 4 tw dtmf 4 (4,52,52) 092722.06 4 event 4, iCode=52 state=1301 092722.08 4 LsGetNbrsRxDigits 4,4 092722.08 4 state [Get Acc No] Number Input 01734 092722.09 4 path {01734} not found 092722.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 092722.33 4 tw dtmf 4 (4,52,52) 092722.34 4 event 4, iCode=52 state=1301 092722.34 4 LsGetNbrsRxDigits 4,4 092722.36 4 state [Get Acc No] Number Input 017344 092722.36 4 path {017344} not found 092722.38 4 timer set 6 EV_TIMEOUT_ENTERDATA 092728.89 4 timer fired EV_TIMEOUT_ENTERDATA 092728.89 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 092728.91 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 092728.91 4 path {EV_TIMEOUT_ENTERDATA} not found 092728.92 4 timer clear 092728.92 4 rv add [Get Acc No]{017344} 092728.94 4 len(017344) min=11, max=14, replays=0/1 092728.95 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 092728.95 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 092728.97 4 tw wav->vox convert end 673031,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 092728.98 4 play start ok, lPlayId=673062 092729.73 4 tw dtmf 1 (4,49,49) 092729.75 4 event 1, iCode=49 state=1300 092729.75 4 LsGetNbrsPlayWelcMsg 1,1 092729.77 4 play PlayStop ok 092729.78 4 state [Get Acc No] Number Input 1 092729.78 4 path {1} not found 092729.80 4 timer set 6 EV_TIMEOUT_ENTERDATA 092729.81 4 tw PlayEnd 4 673062 092729.81 4 play end id=673062, (current ID) 092729.83 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 092729.83 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 092729.84 4 path {EV_PLAY_FINISHED} not found 092729.84 4 awaiting further dtmf input 092729.86 4 tw DialogicEvent 129,TDX_PLAY,673062,0,0,,, 092729.86 4 event TDX_PLAY, iCode=129 state=1301 092729.88 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 092729.88 4 path {TDX_PLAY} not found 092730.05 4 tw dtmf 2 (4,50,50) 092730.05 4 event 2, iCode=50 state=1301 092730.06 4 LsGetNbrsRxDigits 2,2 092730.08 4 state [Get Acc No] Number Input 12 092730.08 4 path {12} not found 092730.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 092736.56 4 timer fired EV_TIMEOUT_ENTERDATA 092736.56 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 092736.58 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 092736.58 4 path {EV_TIMEOUT_ENTERDATA} not found 092736.59 4 timer clear 092736.59 4 rv add [Get Acc No]{12} 092736.61 4 len(12) min=11, max=14, replays=1/1 092736.61 4 next module is [invalid A/C] (idx=62) 092736.63 4 fn RunModule start [Play,[invalid A/C],62,,] 092736.63 4 timer clear 092736.64 4 Play Module start 092736.64 4 state [invalid A/C] Playing 092736.66 4 state [invalid A/C] Playing (Bangla Voice\Inv Acc No.wav) 092736.67 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Inv Acc No.wav 092736.69 4 tw wav->vox convert end 680750,G:\TeleBanking System\Bangla Voice\Inv Acc No.vox,1,0,, 092736.70 4 play start ok, lPlayId=680781 092739.69 4 tw PlayEnd 4 680781 092739.70 4 play end id=680781, (current ID) 092739.72 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 092739.72 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 092739.73 4 path {EV_PLAY_FINISHED} not found 092739.73 4 timer set 10 EV_TIMEOUT_HANGUP 092739.75 4 timer set 1 EV_TIMEOUT_GOTOMODULE 092739.75 4 tw DialogicEvent 129,TDX_PLAY,680781,0,0,,, 092739.77 4 event TDX_PLAY, iCode=129 state=1101 092739.77 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 092739.78 4 path {TDX_PLAY} not found 092740.77 4 timer fired EV_TIMEOUT_GOTOMODULE 092740.77 4 event EV_TIMEOUT_GOTOMODULE, iCode=9002 state=1101 092740.78 4 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE 092740.78 4 path {EV_TIMEOUT_GOTOMODULE} not found 092740.80 4 next module is [Get Acc No] (idx=85) 092740.80 4 fn RunModule start [Get Numbers,[Get Acc No],85,,] 092740.81 4 timer clear 092740.81 4 state [Get Acc No] Number Input 092740.83 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 092740.84 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 092740.86 4 tw wav->vox convert end 684921,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 092740.88 4 play start ok, lPlayId=684937 092744.69 4 tw PlayEnd 4 684937 092744.69 4 play end id=684937, (current ID) 092744.70 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 092744.72 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 092744.72 4 path {EV_PLAY_FINISHED} not found 092744.73 4 timer set 17 EV_TIMEOUT_REPLAYMSG 092744.73 4 tw DialogicEvent 129,TDX_PLAY,684937,0,0,,, 092744.75 4 event TDX_PLAY, iCode=129 state=1301 092744.75 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 092744.77 4 path {TDX_PLAY} not found 092744.97 4 tw dtmf 0 (4,48,48) 092744.98 4 event 0, iCode=48 state=1301 092744.98 4 LsGetNbrsRxDigits 0,0 092745.00 4 state [Get Acc No] Number Input 0 092745.02 4 path {0} not found 092745.02 4 timer set 6 EV_TIMEOUT_ENTERDATA 092745.17 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 092745.19 4 event FAX, iCode=134 state=1301 092745.19 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 092745.20 4 path {FAX} not found 092745.22 4 event TDX_CST, iCode=134 state=1301 092745.22 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 092745.23 4 path {TDX_CST} not found 092745.31 4 tw dtmf 1 (4,49,49) 092745.31 4 event 1, iCode=49 state=1301 092745.33 4 LsGetNbrsRxDigits 1,1 092745.33 4 state [Get Acc No] Number Input 01 092745.34 4 path {01} not found 092745.36 4 timer set 6 EV_TIMEOUT_ENTERDATA 092745.64 4 tw dtmf 7 (4,55,55) 092745.64 4 event 7, iCode=55 state=1301 092745.66 4 LsGetNbrsRxDigits 7,7 092745.66 4 state [Get Acc No] Number Input 017 092745.67 4 path {017} not found 092745.67 4 timer set 6 EV_TIMEOUT_ENTERDATA 092746.09 4 tw dtmf 3 (4,51,51) 092746.09 4 event 3, iCode=51 state=1301 092746.11 4 LsGetNbrsRxDigits 3,3 092746.11 4 state [Get Acc No] Number Input 0173 092746.13 4 path {0173} not found 092746.13 4 timer set 6 EV_TIMEOUT_ENTERDATA 092746.58 4 tw dtmf 4 (4,52,52) 092746.59 4 event 4, iCode=52 state=1301 092746.59 4 LsGetNbrsRxDigits 4,4 092746.61 4 state [Get Acc No] Number Input 01734 092746.61 4 path {01734} not found 092746.63 4 timer set 6 EV_TIMEOUT_ENTERDATA 092747.02 4 tw dtmf 0 (4,48,48) 092747.02 4 event 0, iCode=48 state=1301 092747.03 4 LsGetNbrsRxDigits 0,0 092747.05 4 state [Get Acc No] Number Input 017340 092747.05 4 path {017340} not found 092747.06 4 timer set 6 EV_TIMEOUT_ENTERDATA 092747.33 4 tw dtmf 0 (4,48,48) 092747.33 4 event 0, iCode=48 state=1301 092747.34 4 LsGetNbrsRxDigits 0,0 092747.34 4 state [Get Acc No] Number Input 0173400 092747.36 4 path {0173400} not found 092747.38 4 timer set 6 EV_TIMEOUT_ENTERDATA 092747.66 4 tw dtmf 0 (4,48,48) 092747.66 4 event 0, iCode=48 state=1301 092747.67 4 LsGetNbrsRxDigits 0,0 092747.67 4 state [Get Acc No] Number Input 01734000 092747.69 4 path {01734000} not found 092747.69 4 timer set 6 EV_TIMEOUT_ENTERDATA 092748.33 4 tw dtmf 2 (4,50,50) 092748.34 4 event 2, iCode=50 state=1301 092748.36 4 LsGetNbrsRxDigits 2,2 092748.36 4 state [Get Acc No] Number Input 017340002 092748.38 4 path {017340002} not found 092748.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 092748.63 4 tw dtmf 4 (4,52,52) 092748.63 4 event 4, iCode=52 state=1301 092748.64 4 LsGetNbrsRxDigits 4,4 092748.64 4 state [Get Acc No] Number Input 0173400024 092748.66 4 path {0173400024} not found 092748.67 4 timer set 6 EV_TIMEOUT_ENTERDATA 092748.92 4 tw dtmf 5 (4,53,53) 092748.94 4 event 5, iCode=53 state=1301 092748.94 4 LsGetNbrsRxDigits 5,5 092748.95 4 state [Get Acc No] Number Input 01734000245 092748.95 4 path {01734000245} not found 092748.97 4 timer set 6 EV_TIMEOUT_ENTERDATA 092755.42 4 timer fired EV_TIMEOUT_ENTERDATA 092755.42 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 092755.44 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 092755.44 4 path {EV_TIMEOUT_ENTERDATA} not found 092755.45 4 timer clear 092755.45 4 rv add [Get Acc No]{01734000245} 092755.47 4 path {01734000245} not found 092755.47 4 next module is [Varify A/C] (idx=45) 092755.48 4 rvns add [Get Acc No_PathTaken]{success} 092755.50 4 fn RunModule start [Database Query,[Varify A/C],45,,] 092755.50 4 timer clear 092755.52 4 state [Varify A/C] DB Query 092755.52 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 092755.56 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 092755.56 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:27:12 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:27:14 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:27:14 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{017344}[Get Acc No]{12}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 092755.58 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 092755.59 4 db [Varify A/C] row count=1 092755.59 4 rv add [Varify A/C_RowCount]{1} 092755.61 4 db get RecordsetGetRowsMax 092755.61 4 db get 999 records. (row count=1) 092755.63 4 db update RVs 092755.63 4 db about to close dbDbqDatabase 092755.64 4 db going down path [True] 092755.66 4 next module is [Get PIN No] (idx=84) 092755.66 4 fn RunModule start [Get Numbers,[Get PIN No],84,,] 092755.67 4 timer clear 092755.67 4 state [Get PIN No] Number Input 092755.69 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 092755.69 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 092755.73 4 tw wav->vox convert end 699765,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 092755.75 4 play start ok, lPlayId=699812 092759.03 4 tw dtmf 3 (4,51,51) 092759.05 4 event 3, iCode=51 state=1300 092759.06 4 LsGetNbrsPlayWelcMsg 3,3 092759.08 4 play PlayStop ok 092759.08 4 state [Get PIN No] Number Input 3 092759.09 4 path {3} not found 092759.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 092759.11 4 tw PlayEnd 4 699812 092759.13 4 play end id=699812, (current ID) 092759.13 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 092759.14 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 092759.14 4 path {EV_PLAY_FINISHED} not found 092759.16 4 awaiting further dtmf input 092759.16 4 tw DialogicEvent 129,TDX_PLAY,699812,0,0,,, 092759.17 4 event TDX_PLAY, iCode=129 state=1301 092759.17 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 092759.19 4 path {TDX_PLAY} not found 092759.45 4 tw dtmf 8 (4,56,56) 092759.47 4 event 8, iCode=56 state=1301 092759.47 4 LsGetNbrsRxDigits 8,8 092759.48 4 state [Get PIN No] Number Input 38 092759.50 4 path {38} not found 092759.50 4 timer set 6 EV_TIMEOUT_ENTERDATA 092800.06 4 tw dtmf 0 (4,48,48) 092800.06 4 event 0, iCode=48 state=1301 092800.08 4 LsGetNbrsRxDigits 0,0 092800.08 4 state [Get PIN No] Number Input 380 092800.09 4 path {380} not found 092800.11 4 timer set 6 EV_TIMEOUT_ENTERDATA 092800.42 4 tw dtmf 4 (4,52,52) 092800.42 4 event 4, iCode=52 state=1301 092800.44 4 LsGetNbrsRxDigits 4,4 092800.45 4 state [Get PIN No] Number Input 3804 092800.45 4 path {3804} not found 092800.47 4 timer set 6 EV_TIMEOUT_ENTERDATA 092800.47 4 timer clear 092800.48 4 rv add [Get PIN No]{3804} 092800.48 4 path {3804} not found 092800.50 4 next module is [Varify A/C No] (idx=60) 092800.50 4 rvns add [Get PIN No_PathTaken]{success} 092800.52 4 fn RunModule start [Database Query,[Varify A/C No],60,,] 092800.53 4 timer clear 092800.53 4 state [Varify A/C No] DB Query 092800.55 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 092800.58 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 092800.59 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:27:12 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:27:14 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:27:14 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{017344}[Get Acc No]{12}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 092800.59 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 092800.61 4 db [Varify A/C No] row count=1 092800.63 4 rv add [Varify A/C No_RowCount]{1} 092800.63 4 db get RecordsetGetRowsMax 092800.64 4 db get 999 records. (row count=1) 092800.66 4 db update RVs 092800.66 4 db about to close dbDbqDatabase 092800.67 4 db going down path [True] 092800.67 4 next module is (idx=83) 092800.69 4 fn RunModule start [Play,,83,,] 092800.70 4 timer clear 092800.70 4 Play Module start 092800.72 4 state Playing 092800.72 4 state Playing (Bangla Voice\Acc List.wav) 092800.73 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 092800.77 4 tw wav->vox convert end 704812,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 092800.78 4 play start ok, lPlayId=704843 092802.44 4 tw dtmf 1 (4,49,49) 092802.44 4 event 1, iCode=49 state=1100 092802.45 4 LsPlayMsg 1,1 092802.47 4 next module is [Varify Balance] (idx=82) 092802.48 4 play PlayStop ok 092802.50 4 rv add {1} 092802.50 4 fn RunModule start [Database Query,[Varify Balance],82,,] 092802.52 4 tw PlayEnd 4 704843 092802.52 4 play end id=704843, (current ID) 092802.53 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 092802.55 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 092802.55 4 tw DialogicEvent 129,TDX_PLAY,704843,0,0,,, 092802.56 4 event TDX_PLAY, iCode=129 state=6001 092802.56 4 LsModuleTransition : 129, [TDX_PLAY] 092802.58 4 timer clear 092802.58 4 state [Varify Balance] DB Query 092802.59 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 092802.63 4 db About to execute a Retrieve type operation [sELECT 200 as curbal FROM dual;] 092802.66 4 OpenRecordset: 3146:ODBC--call failed. 092802.67 4 path {0} not found 092802.67 4 path {} not found 092802.69 4 HangupCall start (Fail/False path not defined) 092802.70 4 rv add [Hangup Time]{01/10/2007 9:28:02 AM} 092802.70 4 state Hanging up call... [Fail/False path not defined] 092802.72 4 HangupCall_Common hCall=4 092802.72 4 rec RecSoundStop ok 092802.73 4 play PlayStop ok 092802.75 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 092802.75 4 fnHangupCall end 092802.80 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 092802.81 4 event TDX_SETHOOK, iCode=135 state=900 092802.81 4 LsAwaitingCalls EV_UNKNOWN_135 092802.83 4 event callstate IDLE 4 1,0,0 092802.83 4 WorkingMode@Idle= 092802.84 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 092802.86 4 timer clear 092802.86 4 rec RecSoundStop ok 092802.88 4 play PlayStop ok 092802.89 4 rv add [CallEndTime]{01/10/2007 9:28:02 AM} 092802.91 4 on-hangup script:[] 092802.92 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 092802.94 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 092802.94 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 092802.95 4 init atidle reinit : start 092802.95 4 init atidle reinit iConferenceOtherLegLid=-1 092802.97 4 init atidle reinit : reset all LineState variables 092802.98 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 092802.98 4 state Waiting for a call... 092805.19 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 092805.19 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 092805.20 4 setting iDialoutReadyToDialout = 1 092919.03 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 092919.03 MemStructVgs_ClearVgs [2] 092919.11 load end 092919.13 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 092919.13 0 Erasing Script (new loaded) Id 3 092919.14 0 VgsScriptFree [3] 092919.16 MemStructVgs_ClearVgs [3] 093121.16 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 093121.16 MemStructVgs_ClearVgs [3] 093121.25 load end 093121.25 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 093121.27 0 Erasing Script (new loaded) Id 2 093121.28 0 VgsScriptFree [2] 093121.28 MemStructVgs_ClearVgs [2] 093227.78 4 event callstate OFFERING 4 2,0,0 093227.80 4 script interpretor: VgMulti v6.0.3243 093227.81 4 fired OFFERING event to listeners 093227.81 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 093227.83 4 cid CallerID vars set (in 'offering' event) [,,] 093227.83 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 093227.84 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 093227.84 4 tw ring 1 093227.86 4 ring time since last ring event (sec): 0.00 093227.88 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 093227.88 4 should answer as number of rings reached 093227.89 4 rv clear all 093227.89 4 init LineState ResetAtStartOfNewCall. 093227.91 4 answering the call (,,,0) 093227.91 4 timer clear 093227.92 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 093227.94 4 event TDX_CST, iCode=134 state=6001 093227.95 4 LsModuleTransition : 134, [TDX_CST] 093228.56 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 093228.56 4 event TDX_SETHOOK, iCode=135 state=6001 093228.58 4 LsModuleTransition : 135, [TDX_SETHOOK] 093228.58 4 event callstate CONNECTED 4 256,0,0 093228.59 4 LineEvCallState_Connected hDevice=4 params=256,0,0 093228.59 4 WorkingModes tapi= script= LineState().iState=6001 093228.61 4 Inband detection not enabled 093228.63 4 StartLoadedVgs at 01/10/2007 9:32:28 AM (VgMulti v6.0.3243) 093228.63 4 set LineState().iVgsIdx=1 093228.64 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 093228.64 4 init StartLoadedVgs_InitLineState start 093228.66 4 rv add [$RV_STARTTIME]{01/10/2007 9:32:28 AM} 093228.67 4 rv add [$RV_DEVICEID]{4} 093228.67 4 rv add [DlgcNetworkResource]{dxxxB1C4} 093228.69 4 rv add [DlgcVoiceResource]{dxxxB1C4} 093228.69 4 rv add [$RV_CIDNAME]{} 093228.70 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 093228.72 4 rvns add [scriptsPath]{G:\TeleBanking System\} 093228.72 4 rv add [$RV_CIDNUMBER]{} 093228.73 4 fn RunModule start [Play,[Get Language],1,,] 093228.73 4 tw DialogicEvent 134,TDX_CST,26576,0,0,DE_LCON,, 093228.75 4 event TDX_CST, iCode=134 state=6001 093228.75 4 LsModuleTransition : 134, [TDX_CST] 093228.77 4 timer clear 093228.78 4 Play Module start 093228.78 4 state [Get Language] Playing 093228.80 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 093228.80 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 093228.84 4 tw wav->vox convert end 972875,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 093228.86 4 play start ok, lPlayId=972921 093229.64 4 tw dtmf 1 (4,49,49) 093229.66 4 event 1, iCode=49 state=1100 093229.66 4 LsPlayMsg 1,1 093229.67 4 rv add [scriptEnd_Time]{01/10/2007 9:32:29 AM} 093229.67 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 093229.69 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 093229.72 4 rv add [scriptStart_Time]{01/10/2007 9:32:29 AM} 093229.73 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 093229.73 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 093229.75 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 093229.75 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3 093229.77 4 rvns add [scriptsPath]{G:\TeleBanking System\} 093229.78 4 play PlayStop ok 093229.80 4 rv add [Get Language]{1} 093229.80 4 fn RunModule start [Evaluate,[Get Bangla],66,,] 093229.81 4 tw PlayEnd 4 972921 093229.83 4 play end id=972921, (current ID) 093229.83 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 093229.84 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 093229.84 4 tw DialogicEvent 129,TDX_PLAY,972921,0,0,,, 093229.86 4 event TDX_PLAY, iCode=129 state=6001 093229.86 4 LsModuleTransition : 129, [TDX_PLAY] 093229.88 4 timer clear 093229.89 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 093229.89 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 093229.91 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 093229.91 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 093229.92 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 093229.92 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 093229.94 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 093229.95 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 093229.95 4 matching path not found 093229.97 4 next module is (idx=67) 093229.97 4 matching path was found 093229.98 4 fn RunModule start [Play,,67,,] 093230.00 4 timer clear 093230.00 4 Play Module start 093230.02 4 state Playing 093230.02 4 state Playing (Bangla Voice\Service List.wav) 093230.03 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 093230.06 4 tw wav->vox convert end 974109,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 093230.08 4 play start ok, lPlayId=974140 093232.86 4 tw dtmf 1 (4,49,49) 093232.86 4 event 1, iCode=49 state=1100 093232.88 4 LsPlayMsg 1,1 093232.89 4 next module is [Get Acc No] (idx=45) 093232.91 4 play PlayStop ok 093232.91 4 rv add {1} 093232.92 4 fn RunModule start [Get Numbers,[Get Acc No],45,,] 093232.94 4 tw PlayEnd 4 974140 093232.94 4 play end id=974140, (current ID) 093232.95 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 093232.95 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 093232.97 4 tw DialogicEvent 129,TDX_PLAY,974140,0,0,,, 093232.98 4 event TDX_PLAY, iCode=129 state=6001 093232.98 4 LsModuleTransition : 129, [TDX_PLAY] 093233.00 4 timer clear 093233.00 4 state [Get Acc No] Number Input 093233.02 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 093233.02 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 093233.05 4 tw wav->vox convert end 977093,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 093233.08 4 play start ok, lPlayId=977140 093236.89 4 tw PlayEnd 4 977140 093236.89 4 play end id=977140, (current ID) 093236.91 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 093236.92 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 093236.92 4 path {EV_PLAY_FINISHED} not found 093236.94 4 timer set 17 EV_TIMEOUT_REPLAYMSG 093236.94 4 tw DialogicEvent 129,TDX_PLAY,977140,0,0,,, 093236.95 4 event TDX_PLAY, iCode=129 state=1301 093236.95 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 093236.97 4 path {TDX_PLAY} not found 093237.86 4 tw dtmf 0 (4,48,48) 093237.88 4 event 0, iCode=48 state=1301 093237.88 4 LsGetNbrsRxDigits 0,0 093237.89 4 state [Get Acc No] Number Input 0 093237.89 4 path {0} not found 093237.91 4 timer set 6 EV_TIMEOUT_ENTERDATA 093238.17 4 tw dtmf 1 (4,49,49) 093238.19 4 event 1, iCode=49 state=1301 093238.19 4 LsGetNbrsRxDigits 1,1 093238.20 4 state [Get Acc No] Number Input 01 093238.20 4 path {01} not found 093238.22 4 timer set 6 EV_TIMEOUT_ENTERDATA 093238.63 4 tw dtmf 7 (4,55,55) 093238.64 4 event 7, iCode=55 state=1301 093238.64 4 LsGetNbrsRxDigits 7,7 093238.66 4 state [Get Acc No] Number Input 017 093238.66 4 path {017} not found 093238.67 4 timer set 6 EV_TIMEOUT_ENTERDATA 093239.03 4 tw dtmf 3 (4,51,51) 093239.05 4 event 3, iCode=51 state=1301 093239.06 4 LsGetNbrsRxDigits 3,3 093239.06 4 state [Get Acc No] Number Input 0173 093239.08 4 path {0173} not found 093239.08 4 timer set 6 EV_TIMEOUT_ENTERDATA 093239.59 4 tw dtmf 4 (4,52,52) 093239.59 4 event 4, iCode=52 state=1301 093239.61 4 LsGetNbrsRxDigits 4,4 093239.61 4 state [Get Acc No] Number Input 01734 093239.63 4 path {01734} not found 093239.64 4 timer set 6 EV_TIMEOUT_ENTERDATA 093240.27 4 tw dtmf 0 (4,48,48) 093240.27 4 event 0, iCode=48 state=1301 093240.28 4 LsGetNbrsRxDigits 0,0 093240.28 4 state [Get Acc No] Number Input 017340 093240.30 4 path {017340} not found 093240.31 4 timer set 6 EV_TIMEOUT_ENTERDATA 093240.45 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 093240.47 4 event FAX, iCode=134 state=1301 093240.47 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 093240.48 4 path {FAX} not found 093240.48 4 event TDX_CST, iCode=134 state=1301 093240.50 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 093240.52 4 path {TDX_CST} not found 093240.52 4 tw dtmf 0 (4,48,48) 093240.53 4 event 0, iCode=48 state=1301 093240.55 4 LsGetNbrsRxDigits 0,0 093240.55 4 state [Get Acc No] Number Input 0173400 093240.56 4 path {0173400} not found 093240.56 4 timer set 6 EV_TIMEOUT_ENTERDATA 093240.70 4 tw dtmf 0 (4,48,48) 093240.72 4 event 0, iCode=48 state=1301 093240.72 4 LsGetNbrsRxDigits 0,0 093240.73 4 state [Get Acc No] Number Input 01734000 093240.73 4 path {01734000} not found 093240.75 4 timer set 6 EV_TIMEOUT_ENTERDATA 093241.52 4 tw dtmf 2 (4,50,50) 093241.53 4 event 2, iCode=50 state=1301 093241.53 4 LsGetNbrsRxDigits 2,2 093241.55 4 state [Get Acc No] Number Input 017340002 093241.56 4 path {017340002} not found 093241.56 4 timer set 6 EV_TIMEOUT_ENTERDATA 093241.77 4 tw dtmf 4 (4,52,52) 093241.78 4 event 4, iCode=52 state=1301 093241.80 4 LsGetNbrsRxDigits 4,4 093241.80 4 state [Get Acc No] Number Input 0173400024 093241.81 4 path {0173400024} not found 093241.81 4 timer set 6 EV_TIMEOUT_ENTERDATA 093242.05 4 tw dtmf 5 (4,53,53) 093242.06 4 event 5, iCode=53 state=1301 093242.06 4 LsGetNbrsRxDigits 5,5 093242.08 4 state [Get Acc No] Number Input 01734000245 093242.08 4 path {01734000245} not found 093242.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 093243.30 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 093243.31 4 event FAX, iCode=134 state=1301 093243.31 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 093243.33 4 path {FAX} not found 093243.33 4 event TDX_CST, iCode=134 state=1301 093243.34 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 093243.34 4 path {TDX_CST} not found 093248.61 4 timer fired EV_TIMEOUT_ENTERDATA 093248.61 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 093248.63 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 093248.63 4 path {EV_TIMEOUT_ENTERDATA} not found 093248.64 4 timer clear 093248.66 4 rv add [Get Acc No]{01734000245} 093248.66 4 path {01734000245} not found 093248.67 4 next module is [Varify A/C] (idx=85) 093248.67 4 rvns add [Get Acc No_PathTaken]{success} 093248.69 4 fn RunModule start [Database Query,[Varify A/C],85,,] 093248.69 4 timer clear 093248.70 4 state [Varify A/C] DB Query 093248.72 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 093248.75 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 093248.77 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:32:28 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:32:29 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:32:29 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 093248.77 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 093248.78 4 db [Varify A/C] row count=1 093248.80 4 rv add [Varify A/C_RowCount]{1} 093248.81 4 db get RecordsetGetRowsMax 093248.81 4 db get 999 records. (row count=1) 093248.83 4 db update RVs 093248.83 4 db about to close dbDbqDatabase 093248.84 4 db going down path [True] 093248.86 4 next module is [Get PIN No] (idx=46) 093248.86 4 fn RunModule start [Get Numbers,[Get PIN No],46,,] 093248.88 4 timer clear 093248.88 4 state [Get PIN No] Number Input 093248.89 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 093248.89 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 093248.95 4 tw wav->vox convert end 992968,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 093248.97 4 play start ok, lPlayId=993031 093251.92 4 tw dtmf 3 (4,51,51) 093251.94 4 event 3, iCode=51 state=1300 093251.94 4 LsGetNbrsPlayWelcMsg 3,3 093251.95 4 play PlayStop ok 093251.97 4 state [Get PIN No] Number Input 3 093251.98 4 path {3} not found 093251.98 4 timer set 6 EV_TIMEOUT_ENTERDATA 093252.00 4 tw PlayEnd 4 993031 093252.00 4 play end id=993031, (current ID) 093252.02 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 093252.03 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 093252.03 4 path {EV_PLAY_FINISHED} not found 093252.05 4 awaiting further dtmf input 093252.05 4 tw DialogicEvent 129,TDX_PLAY,993031,0,0,,, 093252.06 4 event TDX_PLAY, iCode=129 state=1301 093252.06 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 093252.08 4 path {TDX_PLAY} not found 093252.45 4 tw dtmf 8 (4,56,56) 093252.45 4 event 8, iCode=56 state=1301 093252.47 4 LsGetNbrsRxDigits 8,8 093252.48 4 state [Get PIN No] Number Input 38 093252.48 4 path {38} not found 093252.50 4 timer set 6 EV_TIMEOUT_ENTERDATA 093253.42 4 tw dtmf 0 (4,48,48) 093253.44 4 event 0, iCode=48 state=1301 093253.44 4 LsGetNbrsRxDigits 0,0 093253.45 4 state [Get PIN No] Number Input 380 093253.45 4 path {380} not found 093253.47 4 timer set 6 EV_TIMEOUT_ENTERDATA 093254.00 4 tw dtmf 4 (4,52,52) 093254.02 4 event 4, iCode=52 state=1301 093254.02 4 LsGetNbrsRxDigits 4,4 093254.03 4 state [Get PIN No] Number Input 3804 093254.03 4 path {3804} not found 093254.05 4 timer set 6 EV_TIMEOUT_ENTERDATA 093254.05 4 timer clear 093254.06 4 rv add [Get PIN No]{3804} 093254.08 4 path {3804} not found 093254.08 4 next module is [Varify A/C No] (idx=70) 093254.09 4 rvns add [Get PIN No_PathTaken]{success} 093254.09 4 fn RunModule start [Database Query,[Varify A/C No],70,,] 093254.11 4 timer clear 093254.13 4 state [Varify A/C No] DB Query 093254.14 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 093254.17 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 093254.19 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:32:28 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:32:29 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:32:29 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 093254.19 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 093254.20 4 db [Varify A/C No] row count=1 093254.22 4 rv add [Varify A/C No_RowCount]{1} 093254.22 4 db get RecordsetGetRowsMax 093254.23 4 db get 999 records. (row count=1) 093254.25 4 db update RVs 093254.25 4 db about to close dbDbqDatabase 093254.27 4 db going down path [True] 093254.28 4 next module is (idx=47) 093254.28 4 fn RunModule start [Play,,47,,] 093254.30 4 timer clear 093254.30 4 Play Module start 093254.31 4 state Playing 093254.31 4 state Playing (Bangla Voice\Acc List.wav) 093254.33 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 093254.38 4 tw wav->vox convert end 998406,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 093254.41 4 play start ok, lPlayId=998468 093255.89 4 tw dtmf 1 (4,49,49) 093255.89 4 event 1, iCode=49 state=1100 093255.91 4 LsPlayMsg 1,1 093255.91 4 next module is [Varify Balance] (idx=48) 093255.94 4 play PlayStop ok 093255.94 4 rv add {1} 093255.95 4 fn RunModule start [Database Query,[Varify Balance],48,,] 093255.95 4 tw PlayEnd 4 998468 093255.97 4 play end id=998468, (current ID) 093255.98 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 093255.98 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 093256.00 4 tw DialogicEvent 129,TDX_PLAY,998468,0,0,,, 093256.00 4 event TDX_PLAY, iCode=129 state=6001 093256.02 4 LsModuleTransition : 129, [TDX_PLAY] 093256.03 4 timer clear 093256.03 4 state [Varify Balance] DB Query 093256.05 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 093256.08 4 rv replace start: [sELECT TRUNC(curbal) curbal FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND acstat<>'CLS'] 093256.09 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:32:28 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:32:29 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:32:29 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}[Varify A/C No_RowCount]{1}[Varify A/C No_1_1]{LX4VNZ41KDX7}{1} 093256.09 4 db About to execute a Retrieve type operation [sELECT TRUNC(curbal) curbal FROM stlbas.stfacmas WHERE actnum=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND acstat<>'CLS] 093256.11 4 db [Varify Balance] row count=1 093256.13 4 rv add [Varify Balance_RowCount]{1} 093256.13 4 db get RecordsetGetRowsMax 093256.14 4 db get 999 records. (row count=1) 093256.16 4 db update RVs 093256.16 4 db about to close dbDbqDatabase 093256.17 4 db going down path [True] 093256.19 4 next module is [say Balance] (idx=81) 093256.19 4 fn RunModule start [say Numbers,[say Balance],81,,] 093256.20 4 timer clear 093256.22 4 rv replace start: [$RV[Varify Balance_1_1]] 093256.22 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:32:28 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:32:29 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:32:29 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success}[Varify A/C No_RowCount]{1}[Varify A/C No_1_1]{LX4VNZ41KDX7}{1}[Varify Balance_RowCount]{1}[Varify Balance_1_1]{60579} 093256.23 4 rv replace end: [60579] 093256.25 4 state [say Balance] Say numbers: 60579 as Number 093256.25 4 fn PlaySoundStartNumbers [bangla Voice\Acc Bal.wav],[],[60579],Number 093256.28 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 093256.28 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 093256.30 4 rv add [Hangup Time]{01/10/2007 9:32:56 AM} 093256.31 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 093256.31 4 HangupCall_Common hCall=4 093256.33 4 rec RecSoundStop ok 093256.34 4 play PlayStop ok 093256.34 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 093256.36 4 fnHangupCall end 093256.41 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 093256.41 4 event TDX_SETHOOK, iCode=135 state=900 093256.42 4 LsAwaitingCalls EV_UNKNOWN_135 093256.42 4 event callstate IDLE 4 1,0,0 093256.44 4 WorkingMode@Idle= 093256.44 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 093256.45 4 timer clear 093256.47 4 rec RecSoundStop ok 093256.47 4 play PlayStop ok 093256.48 4 rv add [CallEndTime]{01/10/2007 9:32:56 AM} 093256.52 4 on-hangup script:[] 093256.53 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 093256.53 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 093256.55 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 093256.55 4 init atidle reinit : start 093256.56 4 init atidle reinit iConferenceOtherLegLid=-1 093256.58 4 init atidle reinit : reset all LineState variables 093256.58 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 093256.59 4 state Waiting for a call... 093258.78 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 093258.78 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 093258.80 4 setting iDialoutReadyToDialout = 1 093339.41 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 093339.42 MemStructVgs_ClearVgs [2] 093339.52 load end 093339.53 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 093339.55 0 Erasing Script (new loaded) Id 3 093339.56 0 VgsScriptFree [3] 093339.58 MemStructVgs_ClearVgs [3] 093912.92 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 093912.92 MemStructVgs_ClearVgs [3] 093913.00 load end 093913.02 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 093913.03 0 Erasing Script (new loaded) Id 2 093913.05 0 VgsScriptFree [2] 093913.05 MemStructVgs_ClearVgs [2] 093920.06 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 093920.08 MemStructVgs_ClearVgs [2] 093920.16 load end 093920.16 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 093920.17 0 Erasing Script (new loaded) Id 3 093920.17 0 VgsScriptFree [3] 093920.19 MemStructVgs_ClearVgs [3] 093939.27 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 093939.27 MemStructVgs_ClearVgs [3] 093939.34 load end 093939.36 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 093939.38 0 Erasing Script (new loaded) Id 2 093939.38 0 VgsScriptFree [2] 093939.39 MemStructVgs_ClearVgs [2] 093955.41 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 093955.41 MemStructVgs_ClearVgs [2] 093955.48 load end 093955.50 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 093955.52 0 Erasing Script (new loaded) Id 3 093955.52 0 VgsScriptFree [3] 093955.53 MemStructVgs_ClearVgs [3] 094003.94 4 event callstate OFFERING 4 2,0,0 094003.94 4 script interpretor: VgMulti v6.0.3243 094003.95 4 fired OFFERING event to listeners 094003.97 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 094003.97 4 cid CallerID vars set (in 'offering' event) [,,] 094003.98 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 094003.98 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 094004.00 4 tw ring 1 094004.02 4 ring time since last ring event (sec): 0.00 094004.02 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 094004.03 4 should answer as number of rings reached 094004.03 4 rv clear all 094004.05 4 init LineState ResetAtStartOfNewCall. 094004.06 4 answering the call (,,,0) 094004.06 4 timer clear 094004.08 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 094004.09 4 event TDX_CST, iCode=134 state=6001 094004.09 4 LsModuleTransition : 134, [TDX_CST] 094004.70 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 094004.72 4 event TDX_SETHOOK, iCode=135 state=6001 094004.73 4 LsModuleTransition : 135, [TDX_SETHOOK] 094004.73 4 event callstate CONNECTED 4 256,0,0 094004.75 4 LineEvCallState_Connected hDevice=4 params=256,0,0 094004.77 4 WorkingModes tapi= script= LineState().iState=6001 094004.77 4 Inband detection not enabled 094004.78 4 StartLoadedVgs at 01/10/2007 9:40:04 AM (VgMulti v6.0.3243) 094004.80 4 set LineState().iVgsIdx=1 094004.80 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 094004.81 4 init StartLoadedVgs_InitLineState start 094004.81 4 rv add [$RV_STARTTIME]{01/10/2007 9:40:04 AM} 094004.83 4 rv add [$RV_DEVICEID]{4} 094004.84 4 rv add [DlgcNetworkResource]{dxxxB1C4} 094004.84 4 rv add [DlgcVoiceResource]{dxxxB1C4} 094004.86 4 rv add [$RV_CIDNAME]{} 094004.86 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 094004.88 4 rvns add [scriptsPath]{G:\TeleBanking System\} 094004.89 4 rv add [$RV_CIDNUMBER]{} 094004.89 4 fn RunModule start [Play,[Get Language],1,,] 094004.91 4 tw DialogicEvent 134,TDX_CST,42831,0,0,DE_LCON,, 094004.91 4 event TDX_CST, iCode=134 state=6001 094004.92 4 LsModuleTransition : 134, [TDX_CST] 094004.94 4 timer clear 094004.94 4 Play Module start 094004.95 4 state [Get Language] Playing 094004.97 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 094004.97 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 094005.02 4 tw wav->vox convert end 429046,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 094005.03 4 play start ok, lPlayId=429093 094007.05 4 tw dtmf 1 (4,49,49) 094007.06 4 event 1, iCode=49 state=1100 094007.06 4 LsPlayMsg 1,1 094007.08 4 rv add [scriptEnd_Time]{01/10/2007 9:40:07 AM} 094007.08 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 094007.09 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 094007.13 4 rv add [scriptStart_Time]{01/10/2007 9:40:07 AM} 094007.14 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 094007.14 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 094007.16 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 094007.17 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=2 094007.17 4 rvns add [scriptsPath]{G:\TeleBanking System\} 094007.19 4 play PlayStop ok 094007.20 4 rv add [Get Language]{1} 094007.20 4 fn RunModule start [Evaluate,[Get Bangla],24,,] 094007.22 4 tw PlayEnd 4 429093 094007.23 4 play end id=429093, (current ID) 094007.23 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 094007.25 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 094007.25 4 tw DialogicEvent 129,TDX_PLAY,429093,0,0,,, 094007.27 4 event TDX_PLAY, iCode=129 state=6001 094007.28 4 LsModuleTransition : 129, [TDX_PLAY] 094007.28 4 timer clear 094007.30 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 094007.30 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 094007.31 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 094007.33 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 094007.33 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 094007.34 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 094007.34 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 094007.36 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 094007.36 4 matching path not found 094007.38 4 next module is (idx=23) 094007.39 4 matching path was found 094007.39 4 fn RunModule start [Play,,23,,] 094007.42 4 timer clear 094007.42 4 Play Module start 094007.44 4 state Playing 094007.44 4 state Playing (Bangla Voice\Service List.wav) 094007.45 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 094007.50 4 tw wav->vox convert end 431531,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 094007.52 4 play start ok, lPlayId=431578 094010.72 4 tw dtmf 1 (4,49,49) 094010.73 4 event 1, iCode=49 state=1100 094010.73 4 LsPlayMsg 1,1 094010.75 4 next module is [Get Acc No] (idx=87) 094010.77 4 play PlayStop ok 094010.78 4 rv add {1} 094010.78 4 fn RunModule start [Get Numbers,[Get Acc No],87,,] 094010.80 4 tw PlayEnd 4 431578 094010.81 4 play end id=431578, (current ID) 094010.81 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 094010.83 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 094010.84 4 tw DialogicEvent 129,TDX_PLAY,431578,0,0,,, 094010.84 4 event TDX_PLAY, iCode=129 state=6001 094010.86 4 LsModuleTransition : 129, [TDX_PLAY] 094010.86 4 timer clear 094010.88 4 state [Get Acc No] Number Input 094010.89 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 094010.89 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 094010.95 4 tw wav->vox convert end 434968,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 094010.97 4 play start ok, lPlayId=435031 094014.78 4 tw PlayEnd 4 435031 094014.80 4 play end id=435031, (current ID) 094014.81 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 094014.81 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 094014.83 4 path {EV_PLAY_FINISHED} not found 094014.83 4 timer set 17 EV_TIMEOUT_REPLAYMSG 094014.84 4 tw DialogicEvent 129,TDX_PLAY,435031,0,0,,, 094014.86 4 event TDX_PLAY, iCode=129 state=1301 094014.86 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 094014.88 4 path {TDX_PLAY} not found 094015.03 4 tw dtmf 0 (4,48,48) 094015.05 4 event 0, iCode=48 state=1301 094015.06 4 LsGetNbrsRxDigits 0,0 094015.06 4 state [Get Acc No] Number Input 0 094015.08 4 path {0} not found 094015.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 094015.45 4 tw dtmf 1 (4,49,49) 094015.45 4 event 1, iCode=49 state=1301 094015.47 4 LsGetNbrsRxDigits 1,1 094015.47 4 state [Get Acc No] Number Input 01 094015.48 4 path {01} not found 094015.50 4 timer set 6 EV_TIMEOUT_ENTERDATA 094015.81 4 tw dtmf 7 (4,55,55) 094015.81 4 event 7, iCode=55 state=1301 094015.83 4 LsGetNbrsRxDigits 7,7 094015.83 4 state [Get Acc No] Number Input 017 094015.84 4 path {017} not found 094015.86 4 timer set 6 EV_TIMEOUT_ENTERDATA 094016.28 4 tw dtmf 3 (4,51,51) 094016.28 4 event 3, iCode=51 state=1301 094016.30 4 LsGetNbrsRxDigits 3,3 094016.30 4 state [Get Acc No] Number Input 0173 094016.31 4 path {0173} not found 094016.33 4 timer set 6 EV_TIMEOUT_ENTERDATA 094016.69 4 tw dtmf 4 (4,52,52) 094016.69 4 event 4, iCode=52 state=1301 094016.70 4 LsGetNbrsRxDigits 4,4 094016.70 4 state [Get Acc No] Number Input 01734 094016.72 4 path {01734} not found 094016.73 4 timer set 6 EV_TIMEOUT_ENTERDATA 094017.13 4 tw dtmf 0 (4,48,48) 094017.14 4 event 0, iCode=48 state=1301 094017.14 4 LsGetNbrsRxDigits 0,0 094017.16 4 state [Get Acc No] Number Input 017340 094017.16 4 path {017340} not found 094017.17 4 timer set 6 EV_TIMEOUT_ENTERDATA 094017.39 4 tw dtmf 0 (4,48,48) 094017.41 4 event 0, iCode=48 state=1301 094017.41 4 LsGetNbrsRxDigits 0,0 094017.42 4 state [Get Acc No] Number Input 0173400 094017.42 4 path {0173400} not found 094017.44 4 timer set 6 EV_TIMEOUT_ENTERDATA 094017.64 4 tw dtmf 0 (4,48,48) 094017.66 4 event 0, iCode=48 state=1301 094017.66 4 LsGetNbrsRxDigits 0,0 094017.67 4 state [Get Acc No] Number Input 01734000 094017.67 4 path {01734000} not found 094017.69 4 timer set 6 EV_TIMEOUT_ENTERDATA 094018.17 4 tw dtmf 2 (4,50,50) 094018.19 4 event 2, iCode=50 state=1301 094018.19 4 LsGetNbrsRxDigits 2,2 094018.20 4 state [Get Acc No] Number Input 017340002 094018.20 4 path {017340002} not found 094018.22 4 timer set 6 EV_TIMEOUT_ENTERDATA 094018.78 4 tw dtmf 5 (4,53,53) 094018.80 4 event 5, iCode=53 state=1301 094018.80 4 LsGetNbrsRxDigits 5,5 094018.81 4 state [Get Acc No] Number Input 0173400025 094018.83 4 path {0173400025} not found 094018.83 4 timer set 6 EV_TIMEOUT_ENTERDATA 094025.30 4 timer fired EV_TIMEOUT_ENTERDATA 094025.30 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 094025.31 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 094025.31 4 path {EV_TIMEOUT_ENTERDATA} not found 094025.33 4 timer clear 094025.34 4 rv add [Get Acc No]{0173400025} 094025.34 4 len(0173400025) min=11, max=14, replays=0/1 094025.36 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 094025.36 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 094025.42 4 tw wav->vox convert end 449437,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 094025.45 4 play start ok, lPlayId=449515 094029.27 4 tw PlayEnd 4 449515 094029.27 4 play end id=449515, (current ID) 094029.28 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 094029.28 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 094029.30 4 path {EV_PLAY_FINISHED} not found 094029.31 4 timer set 10 EV_TIMEOUT_HANGUP 094029.31 4 timer set 6 EV_TIMEOUT_ENTERDATA 094029.33 4 tw DialogicEvent 129,TDX_PLAY,449515,0,0,,, 094029.33 4 event TDX_PLAY, iCode=129 state=1301 094029.34 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 094029.36 4 path {TDX_PLAY} not found 094029.64 4 tw dtmf 0 (4,48,48) 094029.66 4 event 0, iCode=48 state=1301 094029.66 4 LsGetNbrsRxDigits 0,0 094029.67 4 state [Get Acc No] Number Input 0 094029.67 4 path {0} not found 094029.69 4 timer set 6 EV_TIMEOUT_ENTERDATA 094030.00 4 tw dtmf 1 (4,49,49) 094030.02 4 event 1, iCode=49 state=1301 094030.02 4 LsGetNbrsRxDigits 1,1 094030.03 4 state [Get Acc No] Number Input 01 094030.05 4 path {01} not found 094030.05 4 timer set 6 EV_TIMEOUT_ENTERDATA 094030.34 4 tw dtmf 7 (4,55,55) 094030.36 4 event 7, iCode=55 state=1301 094030.38 4 LsGetNbrsRxDigits 7,7 094030.38 4 state [Get Acc No] Number Input 017 094030.39 4 path {017} not found 094030.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 094030.81 4 tw dtmf 3 (4,51,51) 094030.81 4 event 3, iCode=51 state=1301 094030.83 4 LsGetNbrsRxDigits 3,3 094030.84 4 state [Get Acc No] Number Input 0173 094030.84 4 path {0173} not found 094030.86 4 timer set 6 EV_TIMEOUT_ENTERDATA 094031.05 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 094031.06 4 event FAX, iCode=134 state=1301 094031.06 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 094031.08 4 path {FAX} not found 094031.08 4 event TDX_CST, iCode=134 state=1301 094031.09 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 094031.11 4 path {TDX_CST} not found 094031.22 4 tw dtmf 4 (4,52,52) 094031.22 4 event 4, iCode=52 state=1301 094031.23 4 LsGetNbrsRxDigits 4,4 094031.25 4 state [Get Acc No] Number Input 01734 094031.25 4 path {01734} not found 094031.27 4 timer set 6 EV_TIMEOUT_ENTERDATA 094031.67 4 tw dtmf 0 (4,48,48) 094031.69 4 event 0, iCode=48 state=1301 094031.69 4 LsGetNbrsRxDigits 0,0 094031.70 4 state [Get Acc No] Number Input 017340 094031.70 4 path {017340} not found 094031.72 4 timer set 6 EV_TIMEOUT_ENTERDATA 094031.95 4 tw dtmf 0 (4,48,48) 094031.95 4 event 0, iCode=48 state=1301 094031.97 4 LsGetNbrsRxDigits 0,0 094031.97 4 state [Get Acc No] Number Input 0173400 094031.98 4 path {0173400} not found 094032.00 4 timer set 6 EV_TIMEOUT_ENTERDATA 094032.19 4 tw dtmf 0 (4,48,48) 094032.20 4 event 0, iCode=48 state=1301 094032.20 4 LsGetNbrsRxDigits 0,0 094032.22 4 state [Get Acc No] Number Input 01734000 094032.22 4 path {01734000} not found 094032.23 4 timer set 6 EV_TIMEOUT_ENTERDATA 094032.67 4 tw dtmf 2 (4,50,50) 094032.67 4 event 2, iCode=50 state=1301 094032.69 4 LsGetNbrsRxDigits 2,2 094032.69 4 state [Get Acc No] Number Input 017340002 094032.70 4 path {017340002} not found 094032.72 4 timer set 6 EV_TIMEOUT_ENTERDATA 094032.89 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 094032.91 4 event FAX, iCode=134 state=1301 094032.92 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 094032.92 4 path {FAX} not found 094032.94 4 event TDX_CST, iCode=134 state=1301 094032.94 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 094032.95 4 path {TDX_CST} not found 094033.00 4 tw dtmf 4 (4,52,52) 094033.02 4 event 4, iCode=52 state=1301 094033.02 4 LsGetNbrsRxDigits 4,4 094033.03 4 state [Get Acc No] Number Input 0173400024 094033.05 4 path {0173400024} not found 094033.05 4 timer set 6 EV_TIMEOUT_ENTERDATA 094033.42 4 tw dtmf 5 (4,53,53) 094033.44 4 event 5, iCode=53 state=1301 094033.44 4 LsGetNbrsRxDigits 5,5 094033.45 4 state [Get Acc No] Number Input 01734000245 094033.45 4 path {01734000245} not found 094033.47 4 timer set 6 EV_TIMEOUT_ENTERDATA 094039.94 4 timer fired EV_TIMEOUT_ENTERDATA 094039.94 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 094039.95 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 094039.95 4 path {EV_TIMEOUT_ENTERDATA} not found 094039.97 4 timer clear 094039.97 4 rv add [Get Acc No]{01734000245} 094039.98 4 path {01734000245} not found 094040.00 4 next module is [Varify A/C] (idx=5) 094040.00 4 rvns add [Get Acc No_PathTaken]{success} 094040.02 4 fn RunModule start [Database Query,[Varify A/C],5,,] 094040.02 4 timer clear 094040.03 4 state [Varify A/C] DB Query 094040.05 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 094040.08 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 094040.09 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:40:04 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:40:07 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:40:07 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{0173400025}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 094040.11 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 094040.13 4 db [Varify A/C] row count=1 094040.13 4 rv add [Varify A/C_RowCount]{1} 094040.14 4 db get RecordsetGetRowsMax 094040.14 4 db get 999 records. (row count=1) 094040.16 4 db update RVs 094040.17 4 db about to close dbDbqDatabase 094040.17 4 db going down path [True] 094040.19 4 next module is [Get PIN No] (idx=44) 094040.19 4 fn RunModule start [Get Numbers,[Get PIN No],44,,] 094040.20 4 timer clear 094040.22 4 state [Get PIN No] Number Input 094040.22 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 094040.23 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 094040.25 4 tw wav->vox convert end 464312,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 094040.28 4 play start ok, lPlayId=464343 094042.11 4 tw dtmf 3 (4,51,51) 094042.13 4 event 3, iCode=51 state=1300 094042.13 4 LsGetNbrsPlayWelcMsg 3,3 094042.14 4 play PlayStop ok 094042.16 4 state [Get PIN No] Number Input 3 094042.17 4 path {3} not found 094042.17 4 timer set 6 EV_TIMEOUT_ENTERDATA 094042.19 4 tw PlayEnd 4 464343 094042.19 4 play end id=464343, (current ID) 094042.20 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 094042.22 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 094042.22 4 path {EV_PLAY_FINISHED} not found 094042.23 4 awaiting further dtmf input 094042.23 4 tw DialogicEvent 129,TDX_PLAY,464343,0,0,,, 094042.25 4 event TDX_PLAY, iCode=129 state=1301 094042.27 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 094042.27 4 path {TDX_PLAY} not found 094042.84 4 tw dtmf 8 (4,56,56) 094042.86 4 event 8, iCode=56 state=1301 094042.86 4 LsGetNbrsRxDigits 8,8 094042.88 4 state [Get PIN No] Number Input 38 094042.88 4 path {38} not found 094042.89 4 timer set 6 EV_TIMEOUT_ENTERDATA 094043.34 4 tw dtmf 0 (4,48,48) 094043.36 4 event 0, iCode=48 state=1301 094043.36 4 LsGetNbrsRxDigits 0,0 094043.38 4 state [Get PIN No] Number Input 380 094043.39 4 path {380} not found 094043.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 094043.58 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 094043.58 4 event FAX, iCode=134 state=1301 094043.59 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 094043.61 4 path {FAX} not found 094043.61 4 event TDX_CST, iCode=134 state=1301 094043.63 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 094043.63 4 path {TDX_CST} not found 094043.75 4 tw dtmf 4 (4,52,52) 094043.75 4 event 4, iCode=52 state=1301 094043.77 4 LsGetNbrsRxDigits 4,4 094043.78 4 state [Get PIN No] Number Input 3804 094043.78 4 path {3804} not found 094043.80 4 timer set 6 EV_TIMEOUT_ENTERDATA 094043.80 4 timer clear 094043.81 4 rv add [Get PIN No]{3804} 094043.83 4 path {3804} not found 094043.83 4 next module is [Varify A/C No] (idx=20) 094043.84 4 rvns add [Get PIN No_PathTaken]{success} 094043.84 4 fn RunModule start [Database Query,[Varify A/C No],20,,] 094043.86 4 timer clear 094043.88 4 state [Varify A/C No] DB Query 094043.88 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 094043.92 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 094043.92 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:40:04 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:40:07 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:40:07 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{0173400025}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 094043.94 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 094043.95 4 db [Varify A/C No] row count=1 094043.95 4 rv add [Varify A/C No_RowCount]{1} 094043.97 4 db get RecordsetGetRowsMax 094043.97 4 db get 999 records. (row count=1) 094043.98 4 db update RVs 094044.00 4 db about to close dbDbqDatabase 094044.00 4 db going down path [True] 094044.02 4 next module is (idx=43) 094044.03 4 fn RunModule start [Play,,43,,] 094044.03 4 timer clear 094044.05 4 Play Module start 094044.05 4 state Playing 094044.06 4 state Playing (Bangla Voice\Acc List.wav) 094044.08 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 094044.11 4 tw wav->vox convert end 468156,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 094044.14 4 play start ok, lPlayId=468203 094045.47 4 tw dtmf 1 (4,49,49) 094045.48 4 event 1, iCode=49 state=1100 094045.48 4 LsPlayMsg 1,1 094045.50 4 next module is [say Bal 1] (idx=4) 094045.52 4 play PlayStop ok 094045.53 4 rv add {1} 094045.55 4 fn RunModule start [say Numbers,[say Bal 1],4,,] 094045.56 4 tw PlayEnd 4 468203 094045.56 4 play end id=468203, (current ID) 094045.58 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 094045.58 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 094045.59 4 tw DialogicEvent 129,TDX_PLAY,468203,0,0,,, 094045.61 4 event TDX_PLAY, iCode=129 state=6001 094045.61 4 LsModuleTransition : 129, [TDX_PLAY] 094045.64 4 timer clear 094045.64 4 state [say Bal 1] Say numbers: 2000 as Number 094045.66 4 fn PlaySoundStartNumbers [],[],[2000],Number 094045.67 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 094045.69 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 094045.69 4 rv add [Hangup Time]{01/10/2007 9:40:45 AM} 094045.70 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 094045.70 4 HangupCall_Common hCall=4 094045.72 4 rec RecSoundStop ok 094045.73 4 play PlayStop ok 094045.73 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 094045.75 4 fnHangupCall end 094045.77 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 094045.77 4 event FAX, iCode=134 state=900 094045.78 4 LsAwaitingCalls EV_UNKNOWN_134 094045.78 4 event TDX_CST, iCode=134 state=900 094045.80 4 LsAwaitingCalls EV_UNKNOWN_134 094045.81 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 094045.81 4 event TDX_SETHOOK, iCode=135 state=900 094045.83 4 LsAwaitingCalls EV_UNKNOWN_135 094045.83 4 event callstate IDLE 4 1,0,0 094045.84 4 WorkingMode@Idle= 094045.86 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 094045.86 4 timer clear 094045.88 4 rec RecSoundStop ok 094045.89 4 play PlayStop ok 094045.89 4 rv add [CallEndTime]{01/10/2007 9:40:45 AM} 094045.92 4 on-hangup script:[] 094045.94 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 094045.94 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 094045.95 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 094045.97 4 init atidle reinit : start 094045.97 4 init atidle reinit iConferenceOtherLegLid=-1 094045.98 4 init atidle reinit : reset all LineState variables 094045.98 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094046.00 4 state Waiting for a call... 094048.20 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094048.20 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 094048.22 4 setting iDialoutReadyToDialout = 1 094159.66 0 btn Exit (4 lines) 094159.67 1 line state = 0 094159.69 2 line state = 0 094159.69 3 line state = 0 094159.70 4 line state = 900 094159.70 1 state Exiting... 094159.72 2 state Exiting... 094159.73 3 state Exiting... 094159.73 4 state Exiting... 094200.81 0 exit closing all channels start 094200.81 0 exit close dxxxB1C1(1)=> [] 094200.83 0 exit close dxxxB1C2(2)=> [] 094200.84 0 exit close dxxxB1C3(3)=> [] 094200.86 0 exit close dxxxB1C4(4)=> [] 094200.86 0 exit closing all channels end 094201.80 0 deleting EmailQue.mdb 094201.81 0 EmailQue.mdb was deleted 094201.81 0 --------------------------------------------------- 094201.83 0 Stopping VoiceGuide (Dialogic) start 094201.83 0 v6.0.3243 094201.84 0 Stopping VoiceGuide (Dialogic) end 094201.84 0 --------------------------------------------------- 094206.38 0 --------------------------------------------------- 094206.39 0 VoiceGuide for Dialogic 094206.41 0 v6.0.3243 094206.41 0 --------------------------------------------------- 094206.42 0 rv global loaded >>><<< 094206.44 0 cti Inband Signaling Config file not specified 094208.39 0 init ApiMode=[DialogicGC] 094208.42 0 vm loading VMB data begin 094208.44 0 vm loading VMB data - about to delete old entries 094208.45 0 vm loading VMB data - sorting/ordering 094208.47 0 vm loading VMB data end 094208.47 0 dial DbConnectString_ADO is blank 094208.52 0 init DB Workspaces 094208.55 0 init Voicemail LoadIniSettings 094208.56 0 init VmEmailBody_MainGlobalTemplate loaded from C:\Program Files\VoiceGuide\system\vm\EmailForwardTemplate_body.txt 094208.58 0 init temp dir exists [C:\Program Files\VoiceGuide\temp\] 094208.59 0 init read Config.xml start 094208.61 0 dxxxB1C1 dxxxB1C1 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1 094208.63 0 dxxxB1C2 dxxxB1C2 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1 094208.63 0 dxxxB1C3 dxxxB1C3 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1 094208.64 0 dxxxB1C4 dxxxB1C4 G:\TeleBanking System\Tele Banking_Main.vgs RV= allowDialout=1 094208.64 0 init read Config.xml end 094208.66 0 init LineOpenDialogic dxxxB1C1 => [1] 094208.67 1 iIvrDev=1 094208.72 0 init distinct ring definitions found:0 094208.72 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig) 094208.73 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 094208.75 MemStructVgs_ClearVgs [1] 094208.75 load end 094208.77 1 state Waiting for a call... 094208.78 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 094208.78 1 event TDX_SETHOOK, iCode=135 state=0 094208.80 1 event callstate IDLE 1 1,0,0 094208.80 1 WorkingMode@Idle= 094208.81 1 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 094208.83 1 timer clear 094208.83 1 LineState(iLineId).iVgsIdx = 0 094208.84 1 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 094208.84 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094208.86 1 timer set ignored - waiting for line re-init to occur first 094208.88 0 init LineOpenDialogic dxxxB1C2 => [2] 094208.88 2 iIvrDev=2 094208.92 0 init distinct ring definitions found:0 094208.94 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig) 094208.94 2 state Waiting for a call... 094208.95 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 094208.97 2 event TDX_SETHOOK, iCode=135 state=0 094208.97 2 event callstate IDLE 2 1,0,0 094208.98 2 WorkingMode@Idle= 094208.98 2 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 094209.00 2 timer clear 094209.00 2 LineState(iLineId).iVgsIdx = 0 094209.02 2 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 094209.03 1 timer fired EV_TIMEOUT_TIMETOREINITLINE 094209.03 1 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0 094209.05 1 init atidle reinit : start 094209.06 1 init atidle reinit iConferenceOtherLegLid=-1 094209.06 1 init atidle reinit : reset all LineState variables 094209.08 1 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094209.08 1 state Waiting for a call... 094209.09 2 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094209.11 2 timer set ignored - waiting for line re-init to occur first 094209.13 0 init LineOpenDialogic dxxxB1C3 => [3] 094209.13 3 iIvrDev=3 094209.17 0 init distinct ring definitions found:0 094209.19 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig) 094209.19 3 state Waiting for a call... 094209.20 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 094209.20 3 event TDX_SETHOOK, iCode=135 state=0 094209.22 3 event callstate IDLE 3 1,0,0 094209.23 3 WorkingMode@Idle= 094209.23 3 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 094209.25 3 timer clear 094209.25 3 LineState(iLineId).iVgsIdx = 0 094209.27 3 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 094209.28 2 timer fired EV_TIMEOUT_TIMETOREINITLINE 094209.28 2 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0 094209.30 2 init atidle reinit : start 094209.30 2 init atidle reinit iConferenceOtherLegLid=-1 094209.31 2 init atidle reinit : reset all LineState variables 094209.33 2 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094209.33 2 state Waiting for a call... 094209.34 3 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094209.34 3 timer set ignored - waiting for line re-init to occur first 094209.36 0 init LineOpenDialogic dxxxB1C4 => [4] 094209.38 4 iIvrDev=4 094209.41 0 init distinct ring definitions found:0 094209.42 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig) 094209.44 4 state Waiting for a call... 094209.44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 094209.45 4 event TDX_SETHOOK, iCode=135 state=0 094209.47 4 event callstate IDLE 4 1,0,0 094209.47 4 WorkingMode@Idle= 094209.48 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 094209.48 4 timer clear 094209.50 4 LineState(iLineId).iVgsIdx = 0 094209.52 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 094209.52 3 timer fired EV_TIMEOUT_TIMETOREINITLINE 094209.53 3 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0 094209.53 3 init atidle reinit : start 094209.55 3 init atidle reinit iConferenceOtherLegLid=-1 094209.56 3 init atidle reinit : reset all LineState variables 094209.56 3 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094209.58 3 state Waiting for a call... 094209.58 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094209.59 4 timer set ignored - waiting for line re-init to occur first 094209.61 0 init lineids in use: 0-4 094209.61 0 init route channels start 094209.66 0 init route channels => [] 094209.67 0 init no dti channels opened. Not opening signaling channel. 094209.69 0 cti //devicesCTI/ctiLink config.xml section not used in this version 094209.69 0 init read Config.xml //devicesSysManagers/StatusLink start 094209.70 0 tcpsl config.xml does not have //devicesSysManagers/StatusLink section (status link wil use the default port of 14710) 094209.72 0 tcpsl open //devicesSysManagers/StatusLink to listen on port 14710 094209.72 0 init read Config.xml //devicesSysManagers/StatusLink end 094209.73 0 init iLineDevicesControlled=4 094209.75 0 init main form load end 094209.75 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 094209.77 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=0 094209.77 4 init atidle reinit : start 094209.78 4 init atidle reinit iConferenceOtherLegLid=-1 094209.80 4 init atidle reinit : reset all LineState variables 094209.80 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094209.81 4 state Waiting for a call... 094211.67 1 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094211.67 1 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0 094211.69 1 setting iDialoutReadyToDialout = 1 094211.80 2 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094211.80 2 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0 094211.81 2 setting iDialoutReadyToDialout = 1 094211.92 3 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094211.92 3 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0 094211.94 3 setting iDialoutReadyToDialout = 1 094212.05 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 094212.05 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=0 094212.06 4 setting iDialoutReadyToDialout = 1 094304.03 0 sys cleanup Start 094304.03 0 sys cleanup End 095132.84 4 event callstate OFFERING 4 2,0,0 095132.86 4 script interpretor: VgMulti v6.0.3243 095132.86 4 fired OFFERING event to listeners 095132.88 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 095132.89 4 cid CallerID vars set (in 'offering' event) [,,] 095132.89 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 095132.91 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 095132.91 4 tw ring 1 095132.92 4 ring time since last ring event (sec): 0.00 095132.94 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 095132.94 4 should answer as number of rings reached 095132.95 4 rv clear all 095132.95 4 init LineState ResetAtStartOfNewCall. 095132.97 4 answering the call (,,,0) 095132.98 4 timer clear 095133.00 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 095133.00 4 event TDX_CST, iCode=134 state=6001 095133.02 4 LsModuleTransition : 134, [TDX_CST] 095133.63 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 095133.63 4 event TDX_SETHOOK, iCode=135 state=6001 095133.64 4 LsModuleTransition : 135, [TDX_SETHOOK] 095133.66 4 event callstate CONNECTED 4 256,0,0 095133.66 4 LineEvCallState_Connected hDevice=4 params=256,0,0 095133.67 4 WorkingModes tapi= script= LineState().iState=6001 095133.69 4 Inband detection not enabled 095133.70 4 StartLoadedVgs at 01/10/2007 9:51:33 AM (VgMulti v6.0.3243) 095133.70 4 set LineState().iVgsIdx=1 095133.72 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 095133.72 4 init StartLoadedVgs_InitLineState start 095133.73 4 rv add [$RV_STARTTIME]{01/10/2007 9:51:33 AM} 095133.75 4 rv add [$RV_DEVICEID]{4} 095133.75 4 rv add [DlgcNetworkResource]{dxxxB1C4} 095133.77 4 rv add [DlgcVoiceResource]{dxxxB1C4} 095133.78 4 rv add [$RV_CIDNAME]{} 095133.78 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 095133.80 4 rvns add [scriptsPath]{G:\TeleBanking System\} 095133.80 4 rv add [$RV_CIDNUMBER]{} 095133.81 4 fn RunModule start [Play,[Get Language],1,,] 095133.83 4 tw DialogicEvent 134,TDX_CST,64781,0,0,DE_LCON,, 095133.83 4 event TDX_CST, iCode=134 state=6001 095133.84 4 LsModuleTransition : 134, [TDX_CST] 095133.86 4 timer clear 095133.86 4 Play Module start 095133.88 4 state [Get Language] Playing 095133.88 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 095133.89 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 095133.91 4 tw wav->vox convert end 117968,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 095133.94 4 play start ok, lPlayId=118000 095135.41 4 tw dtmf 1 (4,49,49) 095135.42 4 event 1, iCode=49 state=1100 095135.42 4 LsPlayMsg 1,1 095135.44 4 rv add [scriptEnd_Time]{01/10/2007 9:51:35 AM} 095135.44 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 095135.45 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 095135.48 4 rv add [scriptStart_Time]{01/10/2007 9:51:35 AM} 095135.50 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 095135.50 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 095135.52 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095135.53 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095135.53 MemStructVgs_ClearVgs [2] 095135.61 load end 095135.63 4 loaded [G:\TeleBanking System\Tele Banking_Ban.vgs] into:2 095135.64 4 rvns add [scriptsPath]{G:\TeleBanking System\} 095135.66 4 play PlayStop ok 095135.67 4 rv add [Get Language]{1} 095135.67 4 fn RunModule start [Evaluate,[Get Bangla],25,,] 095135.69 4 tw PlayEnd 4 118000 095135.70 4 play end id=118000, (current ID) 095135.70 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 095135.72 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 095135.72 4 tw DialogicEvent 129,TDX_PLAY,118000,0,0,,, 095135.73 4 event TDX_PLAY, iCode=129 state=6001 095135.75 4 LsModuleTransition : 129, [TDX_PLAY] 095135.75 4 timer clear 095135.77 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 095135.80 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 095135.81 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 095135.81 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 095135.83 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 095135.83 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 095135.84 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 095135.86 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 095135.86 4 matching path not found 095135.88 4 next module is (idx=26) 095135.89 4 matching path was found 095135.89 4 fn RunModule start [Play,,26,,] 095135.91 4 timer clear 095135.91 4 Play Module start 095135.92 4 state Playing 095135.94 4 state Playing (Bangla Voice\Service List.wav) 095135.94 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 095136.00 4 tw wav->vox convert end 120015,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 095136.02 4 play start ok, lPlayId=120078 095136.75 4 tw dtmf 1 (4,49,49) 095136.77 4 event 1, iCode=49 state=1100 095136.77 4 LsPlayMsg 1,1 095136.78 4 next module is [Get Acc No] (idx=4) 095136.80 4 play PlayStop ok 095136.81 4 rv add {1} 095136.81 4 fn RunModule start [Get Numbers,[Get Acc No],4,,] 095136.83 4 tw PlayEnd 4 120078 095136.83 4 play end id=120078, (current ID) 095136.84 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 095136.86 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 095136.86 4 tw DialogicEvent 129,TDX_PLAY,120078,0,0,,, 095136.88 4 event TDX_PLAY, iCode=129 state=6001 095136.89 4 LsModuleTransition : 129, [TDX_PLAY] 095136.89 4 timer clear 095136.91 4 state [Get Acc No] Number Input 095136.91 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 095136.92 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 095136.95 4 tw wav->vox convert end 121000,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 095136.98 4 play start ok, lPlayId=121046 095140.80 4 tw PlayEnd 4 121046 095140.81 4 play end id=121046, (current ID) 095140.83 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 095140.83 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 095140.84 4 path {EV_PLAY_FINISHED} not found 095140.86 4 timer set 17 EV_TIMEOUT_REPLAYMSG 095140.86 4 tw DialogicEvent 129,TDX_PLAY,121046,0,0,,, 095140.88 4 event TDX_PLAY, iCode=129 state=1301 095140.88 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 095140.89 4 path {TDX_PLAY} not found 095141.16 4 tw dtmf 0 (4,48,48) 095141.17 4 event 0, iCode=48 state=1301 095141.19 4 LsGetNbrsRxDigits 0,0 095141.19 4 state [Get Acc No] Number Input 0 095141.20 4 path {0} not found 095141.22 4 timer set 6 EV_TIMEOUT_ENTERDATA 095141.48 4 tw dtmf 1 (4,49,49) 095141.50 4 event 1, iCode=49 state=1301 095141.50 4 LsGetNbrsRxDigits 1,1 095141.52 4 state [Get Acc No] Number Input 01 095141.53 4 path {01} not found 095141.53 4 timer set 6 EV_TIMEOUT_ENTERDATA 095141.84 4 tw dtmf 7 (4,55,55) 095141.84 4 event 7, iCode=55 state=1301 095141.86 4 LsGetNbrsRxDigits 7,7 095141.86 4 state [Get Acc No] Number Input 017 095141.88 4 path {017} not found 095141.89 4 timer set 6 EV_TIMEOUT_ENTERDATA 095142.30 4 tw dtmf 3 (4,51,51) 095142.31 4 event 3, iCode=51 state=1301 095142.33 4 LsGetNbrsRxDigits 3,3 095142.33 4 state [Get Acc No] Number Input 0173 095142.34 4 path {0173} not found 095142.36 4 timer set 6 EV_TIMEOUT_ENTERDATA 095142.67 4 tw dtmf 4 (4,52,52) 095142.69 4 event 4, iCode=52 state=1301 095142.69 4 LsGetNbrsRxDigits 4,4 095142.70 4 state [Get Acc No] Number Input 01734 095142.72 4 path {01734} not found 095142.72 4 timer set 6 EV_TIMEOUT_ENTERDATA 095143.28 4 tw dtmf 0 (4,48,48) 095143.30 4 event 0, iCode=48 state=1301 095143.31 4 LsGetNbrsRxDigits 0,0 095143.31 4 state [Get Acc No] Number Input 017340 095143.33 4 path {017340} not found 095143.34 4 timer set 6 EV_TIMEOUT_ENTERDATA 095143.48 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 095143.50 4 event FAX, iCode=134 state=1301 095143.52 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 095143.52 4 path {FAX} not found 095143.53 4 event TDX_CST, iCode=134 state=1301 095143.55 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 095143.55 4 path {TDX_CST} not found 095143.56 4 tw dtmf 0 (4,48,48) 095143.56 4 event 0, iCode=48 state=1301 095143.58 4 LsGetNbrsRxDigits 0,0 095143.59 4 state [Get Acc No] Number Input 0173400 095143.59 4 path {0173400} not found 095143.61 4 timer set 6 EV_TIMEOUT_ENTERDATA 095143.75 4 tw dtmf 0 (4,48,48) 095143.75 4 event 0, iCode=48 state=1301 095143.77 4 LsGetNbrsRxDigits 0,0 095143.78 4 state [Get Acc No] Number Input 01734000 095143.78 4 path {01734000} not found 095143.80 4 timer set 6 EV_TIMEOUT_ENTERDATA 095144.20 4 tw dtmf 2 (4,50,50) 095144.20 4 event 2, iCode=50 state=1301 095144.22 4 LsGetNbrsRxDigits 2,2 095144.23 4 state [Get Acc No] Number Input 017340002 095144.23 4 path {017340002} not found 095144.25 4 timer set 6 EV_TIMEOUT_ENTERDATA 095144.52 4 tw dtmf 4 (4,52,52) 095144.52 4 event 4, iCode=52 state=1301 095144.53 4 LsGetNbrsRxDigits 4,4 095144.55 4 state [Get Acc No] Number Input 0173400024 095144.55 4 path {0173400024} not found 095144.56 4 timer set 6 EV_TIMEOUT_ENTERDATA 095144.83 4 tw dtmf 5 (4,53,53) 095144.84 4 event 5, iCode=53 state=1301 095144.86 4 LsGetNbrsRxDigits 5,5 095144.86 4 state [Get Acc No] Number Input 01734000245 095144.88 4 path {01734000245} not found 095144.89 4 timer set 6 EV_TIMEOUT_ENTERDATA 095151.39 4 timer fired EV_TIMEOUT_ENTERDATA 095151.39 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 095151.41 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 095151.41 4 path {EV_TIMEOUT_ENTERDATA} not found 095151.42 4 timer clear 095151.44 4 rv add [Get Acc No]{01734000245} 095151.44 4 path {01734000245} not found 095151.45 4 next module is [Varify A/C] (idx=44) 095151.45 4 rvns add [Get Acc No_PathTaken]{success} 095151.47 4 fn RunModule start [Database Query,[Varify A/C],44,,] 095151.48 4 timer clear 095151.48 4 state [Varify A/C] DB Query 095151.50 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 095151.86 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 095151.86 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:51:33 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:51:35 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:51:35 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 095151.88 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 095151.89 4 db [Varify A/C] row count=1 095151.89 4 rv add [Varify A/C_RowCount]{1} 095151.91 4 db get RecordsetGetRowsMax 095151.92 4 db get 999 records. (row count=1) 095151.92 4 db update RVs 095151.94 4 db about to close dbDbqDatabase 095151.94 4 db going down path [True] 095151.95 4 next module is [Get PIN No] (idx=5) 095151.97 4 fn RunModule start [Get Numbers,[Get PIN No],5,,] 095151.97 4 timer clear 095151.98 4 state [Get PIN No] Number Input 095152.00 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 095152.00 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 095152.05 4 tw wav->vox convert end 136078,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 095152.06 4 play start ok, lPlayId=136125 095155.39 4 tw PlayEnd 4 136125 095155.39 4 play end id=136125, (current ID) 095155.41 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 095155.41 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 095155.42 4 path {EV_PLAY_FINISHED} not found 095155.44 4 timer set 7 EV_TIMEOUT_REPLAYMSG 095155.44 4 tw DialogicEvent 129,TDX_PLAY,136125,0,0,,, 095155.45 4 event TDX_PLAY, iCode=129 state=1301 095155.45 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 095155.47 4 path {TDX_PLAY} not found 095156.00 4 tw dtmf 3 (4,51,51) 095156.00 4 event 3, iCode=51 state=1301 095156.02 4 LsGetNbrsRxDigits 3,3 095156.03 4 state [Get PIN No] Number Input 3 095156.03 4 path {3} not found 095156.05 4 timer set 6 EV_TIMEOUT_ENTERDATA 095156.61 4 tw dtmf 8 (4,56,56) 095156.61 4 event 8, iCode=56 state=1301 095156.63 4 LsGetNbrsRxDigits 8,8 095156.64 4 state [Get PIN No] Number Input 38 095156.64 4 path {38} not found 095156.66 4 timer set 6 EV_TIMEOUT_ENTERDATA 095157.33 4 tw dtmf 0 (4,48,48) 095157.34 4 event 0, iCode=48 state=1301 095157.34 4 LsGetNbrsRxDigits 0,0 095157.36 4 state [Get PIN No] Number Input 380 095157.36 4 path {380} not found 095157.38 4 timer set 6 EV_TIMEOUT_ENTERDATA 095158.09 4 tw dtmf 4 (4,52,52) 095158.11 4 event 4, iCode=52 state=1301 095158.11 4 LsGetNbrsRxDigits 4,4 095158.13 4 state [Get PIN No] Number Input 3804 095158.14 4 path {3804} not found 095158.14 4 timer set 6 EV_TIMEOUT_ENTERDATA 095158.16 4 timer clear 095158.16 4 rv add [Get PIN No]{3804} 095158.17 4 path {3804} not found 095158.19 4 next module is [Varify A/C No] (idx=29) 095158.19 4 rvns add [Get PIN No_PathTaken]{success} 095158.20 4 fn RunModule start [Database Query,[Varify A/C No],29,,] 095158.22 4 timer clear 095158.23 4 state [Varify A/C No] DB Query 095158.23 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 095158.28 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 095158.28 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:51:33 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:51:35 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:51:35 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 095158.30 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 095158.31 4 db [Varify A/C No] row count=1 095158.31 4 rv add [Varify A/C No_RowCount]{1} 095158.33 4 db get RecordsetGetRowsMax 095158.33 4 db get 999 records. (row count=1) 095158.34 4 db update RVs 095158.36 4 db about to close dbDbqDatabase 095158.36 4 db going down path [True] 095158.38 4 next module is (idx=6) 095158.39 4 fn RunModule start [Play,,6,,] 095158.39 4 timer clear 095158.41 4 Play Module start 095158.41 4 state Playing 095158.42 4 state Playing (Bangla Voice\Acc List.wav) 095158.44 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 095158.48 4 tw wav->vox convert end 142515,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 095158.52 4 play start ok, lPlayId=142578 095200.70 4 tw dtmf 1 (4,49,49) 095200.70 4 event 1, iCode=49 state=1100 095200.72 4 LsPlayMsg 1,1 095200.73 4 next module is [say Bal 1] (idx=45) 095200.75 4 play PlayStop ok 095200.75 4 rv add {1} 095200.77 4 fn RunModule start [say Numbers,[say Bal 1],45,,] 095200.78 4 tw PlayEnd 4 142578 095200.78 4 play end id=142578, (current ID) 095200.80 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 095200.80 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 095200.81 4 tw DialogicEvent 129,TDX_PLAY,142578,0,0,,, 095200.83 4 event TDX_PLAY, iCode=129 state=6001 095200.83 4 LsModuleTransition : 129, [TDX_PLAY] 095200.84 4 timer clear 095200.86 4 state [say Bal 1] Say numbers: 100 as Number 095200.86 4 fn PlaySoundStartNumbers [C:\Program Files\VoiceGuide\system\Bangla Voice\Acc Bal.wav],[],[100],Number 095200.88 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 095200.88 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 095200.89 4 rv add [Hangup Time]{01/10/2007 9:52:00 AM} 095200.91 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 095200.91 4 HangupCall_Common hCall=4 095200.92 4 rec RecSoundStop ok 095200.94 4 play PlayStop ok 095200.94 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 095200.95 4 fnHangupCall end 095201.00 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 095201.00 4 event TDX_SETHOOK, iCode=135 state=900 095201.02 4 LsAwaitingCalls EV_UNKNOWN_135 095201.02 4 event callstate IDLE 4 1,0,0 095201.03 4 WorkingMode@Idle= 095201.05 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 095201.05 4 timer clear 095201.06 4 rec RecSoundStop ok 095201.08 4 play PlayStop ok 095201.08 4 rv add [CallEndTime]{01/10/2007 9:52:01 AM} 095201.11 4 on-hangup script:[] 095201.13 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 095201.13 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 095201.14 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 095201.14 4 init atidle reinit : start 095201.16 4 init atidle reinit iConferenceOtherLegLid=-1 095201.17 4 init atidle reinit : reset all LineState variables 095201.17 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 095201.19 4 state Waiting for a call... 095203.38 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 095203.38 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 095203.39 4 setting iDialoutReadyToDialout = 1 095234.27 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095234.27 MemStructVgs_ClearVgs [3] 095234.34 load end 095234.36 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 095234.38 0 Erasing Script (new loaded) Id 2 095234.38 0 VgsScriptFree [2] 095234.39 MemStructVgs_ClearVgs [2] 095237.41 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095237.41 MemStructVgs_ClearVgs [2] 095237.48 load end 095237.48 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 095237.50 0 Erasing Script (new loaded) Id 3 095237.52 0 VgsScriptFree [3] 095237.52 MemStructVgs_ClearVgs [3] 095320.55 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095320.55 MemStructVgs_ClearVgs [3] 095320.63 load end 095320.64 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 095320.64 0 Erasing Script (new loaded) Id 2 095320.66 0 VgsScriptFree [2] 095320.66 MemStructVgs_ClearVgs [2] 095335.69 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095335.69 MemStructVgs_ClearVgs [2] 095335.77 load end 095335.77 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 095335.78 0 Erasing Script (new loaded) Id 3 095335.80 0 VgsScriptFree [3] 095335.80 MemStructVgs_ClearVgs [3] 095423.81 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095423.81 MemStructVgs_ClearVgs [3] 095423.89 load end 095423.91 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 095423.91 0 Erasing Script (new loaded) Id 2 095423.92 0 VgsScriptFree [2] 095423.94 MemStructVgs_ClearVgs [2] 095555.23 0 vm loading VMB data begin 095555.23 0 vm loading VMB data - about to delete old entries 095555.25 0 vm loading VMB data - sorting/ordering 095555.27 0 vm loading VMB data end 095555.27 0 Loaded new voicemail configuration file (XML) 095708.33 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095708.33 MemStructVgs_ClearVgs [2] 095708.41 load end 095708.42 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 095708.44 0 Erasing Script (new loaded) Id 3 095708.44 0 VgsScriptFree [3] 095708.45 MemStructVgs_ClearVgs [3] 095725.45 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095725.45 MemStructVgs_ClearVgs [3] 095725.53 load end 095725.55 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 095725.56 0 Erasing Script (new loaded) Id 2 095725.56 0 VgsScriptFree [2] 095725.58 MemStructVgs_ClearVgs [2] 095809.61 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095809.61 MemStructVgs_ClearVgs [2] 095809.69 load end 095809.70 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 095809.70 0 Erasing Script (new loaded) Id 3 095809.72 0 VgsScriptFree [3] 095809.73 MemStructVgs_ClearVgs [3] 095825.73 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095825.73 MemStructVgs_ClearVgs [3] 095825.81 load end 095825.83 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 095825.84 0 Erasing Script (new loaded) Id 2 095825.84 0 VgsScriptFree [2] 095825.86 MemStructVgs_ClearVgs [2] 095838.86 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095838.86 MemStructVgs_ClearVgs [2] 095838.94 load end 095838.95 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 095838.95 0 Erasing Script (new loaded) Id 3 095838.97 0 VgsScriptFree [3] 095838.97 MemStructVgs_ClearVgs [3] 095856.98 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095856.98 MemStructVgs_ClearVgs [3] 095857.06 load end 095857.08 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 095857.09 0 Erasing Script (new loaded) Id 2 095857.09 0 VgsScriptFree [2] 095857.11 MemStructVgs_ClearVgs [2] 095905.13 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095905.13 MemStructVgs_ClearVgs [2] 095905.20 load end 095905.22 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 095905.23 0 Erasing Script (new loaded) Id 3 095905.23 0 VgsScriptFree [3] 095905.25 MemStructVgs_ClearVgs [3] 095910.25 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095910.25 MemStructVgs_ClearVgs [3] 095910.33 load end 095910.34 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 095910.36 0 Erasing Script (new loaded) Id 2 095910.36 0 VgsScriptFree [2] 095910.38 MemStructVgs_ClearVgs [2] 095914.38 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095914.38 MemStructVgs_ClearVgs [2] 095914.45 load end 095914.47 loaded Script Id 2: G:\TeleBanking System\Tele Banking_Ban.vgs 095914.48 0 Erasing Script (new loaded) Id 3 095914.48 0 VgsScriptFree [3] 095914.50 MemStructVgs_ClearVgs [3] 095940.97 4 event callstate OFFERING 4 2,0,0 095940.98 4 script interpretor: VgMulti v6.0.3243 095941.00 4 fired OFFERING event to listeners 095941.00 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 095941.02 4 cid CallerID vars set (in 'offering' event) [,,] 095941.02 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 095941.03 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 095941.05 4 tw ring 1 095941.05 4 ring time since last ring event (sec): 0.00 095941.06 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 095941.06 4 should answer as number of rings reached 095941.08 4 rv clear all 095941.09 4 init LineState ResetAtStartOfNewCall. 095941.09 4 answering the call (,,,0) 095941.11 4 timer clear 095941.13 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 095941.13 4 event TDX_CST, iCode=134 state=6001 095941.14 4 LsModuleTransition : 134, [TDX_CST] 095941.75 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 095941.77 4 event TDX_SETHOOK, iCode=135 state=6001 095941.77 4 LsModuleTransition : 135, [TDX_SETHOOK] 095941.78 4 event callstate CONNECTED 4 256,0,0 095941.78 4 LineEvCallState_Connected hDevice=4 params=256,0,0 095941.80 4 WorkingModes tapi= script= LineState().iState=6001 095941.81 4 Inband detection not enabled 095941.81 4 StartLoadedVgs at 01/10/2007 9:59:41 AM (VgMulti v6.0.3243) 095941.83 4 set LineState().iVgsIdx=1 095941.84 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 095941.84 4 init StartLoadedVgs_InitLineState start 095941.86 4 rv add [$RV_STARTTIME]{01/10/2007 9:59:41 AM} 095941.86 4 rv add [$RV_DEVICEID]{4} 095941.88 4 rv add [DlgcNetworkResource]{dxxxB1C4} 095941.89 4 rv add [DlgcVoiceResource]{dxxxB1C4} 095941.89 4 rv add [$RV_CIDNAME]{} 095941.91 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 095941.92 4 rvns add [scriptsPath]{G:\TeleBanking System\} 095941.92 4 rv add [$RV_CIDNUMBER]{} 095941.94 4 fn RunModule start [Play,[Get Language],1,,] 095941.94 4 tw DialogicEvent 134,TDX_CST,46075,0,0,DE_LCON,, 095941.95 4 event TDX_CST, iCode=134 state=6001 095941.97 4 LsModuleTransition : 134, [TDX_CST] 095941.97 4 timer clear 095941.98 4 Play Module start 095941.98 4 state [Get Language] Playing 095942.00 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 095942.02 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 095942.03 4 tw wav->vox convert end 606093,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 095942.06 4 play start ok, lPlayId=606125 095942.78 4 tw dtmf 1 (4,49,49) 095942.78 4 event 1, iCode=49 state=1100 095942.80 4 LsPlayMsg 1,1 095942.80 4 rv add [scriptEnd_Time]{01/10/2007 9:59:42 AM} 095942.81 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 095942.83 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 095942.86 4 rv add [scriptStart_Time]{01/10/2007 9:59:42 AM} 095942.86 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 095942.88 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 095942.88 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 095942.89 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=2 095942.91 4 rvns add [scriptsPath]{G:\TeleBanking System\} 095942.92 4 play PlayStop ok 095942.92 4 rv add [Get Language]{1} 095942.94 4 fn RunModule start [Evaluate,[Get Bangla],25,,] 095942.95 4 tw PlayEnd 4 606125 095942.95 4 play end id=606125, (current ID) 095942.97 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 095942.97 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 095942.98 4 tw DialogicEvent 129,TDX_PLAY,606125,0,0,,, 095943.00 4 event TDX_PLAY, iCode=129 state=6001 095943.00 4 LsModuleTransition : 129, [TDX_PLAY] 095943.02 4 timer clear 095943.02 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 095943.03 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 095943.05 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 095943.05 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 095943.06 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 095943.06 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 095943.08 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 095943.09 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 095943.09 4 matching path not found 095943.11 4 next module is (idx=24) 095943.11 4 matching path was found 095943.13 4 fn RunModule start [Play,,24,,] 095943.14 4 timer clear 095943.14 4 Play Module start 095943.16 4 state Playing 095943.16 4 state Playing (Bangla Voice\Service List.wav) 095943.17 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 095943.20 4 tw wav->vox convert end 607250,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 095943.22 4 play start ok, lPlayId=607296 095944.83 4 tw dtmf 1 (4,49,49) 095944.84 4 event 1, iCode=49 state=1100 095944.84 4 LsPlayMsg 1,1 095944.86 4 next module is [Get Acc No] (idx=87) 095944.88 4 play PlayStop ok 095944.89 4 rv add {1} 095944.89 4 fn RunModule start [Get Numbers,[Get Acc No],87,,] 095944.91 4 tw PlayEnd 4 607296 095944.92 4 play end id=607296, (current ID) 095944.92 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 095944.94 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 095944.94 4 tw DialogicEvent 129,TDX_PLAY,607296,0,0,,, 095944.95 4 event TDX_PLAY, iCode=129 state=6001 095944.97 4 LsModuleTransition : 129, [TDX_PLAY] 095944.97 4 timer clear 095944.98 4 state [Get Acc No] Number Input 095944.98 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 095945.00 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 095945.03 4 tw wav->vox convert end 609078,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 095945.06 4 play start ok, lPlayId=609125 095947.44 4 tw dtmf 0 (4,48,48) 095947.45 4 event 0, iCode=48 state=1300 095947.47 4 LsGetNbrsPlayWelcMsg 0,0 095947.48 4 play PlayStop ok 095947.48 4 state [Get Acc No] Number Input 0 095947.50 4 path {0} not found 095947.52 4 timer set 6 EV_TIMEOUT_ENTERDATA 095947.52 4 tw PlayEnd 4 609125 095947.53 4 play end id=609125, (current ID) 095947.53 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 095947.55 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 095947.56 4 path {EV_PLAY_FINISHED} not found 095947.56 4 awaiting further dtmf input 095947.58 4 tw DialogicEvent 129,TDX_PLAY,609125,0,0,,, 095947.58 4 event TDX_PLAY, iCode=129 state=1301 095947.59 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 095947.61 4 path {TDX_PLAY} not found 095947.64 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 095947.64 4 event FAX, iCode=134 state=1301 095947.66 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 095947.66 4 path {FAX} not found 095947.67 4 event TDX_CST, iCode=134 state=1301 095947.69 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 095947.69 4 path {TDX_CST} not found 095948.02 4 tw dtmf 1 (4,49,49) 095948.03 4 event 1, iCode=49 state=1301 095948.03 4 LsGetNbrsRxDigits 1,1 095948.05 4 state [Get Acc No] Number Input 01 095948.06 4 path {01} not found 095948.06 4 timer set 6 EV_TIMEOUT_ENTERDATA 095948.52 4 tw dtmf 7 (4,55,55) 095948.53 4 event 7, iCode=55 state=1301 095948.55 4 LsGetNbrsRxDigits 7,7 095948.55 4 state [Get Acc No] Number Input 017 095948.56 4 path {017} not found 095948.56 4 timer set 6 EV_TIMEOUT_ENTERDATA 095949.05 4 tw dtmf 3 (4,51,51) 095949.06 4 event 3, iCode=51 state=1301 095949.06 4 LsGetNbrsRxDigits 3,3 095949.08 4 state [Get Acc No] Number Input 0173 095949.09 4 path {0173} not found 095949.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 095949.58 4 tw dtmf 4 (4,52,52) 095949.59 4 event 4, iCode=52 state=1301 095949.59 4 LsGetNbrsRxDigits 4,4 095949.61 4 state [Get Acc No] Number Input 01734 095949.61 4 path {01734} not found 095949.63 4 timer set 6 EV_TIMEOUT_ENTERDATA 095950.09 4 tw dtmf 0 (4,48,48) 095950.11 4 event 0, iCode=48 state=1301 095950.11 4 LsGetNbrsRxDigits 0,0 095950.13 4 state [Get Acc No] Number Input 017340 095950.13 4 path {017340} not found 095950.14 4 timer set 6 EV_TIMEOUT_ENTERDATA 095950.42 4 tw dtmf 0 (4,48,48) 095950.42 4 event 0, iCode=48 state=1301 095950.44 4 LsGetNbrsRxDigits 0,0 095950.45 4 state [Get Acc No] Number Input 0173400 095950.45 4 path {0173400} not found 095950.47 4 timer set 6 EV_TIMEOUT_ENTERDATA 095950.75 4 tw dtmf 0 (4,48,48) 095950.75 4 event 0, iCode=48 state=1301 095950.77 4 LsGetNbrsRxDigits 0,0 095950.77 4 state [Get Acc No] Number Input 01734000 095950.78 4 path {01734000} not found 095950.80 4 timer set 6 EV_TIMEOUT_ENTERDATA 095951.25 4 tw dtmf 2 (4,50,50) 095951.25 4 event 2, iCode=50 state=1301 095951.27 4 LsGetNbrsRxDigits 2,2 095951.28 4 state [Get Acc No] Number Input 017340002 095951.28 4 path {017340002} not found 095951.30 4 timer set 6 EV_TIMEOUT_ENTERDATA 095951.63 4 tw dtmf 4 (4,52,52) 095951.64 4 event 4, iCode=52 state=1301 095951.66 4 LsGetNbrsRxDigits 4,4 095951.66 4 state [Get Acc No] Number Input 0173400024 095951.67 4 path {0173400024} not found 095951.67 4 timer set 6 EV_TIMEOUT_ENTERDATA 095951.95 4 tw dtmf 5 (4,53,53) 095951.97 4 event 5, iCode=53 state=1301 095951.97 4 LsGetNbrsRxDigits 5,5 095951.98 4 state [Get Acc No] Number Input 01734000245 095952.00 4 path {01734000245} not found 095952.00 4 timer set 6 EV_TIMEOUT_ENTERDATA 095958.47 4 timer fired EV_TIMEOUT_ENTERDATA 095958.47 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 095958.48 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 095958.50 4 path {EV_TIMEOUT_ENTERDATA} not found 095958.50 4 timer clear 095958.52 4 rv add [Get Acc No]{01734000245} 095958.52 4 path {01734000245} not found 095958.53 4 next module is [Varify A/C] (idx=6) 095958.55 4 rvns add [Get Acc No_PathTaken]{success} 095958.55 4 fn RunModule start [Database Query,[Varify A/C],6,,] 095958.56 4 timer clear 095958.56 4 state [Varify A/C] DB Query 095958.58 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 095958.63 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 095958.63 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:59:41 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:59:42 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:59:42 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 095958.64 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 095958.66 4 db [Varify A/C] row count=1 095958.66 4 rv add [Varify A/C_RowCount]{1} 095958.67 4 db get RecordsetGetRowsMax 095958.69 4 db get 999 records. (row count=1) 095958.69 4 db update RVs 095958.70 4 db about to close dbDbqDatabase 095958.70 4 db going down path [True] 095958.72 4 next module is [Get PIN No] (idx=45) 095958.73 4 fn RunModule start [Get Numbers,[Get PIN No],45,,] 095958.75 4 timer clear 095958.77 4 state [Get PIN No] Number Input 095958.77 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 095958.78 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 095958.80 4 tw wav->vox convert end 622859,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 095958.81 4 play start ok, lPlayId=622890 100002.14 4 tw PlayEnd 4 622890 100002.16 4 play end id=622890, (current ID) 100002.16 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 100002.17 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 100002.19 4 path {EV_PLAY_FINISHED} not found 100002.19 4 timer set 7 EV_TIMEOUT_REPLAYMSG 100002.20 4 tw DialogicEvent 129,TDX_PLAY,622890,0,0,,, 100002.20 4 event TDX_PLAY, iCode=129 state=1301 100002.22 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 100002.23 4 path {TDX_PLAY} not found 100002.23 4 tw dtmf 3 (4,51,51) 100002.25 4 event 3, iCode=51 state=1301 100002.25 4 LsGetNbrsRxDigits 3,3 100002.27 4 state [Get PIN No] Number Input 3 100002.28 4 path {3} not found 100002.28 4 timer set 6 EV_TIMEOUT_ENTERDATA 100002.92 4 tw dtmf 8 (4,56,56) 100002.94 4 event 8, iCode=56 state=1301 100002.94 4 LsGetNbrsRxDigits 8,8 100002.95 4 state [Get PIN No] Number Input 38 100002.95 4 path {38} not found 100002.97 4 timer set 6 EV_TIMEOUT_ENTERDATA 100003.30 4 tw dtmf 0 (4,48,48) 100003.30 4 event 0, iCode=48 state=1301 100003.31 4 LsGetNbrsRxDigits 0,0 100003.33 4 state [Get PIN No] Number Input 380 100003.33 4 path {380} not found 100003.34 4 timer set 6 EV_TIMEOUT_ENTERDATA 100003.50 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100003.52 4 event FAX, iCode=134 state=1301 100003.52 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100003.53 4 path {FAX} not found 100003.53 4 event TDX_CST, iCode=134 state=1301 100003.55 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100003.56 4 path {TDX_CST} not found 100003.70 4 tw dtmf 4 (4,52,52) 100003.72 4 event 4, iCode=52 state=1301 100003.72 4 LsGetNbrsRxDigits 4,4 100003.73 4 state [Get PIN No] Number Input 3804 100003.73 4 path {3804} not found 100003.75 4 timer set 6 EV_TIMEOUT_ENTERDATA 100003.77 4 timer clear 100003.77 4 rv add [Get PIN No]{3804} 100003.78 4 path {3804} not found 100003.78 4 next module is [Varify A/C No] (idx=21) 100003.80 4 rvns add [Get PIN No_PathTaken]{success} 100003.81 4 fn RunModule start [Database Query,[Varify A/C No],21,,] 100003.83 4 timer clear 100003.83 4 state [Varify A/C No] DB Query 100003.84 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 100003.88 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 100003.89 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 9:59:41 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 9:59:42 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 9:59:42 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 100003.91 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 100003.91 4 db [Varify A/C No] row count=1 100003.92 4 rv add [Varify A/C No_RowCount]{1} 100003.94 4 db get RecordsetGetRowsMax 100003.94 4 db get 999 records. (row count=1) 100003.95 4 db update RVs 100003.95 4 db about to close dbDbqDatabase 100003.97 4 db going down path [True] 100003.98 4 next module is (idx=44) 100003.98 4 fn RunModule start [Play,,44,,] 100004.00 4 timer clear 100004.02 4 Play Module start 100004.02 4 state Playing 100004.03 4 state Playing (Bangla Voice\Acc List.wav) 100004.03 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 100004.08 4 tw wav->vox convert end 628109,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 100004.11 4 play start ok, lPlayId=628171 100010.64 4 tw dtmf 1 (4,49,49) 100010.66 4 event 1, iCode=49 state=1100 100010.66 4 LsPlayMsg 1,1 100010.67 4 next module is [say Bal 1] (idx=5) 100010.69 4 play PlayStop ok 100010.70 4 rv add {1} 100010.70 4 fn RunModule start [Play,[say Bal 1],5,,] 100010.72 4 tw PlayEnd 4 628171 100010.72 4 play end id=628171, (current ID) 100010.73 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100010.75 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100010.75 4 tw DialogicEvent 129,TDX_PLAY,628171,0,0,,, 100010.77 4 event TDX_PLAY, iCode=129 state=6001 100010.78 4 LsModuleTransition : 129, [TDX_PLAY] 100010.80 4 timer clear 100010.80 4 Play Module start 100010.81 4 state [say Bal 1] Playing 100010.81 4 state [say Bal 1] Playing (Bangla Voice\15 digit Credit Card No.wav) 100010.83 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\15 digit Credit Card No.wav 100010.86 4 tw wav->vox convert end 634906,G:\TeleBanking System\Bangla Voice\15 digit Credit Card No.vox,1,0,, 100010.88 4 play start ok, lPlayId=634953 100015.55 4 tw PlayEnd 4 634953 100015.56 4 play end id=634953, (current ID) 100015.56 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 100015.58 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 100015.58 4 path {EV_PLAY_FINISHED} not found 100015.59 4 timer set 5 EV_TIMEOUT_REPLAYMSG 100015.61 4 tw DialogicEvent 129,TDX_PLAY,634953,0,0,,, 100015.61 4 event TDX_PLAY, iCode=129 state=1101 100015.63 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 100015.63 4 path {TDX_PLAY} not found 100019.14 4 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,DISCONNECT_TAPI2, 100019.14 4 event DISCONNECT_TAPI2, iCode=134 state=1101 100019.16 4 LsPlayMsgFinished EV_UNKNOWN_134,DISCONNECT_TAPI2 100019.16 4 path {DISCONNECT_TAPI2} not found 100019.17 4 HangupCall start (Default Handler 20: DISCONNECT_TAPI2) 100019.19 4 rv add [Hangup Time]{01/10/2007 10:00:19 AM} 100019.19 4 state Hanging up call... [Default Handler 20: DISCONNECT_TAPI2] 100019.20 4 HangupCall_Common hCall=4 100019.22 4 rec RecSoundStop ok 100019.22 4 play PlayStop ok 100019.23 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 100019.23 4 fnHangupCall end 100019.25 4 event TDX_CST, iCode=134 state=900 100019.27 4 LsAwaitingCalls EV_UNKNOWN_134 100019.28 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 100019.30 4 event TDX_SETHOOK, iCode=135 state=900 100019.30 4 LsAwaitingCalls EV_UNKNOWN_135 100019.31 4 event callstate IDLE 4 1,0,0 100019.33 4 WorkingMode@Idle= 100019.33 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 100019.34 4 timer clear 100019.34 4 rec RecSoundStop ok 100019.36 4 play PlayStop ok 100019.38 4 rv add [CallEndTime]{01/10/2007 10:00:19 AM} 100019.41 4 on-hangup script:[] 100019.41 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 100019.42 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 100019.44 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 100019.44 4 init atidle reinit : start 100019.45 4 init atidle reinit iConferenceOtherLegLid=-1 100019.45 4 init atidle reinit : reset all LineState variables 100019.47 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100019.48 4 state Waiting for a call... 100021.67 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100021.67 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 100021.69 4 setting iDialoutReadyToDialout = 1 100141.13 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100141.13 MemStructVgs_ClearVgs [3] 100141.22 load end 100141.22 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 100141.23 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100141.23 MemStructVgs_ClearVgs [4] 100141.31 load end 100141.33 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 100141.34 0 Erasing Script (new loaded) Id 2 100141.36 0 VgsScriptFree [2] 100141.38 MemStructVgs_ClearVgs [2] 100141.38 0 Erasing Script (new loaded) Id 3 100141.39 0 VgsScriptFree [3] 100141.41 MemStructVgs_ClearVgs [3] 100149.41 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100149.41 MemStructVgs_ClearVgs [3] 100149.48 load end 100149.50 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 100149.52 0 Erasing Script (new loaded) Id 4 100149.52 0 VgsScriptFree [4] 100149.53 MemStructVgs_ClearVgs [4] 100205.53 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100205.55 MemStructVgs_ClearVgs [4] 100205.63 load end 100205.63 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 100205.64 0 Erasing Script (new loaded) Id 3 100205.66 0 VgsScriptFree [3] 100205.66 MemStructVgs_ClearVgs [3] 100215.66 4 event callstate OFFERING 4 2,0,0 100215.67 4 script interpretor: VgMulti v6.0.3243 100215.67 4 fired OFFERING event to listeners 100215.69 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 100215.69 4 cid CallerID vars set (in 'offering' event) [,,] 100215.70 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 100215.72 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 100215.72 4 tw ring 1 100215.73 4 ring time since last ring event (sec): 0.00 100215.73 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 100215.75 4 should answer as number of rings reached 100215.77 4 rv clear all 100215.77 4 init LineState ResetAtStartOfNewCall. 100215.78 4 answering the call (,,,0) 100215.78 4 timer clear 100215.80 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 100215.81 4 event TDX_CST, iCode=134 state=6001 100215.83 4 LsModuleTransition : 134, [TDX_CST] 100216.44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 100216.44 4 event TDX_SETHOOK, iCode=135 state=6001 100216.45 4 LsModuleTransition : 135, [TDX_SETHOOK] 100216.47 4 event callstate CONNECTED 4 256,0,0 100216.47 4 LineEvCallState_Connected hDevice=4 params=256,0,0 100216.48 4 WorkingModes tapi= script= LineState().iState=6001 100216.48 4 Inband detection not enabled 100216.50 4 StartLoadedVgs at 01/10/2007 10:02:16 AM (VgMulti v6.0.3243) 100216.52 4 set LineState().iVgsIdx=1 100216.52 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 100216.53 4 init StartLoadedVgs_InitLineState start 100216.53 4 rv add [$RV_STARTTIME]{01/10/2007 10:02:16 AM} 100216.55 4 rv add [$RV_DEVICEID]{4} 100216.56 4 rv add [DlgcNetworkResource]{dxxxB1C4} 100216.56 4 rv add [DlgcVoiceResource]{dxxxB1C4} 100216.58 4 rv add [$RV_CIDNAME]{} 100216.58 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 100216.59 4 rvns add [scriptsPath]{G:\TeleBanking System\} 100216.61 4 rv add [$RV_CIDNUMBER]{} 100216.61 4 fn RunModule start [Play,[Get Language],1,,] 100216.63 4 tw DialogicEvent 134,TDX_CST,11714,0,0,DE_LCON,, 100216.64 4 event TDX_CST, iCode=134 state=6001 100216.64 4 LsModuleTransition : 134, [TDX_CST] 100216.66 4 timer clear 100216.66 4 Play Module start 100216.67 4 state [Get Language] Playing 100216.69 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 100216.69 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 100216.75 4 tw wav->vox convert end 760765,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 100216.77 4 play start ok, lPlayId=760843 100217.61 4 tw dtmf 1 (4,49,49) 100217.63 4 event 1, iCode=49 state=1100 100217.63 4 LsPlayMsg 1,1 100217.64 4 rv add [scriptEnd_Time]{01/10/2007 10:02:17 AM} 100217.66 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 100217.66 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 100217.69 4 rv add [scriptStart_Time]{01/10/2007 10:02:17 AM} 100217.70 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 100217.72 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 100217.72 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100217.73 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4 100217.73 4 rvns add [scriptsPath]{G:\TeleBanking System\} 100217.75 4 play PlayStop ok 100217.77 4 rv add [Get Language]{1} 100217.78 4 fn RunModule start [Evaluate,[Get Bangla],108,,] 100217.78 4 tw PlayEnd 4 760843 100217.80 4 play end id=760843, (current ID) 100217.81 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100217.81 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100217.83 4 tw DialogicEvent 129,TDX_PLAY,760843,0,0,,, 100217.83 4 event TDX_PLAY, iCode=129 state=6001 100217.84 4 LsModuleTransition : 129, [TDX_PLAY] 100217.86 4 timer clear 100217.88 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 100217.88 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 100217.89 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 100217.91 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 100217.91 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 100217.92 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 100217.94 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 100217.94 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 100217.95 4 matching path not found 100217.95 4 next module is (idx=107) 100217.97 4 matching path was found 100217.98 4 fn RunModule start [Play,,107,,] 100217.98 4 timer clear 100218.00 4 Play Module start 100218.00 4 state Playing 100218.02 4 state Playing (Bangla Voice\Service List.wav) 100218.03 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 100218.06 4 tw wav->vox convert end 762109,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 100218.09 4 play start ok, lPlayId=762156 100219.36 4 tw dtmf 1 (4,49,49) 100219.38 4 event 1, iCode=49 state=1100 100219.39 4 LsPlayMsg 1,1 100219.39 4 next module is [Get Acc No] (idx=129) 100219.41 4 play PlayStop ok 100219.42 4 rv add {1} 100219.44 4 fn RunModule start [Get Numbers,[Get Acc No],129,,] 100219.44 4 tw PlayEnd 4 762156 100219.45 4 play end id=762156, (current ID) 100219.45 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100219.47 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100219.48 4 tw DialogicEvent 129,TDX_PLAY,762156,0,0,,, 100219.48 4 event TDX_PLAY, iCode=129 state=6001 100219.50 4 LsModuleTransition : 129, [TDX_PLAY] 100219.50 4 timer clear 100219.52 4 state [Get Acc No] Number Input 100219.53 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 100219.53 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 100219.59 4 tw wav->vox convert end 763609,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 100219.61 4 play start ok, lPlayId=763687 100223.44 4 tw PlayEnd 4 763687 100223.44 4 play end id=763687, (current ID) 100223.45 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 100223.45 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 100223.47 4 path {EV_PLAY_FINISHED} not found 100223.48 4 timer set 17 EV_TIMEOUT_REPLAYMSG 100223.48 4 tw DialogicEvent 129,TDX_PLAY,763687,0,0,,, 100223.50 4 event TDX_PLAY, iCode=129 state=1301 100223.52 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 100223.52 4 path {TDX_PLAY} not found 100223.53 4 tw dtmf 0 (4,48,48) 100223.53 4 event 0, iCode=48 state=1301 100223.55 4 LsGetNbrsRxDigits 0,0 100223.56 4 state [Get Acc No] Number Input 0 100223.56 4 path {0} not found 100223.58 4 timer set 6 EV_TIMEOUT_ENTERDATA 100223.70 4 tw dtmf 1 (4,49,49) 100223.72 4 event 1, iCode=49 state=1301 100223.73 4 LsGetNbrsRxDigits 1,1 100223.73 4 state [Get Acc No] Number Input 01 100223.75 4 path {01} not found 100223.75 4 timer set 6 EV_TIMEOUT_ENTERDATA 100224.05 4 tw dtmf 7 (4,55,55) 100224.05 4 event 7, iCode=55 state=1301 100224.06 4 LsGetNbrsRxDigits 7,7 100224.08 4 state [Get Acc No] Number Input 017 100224.08 4 path {017} not found 100224.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 100224.88 4 tw dtmf 3 (4,51,51) 100224.88 4 event 3, iCode=51 state=1301 100224.89 4 LsGetNbrsRxDigits 3,3 100224.91 4 state [Get Acc No] Number Input 0173 100224.91 4 path {0173} not found 100224.92 4 timer set 6 EV_TIMEOUT_ENTERDATA 100225.34 4 tw dtmf 4 (4,52,52) 100225.34 4 event 4, iCode=52 state=1301 100225.36 4 LsGetNbrsRxDigits 4,4 100225.38 4 state [Get Acc No] Number Input 01734 100225.38 4 path {01734} not found 100225.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 100225.56 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100225.56 4 event FAX, iCode=134 state=1301 100225.58 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100225.58 4 path {FAX} not found 100225.59 4 event TDX_CST, iCode=134 state=1301 100225.61 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100225.61 4 path {TDX_CST} not found 100225.75 4 tw dtmf 0 (4,48,48) 100225.75 4 event 0, iCode=48 state=1301 100225.77 4 LsGetNbrsRxDigits 0,0 100225.78 4 state [Get Acc No] Number Input 017340 100225.78 4 path {017340} not found 100225.80 4 timer set 6 EV_TIMEOUT_ENTERDATA 100226.02 4 tw dtmf 0 (4,48,48) 100226.02 4 event 0, iCode=48 state=1301 100226.03 4 LsGetNbrsRxDigits 0,0 100226.05 4 state [Get Acc No] Number Input 0173400 100226.05 4 path {0173400} not found 100226.06 4 timer set 6 EV_TIMEOUT_ENTERDATA 100226.25 4 tw dtmf 0 (4,48,48) 100226.27 4 event 0, iCode=48 state=1301 100226.28 4 LsGetNbrsRxDigits 0,0 100226.28 4 state [Get Acc No] Number Input 01734000 100226.30 4 path {01734000} not found 100226.30 4 timer set 6 EV_TIMEOUT_ENTERDATA 100226.75 4 tw dtmf 2 (4,50,50) 100226.77 4 event 2, iCode=50 state=1301 100226.78 4 LsGetNbrsRxDigits 2,2 100226.78 4 state [Get Acc No] Number Input 017340002 100226.80 4 path {017340002} not found 100226.83 4 timer set 6 EV_TIMEOUT_ENTERDATA 100227.06 4 tw dtmf 4 (4,52,52) 100227.06 4 event 4, iCode=52 state=1301 100227.08 4 LsGetNbrsRxDigits 4,4 100227.08 4 state [Get Acc No] Number Input 0173400024 100227.09 4 path {0173400024} not found 100227.11 4 timer set 6 EV_TIMEOUT_ENTERDATA 100227.38 4 tw dtmf 5 (4,53,53) 100227.38 4 event 5, iCode=53 state=1301 100227.39 4 LsGetNbrsRxDigits 5,5 100227.39 4 state [Get Acc No] Number Input 01734000245 100227.41 4 path {01734000245} not found 100227.42 4 timer set 6 EV_TIMEOUT_ENTERDATA 100233.89 4 timer fired EV_TIMEOUT_ENTERDATA 100233.89 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 100233.91 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 100233.91 4 path {EV_TIMEOUT_ENTERDATA} not found 100233.92 4 timer clear 100233.94 4 rv add [Get Acc No]{01734000245} 100233.94 4 path {01734000245} not found 100233.95 4 next module is [Varify A/C] (idx=89) 100233.97 4 rvns add [Get Acc No_PathTaken]{success} 100233.97 4 fn RunModule start [Database Query,[Varify A/C],89,,] 100233.98 4 timer clear 100233.98 4 state [Varify A/C] DB Query 100234.00 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 100234.05 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 100234.06 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:02:16 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:02:17 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:02:17 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 100234.08 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 100234.08 4 db [Varify A/C] row count=1 100234.09 4 rv add [Varify A/C_RowCount]{1} 100234.11 4 db get RecordsetGetRowsMax 100234.11 4 db get 999 records. (row count=1) 100234.13 4 db update RVs 100234.14 4 db about to close dbDbqDatabase 100234.14 4 db going down path [True] 100234.16 4 next module is [Get PIN No] (idx=128) 100234.16 4 fn RunModule start [Get Numbers,[Get PIN No],128,,] 100234.17 4 timer clear 100234.19 4 state [Get PIN No] Number Input 100234.19 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 100234.20 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 100234.22 4 tw wav->vox convert end 778281,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 100234.25 4 play start ok, lPlayId=778312 100237.56 4 tw PlayEnd 4 778312 100237.58 4 play end id=778312, (current ID) 100237.59 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 100237.59 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 100237.61 4 path {EV_PLAY_FINISHED} not found 100237.63 4 timer set 7 EV_TIMEOUT_REPLAYMSG 100237.63 4 tw DialogicEvent 129,TDX_PLAY,778312,0,0,,, 100237.64 4 event TDX_PLAY, iCode=129 state=1301 100237.64 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 100237.66 4 path {TDX_PLAY} not found 100238.03 4 tw dtmf 3 (4,51,51) 100238.05 4 event 3, iCode=51 state=1301 100238.06 4 LsGetNbrsRxDigits 3,3 100238.06 4 state [Get PIN No] Number Input 3 100238.08 4 path {3} not found 100238.08 4 timer set 6 EV_TIMEOUT_ENTERDATA 100239.17 4 tw dtmf 8 (4,56,56) 100239.19 4 event 8, iCode=56 state=1301 100239.19 4 LsGetNbrsRxDigits 8,8 100239.20 4 state [Get PIN No] Number Input 38 100239.22 4 path {38} not found 100239.22 4 timer set 6 EV_TIMEOUT_ENTERDATA 100239.41 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100239.41 4 event FAX, iCode=134 state=1301 100239.42 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100239.44 4 path {FAX} not found 100239.44 4 event TDX_CST, iCode=134 state=1301 100239.45 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100239.47 4 path {TDX_CST} not found 100239.63 4 tw dtmf 0 (4,48,48) 100239.63 4 event 0, iCode=48 state=1301 100239.64 4 LsGetNbrsRxDigits 0,0 100239.66 4 state [Get PIN No] Number Input 380 100239.66 4 path {380} not found 100239.67 4 timer set 6 EV_TIMEOUT_ENTERDATA 100240.05 4 tw dtmf 4 (4,52,52) 100240.06 4 event 4, iCode=52 state=1301 100240.08 4 LsGetNbrsRxDigits 4,4 100240.08 4 state [Get PIN No] Number Input 3804 100240.09 4 path {3804} not found 100240.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 100240.11 4 timer clear 100240.13 4 rv add [Get PIN No]{3804} 100240.13 4 path {3804} not found 100240.14 4 next module is [Varify A/C No] (idx=104) 100240.14 4 rvns add [Get PIN No_PathTaken]{success} 100240.16 4 fn RunModule start [Database Query,[Varify A/C No],104,,] 100240.17 4 timer clear 100240.17 4 state [Varify A/C No] DB Query 100240.19 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 100240.22 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 100240.23 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:02:16 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:02:17 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:02:17 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 100240.25 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 100240.25 4 db [Varify A/C No] row count=1 100240.27 4 rv add [Varify A/C No_RowCount]{1} 100240.28 4 db get RecordsetGetRowsMax 100240.28 4 db get 999 records. (row count=1) 100240.30 4 db update RVs 100240.30 4 db about to close dbDbqDatabase 100240.31 4 db going down path [True] 100240.33 4 next module is (idx=127) 100240.33 4 fn RunModule start [Play,,127,,] 100240.34 4 timer clear 100240.36 4 Play Module start 100240.36 4 state Playing 100240.38 4 state Playing (Bangla Voice\Acc List.wav) 100240.39 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 100240.42 4 tw wav->vox convert end 784468,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 100240.44 4 play start ok, lPlayId=784500 100244.42 4 tw dtmf 1 (4,49,49) 100244.44 4 event 1, iCode=49 state=1100 100244.44 4 LsPlayMsg 1,1 100244.45 4 next module is [say Bal 1] (idx=88) 100244.47 4 play PlayStop ok 100244.48 4 rv add {1} 100244.48 4 fn RunModule start [say Numbers,[say Bal 1],88,,] 100244.50 4 tw PlayEnd 4 784500 100244.50 4 play end id=784500, (current ID) 100244.52 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100244.53 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100244.53 4 tw DialogicEvent 129,TDX_PLAY,784500,0,0,,, 100244.55 4 event TDX_PLAY, iCode=129 state=6001 100244.56 4 LsModuleTransition : 129, [TDX_PLAY] 100244.56 4 timer clear 100244.58 4 state [say Bal 1] Say numbers: as 100244.58 4 fn PlaySoundStartNumbers [bangla Voice\16 digit Credit Card No.wav],[],[], 100244.59 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 100244.61 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 100244.61 4 rv add [Hangup Time]{01/10/2007 10:02:44 AM} 100244.63 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 100244.63 4 HangupCall_Common hCall=4 100244.64 4 rec RecSoundStop ok 100244.66 4 play PlayStop ok 100244.66 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 100244.67 4 fnHangupCall end 100244.72 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 100244.72 4 event TDX_SETHOOK, iCode=135 state=900 100244.73 4 LsAwaitingCalls EV_UNKNOWN_135 100244.75 4 event callstate IDLE 4 1,0,0 100244.75 4 WorkingMode@Idle= 100244.77 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 100244.77 4 timer clear 100244.78 4 rec RecSoundStop ok 100244.80 4 play PlayStop ok 100244.81 4 rv add [CallEndTime]{01/10/2007 10:02:44 AM} 100244.86 4 on-hangup script:[] 100244.86 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 100244.88 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 100244.88 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 100244.89 4 init atidle reinit : start 100244.91 4 init atidle reinit iConferenceOtherLegLid=-1 100244.91 4 init atidle reinit : reset all LineState variables 100244.92 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100244.92 4 state Waiting for a call... 100247.13 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100247.13 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 100247.14 4 setting iDialoutReadyToDialout = 1 100319.95 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100319.95 MemStructVgs_ClearVgs [3] 100320.05 load end 100320.05 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 100320.06 0 Erasing Script (new loaded) Id 4 100320.08 0 VgsScriptFree [4] 100320.08 MemStructVgs_ClearVgs [4] 100351.09 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100351.11 MemStructVgs_ClearVgs [4] 100351.19 load end 100351.19 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 100351.20 0 Erasing Script (new loaded) Id 3 100351.22 0 VgsScriptFree [3] 100351.22 MemStructVgs_ClearVgs [3] 100404.23 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100404.23 MemStructVgs_ClearVgs [3] 100404.33 load end 100404.33 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 100404.34 0 Erasing Script (new loaded) Id 4 100404.36 0 VgsScriptFree [4] 100404.36 MemStructVgs_ClearVgs [4] 100414.17 4 event callstate OFFERING 4 2,0,0 100414.17 4 script interpretor: VgMulti v6.0.3243 100414.19 4 fired OFFERING event to listeners 100414.19 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 100414.20 4 cid CallerID vars set (in 'offering' event) [,,] 100414.22 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 100414.22 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 100414.23 4 tw ring 1 100414.23 4 ring time since last ring event (sec): 0.00 100414.25 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 100414.27 4 should answer as number of rings reached 100414.27 4 rv clear all 100414.28 4 init LineState ResetAtStartOfNewCall. 100414.30 4 answering the call (,,,0) 100414.30 4 timer clear 100414.31 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 100414.33 4 event TDX_CST, iCode=134 state=6001 100414.33 4 LsModuleTransition : 134, [TDX_CST] 100414.94 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 100414.95 4 event TDX_SETHOOK, iCode=135 state=6001 100414.97 4 LsModuleTransition : 135, [TDX_SETHOOK] 100414.97 4 event callstate CONNECTED 4 256,0,0 100414.98 4 LineEvCallState_Connected hDevice=4 params=256,0,0 100414.98 4 WorkingModes tapi= script= LineState().iState=6001 100415.00 4 Inband detection not enabled 100415.02 4 StartLoadedVgs at 01/10/2007 10:04:15 AM (VgMulti v6.0.3243) 100415.02 4 set LineState().iVgsIdx=1 100415.03 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 100415.05 4 init StartLoadedVgs_InitLineState start 100415.05 4 rv add [$RV_STARTTIME]{01/10/2007 10:04:15 AM} 100415.06 4 rv add [$RV_DEVICEID]{4} 100415.06 4 rv add [DlgcNetworkResource]{dxxxB1C4} 100415.08 4 rv add [DlgcVoiceResource]{dxxxB1C4} 100415.09 4 rv add [$RV_CIDNAME]{} 100415.09 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 100415.11 4 rvns add [scriptsPath]{G:\TeleBanking System\} 100415.13 4 rv add [$RV_CIDNUMBER]{} 100415.13 4 fn RunModule start [Play,[Get Language],1,,] 100415.14 4 tw DialogicEvent 134,TDX_CST,9022,0,0,DE_LCON,, 100415.14 4 event TDX_CST, iCode=134 state=6001 100415.16 4 LsModuleTransition : 134, [TDX_CST] 100415.17 4 timer clear 100415.19 4 Play Module start 100415.19 4 state [Get Language] Playing 100415.20 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 100415.22 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 100415.22 4 tw wav->vox convert end 879296,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 100415.25 4 play start ok, lPlayId=879312 100415.92 4 tw dtmf 1 (4,49,49) 100415.94 4 event 1, iCode=49 state=1100 100415.94 4 LsPlayMsg 1,1 100415.95 4 rv add [scriptEnd_Time]{01/10/2007 10:04:15 AM} 100415.95 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 100415.97 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 100416.00 4 rv add [scriptStart_Time]{01/10/2007 10:04:15 AM} 100416.02 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 100416.02 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 100416.03 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100416.03 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3 100416.05 4 rvns add [scriptsPath]{G:\TeleBanking System\} 100416.06 4 play PlayStop ok 100416.08 4 rv add [Get Language]{1} 100416.08 4 fn RunModule start [Evaluate,[Get Bangla],66,,] 100416.09 4 tw PlayEnd 4 879312 100416.11 4 play end id=879312, (current ID) 100416.11 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100416.13 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100416.13 4 tw DialogicEvent 129,TDX_PLAY,879312,0,0,,, 100416.14 4 event TDX_PLAY, iCode=129 state=6001 100416.16 4 LsModuleTransition : 129, [TDX_PLAY] 100416.16 4 timer clear 100416.17 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 100416.19 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 100416.19 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 100416.20 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 100416.20 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 100416.22 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 100416.23 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 100416.23 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 100416.25 4 matching path not found 100416.25 4 next module is (idx=67) 100416.27 4 matching path was found 100416.28 4 fn RunModule start [Play,,67,,] 100416.30 4 timer clear 100416.31 4 Play Module start 100416.31 4 state Playing 100416.33 4 state Playing (Bangla Voice\Service List.wav) 100416.33 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 100416.39 4 tw wav->vox convert end 880406,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 100416.41 4 play start ok, lPlayId=880484 100417.13 4 tw dtmf 1 (4,49,49) 100417.13 4 event 1, iCode=49 state=1100 100417.14 4 LsPlayMsg 1,1 100417.16 4 next module is [Get Acc No] (idx=4) 100417.17 4 play PlayStop ok 100417.17 4 rv add {1} 100417.19 4 fn RunModule start [Get Numbers,[Get Acc No],4,,] 100417.20 4 tw PlayEnd 4 880484 100417.20 4 play end id=880484, (current ID) 100417.22 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100417.23 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100417.23 4 tw DialogicEvent 129,TDX_PLAY,880484,0,0,,, 100417.25 4 event TDX_PLAY, iCode=129 state=6001 100417.25 4 LsModuleTransition : 129, [TDX_PLAY] 100417.27 4 timer clear 100417.28 4 state [Get Acc No] Number Input 100417.28 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 100417.30 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 100417.31 4 tw wav->vox convert end 881375,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 100417.33 4 play start ok, lPlayId=881390 100421.14 4 tw PlayEnd 4 881390 100421.16 4 play end id=881390, (current ID) 100421.16 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 100421.17 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 100421.17 4 path {EV_PLAY_FINISHED} not found 100421.19 4 timer set 17 EV_TIMEOUT_REPLAYMSG 100421.20 4 tw DialogicEvent 129,TDX_PLAY,881390,0,0,,, 100421.20 4 event TDX_PLAY, iCode=129 state=1301 100421.22 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 100421.23 4 path {TDX_PLAY} not found 100421.91 4 tw dtmf 0 (4,48,48) 100421.92 4 event 0, iCode=48 state=1301 100421.92 4 LsGetNbrsRxDigits 0,0 100421.94 4 state [Get Acc No] Number Input 0 100421.95 4 path {0} not found 100421.95 4 timer set 6 EV_TIMEOUT_ENTERDATA 100422.13 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100422.14 4 event FAX, iCode=134 state=1301 100422.14 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100422.16 4 path {FAX} not found 100422.16 4 event TDX_CST, iCode=134 state=1301 100422.17 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100422.19 4 path {TDX_CST} not found 100422.36 4 tw dtmf 1 (4,49,49) 100422.36 4 event 1, iCode=49 state=1301 100422.38 4 LsGetNbrsRxDigits 1,1 100422.38 4 state [Get Acc No] Number Input 01 100422.39 4 path {01} not found 100422.41 4 timer set 6 EV_TIMEOUT_ENTERDATA 100422.72 4 tw dtmf 7 (4,55,55) 100422.73 4 event 7, iCode=55 state=1301 100422.75 4 LsGetNbrsRxDigits 7,7 100422.75 4 state [Get Acc No] Number Input 017 100422.77 4 path {017} not found 100422.77 4 timer set 6 EV_TIMEOUT_ENTERDATA 100423.19 4 tw dtmf 3 (4,51,51) 100423.20 4 event 3, iCode=51 state=1301 100423.22 4 LsGetNbrsRxDigits 3,3 100423.22 4 state [Get Acc No] Number Input 0173 100423.23 4 path {0173} not found 100423.23 4 timer set 6 EV_TIMEOUT_ENTERDATA 100423.42 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100423.44 4 event FAX, iCode=134 state=1301 100423.44 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100423.45 4 path {FAX} not found 100423.45 4 event TDX_CST, iCode=134 state=1301 100423.47 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100423.48 4 path {TDX_CST} not found 100423.59 4 tw dtmf 4 (4,52,52) 100423.61 4 event 4, iCode=52 state=1301 100423.63 4 LsGetNbrsRxDigits 4,4 100423.63 4 state [Get Acc No] Number Input 01734 100423.64 4 path {01734} not found 100423.66 4 timer set 6 EV_TIMEOUT_ENTERDATA 100423.81 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100423.83 4 event FAX, iCode=134 state=1301 100423.84 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100423.84 4 path {FAX} not found 100423.86 4 event TDX_CST, iCode=134 state=1301 100423.86 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100423.88 4 path {TDX_CST} not found 100424.02 4 tw dtmf 0 (4,48,48) 100424.02 4 event 0, iCode=48 state=1301 100424.03 4 LsGetNbrsRxDigits 0,0 100424.03 4 state [Get Acc No] Number Input 017340 100424.05 4 path {017340} not found 100424.06 4 timer set 6 EV_TIMEOUT_ENTERDATA 100424.34 4 tw dtmf 0 (4,48,48) 100424.36 4 event 0, iCode=48 state=1301 100424.36 4 LsGetNbrsRxDigits 0,0 100424.38 4 state [Get Acc No] Number Input 0173400 100424.39 4 path {0173400} not found 100424.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 100424.59 4 tw dtmf 0 (4,48,48) 100424.61 4 event 0, iCode=48 state=1301 100424.61 4 LsGetNbrsRxDigits 0,0 100424.63 4 state [Get Acc No] Number Input 01734000 100424.64 4 path {01734000} not found 100424.64 4 timer set 6 EV_TIMEOUT_ENTERDATA 100425.11 4 tw dtmf 2 (4,50,50) 100425.13 4 event 2, iCode=50 state=1301 100425.13 4 LsGetNbrsRxDigits 2,2 100425.14 4 state [Get Acc No] Number Input 017340002 100425.16 4 path {017340002} not found 100425.16 4 timer set 6 EV_TIMEOUT_ENTERDATA 100425.47 4 tw dtmf 4 (4,52,52) 100425.47 4 event 4, iCode=52 state=1301 100425.48 4 LsGetNbrsRxDigits 4,4 100425.48 4 state [Get Acc No] Number Input 0173400024 100425.50 4 path {0173400024} not found 100425.52 4 timer set 6 EV_TIMEOUT_ENTERDATA 100425.75 4 tw dtmf 5 (4,53,53) 100425.77 4 event 5, iCode=53 state=1301 100425.77 4 LsGetNbrsRxDigits 5,5 100425.78 4 state [Get Acc No] Number Input 01734000245 100425.78 4 path {01734000245} not found 100425.80 4 timer set 6 EV_TIMEOUT_ENTERDATA 100432.31 4 timer fired EV_TIMEOUT_ENTERDATA 100432.31 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 100432.33 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 100432.33 4 path {EV_TIMEOUT_ENTERDATA} not found 100432.34 4 timer clear 100432.36 4 rv add [Get Acc No]{01734000245} 100432.36 4 path {01734000245} not found 100432.38 4 next module is [Varify A/C] (idx=85) 100432.39 4 rvns add [Get Acc No_PathTaken]{success} 100432.39 4 fn RunModule start [Database Query,[Varify A/C],85,,] 100432.41 4 timer clear 100432.42 4 state [Varify A/C] DB Query 100432.44 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 100432.47 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 100432.48 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:04:15 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:04:15 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:04:15 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 100432.48 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 100432.50 4 db [Varify A/C] row count=1 100432.52 4 rv add [Varify A/C_RowCount]{1} 100432.52 4 db get RecordsetGetRowsMax 100432.53 4 db get 999 records. (row count=1) 100432.55 4 db update RVs 100432.55 4 db about to close dbDbqDatabase 100432.56 4 db going down path [True] 100432.56 4 next module is [Get PIN No] (idx=46) 100432.58 4 fn RunModule start [Get Numbers,[Get PIN No],46,,] 100432.59 4 timer clear 100432.59 4 state [Get PIN No] Number Input 100432.61 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 100432.63 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 100432.64 4 tw wav->vox convert end 896703,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 100432.66 4 play start ok, lPlayId=896734 100435.98 4 tw PlayEnd 4 896734 100436.00 4 play end id=896734, (current ID) 100436.00 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 100436.02 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 100436.03 4 path {EV_PLAY_FINISHED} not found 100436.03 4 timer set 7 EV_TIMEOUT_REPLAYMSG 100436.05 4 tw DialogicEvent 129,TDX_PLAY,896734,0,0,,, 100436.05 4 event TDX_PLAY, iCode=129 state=1301 100436.06 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 100436.08 4 path {TDX_PLAY} not found 100436.08 4 tw dtmf 3 (4,51,51) 100436.09 4 event 3, iCode=51 state=1301 100436.09 4 LsGetNbrsRxDigits 3,3 100436.11 4 state [Get PIN No] Number Input 3 100436.13 4 path {3} not found 100436.13 4 timer set 6 EV_TIMEOUT_ENTERDATA 100437.50 4 tw dtmf 8 (4,56,56) 100437.50 4 event 8, iCode=56 state=1301 100437.52 4 LsGetNbrsRxDigits 8,8 100437.53 4 state [Get PIN No] Number Input 38 100437.53 4 path {38} not found 100437.55 4 timer set 6 EV_TIMEOUT_ENTERDATA 100437.86 4 tw dtmf 0 (4,48,48) 100437.86 4 event 0, iCode=48 state=1301 100437.88 4 LsGetNbrsRxDigits 0,0 100437.89 4 state [Get PIN No] Number Input 380 100437.89 4 path {380} not found 100437.91 4 timer set 6 EV_TIMEOUT_ENTERDATA 100438.34 4 tw dtmf 4 (4,52,52) 100438.34 4 event 4, iCode=52 state=1301 100438.36 4 LsGetNbrsRxDigits 4,4 100438.36 4 state [Get PIN No] Number Input 3804 100438.38 4 path {3804} not found 100438.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 100438.39 4 timer clear 100438.41 4 rv add [Get PIN No]{3804} 100438.41 4 path {3804} not found 100438.42 4 next module is [Varify A/C No] (idx=70) 100438.44 4 rvns add [Get PIN No_PathTaken]{success} 100438.44 4 fn RunModule start [Database Query,[Varify A/C No],70,,] 100438.47 4 timer clear 100438.47 4 state [Varify A/C No] DB Query 100438.48 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 100438.52 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 100438.53 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:04:15 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:04:15 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:04:15 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 100438.53 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 100438.55 4 db [Varify A/C No] row count=1 100438.56 4 rv add [Varify A/C No_RowCount]{1} 100438.56 4 db get RecordsetGetRowsMax 100438.58 4 db get 999 records. (row count=1) 100438.59 4 db update RVs 100438.59 4 db about to close dbDbqDatabase 100438.61 4 db going down path [True] 100438.63 4 next module is (idx=47) 100438.63 4 fn RunModule start [Play,,47,,] 100438.64 4 timer clear 100438.66 4 Play Module start 100438.66 4 state Playing 100438.67 4 state Playing (Bangla Voice\Acc List.wav) 100438.67 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 100438.73 4 tw wav->vox convert end 902750,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 100438.75 4 play start ok, lPlayId=902828 100441.03 4 tw dtmf 1 (4,49,49) 100441.05 4 event 1, iCode=49 state=1100 100441.06 4 LsPlayMsg 1,1 100441.06 4 next module is [say Bal 1] (idx=86) 100441.08 4 play PlayStop ok 100441.09 4 rv add {1} 100441.11 4 fn RunModule start [say Numbers,[say Bal 1],86,,] 100441.11 4 tw PlayEnd 4 902828 100441.13 4 play end id=902828, (current ID) 100441.14 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100441.14 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100441.16 4 tw DialogicEvent 129,TDX_PLAY,902828,0,0,,, 100441.16 4 event TDX_PLAY, iCode=129 state=6001 100441.17 4 LsModuleTransition : 129, [TDX_PLAY] 100441.19 4 timer clear 100441.19 4 state [say Bal 1] Say numbers: 200 as Number 100441.20 4 fn PlaySoundStartNumbers [C:\Program Files\VoiceGuide\system\Bangla Voice\16 digit Credit Card No.wav],[],[200],Number 100441.20 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 100441.22 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 100441.23 4 rv add [Hangup Time]{01/10/2007 10:04:41 AM} 100441.23 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 100441.25 4 HangupCall_Common hCall=4 100441.27 4 rec RecSoundStop ok 100441.27 4 play PlayStop ok 100441.28 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 100441.28 4 fnHangupCall end 100441.33 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 100441.34 4 event TDX_SETHOOK, iCode=135 state=900 100441.36 4 LsAwaitingCalls EV_UNKNOWN_135 100441.36 4 event callstate IDLE 4 1,0,0 100441.38 4 WorkingMode@Idle= 100441.38 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 100441.39 4 timer clear 100441.41 4 rec RecSoundStop ok 100441.41 4 play PlayStop ok 100441.42 4 rv add [CallEndTime]{01/10/2007 10:04:41 AM} 100441.45 4 on-hangup script:[] 100441.47 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 100441.47 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 100441.48 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 100441.48 4 init atidle reinit : start 100441.50 4 init atidle reinit iConferenceOtherLegLid=-1 100441.52 4 init atidle reinit : reset all LineState variables 100441.52 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100441.53 4 state Waiting for a call... 100443.73 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100443.73 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 100443.75 4 setting iDialoutReadyToDialout = 1 100549.69 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100549.69 MemStructVgs_ClearVgs [4] 100549.78 load end 100549.80 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 100549.80 0 Erasing Script (new loaded) Id 3 100549.81 0 VgsScriptFree [3] 100549.83 MemStructVgs_ClearVgs [3] 100553.83 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100553.84 MemStructVgs_ClearVgs [3] 100553.91 load end 100553.92 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 100553.94 0 Erasing Script (new loaded) Id 4 100553.94 0 VgsScriptFree [4] 100553.95 MemStructVgs_ClearVgs [4] 100605.97 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100605.98 MemStructVgs_ClearVgs [4] 100606.06 load end 100606.08 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 100606.08 0 Erasing Script (new loaded) Id 3 100606.09 0 VgsScriptFree [3] 100606.11 MemStructVgs_ClearVgs [3] 100615.02 4 event callstate OFFERING 4 2,0,0 100615.02 4 script interpretor: VgMulti v6.0.3243 100615.03 4 fired OFFERING event to listeners 100615.03 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 100615.05 4 cid CallerID vars set (in 'offering' event) [,,] 100615.06 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 100615.06 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 100615.08 4 tw ring 1 100615.09 4 ring time since last ring event (sec): 0.00 100615.09 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 100615.11 4 should answer as number of rings reached 100615.11 4 rv clear all 100615.13 4 init LineState ResetAtStartOfNewCall. 100615.14 4 answering the call (,,,0) 100615.14 4 timer clear 100615.16 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 100615.17 4 event TDX_CST, iCode=134 state=6001 100615.17 4 LsModuleTransition : 134, [TDX_CST] 100615.80 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 100615.80 4 event TDX_SETHOOK, iCode=135 state=6001 100615.81 4 LsModuleTransition : 135, [TDX_SETHOOK] 100615.81 4 event callstate CONNECTED 4 256,0,0 100615.83 4 LineEvCallState_Connected hDevice=4 params=256,0,0 100615.84 4 WorkingModes tapi= script= LineState().iState=6001 100615.84 4 Inband detection not enabled 100615.86 4 StartLoadedVgs at 01/10/2007 10:06:15 AM (VgMulti v6.0.3243) 100615.88 4 set LineState().iVgsIdx=1 100615.88 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 100615.89 4 init StartLoadedVgs_InitLineState start 100615.91 4 rv add [$RV_STARTTIME]{01/10/2007 10:06:15 AM} 100615.91 4 rv add [$RV_DEVICEID]{4} 100615.92 4 rv add [DlgcNetworkResource]{dxxxB1C4} 100615.92 4 rv add [DlgcVoiceResource]{dxxxB1C4} 100615.94 4 rv add [$RV_CIDNAME]{} 100615.95 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 100615.95 4 rvns add [scriptsPath]{G:\TeleBanking System\} 100615.97 4 rv add [$RV_CIDNUMBER]{} 100615.98 4 fn RunModule start [Play,[Get Language],1,,] 100615.98 4 tw DialogicEvent 134,TDX_CST,9446,0,0,DE_LCON,, 100616.00 4 event TDX_CST, iCode=134 state=6001 100616.00 4 LsModuleTransition : 134, [TDX_CST] 100616.02 4 timer clear 100616.03 4 Play Module start 100616.03 4 state [Get Language] Playing 100616.05 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 100616.06 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 100616.08 4 tw wav->vox convert end 140,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 100616.11 4 play start ok, lPlayId=171 100617.70 4 tw dtmf 1 (4,49,49) 100617.72 4 event 1, iCode=49 state=1100 100617.73 4 LsPlayMsg 1,1 100617.73 4 rv add [scriptEnd_Time]{01/10/2007 10:06:17 AM} 100617.75 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 100617.77 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 100617.80 4 rv add [scriptStart_Time]{01/10/2007 10:06:17 AM} 100617.80 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 100617.81 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 100617.83 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100617.83 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4 100617.84 4 rvns add [scriptsPath]{G:\TeleBanking System\} 100617.86 4 play PlayStop ok 100617.88 4 rv add [Get Language]{1} 100617.89 4 fn RunModule start [Evaluate,[Get Bangla],109,,] 100617.89 4 tw PlayEnd 4 171 100617.91 4 play end id=171, (current ID) 100617.92 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100617.92 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100617.94 4 tw DialogicEvent 129,TDX_PLAY,171,0,0,,, 100617.94 4 event TDX_PLAY, iCode=129 state=6001 100617.95 4 LsModuleTransition : 129, [TDX_PLAY] 100617.97 4 timer clear 100617.97 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 100617.98 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 100618.00 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 100618.00 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 100618.02 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 100618.02 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 100618.03 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 100618.05 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 100618.05 4 matching path not found 100618.06 4 next module is (idx=110) 100618.08 4 matching path was found 100618.08 4 fn RunModule start [Play,,110,,] 100618.09 4 timer clear 100618.09 4 Play Module start 100618.11 4 state Playing 100618.13 4 state Playing (Bangla Voice\Service List.wav) 100618.13 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 100618.17 4 tw wav->vox convert end 2203,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 100618.19 4 play start ok, lPlayId=2265 100619.20 4 tw dtmf 1 (4,49,49) 100619.22 4 event 1, iCode=49 state=1100 100619.23 4 LsPlayMsg 1,1 100619.23 4 next module is [Get Acc No] (idx=88) 100619.25 4 play PlayStop ok 100619.27 4 rv add {1} 100619.28 4 fn RunModule start [Get Numbers,[Get Acc No],88,,] 100619.28 4 tw PlayEnd 4 2265 100619.30 4 play end id=2265, (current ID) 100619.31 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100619.31 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100619.33 4 tw DialogicEvent 129,TDX_PLAY,2265,0,0,,, 100619.33 4 event TDX_PLAY, iCode=129 state=6001 100619.34 4 LsModuleTransition : 129, [TDX_PLAY] 100619.36 4 timer clear 100619.38 4 state [Get Acc No] Number Input 100619.39 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 100619.39 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 100619.44 4 tw wav->vox convert end 3468,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 100619.47 4 play start ok, lPlayId=3531 100622.17 4 tw dtmf 0 (4,48,48) 100622.19 4 event 0, iCode=48 state=1300 100622.19 4 LsGetNbrsPlayWelcMsg 0,0 100622.20 4 play PlayStop ok 100622.22 4 state [Get Acc No] Number Input 0 100622.23 4 path {0} not found 100622.23 4 timer set 6 EV_TIMEOUT_ENTERDATA 100622.25 4 tw PlayEnd 4 3531 100622.27 4 play end id=3531, (current ID) 100622.27 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 100622.28 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 100622.28 4 path {EV_PLAY_FINISHED} not found 100622.30 4 awaiting further dtmf input 100622.31 4 tw DialogicEvent 129,TDX_PLAY,3531,0,0,,, 100622.31 4 event TDX_PLAY, iCode=129 state=1301 100622.33 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 100622.34 4 path {TDX_PLAY} not found 100622.52 4 tw dtmf 1 (4,49,49) 100622.52 4 event 1, iCode=49 state=1301 100622.53 4 LsGetNbrsRxDigits 1,1 100622.53 4 state [Get Acc No] Number Input 01 100622.55 4 path {01} not found 100622.56 4 timer set 6 EV_TIMEOUT_ENTERDATA 100622.95 4 tw dtmf 7 (4,55,55) 100622.97 4 event 7, iCode=55 state=1301 100622.97 4 LsGetNbrsRxDigits 7,7 100622.98 4 state [Get Acc No] Number Input 017 100623.00 4 path {017} not found 100623.00 4 timer set 6 EV_TIMEOUT_ENTERDATA 100623.44 4 tw dtmf 3 (4,51,51) 100623.44 4 event 3, iCode=51 state=1301 100623.45 4 LsGetNbrsRxDigits 3,3 100623.47 4 state [Get Acc No] Number Input 0173 100623.47 4 path {0173} not found 100623.48 4 timer set 6 EV_TIMEOUT_ENTERDATA 100623.88 4 tw dtmf 4 (4,52,52) 100623.89 4 event 4, iCode=52 state=1301 100623.89 4 LsGetNbrsRxDigits 4,4 100623.91 4 state [Get Acc No] Number Input 01734 100623.92 4 path {01734} not found 100623.92 4 timer set 6 EV_TIMEOUT_ENTERDATA 100624.34 4 tw dtmf 0 (4,48,48) 100624.36 4 event 0, iCode=48 state=1301 100624.36 4 LsGetNbrsRxDigits 0,0 100624.38 4 state [Get Acc No] Number Input 017340 100624.39 4 path {017340} not found 100624.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 100624.67 4 tw dtmf 0 (4,48,48) 100624.69 4 event 0, iCode=48 state=1301 100624.69 4 LsGetNbrsRxDigits 0,0 100624.70 4 state [Get Acc No] Number Input 0173400 100624.70 4 path {0173400} not found 100624.72 4 timer set 6 EV_TIMEOUT_ENTERDATA 100624.98 4 tw dtmf 0 (4,48,48) 100624.98 4 event 0, iCode=48 state=1301 100625.00 4 LsGetNbrsRxDigits 0,0 100625.02 4 state [Get Acc No] Number Input 01734000 100625.02 4 path {01734000} not found 100625.03 4 timer set 6 EV_TIMEOUT_ENTERDATA 100625.50 4 tw dtmf 2 (4,50,50) 100625.50 4 event 2, iCode=50 state=1301 100625.52 4 LsGetNbrsRxDigits 2,2 100625.53 4 state [Get Acc No] Number Input 017340002 100625.53 4 path {017340002} not found 100625.55 4 timer set 6 EV_TIMEOUT_ENTERDATA 100625.72 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100625.73 4 event FAX, iCode=134 state=1301 100625.75 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100625.75 4 path {FAX} not found 100625.77 4 event TDX_CST, iCode=134 state=1301 100625.78 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100625.78 4 path {TDX_CST} not found 100625.98 4 tw dtmf 4 (4,52,52) 100626.02 4 event 4, iCode=52 state=1301 100626.02 4 LsGetNbrsRxDigits 4,4 100626.03 4 state [Get Acc No] Number Input 0173400024 100626.03 4 path {0173400024} not found 100626.05 4 timer set 6 EV_TIMEOUT_ENTERDATA 100626.59 4 tw dtmf 5 (4,53,53) 100626.59 4 event 5, iCode=53 state=1301 100626.61 4 LsGetNbrsRxDigits 5,5 100626.63 4 state [Get Acc No] Number Input 01734000245 100626.63 4 path {01734000245} not found 100626.64 4 timer set 6 EV_TIMEOUT_ENTERDATA 100633.11 4 timer fired EV_TIMEOUT_ENTERDATA 100633.11 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 100633.13 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 100633.13 4 path {EV_TIMEOUT_ENTERDATA} not found 100633.14 4 timer clear 100633.16 4 rv add [Get Acc No]{01734000245} 100633.16 4 path {01734000245} not found 100633.17 4 next module is [Varify A/C] (idx=128) 100633.19 4 rvns add [Get Acc No_PathTaken]{success} 100633.19 4 fn RunModule start [Database Query,[Varify A/C],128,,] 100633.20 4 timer clear 100633.20 4 state [Varify A/C] DB Query 100633.22 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 100633.27 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 100633.27 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:06:15 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:06:17 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:06:17 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 100633.28 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 100633.30 4 db [Varify A/C] row count=1 100633.30 4 rv add [Varify A/C_RowCount]{1} 100633.31 4 db get RecordsetGetRowsMax 100633.33 4 db get 999 records. (row count=1) 100633.33 4 db update RVs 100633.34 4 db about to close dbDbqDatabase 100633.36 4 db going down path [True] 100633.36 4 next module is [Get PIN No] (idx=89) 100633.38 4 fn RunModule start [Get Numbers,[Get PIN No],89,,] 100633.39 4 timer clear 100633.39 4 state [Get PIN No] Number Input 100633.41 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 100633.42 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 100633.45 4 tw wav->vox convert end 17500,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 100633.48 4 play start ok, lPlayId=17546 100636.02 4 tw dtmf 3 (4,51,51) 100636.03 4 event 3, iCode=51 state=1300 100636.05 4 LsGetNbrsPlayWelcMsg 3,3 100636.06 4 play PlayStop ok 100636.06 4 state [Get PIN No] Number Input 3 100636.08 4 path {3} not found 100636.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 100636.09 4 tw PlayEnd 4 17546 100636.11 4 play end id=17546, (current ID) 100636.11 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 100636.13 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 100636.14 4 path {EV_PLAY_FINISHED} not found 100636.14 4 awaiting further dtmf input 100636.16 4 tw DialogicEvent 129,TDX_PLAY,17546,0,0,,, 100636.17 4 event TDX_PLAY, iCode=129 state=1301 100636.17 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 100636.19 4 path {TDX_PLAY} not found 100636.58 4 tw dtmf 8 (4,56,56) 100636.59 4 event 8, iCode=56 state=1301 100636.61 4 LsGetNbrsRxDigits 8,8 100636.61 4 state [Get PIN No] Number Input 38 100636.63 4 path {38} not found 100636.64 4 timer set 6 EV_TIMEOUT_ENTERDATA 100637.20 4 tw dtmf 0 (4,48,48) 100637.20 4 event 0, iCode=48 state=1301 100637.22 4 LsGetNbrsRxDigits 0,0 100637.23 4 state [Get PIN No] Number Input 380 100637.23 4 path {380} not found 100637.25 4 timer set 6 EV_TIMEOUT_ENTERDATA 100637.66 4 tw dtmf 4 (4,52,52) 100637.66 4 event 4, iCode=52 state=1301 100637.67 4 LsGetNbrsRxDigits 4,4 100637.69 4 state [Get PIN No] Number Input 3804 100637.69 4 path {3804} not found 100637.70 4 timer set 6 EV_TIMEOUT_ENTERDATA 100637.72 4 timer clear 100637.72 4 rv add [Get PIN No]{3804} 100637.73 4 path {3804} not found 100637.73 4 next module is [Varify A/C No] (idx=113) 100637.75 4 rvns add [Get PIN No_PathTaken]{success} 100637.77 4 fn RunModule start [Database Query,[Varify A/C No],113,,] 100637.77 4 timer clear 100637.78 4 state [Varify A/C No] DB Query 100637.80 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 100637.83 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 100637.83 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:06:15 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:06:17 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:06:17 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 100637.84 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 100637.86 4 db [Varify A/C No] row count=1 100637.88 4 rv add [Varify A/C No_RowCount]{1} 100637.88 4 db get RecordsetGetRowsMax 100637.89 4 db get 999 records. (row count=1) 100637.91 4 db update RVs 100637.91 4 db about to close dbDbqDatabase 100637.92 4 db going down path [True] 100637.94 4 next module is (idx=90) 100637.94 4 fn RunModule start [Play,,90,,] 100637.95 4 timer clear 100637.95 4 Play Module start 100637.97 4 state Playing 100637.98 4 state Playing (Bangla Voice\Acc List.wav) 100637.98 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 100638.03 4 tw wav->vox convert end 22062,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 100638.05 4 play start ok, lPlayId=22109 100644.00 4 tw dtmf 1 (4,49,49) 100644.02 4 event 1, iCode=49 state=1100 100644.02 4 LsPlayMsg 1,1 100644.03 4 next module is [say Bal 1] (idx=129) 100644.05 4 play PlayStop ok 100644.06 4 rv add {1} 100644.06 4 fn RunModule start [Play,[say Bal 1],129,,] 100644.08 4 tw PlayEnd 4 22109 100644.09 4 play end id=22109, (current ID) 100644.09 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100644.11 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100644.13 4 tw DialogicEvent 129,TDX_PLAY,22109,0,0,,, 100644.13 4 event TDX_PLAY, iCode=129 state=6001 100644.14 4 LsModuleTransition : 129, [TDX_PLAY] 100644.14 4 timer clear 100644.16 4 Play Module start 100644.17 4 state [say Bal 1] Playing 100644.17 4 state [say Bal 1] Playing (C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav) 100644.19 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav 100644.22 4 tw wav->vox convert end 28265,C:\Program Files\VoiceGuide\system\Bangla Voice\7.vox,1,0,, 100644.25 4 play start ok, lPlayId=28312 100644.81 4 tw PlayEnd 4 28312 100644.81 4 play end id=28312, (current ID) 100644.83 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 100644.83 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 100644.84 4 path {EV_PLAY_FINISHED} not found 100644.86 4 timer set 5 EV_TIMEOUT_REPLAYMSG 100644.86 4 tw DialogicEvent 129,TDX_PLAY,28312,0,0,,, 100644.88 4 event TDX_PLAY, iCode=129 state=1101 100644.89 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 100644.89 4 path {TDX_PLAY} not found 100648.39 0 btn Hangup on line 1 100648.41 1 event EV_TIMEOUT_HANGUP, iCode=9001 state=0 100650.27 4 timer fired EV_TIMEOUT_REPLAYMSG 100650.27 4 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101 100650.28 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG 100650.28 4 path {EV_TIMEOUT_REPLAYMSG} not found 100650.30 4 state [say Bal 1] Playing (C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav) 100650.31 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav 100650.31 4 tw wav->vox convert end 34390,C:\Program Files\VoiceGuide\system\Bangla Voice\7.vox,1,0,, 100650.34 4 play start ok, lPlayId=34406 100650.91 4 tw PlayEnd 4 34406 100650.91 4 play end id=34406, (current ID) 100650.92 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 100650.94 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 100650.94 4 path {EV_PLAY_FINISHED} not found 100650.95 4 timer set 5 EV_TIMEOUT_REPLAYMSG 100650.95 4 tw DialogicEvent 129,TDX_PLAY,34406,0,0,,, 100650.97 4 event TDX_PLAY, iCode=129 state=1101 100650.98 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 100650.98 4 path {TDX_PLAY} not found 100654.61 0 btn Hangup on line 1 100654.63 1 event EV_TIMEOUT_HANGUP, iCode=9001 state=0 100656.36 4 timer fired EV_TIMEOUT_REPLAYMSG 100656.36 4 event EV_TIMEOUT_REPLAYMSG, iCode=9005 state=1101 100656.38 4 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG 100656.38 4 path {EV_TIMEOUT_REPLAYMSG} not found 100656.39 4 state [say Bal 1] Playing (C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav) 100656.41 4 tw ConvertWav2Vox C:\Program Files\VoiceGuide\system\Bangla Voice\7.wav 100656.41 4 tw wav->vox convert end 40484,C:\Program Files\VoiceGuide\system\Bangla Voice\7.vox,1,0,, 100656.44 4 play start ok, lPlayId=40500 100656.45 4 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,DISCONNECT_TAPI2, 100656.45 4 event DISCONNECT_TAPI2, iCode=134 state=1100 100656.47 4 LsPlayMsg EV_UNKNOWN_134,DISCONNECT_TAPI2 100656.48 4 path {DISCONNECT_TAPI2} not found 100656.48 4 HangupCall start (Default Handler 20: DISCONNECT_TAPI2) 100656.50 4 rv add [Hangup Time]{01/10/2007 10:06:56 AM} 100656.50 4 state Hanging up call... [Default Handler 20: DISCONNECT_TAPI2] 100656.52 4 HangupCall_Common hCall=4 100656.55 4 rec RecSoundStop ok 100656.55 4 play PlayStop ok 100656.56 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 100656.58 4 fnHangupCall end 100656.58 4 event TDX_CST, iCode=134 state=900 100656.59 4 LsAwaitingCalls EV_UNKNOWN_134 100656.61 4 tw PlayEnd 4 40500 100656.61 4 play end id=40500, (current ID) 100656.63 4 event EV_PLAY_FINISHED, iCode=8001 state=900 100656.63 4 LsAwaitingCalls EV_PLAY_FINISHED 100656.64 4 tw DialogicEvent 129,TDX_PLAY,40500,0,0,,, 100656.66 4 event TDX_PLAY, iCode=129 state=900 100656.66 4 LsAwaitingCalls EV_UNKNOWN_129 100656.67 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 100656.69 4 event TDX_SETHOOK, iCode=135 state=900 100656.69 4 LsAwaitingCalls EV_UNKNOWN_135 100656.70 4 event callstate IDLE 4 1,0,0 100656.70 4 WorkingMode@Idle= 100656.72 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 100656.73 4 timer clear 100656.73 4 rec RecSoundStop ok 100656.75 4 play PlayStop ok 100656.77 4 rv add [CallEndTime]{01/10/2007 10:06:56 AM} 100656.80 4 on-hangup script:[] 100656.81 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 100656.81 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 100656.83 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 100656.83 4 init atidle reinit : start 100656.84 4 init atidle reinit iConferenceOtherLegLid=-1 100656.86 4 init atidle reinit : reset all LineState variables 100656.86 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100656.88 4 state Waiting for a call... 100659.64 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100659.64 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 100659.66 4 setting iDialoutReadyToDialout = 1 100741.77 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100741.78 MemStructVgs_ClearVgs [3] 100741.86 load end 100741.86 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 100741.88 0 Erasing Script (new loaded) Id 4 100741.89 0 VgsScriptFree [4] 100741.89 MemStructVgs_ClearVgs [4] 100749.91 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100749.91 MemStructVgs_ClearVgs [4] 100749.98 load end 100750.00 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 100750.00 0 Erasing Script (new loaded) Id 3 100750.02 0 VgsScriptFree [3] 100750.03 MemStructVgs_ClearVgs [3] 100808.03 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100808.05 MemStructVgs_ClearVgs [3] 100808.11 load end 100808.13 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 100808.14 0 Erasing Script (new loaded) Id 4 100808.14 0 VgsScriptFree [4] 100808.16 MemStructVgs_ClearVgs [4] 100819.17 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100819.19 MemStructVgs_ClearVgs [4] 100819.27 load end 100819.27 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 100819.28 0 Erasing Script (new loaded) Id 3 100819.30 0 VgsScriptFree [3] 100819.30 MemStructVgs_ClearVgs [3] 100828.31 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100828.31 MemStructVgs_ClearVgs [3] 100828.39 load end 100828.41 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 100828.41 0 Erasing Script (new loaded) Id 4 100828.42 0 VgsScriptFree [4] 100828.42 MemStructVgs_ClearVgs [4] 100837.08 4 event callstate OFFERING 4 2,0,0 100837.08 4 script interpretor: VgMulti v6.0.3243 100837.09 4 fired OFFERING event to listeners 100837.11 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 100837.11 4 cid CallerID vars set (in 'offering' event) [,,] 100837.13 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 100837.13 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 100837.14 4 tw ring 1 100837.16 4 ring time since last ring event (sec): 0.00 100837.16 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 100837.17 4 should answer as number of rings reached 100837.19 4 rv clear all 100837.19 4 init LineState ResetAtStartOfNewCall. 100837.20 4 answering the call (,,,0) 100837.22 4 timer clear 100837.22 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 100837.23 4 event TDX_CST, iCode=134 state=6001 100837.25 4 LsModuleTransition : 134, [TDX_CST] 100837.86 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 100837.86 4 event TDX_SETHOOK, iCode=135 state=6001 100837.88 4 LsModuleTransition : 135, [TDX_SETHOOK] 100837.89 4 event callstate CONNECTED 4 256,0,0 100837.89 4 LineEvCallState_Connected hDevice=4 params=256,0,0 100837.91 4 WorkingModes tapi= script= LineState().iState=6001 100837.92 4 Inband detection not enabled 100837.94 4 StartLoadedVgs at 01/10/2007 10:08:37 AM (VgMulti v6.0.3243) 100837.94 4 set LineState().iVgsIdx=1 100837.95 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 100837.97 4 init StartLoadedVgs_InitLineState start 100837.97 4 rv add [$RV_STARTTIME]{01/10/2007 10:08:37 AM} 100837.98 4 rv add [$RV_DEVICEID]{4} 100837.98 4 rv add [DlgcNetworkResource]{dxxxB1C4} 100838.00 4 rv add [DlgcVoiceResource]{dxxxB1C4} 100838.02 4 rv add [$RV_CIDNAME]{} 100838.02 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 100838.03 4 rvns add [scriptsPath]{G:\TeleBanking System\} 100838.05 4 rv add [$RV_CIDNUMBER]{} 100838.05 4 fn RunModule start [Play,[Get Language],1,,] 100838.06 4 tw DialogicEvent 134,TDX_CST,10123,0,0,DE_LCON,, 100838.08 4 event TDX_CST, iCode=134 state=6001 100838.08 4 LsModuleTransition : 134, [TDX_CST] 100838.09 4 timer clear 100838.11 4 Play Module start 100838.13 4 state [Get Language] Playing 100838.13 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 100838.14 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 100838.19 4 tw wav->vox convert end 142218,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 100838.20 4 play start ok, lPlayId=142281 100838.86 4 tw dtmf 1 (4,49,49) 100838.86 4 event 1, iCode=49 state=1100 100838.88 4 LsPlayMsg 1,1 100838.89 4 rv add [scriptEnd_Time]{01/10/2007 10:08:38 AM} 100838.89 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 100838.91 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 100838.94 4 rv add [scriptStart_Time]{01/10/2007 10:08:38 AM} 100838.95 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 100838.95 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 100838.97 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100838.98 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3 100838.98 4 rvns add [scriptsPath]{G:\TeleBanking System\} 100839.02 4 play PlayStop ok 100839.02 4 rv add [Get Language]{1} 100839.03 4 fn RunModule start [Evaluate,[Get Bangla],65,,] 100839.05 4 tw PlayEnd 4 142281 100839.05 4 play end id=142281, (current ID) 100839.06 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100839.08 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100839.08 4 tw DialogicEvent 129,TDX_PLAY,142281,0,0,,, 100839.09 4 event TDX_PLAY, iCode=129 state=6001 100839.09 4 LsModuleTransition : 129, [TDX_PLAY] 100839.13 4 timer clear 100839.13 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 100839.14 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 100839.16 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 100839.16 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 100839.17 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 100839.19 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 100839.19 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 100839.20 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 100839.22 4 matching path not found 100839.22 4 next module is (idx=66) 100839.23 4 matching path was found 100839.25 4 fn RunModule start [Play,,66,,] 100839.25 4 timer clear 100839.27 4 Play Module start 100839.28 4 state Playing 100839.28 4 state Playing (Bangla Voice\Service List.wav) 100839.30 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 100839.31 4 tw wav->vox convert end 143375,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 100839.33 4 play start ok, lPlayId=143406 100840.05 4 tw dtmf 1 (4,49,49) 100840.06 4 event 1, iCode=49 state=1100 100840.08 4 LsPlayMsg 1,1 100840.08 4 next module is [Get Acc No] (idx=86) 100840.11 4 play PlayStop ok 100840.11 4 rv add {1} 100840.13 4 fn RunModule start [Get Numbers,[Get Acc No],86,,] 100840.14 4 tw PlayEnd 4 143406 100840.14 4 play end id=143406, (current ID) 100840.16 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 100840.16 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 100840.17 4 tw DialogicEvent 129,TDX_PLAY,143406,0,0,,, 100840.19 4 event TDX_PLAY, iCode=129 state=6001 100840.19 4 LsModuleTransition : 129, [TDX_PLAY] 100840.22 4 timer clear 100840.22 4 state [Get Acc No] Number Input 100840.23 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 100840.25 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 100840.28 4 tw wav->vox convert end 144328,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 100840.30 4 play start ok, lPlayId=144375 100842.25 4 tw dtmf 0 (4,48,48) 100842.27 4 event 0, iCode=48 state=1300 100842.27 4 LsGetNbrsPlayWelcMsg 0,0 100842.30 4 play PlayStop ok 100842.31 4 state [Get Acc No] Number Input 0 100842.31 4 path {0} not found 100842.33 4 timer set 6 EV_TIMEOUT_ENTERDATA 100842.34 4 tw PlayEnd 4 144375 100842.34 4 play end id=144375, (current ID) 100842.36 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 100842.38 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 100842.38 4 path {EV_PLAY_FINISHED} not found 100842.39 4 awaiting further dtmf input 100842.41 4 tw DialogicEvent 129,TDX_PLAY,144375,0,0,,, 100842.41 4 event TDX_PLAY, iCode=129 state=1301 100842.42 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 100842.44 4 path {TDX_PLAY} not found 100842.44 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100842.45 4 event FAX, iCode=134 state=1301 100842.47 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100842.47 4 path {FAX} not found 100842.48 4 event TDX_CST, iCode=134 state=1301 100842.50 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100842.50 4 path {TDX_CST} not found 100842.63 4 tw dtmf 1 (4,49,49) 100842.64 4 event 1, iCode=49 state=1301 100842.64 4 LsGetNbrsRxDigits 1,1 100842.66 4 state [Get Acc No] Number Input 01 100842.66 4 path {01} not found 100842.67 4 timer set 6 EV_TIMEOUT_ENTERDATA 100843.00 4 tw dtmf 7 (4,55,55) 100843.02 4 event 7, iCode=55 state=1301 100843.03 4 LsGetNbrsRxDigits 7,7 100843.03 4 state [Get Acc No] Number Input 017 100843.05 4 path {017} not found 100843.06 4 timer set 6 EV_TIMEOUT_ENTERDATA 100843.53 4 tw dtmf 3 (4,51,51) 100843.55 4 event 3, iCode=51 state=1301 100843.56 4 LsGetNbrsRxDigits 3,3 100843.56 4 state [Get Acc No] Number Input 0173 100843.58 4 path {0173} not found 100843.58 4 timer set 6 EV_TIMEOUT_ENTERDATA 100844.03 4 tw dtmf 4 (4,52,52) 100844.05 4 event 4, iCode=52 state=1301 100844.06 4 LsGetNbrsRxDigits 4,4 100844.06 4 state [Get Acc No] Number Input 01734 100844.08 4 path {01734} not found 100844.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 100844.52 4 tw dtmf 0 (4,48,48) 100844.53 4 event 0, iCode=48 state=1301 100844.53 4 LsGetNbrsRxDigits 0,0 100844.55 4 state [Get Acc No] Number Input 017340 100844.56 4 path {017340} not found 100844.58 4 timer set 6 EV_TIMEOUT_ENTERDATA 100844.81 4 tw dtmf 0 (4,48,48) 100844.81 4 event 0, iCode=48 state=1301 100844.83 4 LsGetNbrsRxDigits 0,0 100844.84 4 state [Get Acc No] Number Input 0173400 100844.84 4 path {0173400} not found 100844.86 4 timer set 6 EV_TIMEOUT_ENTERDATA 100845.02 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100845.03 4 event FAX, iCode=134 state=1301 100845.05 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100845.05 4 path {FAX} not found 100845.06 4 event TDX_CST, iCode=134 state=1301 100845.08 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100845.08 4 path {TDX_CST} not found 100845.23 4 tw dtmf 0 (4,48,48) 100845.25 4 event 0, iCode=48 state=1301 100845.27 4 LsGetNbrsRxDigits 0,0 100845.27 4 state [Get Acc No] Number Input 01734000 100845.28 4 path {01734000} not found 100845.30 4 timer set 6 EV_TIMEOUT_ENTERDATA 100845.73 4 tw dtmf 2 (4,50,50) 100845.73 4 event 2, iCode=50 state=1301 100845.75 4 LsGetNbrsRxDigits 2,2 100845.77 4 state [Get Acc No] Number Input 017340002 100845.77 4 path {017340002} not found 100845.78 4 timer set 6 EV_TIMEOUT_ENTERDATA 100846.11 4 tw dtmf 4 (4,52,52) 100846.11 4 event 4, iCode=52 state=1301 100846.13 4 LsGetNbrsRxDigits 4,4 100846.14 4 state [Get Acc No] Number Input 0173400024 100846.14 4 path {0173400024} not found 100846.16 4 timer set 6 EV_TIMEOUT_ENTERDATA 100846.45 4 tw dtmf 5 (4,53,53) 100846.47 4 event 5, iCode=53 state=1301 100846.47 4 LsGetNbrsRxDigits 5,5 100846.48 4 state [Get Acc No] Number Input 01734000245 100846.48 4 path {01734000245} not found 100846.50 4 timer set 6 EV_TIMEOUT_ENTERDATA 100852.97 4 timer fired EV_TIMEOUT_ENTERDATA 100852.97 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 100852.98 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 100853.00 4 path {EV_TIMEOUT_ENTERDATA} not found 100853.00 4 timer clear 100853.02 4 rv add [Get Acc No]{01734000245} 100853.03 4 path {01734000245} not found 100853.03 4 next module is [Varify A/C] (idx=84) 100853.05 4 rvns add [Get Acc No_PathTaken]{success} 100853.06 4 fn RunModule start [Database Query,[Varify A/C],84,,] 100853.06 4 timer clear 100853.08 4 state [Varify A/C] DB Query 100853.09 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 100853.13 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 100853.14 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:08:37 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:08:38 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:08:38 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 100853.14 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 100853.16 4 db [Varify A/C] row count=1 100853.17 4 rv add [Varify A/C_RowCount]{1} 100853.19 4 db get RecordsetGetRowsMax 100853.19 4 db get 999 records. (row count=1) 100853.20 4 db update RVs 100853.22 4 db about to close dbDbqDatabase 100853.22 4 db going down path [True] 100853.23 4 next module is [Get PIN No] (idx=4) 100853.25 4 fn RunModule start [Get Numbers,[Get PIN No],4,,] 100853.27 4 timer clear 100853.28 4 state [Get PIN No] Number Input 100853.28 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 100853.30 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 100853.33 4 tw wav->vox convert end 157375,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 100853.34 4 play start ok, lPlayId=157421 100855.69 4 tw dtmf 3 (4,51,51) 100855.70 4 event 3, iCode=51 state=1300 100855.72 4 LsGetNbrsPlayWelcMsg 3,3 100855.73 4 play PlayStop ok 100855.75 4 state [Get PIN No] Number Input 3 100855.77 4 path {3} not found 100855.77 4 timer set 6 EV_TIMEOUT_ENTERDATA 100855.78 4 tw PlayEnd 4 157421 100855.80 4 play end id=157421, (current ID) 100855.80 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 100855.81 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 100855.83 4 path {EV_PLAY_FINISHED} not found 100855.83 4 awaiting further dtmf input 100855.84 4 tw DialogicEvent 129,TDX_PLAY,157421,0,0,,, 100855.84 4 event TDX_PLAY, iCode=129 state=1301 100855.86 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 100855.88 4 path {TDX_PLAY} not found 100856.11 4 tw dtmf 8 (4,56,56) 100856.13 4 event 8, iCode=56 state=1301 100856.13 4 LsGetNbrsRxDigits 8,8 100856.14 4 state [Get PIN No] Number Input 38 100856.16 4 path {38} not found 100856.16 4 timer set 6 EV_TIMEOUT_ENTERDATA 100856.50 4 tw dtmf 0 (4,48,48) 100856.50 4 event 0, iCode=48 state=1301 100856.52 4 LsGetNbrsRxDigits 0,0 100856.53 4 state [Get PIN No] Number Input 380 100856.53 4 path {380} not found 100856.55 4 timer set 6 EV_TIMEOUT_ENTERDATA 100856.72 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 100856.72 4 event FAX, iCode=134 state=1301 100856.73 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 100856.73 4 path {FAX} not found 100856.75 4 event TDX_CST, iCode=134 state=1301 100856.77 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 100856.77 4 path {TDX_CST} not found 100856.91 4 tw dtmf 4 (4,52,52) 100856.92 4 event 4, iCode=52 state=1301 100856.94 4 LsGetNbrsRxDigits 4,4 100856.94 4 state [Get PIN No] Number Input 3804 100856.95 4 path {3804} not found 100856.97 4 timer set 6 EV_TIMEOUT_ENTERDATA 100856.97 4 timer clear 100856.98 4 rv add [Get PIN No]{3804} 100857.00 4 path {3804} not found 100857.00 4 next module is [Varify A/C No] (idx=69) 100857.02 4 rvns add [Get PIN No_PathTaken]{success} 100857.03 4 fn RunModule start [Database Query,[Varify A/C No],69,,] 100857.03 4 timer clear 100857.05 4 state [Varify A/C No] DB Query 100857.06 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 100857.09 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 100857.11 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:08:37 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:08:38 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:08:38 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 100857.11 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 100857.13 4 db [Varify A/C No] row count=1 100857.14 4 rv add [Varify A/C No_RowCount]{1} 100857.16 4 db get RecordsetGetRowsMax 100857.16 4 db get 999 records. (row count=1) 100857.17 4 db update RVs 100857.19 4 db about to close dbDbqDatabase 100857.20 4 db going down path [True] 100857.20 4 next module is (idx=46) 100857.22 4 fn RunModule start [Play,,46,,] 100857.22 4 timer clear 100857.23 4 Play Module start 100857.25 4 state Playing 100857.25 4 state Playing (Bangla Voice\Acc List.wav) 100857.27 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 100857.30 4 tw wav->vox convert end 161343,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 100857.31 4 play start ok, lPlayId=161375 100909.94 4 tw PlayEnd 4 161375 100909.94 4 play end id=161375, (current ID) 100909.95 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 100909.97 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 100909.97 4 path {EV_PLAY_FINISHED} not found 100909.98 4 timer set 7 EV_TIMEOUT_REPLAYMSG 100910.00 4 tw DialogicEvent 129,TDX_PLAY,161375,0,0,,, 100910.00 4 event TDX_PLAY, iCode=129 state=1101 100910.02 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 100910.03 4 path {TDX_PLAY} not found 100910.56 4 tw dtmf 1 (4,49,49) 100910.56 4 event 1, iCode=49 state=1101 100910.58 4 LsPlayMsgFinished 1,1 100910.59 4 next module is [say Bal 1] (idx=85) 100910.59 4 rv add {1} 100910.61 4 fn RunModule start [say Numbers,[say Bal 1],85,,] 100910.63 4 timer clear 100910.63 4 state [say Bal 1] Say numbers: 7 as Number 100910.64 4 fn PlaySoundStartNumbers [],[],[7],Number 100910.66 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 100910.66 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 100910.67 4 rv add [Hangup Time]{01/10/2007 10:09:10 AM} 100910.69 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 100910.69 4 HangupCall_Common hCall=4 100910.70 4 rec RecSoundStop ok 100910.72 4 play PlayStop ok 100910.72 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 100910.73 4 fnHangupCall end 100910.78 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 100910.80 4 event TDX_SETHOOK, iCode=135 state=900 100910.80 4 LsAwaitingCalls EV_UNKNOWN_135 100910.81 4 event callstate IDLE 4 1,0,0 100910.83 4 WorkingMode@Idle= 100910.83 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 100910.84 4 timer clear 100910.86 4 rec RecSoundStop ok 100910.86 4 play PlayStop ok 100910.88 4 rv add [CallEndTime]{01/10/2007 10:09:10 AM} 100910.91 4 on-hangup script:[] 100910.92 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 100910.94 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 100910.94 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 100910.95 4 init atidle reinit : start 100910.95 4 init atidle reinit iConferenceOtherLegLid=-1 100910.97 4 init atidle reinit : reset all LineState variables 100910.98 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100910.98 4 state Waiting for a call... 100913.19 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 100913.19 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 100913.20 4 setting iDialoutReadyToDialout = 1 100921.58 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 100921.59 MemStructVgs_ClearVgs [4] 100921.59 load end 100921.61 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Main.vgs 100921.63 0 Erasing Script (new loaded) Id 1 100921.64 0 VgsScriptFree [1] 100921.66 MemStructVgs_ClearVgs [1] 100934.66 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 100934.67 MemStructVgs_ClearVgs [1] 100934.73 load end 100934.75 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs 100934.77 0 Erasing Script (new loaded) Id 3 100934.77 0 VgsScriptFree [3] 100934.78 MemStructVgs_ClearVgs [3] 101304.22 0 sys cleanup Start 101304.22 0 sys cleanup End 101356.81 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 101356.81 MemStructVgs_ClearVgs [3] 101356.91 load end 101356.91 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 101356.92 0 Erasing Script (new loaded) Id 1 101356.94 0 VgsScriptFree [1] 101356.94 MemStructVgs_ClearVgs [1] 101404.97 4 event callstate OFFERING 4 2,0,0 101404.98 4 script interpretor: VgMulti v6.0.3243 101405.00 4 fired OFFERING event to listeners 101405.00 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 101405.02 4 cid CallerID vars set (in 'offering' event) [,,] 101405.03 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 101405.03 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 101405.05 4 tw ring 1 101405.06 4 ring time since last ring event (sec): 0.00 101405.06 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 101405.08 4 should answer as number of rings reached 101405.08 4 rv clear all 101405.09 4 init LineState ResetAtStartOfNewCall. 101405.11 4 answering the call (,,,0) 101405.11 4 timer clear 101405.13 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 101405.14 4 event TDX_CST, iCode=134 state=6001 101405.16 4 LsModuleTransition : 134, [TDX_CST] 101405.75 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 101405.77 4 event TDX_SETHOOK, iCode=135 state=6001 101405.78 4 LsModuleTransition : 135, [TDX_SETHOOK] 101405.78 4 event callstate CONNECTED 4 256,0,0 101405.80 4 LineEvCallState_Connected hDevice=4 params=256,0,0 101405.81 4 WorkingModes tapi= script= LineState().iState=6001 101405.81 4 Inband detection not enabled 101405.83 4 StartLoadedVgs at 01/10/2007 10:14:05 AM (VgMulti v6.0.3243) 101405.84 4 set LineState().iVgsIdx=4 101405.84 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 101405.86 4 init StartLoadedVgs_InitLineState start 101405.88 4 rv add [$RV_STARTTIME]{01/10/2007 10:14:05 AM} 101405.88 4 rv add [$RV_DEVICEID]{4} 101405.89 4 rv add [DlgcNetworkResource]{dxxxB1C4} 101405.89 4 rv add [DlgcVoiceResource]{dxxxB1C4} 101405.91 4 rv add [$RV_CIDNAME]{} 101405.92 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 101405.92 4 rvns add [scriptsPath]{G:\TeleBanking System\} 101405.94 4 rv add [$RV_CIDNUMBER]{} 101405.95 4 fn RunModule start [Play,[Get Language],129,,] 101405.95 4 tw DialogicEvent 134,TDX_CST,29497,0,0,DE_LCON,, 101405.97 4 event TDX_CST, iCode=134 state=6001 101405.98 4 LsModuleTransition : 134, [TDX_CST] 101405.98 4 timer clear 101406.00 4 Play Module start 101406.00 4 state [Get Language] Playing 101406.02 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 101406.03 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 101406.08 4 tw wav->vox convert end 470109,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 101406.11 4 play start ok, lPlayId=470171 101408.00 4 tw dtmf 1 (4,49,49) 101408.00 4 event 1, iCode=49 state=1100 101408.02 4 LsPlayMsg 1,1 101408.03 4 rv add [scriptEnd_Time]{01/10/2007 10:14:08 AM} 101408.03 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 101408.05 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 101408.08 4 rv add [scriptStart_Time]{01/10/2007 10:14:08 AM} 101408.08 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 101408.09 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 101408.11 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 101408.11 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=3 101408.13 4 rvns add [scriptsPath]{G:\TeleBanking System\} 101408.16 4 play PlayStop ok 101408.16 4 rv add [Get Language]{1} 101408.17 4 fn RunModule start [Evaluate,[Get Bangla],64,,] 101408.17 4 tw PlayEnd 4 470171 101408.19 4 play end id=470171, (current ID) 101408.20 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 101408.20 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 101408.22 4 tw DialogicEvent 129,TDX_PLAY,470171,0,0,,, 101408.23 4 event TDX_PLAY, iCode=129 state=6001 101408.23 4 LsModuleTransition : 129, [TDX_PLAY] 101408.25 4 timer clear 101408.27 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 101408.27 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 101408.28 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 101408.30 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 101408.30 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 101408.31 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 101408.31 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 101408.33 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 101408.34 4 matching path not found 101408.34 4 next module is (idx=63) 101408.36 4 matching path was found 101408.38 4 fn RunModule start [Play,,63,,] 101408.38 4 timer clear 101408.39 4 Play Module start 101408.41 4 state Playing 101408.41 4 state Playing (Bangla Voice\Service List.wav) 101408.42 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 101408.47 4 tw wav->vox convert end 472500,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 101408.48 4 play start ok, lPlayId=472546 101411.28 4 tw dtmf 1 (4,49,49) 101411.30 4 event 1, iCode=49 state=1100 101411.30 4 LsPlayMsg 1,1 101411.31 4 next module is [Get Acc No] (idx=85) 101411.33 4 play PlayStop ok 101411.34 4 rv add {1} 101411.34 4 fn RunModule start [Get Numbers,[Get Acc No],85,,] 101411.36 4 tw PlayEnd 4 472546 101411.38 4 play end id=472546, (current ID) 101411.38 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 101411.39 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 101411.41 4 tw DialogicEvent 129,TDX_PLAY,472546,0,0,,, 101411.41 4 event TDX_PLAY, iCode=129 state=6001 101411.42 4 LsModuleTransition : 129, [TDX_PLAY] 101411.44 4 timer clear 101411.44 4 state [Get Acc No] Number Input 101411.45 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 101411.45 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 101411.52 4 tw wav->vox convert end 475531,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 101411.53 4 play start ok, lPlayId=475609 101415.34 4 tw dtmf 0 (4,48,48) 101415.34 4 event 0, iCode=48 state=1300 101415.36 4 LsGetNbrsPlayWelcMsg 0,0 101415.38 4 play PlayStop ok 101415.38 4 state [Get Acc No] Number Input 0 101415.39 4 path {0} not found 101415.41 4 timer set 6 EV_TIMEOUT_ENTERDATA 101415.41 4 tw PlayEnd 4 475609 101415.42 4 play end id=475609, (current ID) 101415.42 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 101415.44 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 101415.45 4 path {EV_PLAY_FINISHED} not found 101415.45 4 awaiting further dtmf input 101415.47 4 tw DialogicEvent 129,TDX_PLAY,475609,0,0,,, 101415.48 4 event TDX_PLAY, iCode=129 state=1301 101415.48 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 101415.50 4 path {TDX_PLAY} not found 101415.75 4 tw dtmf 1 (4,49,49) 101415.75 4 event 1, iCode=49 state=1301 101415.77 4 LsGetNbrsRxDigits 1,1 101415.78 4 state [Get Acc No] Number Input 01 101415.78 4 path {01} not found 101415.80 4 timer set 6 EV_TIMEOUT_ENTERDATA 101416.17 4 tw dtmf 7 (4,55,55) 101416.19 4 event 7, iCode=55 state=1301 101416.20 4 LsGetNbrsRxDigits 7,7 101416.20 4 state [Get Acc No] Number Input 017 101416.22 4 path {017} not found 101416.22 4 timer set 6 EV_TIMEOUT_ENTERDATA 101416.75 4 tw dtmf 3 (4,51,51) 101416.77 4 event 3, iCode=51 state=1301 101416.77 4 LsGetNbrsRxDigits 3,3 101416.78 4 state [Get Acc No] Number Input 0173 101416.80 4 path {0173} not found 101416.80 4 timer set 6 EV_TIMEOUT_ENTERDATA 101417.27 4 tw dtmf 4 (4,52,52) 101417.28 4 event 4, iCode=52 state=1301 101417.28 4 LsGetNbrsRxDigits 4,4 101417.30 4 state [Get Acc No] Number Input 01734 101417.31 4 path {01734} not found 101417.31 4 timer set 6 EV_TIMEOUT_ENTERDATA 101417.77 4 tw dtmf 0 (4,48,48) 101417.77 4 event 0, iCode=48 state=1301 101417.78 4 LsGetNbrsRxDigits 0,0 101417.80 4 state [Get Acc No] Number Input 017340 101417.80 4 path {017340} not found 101417.81 4 timer set 6 EV_TIMEOUT_ENTERDATA 101418.14 4 tw dtmf 0 (4,48,48) 101418.16 4 event 0, iCode=48 state=1301 101418.17 4 LsGetNbrsRxDigits 0,0 101418.17 4 state [Get Acc No] Number Input 0173400 101418.19 4 path {0173400} not found 101418.19 4 timer set 6 EV_TIMEOUT_ENTERDATA 101418.45 4 tw dtmf 0 (4,48,48) 101418.47 4 event 0, iCode=48 state=1301 101418.47 4 LsGetNbrsRxDigits 0,0 101418.48 4 state [Get Acc No] Number Input 01734000 101418.50 4 path {01734000} not found 101418.50 4 timer set 6 EV_TIMEOUT_ENTERDATA 101418.97 4 tw dtmf 2 (4,50,50) 101418.98 4 event 2, iCode=50 state=1301 101419.00 4 LsGetNbrsRxDigits 2,2 101419.02 4 state [Get Acc No] Number Input 017340002 101419.02 4 path {017340002} not found 101419.03 4 timer set 6 EV_TIMEOUT_ENTERDATA 101419.41 4 tw dtmf 4 (4,52,52) 101419.42 4 event 4, iCode=52 state=1301 101419.42 4 LsGetNbrsRxDigits 4,4 101419.44 4 state [Get Acc No] Number Input 0173400024 101419.45 4 path {0173400024} not found 101419.45 4 timer set 6 EV_TIMEOUT_ENTERDATA 101419.69 4 tw dtmf 5 (4,53,53) 101419.70 4 event 5, iCode=53 state=1301 101419.72 4 LsGetNbrsRxDigits 5,5 101419.72 4 state [Get Acc No] Number Input 01734000245 101419.73 4 path {01734000245} not found 101419.75 4 timer set 6 EV_TIMEOUT_ENTERDATA 101426.20 4 timer fired EV_TIMEOUT_ENTERDATA 101426.20 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 101426.22 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 101426.23 4 path {EV_TIMEOUT_ENTERDATA} not found 101426.23 4 timer clear 101426.25 4 rv add [Get Acc No]{01734000245} 101426.25 4 path {01734000245} not found 101426.27 4 next module is [Varify A/C] (idx=4) 101426.28 4 rvns add [Get Acc No_PathTaken]{success} 101426.28 4 fn RunModule start [Database Query,[Varify A/C],4,,] 101426.30 4 timer clear 101426.31 4 state [Varify A/C] DB Query 101426.31 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 101426.36 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 101426.38 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:14:05 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:14:08 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:14:08 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 101426.38 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 101426.39 4 db [Varify A/C] row count=1 101426.41 4 rv add [Varify A/C_RowCount]{1} 101426.41 4 db get RecordsetGetRowsMax 101426.42 4 db get 999 records. (row count=1) 101426.44 4 db update RVs 101426.44 4 db about to close dbDbqDatabase 101426.45 4 db going down path [True] 101426.47 4 next module is [Get PIN No] (idx=84) 101426.47 4 fn RunModule start [Get Numbers,[Get PIN No],84,,] 101426.48 4 timer clear 101426.50 4 state [Get PIN No] Number Input 101426.50 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 101426.52 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 101426.55 4 tw wav->vox convert end 490593,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 101426.56 4 play start ok, lPlayId=490640 101429.17 4 tw dtmf 3 (4,51,51) 101429.19 4 event 3, iCode=51 state=1300 101429.19 4 LsGetNbrsPlayWelcMsg 3,3 101429.22 4 play PlayStop ok 101429.23 4 state [Get PIN No] Number Input 3 101429.23 4 path {3} not found 101429.25 4 timer set 6 EV_TIMEOUT_ENTERDATA 101429.27 4 tw PlayEnd 4 490640 101429.27 4 play end id=490640, (current ID) 101429.28 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 101429.30 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 101429.30 4 path {EV_PLAY_FINISHED} not found 101429.31 4 awaiting further dtmf input 101429.31 4 tw DialogicEvent 129,TDX_PLAY,490640,0,0,,, 101429.33 4 event TDX_PLAY, iCode=129 state=1301 101429.34 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 101429.34 4 path {TDX_PLAY} not found 101429.67 4 tw dtmf 8 (4,56,56) 101429.69 4 event 8, iCode=56 state=1301 101429.70 4 LsGetNbrsRxDigits 8,8 101429.70 4 state [Get PIN No] Number Input 38 101429.72 4 path {38} not found 101429.73 4 timer set 6 EV_TIMEOUT_ENTERDATA 101430.11 4 tw dtmf 0 (4,48,48) 101430.13 4 event 0, iCode=48 state=1301 101430.13 4 LsGetNbrsRxDigits 0,0 101430.14 4 state [Get PIN No] Number Input 380 101430.16 4 path {380} not found 101430.16 4 timer set 6 EV_TIMEOUT_ENTERDATA 101430.34 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 101430.34 4 event FAX, iCode=134 state=1301 101430.36 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 101430.36 4 path {FAX} not found 101430.38 4 event TDX_CST, iCode=134 state=1301 101430.39 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 101430.41 4 path {TDX_CST} not found 101430.55 4 tw dtmf 4 (4,52,52) 101430.55 4 event 4, iCode=52 state=1301 101430.56 4 LsGetNbrsRxDigits 4,4 101430.56 4 state [Get PIN No] Number Input 3804 101430.58 4 path {3804} not found 101430.59 4 timer set 6 EV_TIMEOUT_ENTERDATA 101430.59 4 timer clear 101430.61 4 rv add [Get PIN No]{3804} 101430.63 4 path {3804} not found 101430.63 4 next module is [Varify A/C No] (idx=60) 101430.64 4 rvns add [Get PIN No_PathTaken]{success} 101430.66 4 fn RunModule start [Database Query,[Varify A/C No],60,,] 101430.66 4 timer clear 101430.67 4 state [Varify A/C No] DB Query 101430.69 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 101430.72 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 101430.73 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:14:05 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:14:08 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:14:08 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 101430.75 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 101430.77 4 db [Varify A/C No] row count=1 101430.77 4 rv add [Varify A/C No_RowCount]{1} 101430.78 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 101430.80 4 event FAX, iCode=134 state=1400 101430.80 4 LsDbQuery EV_UNKNOWN_134 101430.81 4 event TDX_CST, iCode=134 state=1400 101430.83 4 LsDbQuery EV_UNKNOWN_134 101430.84 4 db get RecordsetGetRowsMax 101430.84 4 db get 999 records. (row count=1) 101430.86 4 db update RVs 101430.88 4 db about to close dbDbqDatabase 101430.88 4 db going down path [True] 101430.89 4 next module is (idx=83) 101430.91 4 fn RunModule start [Play,,83,,] 101430.91 4 timer clear 101430.92 4 Play Module start 101430.94 4 state Playing 101430.94 4 state Playing (Bangla Voice\Acc List.wav) 101430.95 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 101430.97 4 tw wav->vox convert end 495031,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 101430.98 4 play start ok, lPlayId=495046 101432.89 4 tw dtmf 1 (4,49,49) 101432.91 4 event 1, iCode=49 state=1100 101432.91 4 LsPlayMsg 1,1 101432.92 4 next module is [say Bal 1] (idx=86) 101432.94 4 play PlayStop ok 101432.95 4 rv add {1} 101432.97 4 fn RunModule start [say Numbers,[say Bal 1],86,,] 101432.97 4 tw PlayEnd 4 495046 101432.98 4 play end id=495046, (current ID) 101433.00 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 101433.00 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 101433.02 4 tw DialogicEvent 129,TDX_PLAY,495046,0,0,,, 101433.02 4 event TDX_PLAY, iCode=129 state=6001 101433.03 4 LsModuleTransition : 129, [TDX_PLAY] 101433.05 4 timer clear 101433.05 4 state [say Bal 1] Say numbers: 7 as Number 101433.06 4 fn PlaySoundStartNumbers [],[],[7],Number 101433.08 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 101433.08 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 101433.09 4 rv add [Hangup Time]{01/10/2007 10:14:33 AM} 101433.11 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 101433.11 4 HangupCall_Common hCall=4 101433.13 4 rec RecSoundStop ok 101433.14 4 play PlayStop ok 101433.14 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 101433.16 4 fnHangupCall end 101433.20 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 101433.20 4 event TDX_SETHOOK, iCode=135 state=900 101433.22 4 LsAwaitingCalls EV_UNKNOWN_135 101433.23 4 event callstate IDLE 4 1,0,0 101433.23 4 WorkingMode@Idle= 101433.25 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 101433.25 4 timer clear 101433.27 4 rec RecSoundStop ok 101433.28 4 play PlayStop ok 101433.28 4 rv add [CallEndTime]{01/10/2007 10:14:33 AM} 101433.33 4 on-hangup script:[] 101433.33 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 101433.34 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 101433.36 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 101433.36 4 init atidle reinit : start 101433.38 4 init atidle reinit iConferenceOtherLegLid=-1 101433.38 4 init atidle reinit : reset all LineState variables 101433.39 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 101433.41 4 state Waiting for a call... 101435.59 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 101435.59 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 101435.61 4 setting iDialoutReadyToDialout = 1 101539.39 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 101539.39 MemStructVgs_ClearVgs [1] 101539.47 load end 101539.52 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs 101539.53 0 Erasing Script (new loaded) Id 3 101539.55 0 VgsScriptFree [3] 101539.55 MemStructVgs_ClearVgs [3] 101614.56 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 101614.58 MemStructVgs_ClearVgs [3] 101614.67 load end 101614.69 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 101614.70 0 Erasing Script (new loaded) Id 1 101614.70 0 VgsScriptFree [1] 101614.72 MemStructVgs_ClearVgs [1] 101842.22 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 101842.22 MemStructVgs_ClearVgs [1] 101842.30 load end 101842.31 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs 101842.33 0 Erasing Script (new loaded) Id 3 101842.33 0 VgsScriptFree [3] 101842.34 MemStructVgs_ClearVgs [3] 101952.36 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 101952.36 MemStructVgs_ClearVgs [3] 101952.44 load end 101952.45 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 101952.47 0 Erasing Script (new loaded) Id 1 101952.47 0 VgsScriptFree [1] 101952.48 MemStructVgs_ClearVgs [1] 102020.50 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 102020.50 MemStructVgs_ClearVgs [1] 102020.59 load end 102020.61 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs 102020.63 0 Erasing Script (new loaded) Id 3 102020.64 0 VgsScriptFree [3] 102020.66 MemStructVgs_ClearVgs [3] 102029.48 4 event callstate OFFERING 4 2,0,0 102029.50 4 script interpretor: VgMulti v6.0.3243 102029.50 4 fired OFFERING event to listeners 102029.52 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 102029.52 4 cid CallerID vars set (in 'offering' event) [,,] 102029.53 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 102029.55 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 102029.55 4 tw ring 1 102029.56 4 ring time since last ring event (sec): 0.00 102029.58 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 102029.58 4 should answer as number of rings reached 102029.59 4 rv clear all 102029.61 4 init LineState ResetAtStartOfNewCall. 102029.61 4 answering the call (,,,0) 102029.63 4 timer clear 102029.64 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 102029.66 4 event TDX_CST, iCode=134 state=6001 102029.66 4 LsModuleTransition : 134, [TDX_CST] 102030.27 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 102030.28 4 event TDX_SETHOOK, iCode=135 state=6001 102030.30 4 LsModuleTransition : 135, [TDX_SETHOOK] 102030.30 4 event callstate CONNECTED 4 256,0,0 102030.31 4 LineEvCallState_Connected hDevice=4 params=256,0,0 102030.33 4 WorkingModes tapi= script= LineState().iState=6001 102030.33 4 Inband detection not enabled 102030.34 4 StartLoadedVgs at 01/10/2007 10:20:30 AM (VgMulti v6.0.3243) 102030.36 4 set LineState().iVgsIdx=4 102030.36 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 102030.38 4 init StartLoadedVgs_InitLineState start 102030.39 4 rv add [$RV_STARTTIME]{01/10/2007 10:20:30 AM} 102030.39 4 rv add [$RV_DEVICEID]{4} 102030.41 4 rv add [DlgcNetworkResource]{dxxxB1C4} 102030.41 4 rv add [DlgcVoiceResource]{dxxxB1C4} 102030.42 4 rv add [$RV_CIDNAME]{} 102030.44 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 102030.44 4 rvns add [scriptsPath]{G:\TeleBanking System\} 102030.45 4 rv add [$RV_CIDNUMBER]{} 102030.47 4 fn RunModule start [Play,[Get Language],129,,] 102030.48 4 tw DialogicEvent 134,TDX_CST,35707,0,0,DE_LCON,, 102030.48 4 event TDX_CST, iCode=134 state=6001 102030.50 4 LsModuleTransition : 134, [TDX_CST] 102030.52 4 timer clear 102030.53 4 Play Module start 102030.55 4 state [Get Language] Playing 102030.55 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 102030.56 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 102030.61 4 tw wav->vox convert end 854640,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 102030.64 4 play start ok, lPlayId=854703 102031.52 4 tw dtmf 1 (4,49,49) 102031.53 4 event 1, iCode=49 state=1100 102031.53 4 LsPlayMsg 1,1 102031.55 4 rv add [scriptEnd_Time]{01/10/2007 10:20:31 AM} 102031.56 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 102031.56 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 102031.61 4 rv add [scriptStart_Time]{01/10/2007 10:20:31 AM} 102031.61 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 102031.63 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 102031.64 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 102031.64 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=1 102031.66 4 rvns add [scriptsPath]{G:\TeleBanking System\} 102031.69 4 play PlayStop ok 102031.70 4 rv add [Get Language]{1} 102031.70 4 fn RunModule start [Evaluate,[Get Bangla],109,,] 102031.72 4 tw PlayEnd 4 854703 102031.73 4 play end id=854703, (current ID) 102031.73 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 102031.75 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 102031.77 4 tw DialogicEvent 129,TDX_PLAY,854703,0,0,,, 102031.77 4 event TDX_PLAY, iCode=129 state=6001 102031.78 4 LsModuleTransition : 129, [TDX_PLAY] 102031.80 4 timer clear 102031.80 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 102031.81 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 102031.83 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 102031.83 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 102031.84 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 102031.86 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 102031.88 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 102031.88 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 102031.89 4 matching path not found 102031.89 4 next module is (idx=110) 102031.91 4 matching path was found 102031.92 4 fn RunModule start [Play,,110,,] 102031.92 4 timer clear 102031.94 4 Play Module start 102031.95 4 state Playing 102031.95 4 state Playing (Bangla Voice\Service List.wav) 102031.97 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 102031.98 4 tw wav->vox convert end 856046,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 102032.02 4 play start ok, lPlayId=856078 102033.31 4 tw dtmf 1 (4,49,49) 102033.33 4 event 1, iCode=49 state=1100 102033.34 4 LsPlayMsg 1,1 102033.34 4 next module is [Get Acc No] (idx=88) 102033.36 4 play PlayStop ok 102033.38 4 rv add {1} 102033.39 4 fn RunModule start [Get Numbers,[Get Acc No],88,,] 102033.39 4 tw PlayEnd 4 856078 102033.41 4 play end id=856078, (current ID) 102033.42 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 102033.42 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 102033.44 4 tw DialogicEvent 129,TDX_PLAY,856078,0,0,,, 102033.45 4 event TDX_PLAY, iCode=129 state=6001 102033.45 4 LsModuleTransition : 129, [TDX_PLAY] 102033.47 4 timer clear 102033.47 4 state [Get Acc No] Number Input 102033.48 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 102033.50 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 102033.52 4 tw wav->vox convert end 857578,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 102033.53 4 play start ok, lPlayId=857609 102037.34 4 tw PlayEnd 4 857609 102037.36 4 play end id=857609, (current ID) 102037.38 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 102037.38 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 102037.39 4 path {EV_PLAY_FINISHED} not found 102037.39 4 timer set 17 EV_TIMEOUT_REPLAYMSG 102037.41 4 tw DialogicEvent 129,TDX_PLAY,857609,0,0,,, 102037.42 4 event TDX_PLAY, iCode=129 state=1301 102037.42 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 102037.44 4 path {TDX_PLAY} not found 102037.45 4 tw dtmf 0 (4,48,48) 102037.45 4 event 0, iCode=48 state=1301 102037.47 4 LsGetNbrsRxDigits 0,0 102037.48 4 state [Get Acc No] Number Input 0 102037.48 4 path {0} not found 102037.50 4 timer set 6 EV_TIMEOUT_ENTERDATA 102037.64 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 102037.66 4 event FAX, iCode=134 state=1301 102037.67 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 102037.69 4 path {FAX} not found 102037.70 4 event TDX_CST, iCode=134 state=1301 102037.72 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 102037.72 4 path {TDX_CST} not found 102037.88 4 tw dtmf 1 (4,49,49) 102037.89 4 event 1, iCode=49 state=1301 102037.91 4 LsGetNbrsRxDigits 1,1 102037.91 4 state [Get Acc No] Number Input 01 102037.92 4 path {01} not found 102037.94 4 timer set 6 EV_TIMEOUT_ENTERDATA 102038.11 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 102038.11 4 event FAX, iCode=134 state=1301 102038.13 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 102038.14 4 path {FAX} not found 102038.14 4 event TDX_CST, iCode=134 state=1301 102038.16 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 102038.17 4 path {TDX_CST} not found 102038.31 4 tw dtmf 7 (4,55,55) 102038.31 4 event 7, iCode=55 state=1301 102038.33 4 LsGetNbrsRxDigits 7,7 102038.34 4 state [Get Acc No] Number Input 017 102038.36 4 path {017} not found 102038.36 4 timer set 6 EV_TIMEOUT_ENTERDATA 102038.83 4 tw dtmf 3 (4,51,51) 102038.84 4 event 3, iCode=51 state=1301 102038.86 4 LsGetNbrsRxDigits 3,3 102038.88 4 state [Get Acc No] Number Input 0173 102038.88 4 path {0173} not found 102038.89 4 timer set 6 EV_TIMEOUT_ENTERDATA 102039.41 4 tw dtmf 4 (4,52,52) 102039.41 4 event 4, iCode=52 state=1301 102039.42 4 LsGetNbrsRxDigits 4,4 102039.44 4 state [Get Acc No] Number Input 01734 102039.44 4 path {01734} not found 102039.45 4 timer set 6 EV_TIMEOUT_ENTERDATA 102039.95 4 tw dtmf 0 (4,48,48) 102039.97 4 event 0, iCode=48 state=1301 102039.97 4 LsGetNbrsRxDigits 0,0 102039.98 4 state [Get Acc No] Number Input 017340 102040.00 4 path {017340} not found 102040.00 4 timer set 6 EV_TIMEOUT_ENTERDATA 102040.33 4 tw dtmf 0 (4,48,48) 102040.34 4 event 0, iCode=48 state=1301 102040.36 4 LsGetNbrsRxDigits 0,0 102040.36 4 state [Get Acc No] Number Input 0173400 102040.38 4 path {0173400} not found 102040.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 102040.64 4 tw dtmf 0 (4,48,48) 102040.66 4 event 0, iCode=48 state=1301 102040.67 4 LsGetNbrsRxDigits 0,0 102040.67 4 state [Get Acc No] Number Input 01734000 102040.69 4 path {01734000} not found 102040.70 4 timer set 6 EV_TIMEOUT_ENTERDATA 102041.17 4 tw dtmf 2 (4,50,50) 102041.19 4 event 2, iCode=50 state=1301 102041.20 4 LsGetNbrsRxDigits 2,2 102041.20 4 state [Get Acc No] Number Input 017340002 102041.22 4 path {017340002} not found 102041.23 4 timer set 6 EV_TIMEOUT_ENTERDATA 102041.52 4 tw dtmf 4 (4,52,52) 102041.59 4 event 4, iCode=52 state=1301 102041.59 4 LsGetNbrsRxDigits 4,4 102041.61 4 state [Get Acc No] Number Input 0173400024 102041.63 4 path {0173400024} not found 102041.63 4 timer set 6 EV_TIMEOUT_ENTERDATA 102041.75 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 102041.77 4 event FAX, iCode=134 state=1301 102041.77 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 102041.78 4 path {FAX} not found 102041.80 4 event TDX_CST, iCode=134 state=1301 102041.80 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 102041.81 4 path {TDX_CST} not found 102041.89 4 tw dtmf 5 (4,53,53) 102041.91 4 event 5, iCode=53 state=1301 102041.92 4 LsGetNbrsRxDigits 5,5 102041.92 4 state [Get Acc No] Number Input 01734000245 102041.94 4 path {01734000245} not found 102041.95 4 timer set 6 EV_TIMEOUT_ENTERDATA 102048.42 4 timer fired EV_TIMEOUT_ENTERDATA 102048.42 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 102048.44 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 102048.45 4 path {EV_TIMEOUT_ENTERDATA} not found 102048.45 4 timer clear 102048.47 4 rv add [Get Acc No]{01734000245} 102048.48 4 path {01734000245} not found 102048.48 4 next module is [Varify A/C] (idx=2) 102048.50 4 rvns add [Get Acc No_PathTaken]{success} 102048.52 4 fn RunModule start [Database Query,[Varify A/C],2,,] 102048.52 4 timer clear 102048.53 4 state [Varify A/C] DB Query 102048.55 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 102048.58 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 102048.59 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:20:30 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:20:31 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:20:31 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 102048.61 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 102048.61 4 db [Varify A/C] row count=1 102048.63 4 rv add [Varify A/C_RowCount]{1} 102048.64 4 db get RecordsetGetRowsMax 102048.64 4 db get 999 records. (row count=1) 102048.66 4 db update RVs 102048.67 4 db about to close dbDbqDatabase 102048.69 4 db going down path [True] 102048.69 4 next module is [Get PIN No] (idx=89) 102048.70 4 fn RunModule start [Get Numbers,[Get PIN No],89,,] 102048.72 4 timer clear 102048.72 4 state [Get PIN No] Number Input 102048.73 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 102048.75 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 102048.80 4 tw wav->vox convert end 872828,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 102048.83 4 play start ok, lPlayId=872890 102052.16 4 tw PlayEnd 4 872890 102052.17 4 play end id=872890, (current ID) 102052.17 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 102052.19 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 102052.20 4 path {EV_PLAY_FINISHED} not found 102052.20 4 timer set 7 EV_TIMEOUT_REPLAYMSG 102052.22 4 tw DialogicEvent 129,TDX_PLAY,872890,0,0,,, 102052.23 4 event TDX_PLAY, iCode=129 state=1301 102052.23 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 102052.25 4 path {TDX_PLAY} not found 102053.05 4 tw dtmf 3 (4,51,51) 102053.05 4 event 3, iCode=51 state=1301 102053.06 4 LsGetNbrsRxDigits 3,3 102053.08 4 state [Get PIN No] Number Input 3 102053.08 4 path {3} not found 102053.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 102053.73 4 tw dtmf 8 (4,56,56) 102053.75 4 event 8, iCode=56 state=1301 102053.77 4 LsGetNbrsRxDigits 8,8 102053.77 4 state [Get PIN No] Number Input 38 102053.78 4 path {38} not found 102053.80 4 timer set 6 EV_TIMEOUT_ENTERDATA 102054.14 4 tw dtmf 0 (4,48,48) 102054.16 4 event 0, iCode=48 state=1301 102054.17 4 LsGetNbrsRxDigits 0,0 102054.19 4 state [Get PIN No] Number Input 380 102054.19 4 path {380} not found 102054.20 4 timer set 6 EV_TIMEOUT_ENTERDATA 102054.50 4 tw dtmf 4 (4,52,52) 102054.52 4 event 4, iCode=52 state=1301 102054.53 4 LsGetNbrsRxDigits 4,4 102054.53 4 state [Get PIN No] Number Input 3804 102054.55 4 path {3804} not found 102054.56 4 timer set 6 EV_TIMEOUT_ENTERDATA 102054.56 4 timer clear 102054.58 4 rv add [Get PIN No]{3804} 102054.59 4 path {3804} not found 102054.59 4 next module is [Varify A/C No] (idx=113) 102054.61 4 rvns add [Get PIN No_PathTaken]{success} 102054.63 4 fn RunModule start [Database Query,[Varify A/C No],113,,] 102054.63 4 timer clear 102054.64 4 state [Varify A/C No] DB Query 102054.66 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 102054.69 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 102054.70 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:20:30 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:20:31 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:20:31 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 102054.72 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 102054.72 4 db [Varify A/C No] row count=1 102054.73 4 rv add [Varify A/C No_RowCount]{1} 102054.75 4 db get RecordsetGetRowsMax 102054.75 4 db get 999 records. (row count=1) 102054.77 4 db update RVs 102054.78 4 db about to close dbDbqDatabase 102054.80 4 db going down path [True] 102054.80 4 next module is (idx=90) 102054.81 4 fn RunModule start [Play,,90,,] 102054.83 4 timer clear 102054.83 4 Play Module start 102054.84 4 state Playing 102054.86 4 state Playing (Bangla Voice\Acc List.wav) 102054.86 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 102054.89 4 tw wav->vox convert end 878937,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 102054.92 4 play start ok, lPlayId=878984 102056.42 4 tw dtmf 1 (4,49,49) 102056.44 4 event 1, iCode=49 state=1100 102056.45 4 LsPlayMsg 1,1 102056.45 4 next module is [say Bal 1] (idx=3) 102056.47 4 play PlayStop ok 102056.48 4 rv add {1} 102056.50 4 fn RunModule start [say Numbers,[say Bal 1],3,,] 102056.50 4 tw PlayEnd 4 878984 102056.52 4 play end id=878984, (current ID) 102056.53 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 102056.53 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 102056.55 4 tw DialogicEvent 129,TDX_PLAY,878984,0,0,,, 102056.56 4 event TDX_PLAY, iCode=129 state=6001 102056.56 4 LsModuleTransition : 129, [TDX_PLAY] 102056.58 4 timer clear 102056.59 4 state [say Bal 1] Say numbers: 01/02/2007 as Date - DDMMYYYY 102056.61 4 fn PlaySoundStartNumbers [],[],[01/02/2007],Date - DDMMYYYY 102056.63 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 102056.64 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 102056.64 4 rv add [Hangup Time]{01/10/2007 10:20:56 AM} 102056.66 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 102056.67 4 HangupCall_Common hCall=4 102056.67 4 rec RecSoundStop ok 102056.69 4 play PlayStop ok 102056.70 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 102056.70 4 fnHangupCall end 102056.72 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 102056.73 4 event FAX, iCode=134 state=900 102056.73 4 LsAwaitingCalls EV_UNKNOWN_134 102056.75 4 event TDX_CST, iCode=134 state=900 102056.77 4 LsAwaitingCalls EV_UNKNOWN_134 102056.77 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 102056.78 4 event TDX_SETHOOK, iCode=135 state=900 102056.80 4 LsAwaitingCalls EV_UNKNOWN_135 102056.80 4 event callstate IDLE 4 1,0,0 102056.81 4 WorkingMode@Idle= 102056.83 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 102056.83 4 timer clear 102056.84 4 rec RecSoundStop ok 102056.86 4 play PlayStop ok 102056.88 4 rv add [CallEndTime]{01/10/2007 10:20:56 AM} 102056.91 4 on-hangup script:[] 102056.92 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 102056.92 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 102056.94 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 102056.95 4 init atidle reinit : start 102056.95 4 init atidle reinit iConferenceOtherLegLid=-1 102056.97 4 init atidle reinit : reset all LineState variables 102056.98 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 102056.98 4 state Waiting for a call... 102059.19 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 102059.19 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 102059.20 4 setting iDialoutReadyToDialout = 1 102205.00 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 102205.02 MemStructVgs_ClearVgs [3] 102205.02 load end 102205.03 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 102205.05 0 Erasing Script (new loaded) Id 4 102205.05 0 VgsScriptFree [4] 102205.06 MemStructVgs_ClearVgs [4] 102207.08 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 102207.08 MemStructVgs_ClearVgs [4] 102207.09 load end 102207.11 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Main.vgs 102207.13 0 Erasing Script (new loaded) Id 3 102207.13 0 VgsScriptFree [3] 102207.14 MemStructVgs_ClearVgs [3] 102216.16 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 102216.16 MemStructVgs_ClearVgs [3] 102216.17 load end 102216.19 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 102216.19 0 Erasing Script (new loaded) Id 4 102216.20 0 VgsScriptFree [4] 102216.22 MemStructVgs_ClearVgs [4] 102555.61 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 102555.61 MemStructVgs_ClearVgs [4] 102555.70 load end 102555.72 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 102555.73 0 Erasing Script (new loaded) Id 1 102555.75 0 VgsScriptFree [1] 102555.75 MemStructVgs_ClearVgs [1] 103953.97 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 103953.97 MemStructVgs_ClearVgs [1] 103954.05 load end 103954.06 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs 103954.06 0 Erasing Script (new loaded) Id 4 103954.08 0 VgsScriptFree [4] 103954.09 MemStructVgs_ClearVgs [4] 103957.09 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 103957.09 MemStructVgs_ClearVgs [4] 103957.17 load end 103957.19 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 103957.20 0 Erasing Script (new loaded) Id 1 103957.20 0 VgsScriptFree [1] 103957.22 MemStructVgs_ClearVgs [1] 104131.23 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104131.25 MemStructVgs_ClearVgs [1] 104131.33 load end 104131.34 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Ban.vgs 104131.36 0 Erasing Script (new loaded) Id 4 104131.36 0 VgsScriptFree [4] 104131.38 MemStructVgs_ClearVgs [4] 104304.23 0 sys cleanup Start 104304.23 0 sys cleanup End 104323.39 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104323.39 MemStructVgs_ClearVgs [4] 104323.47 load end 104323.48 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 104323.50 0 Erasing Script (new loaded) Id 1 104323.50 0 VgsScriptFree [1] 104323.52 MemStructVgs_ClearVgs [1] 104332.34 4 event callstate OFFERING 4 2,0,0 104332.36 4 script interpretor: VgMulti v6.0.3243 104332.36 4 fired OFFERING event to listeners 104332.38 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 104332.39 4 cid CallerID vars set (in 'offering' event) [,,] 104332.39 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 104332.41 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 104332.42 4 tw ring 1 104332.42 4 ring time since last ring event (sec): 0.00 104332.44 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 104332.45 4 should answer as number of rings reached 104332.45 4 rv clear all 104332.47 4 init LineState ResetAtStartOfNewCall. 104332.48 4 answering the call (,,,0) 104332.48 4 timer clear 104332.50 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 104332.52 4 event TDX_CST, iCode=134 state=6001 104332.53 4 LsModuleTransition : 134, [TDX_CST] 104333.14 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 104333.14 4 event TDX_SETHOOK, iCode=135 state=6001 104333.16 4 LsModuleTransition : 135, [TDX_SETHOOK] 104333.17 4 event callstate CONNECTED 4 256,0,0 104333.17 4 LineEvCallState_Connected hDevice=4 params=256,0,0 104333.19 4 WorkingModes tapi= script= LineState().iState=6001 104333.20 4 Inband detection not enabled 104333.20 4 StartLoadedVgs at 01/10/2007 10:43:33 AM (VgMulti v6.0.3243) 104333.22 4 set LineState().iVgsIdx=3 104333.23 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 104333.23 4 init StartLoadedVgs_InitLineState start 104333.25 4 rv add [$RV_STARTTIME]{01/10/2007 10:43:33 AM} 104333.25 4 rv add [$RV_DEVICEID]{4} 104333.27 4 rv add [DlgcNetworkResource]{dxxxB1C4} 104333.28 4 rv add [DlgcVoiceResource]{dxxxB1C4} 104333.28 4 rv add [$RV_CIDNAME]{} 104333.30 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 104333.31 4 rvns add [scriptsPath]{G:\TeleBanking System\} 104333.31 4 rv add [$RV_CIDNUMBER]{} 104333.33 4 fn RunModule start [Play,[Get Language],46,,] 104333.34 4 tw DialogicEvent 134,TDX_CST,65535,0,0,DE_LCON,, 104333.34 4 event TDX_CST, iCode=134 state=6001 104333.36 4 LsModuleTransition : 134, [TDX_CST] 104333.38 4 timer clear 104333.39 4 Play Module start 104333.39 4 state [Get Language] Playing 104333.41 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 104333.42 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 104333.45 4 tw wav->vox convert end 237500,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 104333.47 4 play start ok, lPlayId=237546 104334.78 4 tw dtmf 1 (4,49,49) 104334.80 4 event 1, iCode=49 state=1100 104334.81 4 LsPlayMsg 1,1 104334.81 4 rv add [scriptEnd_Time]{01/10/2007 10:43:34 AM} 104334.83 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 104334.84 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 104334.88 4 rv add [scriptStart_Time]{01/10/2007 10:43:34 AM} 104334.88 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 104334.89 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 104334.91 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104334.91 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4 104334.92 4 rvns add [scriptsPath]{G:\TeleBanking System\} 104334.94 4 play PlayStop ok 104334.95 4 rv add [Get Language]{1} 104334.97 4 fn RunModule start [Evaluate,[Get Bangla],65,,] 104334.97 4 tw PlayEnd 4 237546 104334.98 4 play end id=237546, (current ID) 104335.00 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 104335.00 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 104335.02 4 tw DialogicEvent 129,TDX_PLAY,237546,0,0,,, 104335.03 4 event TDX_PLAY, iCode=129 state=6001 104335.03 4 LsModuleTransition : 129, [TDX_PLAY] 104335.05 4 timer clear 104335.05 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 104335.06 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 104335.08 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 104335.08 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 104335.09 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 104335.11 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 104335.11 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 104335.13 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 104335.14 4 matching path not found 104335.14 4 next module is (idx=66) 104335.16 4 matching path was found 104335.16 4 fn RunModule start [Play,,66,,] 104335.17 4 timer clear 104335.19 4 Play Module start 104335.19 4 state Playing 104335.20 4 state Playing (Bangla Voice\Service List.wav) 104335.22 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 104335.23 4 tw wav->vox convert end 239296,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 104335.25 4 play start ok, lPlayId=239312 104336.03 4 tw dtmf 1 (4,49,49) 104336.03 4 event 1, iCode=49 state=1100 104336.05 4 LsPlayMsg 1,1 104336.05 4 next module is [Get Acc No] (idx=129) 104336.08 4 play PlayStop ok 104336.08 4 rv add {1} 104336.09 4 fn RunModule start [Get Numbers,[Get Acc No],129,,] 104336.11 4 tw PlayEnd 4 239312 104336.11 4 play end id=239312, (current ID) 104336.13 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 104336.14 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 104336.14 4 tw DialogicEvent 129,TDX_PLAY,239312,0,0,,, 104336.16 4 event TDX_PLAY, iCode=129 state=6001 104336.16 4 LsModuleTransition : 129, [TDX_PLAY] 104336.17 4 timer clear 104336.19 4 state [Get Acc No] Number Input 104336.19 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 104336.20 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 104336.25 4 tw wav->vox convert end 240281,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 104336.27 4 play start ok, lPlayId=240328 104339.48 4 tw dtmf 0 (4,48,48) 104339.50 4 event 0, iCode=48 state=1300 104339.52 4 LsGetNbrsPlayWelcMsg 0,0 104339.53 4 play PlayStop ok 104339.53 4 state [Get Acc No] Number Input 0 104339.55 4 path {0} not found 104339.56 4 timer set 6 EV_TIMEOUT_ENTERDATA 104339.56 4 tw PlayEnd 4 240328 104339.58 4 play end id=240328, (current ID) 104339.59 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 104339.59 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 104339.61 4 path {EV_PLAY_FINISHED} not found 104339.63 4 awaiting further dtmf input 104339.63 4 tw DialogicEvent 129,TDX_PLAY,240328,0,0,,, 104339.64 4 event TDX_PLAY, iCode=129 state=1301 104339.64 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 104339.66 4 path {TDX_PLAY} not found 104340.31 4 tw dtmf 1 (4,49,49) 104340.31 4 event 1, iCode=49 state=1301 104340.33 4 LsGetNbrsRxDigits 1,1 104340.34 4 state [Get Acc No] Number Input 01 104340.34 4 path {01} not found 104340.36 4 timer set 6 EV_TIMEOUT_ENTERDATA 104341.59 4 tw dtmf 7 (4,55,55) 104341.61 4 event 7, iCode=55 state=1301 104341.61 4 LsGetNbrsRxDigits 7,7 104341.63 4 state [Get Acc No] Number Input 017 104341.63 4 path {017} not found 104341.64 4 timer set 6 EV_TIMEOUT_ENTERDATA 104341.81 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 104341.83 4 event FAX, iCode=134 state=1301 104341.84 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 104341.84 4 path {FAX} not found 104341.86 4 event TDX_CST, iCode=134 state=1301 104341.88 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 104341.88 4 path {TDX_CST} not found 104342.03 4 tw dtmf 3 (4,51,51) 104342.05 4 event 3, iCode=51 state=1301 104342.06 4 LsGetNbrsRxDigits 3,3 104342.06 4 state [Get Acc No] Number Input 0173 104342.08 4 path {0173} not found 104342.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 104342.61 4 tw dtmf 4 (4,52,52) 104342.63 4 event 4, iCode=52 state=1301 104342.63 4 LsGetNbrsRxDigits 4,4 104342.64 4 state [Get Acc No] Number Input 01734 104342.66 4 path {01734} not found 104342.66 4 timer set 6 EV_TIMEOUT_ENTERDATA 104343.05 4 tw dtmf 0 (4,48,48) 104343.05 4 event 0, iCode=48 state=1301 104343.06 4 LsGetNbrsRxDigits 0,0 104343.08 4 state [Get Acc No] Number Input 017340 104343.08 4 path {017340} not found 104343.09 4 timer set 6 EV_TIMEOUT_ENTERDATA 104343.38 4 tw dtmf 0 (4,48,48) 104343.39 4 event 0, iCode=48 state=1301 104343.41 4 LsGetNbrsRxDigits 0,0 104343.41 4 state [Get Acc No] Number Input 0173400 104343.42 4 path {0173400} not found 104343.44 4 timer set 6 EV_TIMEOUT_ENTERDATA 104343.58 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 104343.59 4 event FAX, iCode=134 state=1301 104343.61 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 104343.61 4 path {FAX} not found 104343.63 4 event TDX_CST, iCode=134 state=1301 104343.64 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 104343.64 4 path {TDX_CST} not found 104343.77 4 tw dtmf 0 (4,48,48) 104343.78 4 event 0, iCode=48 state=1301 104343.78 4 LsGetNbrsRxDigits 0,0 104343.80 4 state [Get Acc No] Number Input 01734000 104343.80 4 path {01734000} not found 104343.81 4 timer set 6 EV_TIMEOUT_ENTERDATA 104343.98 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 104343.98 4 event FAX, iCode=134 state=1301 104344.00 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 104344.02 4 path {FAX} not found 104344.02 4 event TDX_CST, iCode=134 state=1301 104344.03 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 104344.05 4 path {TDX_CST} not found 104344.20 4 tw dtmf 2 (4,50,50) 104344.22 4 event 2, iCode=50 state=1301 104344.23 4 LsGetNbrsRxDigits 2,2 104344.23 4 state [Get Acc No] Number Input 017340002 104344.25 4 path {017340002} not found 104344.25 4 timer set 6 EV_TIMEOUT_ENTERDATA 104344.56 4 tw dtmf 4 (4,52,52) 104344.58 4 event 4, iCode=52 state=1301 104344.59 4 LsGetNbrsRxDigits 4,4 104344.59 4 state [Get Acc No] Number Input 0173400024 104344.61 4 path {0173400024} not found 104344.63 4 timer set 6 EV_TIMEOUT_ENTERDATA 104344.88 4 tw dtmf 5 (4,53,53) 104344.88 4 event 5, iCode=53 state=1301 104344.89 4 LsGetNbrsRxDigits 5,5 104344.89 4 state [Get Acc No] Number Input 01734000245 104344.91 4 path {01734000245} not found 104344.92 4 timer set 6 EV_TIMEOUT_ENTERDATA 104351.42 4 timer fired EV_TIMEOUT_ENTERDATA 104351.42 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 104351.44 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 104351.44 4 path {EV_TIMEOUT_ENTERDATA} not found 104351.45 4 timer clear 104351.47 4 rv add [Get Acc No]{01734000245} 104351.47 4 path {01734000245} not found 104351.48 4 next module is [Varify A/C] (idx=84) 104351.50 4 rvns add [Get Acc No_PathTaken]{success} 104351.50 4 fn RunModule start [Database Query,[Varify A/C],84,,] 104351.52 4 timer clear 104351.53 4 state [Varify A/C] DB Query 104351.53 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 104351.58 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 104351.58 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:43:33 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:43:34 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:43:34 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 104351.59 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 104351.61 4 db [Varify A/C] row count=1 104351.63 4 rv add [Varify A/C_RowCount]{1} 104351.63 4 db get RecordsetGetRowsMax 104351.64 4 db get 999 records. (row count=1) 104351.64 4 db update RVs 104351.66 4 db about to close dbDbqDatabase 104351.67 4 db going down path [True] 104351.67 4 next module is [Get PIN No] (idx=128) 104351.69 4 fn RunModule start [Get Numbers,[Get PIN No],128,,] 104351.70 4 timer clear 104351.70 4 state [Get PIN No] Number Input 104351.72 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 104351.73 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 104351.78 4 tw wav->vox convert end 255812,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 104351.81 4 play start ok, lPlayId=255875 104355.13 4 tw PlayEnd 4 255875 104355.14 4 play end id=255875, (current ID) 104355.14 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 104355.16 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 104355.17 4 path {EV_PLAY_FINISHED} not found 104355.17 4 timer set 7 EV_TIMEOUT_REPLAYMSG 104355.19 4 tw DialogicEvent 129,TDX_PLAY,255875,0,0,,, 104355.20 4 event TDX_PLAY, iCode=129 state=1301 104355.20 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 104355.22 4 path {TDX_PLAY} not found 104355.42 4 tw dtmf 3 (4,51,51) 104355.42 4 event 3, iCode=51 state=1301 104355.44 4 LsGetNbrsRxDigits 3,3 104355.45 4 state [Get PIN No] Number Input 3 104355.45 4 path {3} not found 104355.47 4 timer set 6 EV_TIMEOUT_ENTERDATA 104356.22 4 tw dtmf 8 (4,56,56) 104356.23 4 event 8, iCode=56 state=1301 104356.23 4 LsGetNbrsRxDigits 8,8 104356.25 4 state [Get PIN No] Number Input 38 104356.27 4 path {38} not found 104356.27 4 timer set 6 EV_TIMEOUT_ENTERDATA 104356.70 4 tw dtmf 0 (4,48,48) 104356.70 4 event 0, iCode=48 state=1301 104356.72 4 LsGetNbrsRxDigits 0,0 104356.73 4 state [Get PIN No] Number Input 380 104356.73 4 path {380} not found 104356.75 4 timer set 6 EV_TIMEOUT_ENTERDATA 104357.09 4 tw dtmf 4 (4,52,52) 104357.11 4 event 4, iCode=52 state=1301 104357.11 4 LsGetNbrsRxDigits 4,4 104357.13 4 state [Get PIN No] Number Input 3804 104357.14 4 path {3804} not found 104357.14 4 timer set 6 EV_TIMEOUT_ENTERDATA 104357.16 4 timer clear 104357.17 4 rv add [Get PIN No]{3804} 104357.17 4 path {3804} not found 104357.19 4 next module is [Varify A/C No] (idx=69) 104357.20 4 rvns add [Get PIN No_PathTaken]{success} 104357.20 4 fn RunModule start [Database Query,[Varify A/C No],69,,] 104357.22 4 timer clear 104357.22 4 state [Varify A/C No] DB Query 104357.23 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 104357.27 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 104357.28 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:43:33 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:43:34 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:43:34 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 104357.30 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 104357.30 4 db [Varify A/C No] row count=1 104357.31 4 rv add [Varify A/C No_RowCount]{1} 104357.33 4 db get RecordsetGetRowsMax 104357.33 4 db get 999 records. (row count=1) 104357.34 4 db update RVs 104357.36 4 db about to close dbDbqDatabase 104357.36 4 db going down path [True] 104357.38 4 next module is (idx=127) 104357.39 4 fn RunModule start [Play,,127,,] 104357.41 4 timer clear 104357.42 4 Play Module start 104357.42 4 state Playing 104357.44 4 state Playing (Bangla Voice\Acc List.wav) 104357.44 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 104357.47 4 tw wav->vox convert end 261515,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 104357.50 4 play start ok, lPlayId=261562 104410.13 4 tw PlayEnd 4 261562 104410.14 4 play end id=261562, (current ID) 104410.14 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 104410.16 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 104410.17 4 path {EV_PLAY_FINISHED} not found 104410.17 4 timer set 7 EV_TIMEOUT_REPLAYMSG 104410.19 4 tw DialogicEvent 129,TDX_PLAY,261562,0,0,,, 104410.20 4 event TDX_PLAY, iCode=129 state=1101 104410.20 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 104410.22 4 path {TDX_PLAY} not found 104410.23 4 tw dtmf 1 (4,49,49) 104410.23 4 event 1, iCode=49 state=1101 104410.25 4 LsPlayMsgFinished 1,1 104410.25 4 next module is [say Bal 1] (idx=85) 104410.27 4 rv add {1} 104410.28 4 fn RunModule start [say Numbers,[say Bal 1],85,,] 104410.28 4 timer clear 104410.30 4 state [say Bal 1] Say numbers: 01/02/2007 as Date - DDMMYYYY 104410.31 4 fn PlaySoundStartNumbers [],[],[01/02/2007],Date - DDMMYYYY 104410.31 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 104410.33 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 104410.34 4 rv add [Hangup Time]{01/10/2007 10:44:10 AM} 104410.34 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 104410.36 4 HangupCall_Common hCall=4 104410.36 4 rec RecSoundStop ok 104410.38 4 play PlayStop ok 104410.39 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 104410.41 4 fnHangupCall end 104410.44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 104410.45 4 event TDX_SETHOOK, iCode=135 state=900 104410.47 4 LsAwaitingCalls EV_UNKNOWN_135 104410.47 4 event callstate IDLE 4 1,0,0 104410.48 4 WorkingMode@Idle= 104410.50 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 104410.50 4 timer clear 104410.52 4 rec RecSoundStop ok 104410.53 4 play PlayStop ok 104410.53 4 rv add [CallEndTime]{01/10/2007 10:44:10 AM} 104410.56 4 on-hangup script:[] 104410.58 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 104410.58 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 104410.59 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 104410.61 4 init atidle reinit : start 104410.61 4 init atidle reinit iConferenceOtherLegLid=-1 104410.63 4 init atidle reinit : reset all LineState variables 104410.64 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 104410.64 4 state Waiting for a call... 104412.84 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 104412.84 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 104412.86 4 setting iDialoutReadyToDialout = 1 104449.72 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 104449.72 MemStructVgs_ClearVgs [1] 104449.73 load end 104449.75 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 104449.77 0 Erasing Script (new loaded) Id 3 104449.77 0 VgsScriptFree [3] 104449.78 MemStructVgs_ClearVgs [3] 104532.80 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104532.80 MemStructVgs_ClearVgs [3] 104532.89 load end 104532.89 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 104532.91 0 Erasing Script (new loaded) Id 4 104532.92 0 VgsScriptFree [4] 104532.92 MemStructVgs_ClearVgs [4] 104542.94 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104542.94 MemStructVgs_ClearVgs [4] 104543.02 load end 104543.03 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 104543.05 0 Erasing Script (new loaded) Id 3 104543.05 0 VgsScriptFree [3] 104543.06 MemStructVgs_ClearVgs [3] 104554.08 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104554.08 MemStructVgs_ClearVgs [3] 104554.16 load end 104554.17 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 104554.19 0 Erasing Script (new loaded) Id 4 104554.19 0 VgsScriptFree [4] 104554.20 MemStructVgs_ClearVgs [4] 104604.22 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104604.22 MemStructVgs_ClearVgs [4] 104604.30 load end 104604.31 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 104604.33 0 Erasing Script (new loaded) Id 3 104604.33 0 VgsScriptFree [3] 104604.34 MemStructVgs_ClearVgs [3] 104612.36 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104612.36 MemStructVgs_ClearVgs [3] 104612.44 load end 104612.45 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 104612.47 0 Erasing Script (new loaded) Id 4 104612.48 0 VgsScriptFree [4] 104612.48 MemStructVgs_ClearVgs [4] 104634.50 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104634.50 MemStructVgs_ClearVgs [4] 104634.58 load end 104634.59 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 104634.61 0 Erasing Script (new loaded) Id 3 104634.63 0 VgsScriptFree [3] 104634.63 MemStructVgs_ClearVgs [3] 104643.64 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104643.64 MemStructVgs_ClearVgs [3] 104643.72 load end 104643.73 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 104643.73 0 Erasing Script (new loaded) Id 4 104643.75 0 VgsScriptFree [4] 104643.77 MemStructVgs_ClearVgs [4] 104644.77 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104644.77 MemStructVgs_ClearVgs [4] 104644.84 load end 104644.86 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 104644.88 0 Erasing Script (new loaded) Id 3 104644.88 0 VgsScriptFree [3] 104644.89 MemStructVgs_ClearVgs [3] 104647.91 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104647.91 MemStructVgs_ClearVgs [3] 104647.98 load end 104648.00 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Ban.vgs 104648.02 0 Erasing Script (new loaded) Id 4 104648.02 0 VgsScriptFree [4] 104648.03 MemStructVgs_ClearVgs [4] 104703.05 load start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104703.06 MemStructVgs_ClearVgs [4] 104703.16 load end 104703.17 loaded Script Id 4: G:\TeleBanking System\Tele Banking_Ban.vgs 104703.19 0 Erasing Script (new loaded) Id 3 104703.22 0 VgsScriptFree [3] 104703.23 MemStructVgs_ClearVgs [3] 104752.89 4 event callstate OFFERING 4 2,0,0 104752.91 4 script interpretor: VgMulti v6.0.3243 104752.91 4 fired OFFERING event to listeners 104752.92 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 104752.94 4 cid CallerID vars set (in 'offering' event) [,,] 104752.94 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 104752.95 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 104752.97 4 tw ring 1 104752.97 4 ring time since last ring event (sec): 0.00 104752.98 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 104753.00 4 should answer as number of rings reached 104753.00 4 rv clear all 104753.02 4 init LineState ResetAtStartOfNewCall. 104753.02 4 answering the call (,,,0) 104753.03 4 timer clear 104753.05 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 104753.06 4 event TDX_CST, iCode=134 state=6001 104753.06 4 LsModuleTransition : 134, [TDX_CST] 104753.67 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 104753.69 4 event TDX_SETHOOK, iCode=135 state=6001 104753.70 4 LsModuleTransition : 135, [TDX_SETHOOK] 104753.70 4 event callstate CONNECTED 4 256,0,0 104753.72 4 LineEvCallState_Connected hDevice=4 params=256,0,0 104753.73 4 WorkingModes tapi= script= LineState().iState=6001 104753.73 4 Inband detection not enabled 104753.75 4 StartLoadedVgs at 01/10/2007 10:47:53 AM (VgMulti v6.0.3243) 104753.77 4 set LineState().iVgsIdx=1 104753.77 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 104753.78 4 init StartLoadedVgs_InitLineState start 104753.80 4 rv add [$RV_STARTTIME]{01/10/2007 10:47:53 AM} 104753.80 4 rv add [$RV_DEVICEID]{4} 104753.81 4 rv add [DlgcNetworkResource]{dxxxB1C4} 104753.81 4 rv add [DlgcVoiceResource]{dxxxB1C4} 104753.83 4 rv add [$RV_CIDNAME]{} 104753.84 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 104753.84 4 rvns add [scriptsPath]{G:\TeleBanking System\} 104753.86 4 rv add [$RV_CIDNUMBER]{} 104753.88 4 fn RunModule start [Play,[Get Language],3,,] 104753.88 4 tw DialogicEvent 134,TDX_CST,22324,0,0,DE_LCON,, 104753.89 4 event TDX_CST, iCode=134 state=6001 104753.89 4 LsModuleTransition : 134, [TDX_CST] 104753.91 4 timer clear 104753.92 4 Play Module start 104753.92 4 state [Get Language] Playing 104753.94 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 104753.95 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 104753.97 4 tw wav->vox convert end 498031,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 104754.00 4 play start ok, lPlayId=498062 104754.70 4 tw dtmf 1 (4,49,49) 104754.72 4 event 1, iCode=49 state=1100 104754.73 4 LsPlayMsg 1,1 104754.73 4 rv add [scriptEnd_Time]{01/10/2007 10:47:54 AM} 104754.75 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 104754.77 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 104754.80 4 rv add [scriptStart_Time]{01/10/2007 10:47:54 AM} 104754.80 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 104754.81 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 104754.83 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 104754.83 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4 104754.84 4 rvns add [scriptsPath]{G:\TeleBanking System\} 104754.86 4 play PlayStop ok 104754.88 4 rv add [Get Language]{1} 104754.89 4 fn RunModule start [Evaluate,[Get Bangla],64,,] 104754.89 4 tw PlayEnd 4 498062 104754.91 4 play end id=498062, (current ID) 104754.92 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 104754.92 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 104754.94 4 tw DialogicEvent 129,TDX_PLAY,498062,0,0,,, 104754.95 4 event TDX_PLAY, iCode=129 state=6001 104754.95 4 LsModuleTransition : 129, [TDX_PLAY] 104754.97 4 timer clear 104754.97 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 104754.98 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 104755.00 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 104755.00 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 104755.02 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 104755.03 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 104755.03 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 104755.05 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 104755.05 4 matching path not found 104755.06 4 next module is (idx=63) 104755.08 4 matching path was found 104755.08 4 fn RunModule start [Play,,63,,] 104755.09 4 timer clear 104755.11 4 Play Module start 104755.11 4 state Playing 104755.13 4 state Playing (Bangla Voice\Service List.wav) 104755.14 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 104755.19 4 tw wav->vox convert end 499218,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 104755.22 4 play start ok, lPlayId=499281 104756.31 4 tw dtmf 1 (4,49,49) 104756.33 4 event 1, iCode=49 state=1100 104756.34 4 LsPlayMsg 1,1 104756.36 4 next module is [Get Acc No] (idx=85) 104756.39 4 play PlayStop ok 104756.41 4 rv add {1} 104756.41 4 fn RunModule start [Get Numbers,[Get Acc No],85,,] 104756.42 4 tw PlayEnd 4 499281 104756.44 4 play end id=499281, (current ID) 104756.44 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 104756.45 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 104756.45 4 tw DialogicEvent 129,TDX_PLAY,499281,0,0,,, 104756.47 4 event TDX_PLAY, iCode=129 state=6001 104756.48 4 LsModuleTransition : 129, [TDX_PLAY] 104756.48 4 timer clear 104756.50 4 state [Get Acc No] Number Input 104756.52 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 104756.52 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 104756.56 4 tw wav->vox convert end 500593,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 104756.58 4 play start ok, lPlayId=500656 104800.39 4 tw dtmf 0 (4,48,48) 104800.39 4 event 0, iCode=48 state=1300 104800.41 4 LsGetNbrsPlayWelcMsg 0,0 104800.42 4 play PlayStop ok 104800.42 4 state [Get Acc No] Number Input 0 104800.44 4 path {0} not found 104800.45 4 timer set 6 EV_TIMEOUT_ENTERDATA 104800.45 4 tw PlayEnd 4 500656 104800.47 4 play end id=500656, (current ID) 104800.48 4 event EV_PLAY_FINISHED, iCode=8001 state=1301 104800.48 4 LsGetNbrsRxDigits EV_PLAY_FINISHED,EV_PLAY_FINISHED 104800.50 4 path {EV_PLAY_FINISHED} not found 104800.52 4 awaiting further dtmf input 104800.52 4 tw DialogicEvent 129,TDX_PLAY,500656,0,0,,, 104800.53 4 event TDX_PLAY, iCode=129 state=1301 104800.53 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 104800.55 4 path {TDX_PLAY} not found 104800.70 4 tw dtmf 1 (4,49,49) 104800.72 4 event 1, iCode=49 state=1301 104800.73 4 LsGetNbrsRxDigits 1,1 104800.73 4 state [Get Acc No] Number Input 01 104800.75 4 path {01} not found 104800.77 4 timer set 6 EV_TIMEOUT_ENTERDATA 104801.13 4 tw dtmf 7 (4,55,55) 104801.14 4 event 7, iCode=55 state=1301 104801.16 4 LsGetNbrsRxDigits 7,7 104801.16 4 state [Get Acc No] Number Input 017 104801.17 4 path {017} not found 104801.17 4 timer set 6 EV_TIMEOUT_ENTERDATA 104801.63 4 tw dtmf 3 (4,51,51) 104801.63 4 event 3, iCode=51 state=1301 104801.64 4 LsGetNbrsRxDigits 3,3 104801.66 4 state [Get Acc No] Number Input 0173 104801.66 4 path {0173} not found 104801.67 4 timer set 6 EV_TIMEOUT_ENTERDATA 104802.05 4 tw dtmf 4 (4,52,52) 104802.06 4 event 4, iCode=52 state=1301 104802.08 4 LsGetNbrsRxDigits 4,4 104802.08 4 state [Get Acc No] Number Input 01734 104802.09 4 path {01734} not found 104802.11 4 timer set 6 EV_TIMEOUT_ENTERDATA 104802.52 4 tw dtmf 0 (4,48,48) 104802.53 4 event 0, iCode=48 state=1301 104802.55 4 LsGetNbrsRxDigits 0,0 104802.55 4 state [Get Acc No] Number Input 017340 104802.56 4 path {017340} not found 104802.58 4 timer set 6 EV_TIMEOUT_ENTERDATA 104802.88 4 tw dtmf 0 (4,48,48) 104802.88 4 event 0, iCode=48 state=1301 104802.89 4 LsGetNbrsRxDigits 0,0 104802.91 4 state [Get Acc No] Number Input 0173400 104802.91 4 path {0173400} not found 104802.92 4 timer set 6 EV_TIMEOUT_ENTERDATA 104803.16 4 tw dtmf 0 (4,48,48) 104803.17 4 event 0, iCode=48 state=1301 104803.17 4 LsGetNbrsRxDigits 0,0 104803.19 4 state [Get Acc No] Number Input 01734000 104803.20 4 path {01734000} not found 104803.20 4 timer set 6 EV_TIMEOUT_ENTERDATA 104803.66 4 tw dtmf 2 (4,50,50) 104803.66 4 event 2, iCode=50 state=1301 104803.67 4 LsGetNbrsRxDigits 2,2 104803.67 4 state [Get Acc No] Number Input 017340002 104803.69 4 path {017340002} not found 104803.70 4 timer set 6 EV_TIMEOUT_ENTERDATA 104804.34 4 tw dtmf 5 (4,53,53) 104804.36 4 event 5, iCode=53 state=1301 104804.36 4 LsGetNbrsRxDigits 5,5 104804.38 4 state [Get Acc No] Number Input 0173400025 104804.39 4 path {0173400025} not found 104804.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 104810.86 4 timer fired EV_TIMEOUT_ENTERDATA 104810.86 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 104810.88 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 104810.88 4 path {EV_TIMEOUT_ENTERDATA} not found 104810.89 4 timer clear 104810.91 4 rv add [Get Acc No]{0173400025} 104810.91 4 len(0173400025) min=11, max=14, replays=0/1 104810.92 4 state [Get Acc No] Playing (Bangla Voice\11 digit Acc No.wav) 104810.94 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\11 digit Acc No.wav 104810.98 4 tw wav->vox convert end 515015,G:\TeleBanking System\Bangla Voice\11 digit Acc No.vox,1,0,, 104811.00 4 play start ok, lPlayId=515078 104814.83 4 tw PlayEnd 4 515078 104814.83 4 play end id=515078, (current ID) 104814.84 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 104814.84 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 104814.86 4 path {EV_PLAY_FINISHED} not found 104814.88 4 timer set 10 EV_TIMEOUT_HANGUP 104814.88 4 timer set 6 EV_TIMEOUT_ENTERDATA 104814.89 4 tw DialogicEvent 129,TDX_PLAY,515078,0,0,,, 104814.91 4 event TDX_PLAY, iCode=129 state=1301 104814.91 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 104814.92 4 path {TDX_PLAY} not found 104816.02 4 tw dtmf 0 (4,48,48) 104816.03 4 event 0, iCode=48 state=1301 104816.05 4 LsGetNbrsRxDigits 0,0 104816.05 4 state [Get Acc No] Number Input 0 104816.06 4 path {0} not found 104816.08 4 timer set 6 EV_TIMEOUT_ENTERDATA 104816.23 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 104816.25 4 event FAX, iCode=134 state=1301 104816.27 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 104816.27 4 path {FAX} not found 104816.28 4 event TDX_CST, iCode=134 state=1301 104816.28 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 104816.30 4 path {TDX_CST} not found 104816.53 4 tw dtmf 1 (4,49,49) 104816.53 4 event 1, iCode=49 state=1301 104816.55 4 LsGetNbrsRxDigits 1,1 104816.56 4 state [Get Acc No] Number Input 01 104816.56 4 path {01} not found 104816.58 4 timer set 6 EV_TIMEOUT_ENTERDATA 104816.97 4 tw dtmf 7 (4,55,55) 104816.98 4 event 7, iCode=55 state=1301 104816.98 4 LsGetNbrsRxDigits 7,7 104817.00 4 state [Get Acc No] Number Input 017 104817.02 4 path {017} not found 104817.02 4 timer set 6 EV_TIMEOUT_ENTERDATA 104817.48 4 tw dtmf 3 (4,51,51) 104817.50 4 event 3, iCode=51 state=1301 104817.50 4 LsGetNbrsRxDigits 3,3 104817.52 4 state [Get Acc No] Number Input 0173 104817.53 4 path {0173} not found 104817.53 4 timer set 6 EV_TIMEOUT_ENTERDATA 104817.91 4 tw dtmf 4 (4,52,52) 104817.92 4 event 4, iCode=52 state=1301 104817.92 4 LsGetNbrsRxDigits 4,4 104817.94 4 state [Get Acc No] Number Input 01734 104817.95 4 path {01734} not found 104817.95 4 timer set 6 EV_TIMEOUT_ENTERDATA 104818.13 4 tw DialogicEvent 134,TDX_CST,191,0,0,DE_TONEON,FAX, 104818.13 4 event FAX, iCode=134 state=1301 104818.14 4 LsGetNbrsRxDigits EV_UNKNOWN_134,FAX 104818.16 4 path {FAX} not found 104818.16 4 event TDX_CST, iCode=134 state=1301 104818.17 4 LsGetNbrsRxDigits EV_UNKNOWN_134,TDX_CST 104818.19 4 path {TDX_CST} not found 104818.34 4 tw dtmf 0 (4,48,48) 104818.36 4 event 0, iCode=48 state=1301 104818.38 4 LsGetNbrsRxDigits 0,0 104818.38 4 state [Get Acc No] Number Input 017340 104818.39 4 path {017340} not found 104818.41 4 timer set 6 EV_TIMEOUT_ENTERDATA 104818.66 4 tw dtmf 0 (4,48,48) 104818.66 4 event 0, iCode=48 state=1301 104818.67 4 LsGetNbrsRxDigits 0,0 104818.67 4 state [Get Acc No] Number Input 0173400 104818.69 4 path {0173400} not found 104818.70 4 timer set 6 EV_TIMEOUT_ENTERDATA 104818.94 4 tw dtmf 0 (4,48,48) 104818.95 4 event 0, iCode=48 state=1301 104818.95 4 LsGetNbrsRxDigits 0,0 104818.97 4 state [Get Acc No] Number Input 01734000 104818.98 4 path {01734000} not found 104818.98 4 timer set 6 EV_TIMEOUT_ENTERDATA 104819.59 4 tw dtmf 2 (4,50,50) 104819.61 4 event 2, iCode=50 state=1301 104819.63 4 LsGetNbrsRxDigits 2,2 104819.63 4 state [Get Acc No] Number Input 017340002 104819.64 4 path {017340002} not found 104819.64 4 timer set 6 EV_TIMEOUT_ENTERDATA 104819.97 4 tw dtmf 4 (4,52,52) 104819.98 4 event 4, iCode=52 state=1301 104819.98 4 LsGetNbrsRxDigits 4,4 104820.00 4 state [Get Acc No] Number Input 0173400024 104820.02 4 path {0173400024} not found 104820.02 4 timer set 6 EV_TIMEOUT_ENTERDATA 104820.30 4 tw dtmf 5 (4,53,53) 104820.30 4 event 5, iCode=53 state=1301 104820.31 4 LsGetNbrsRxDigits 5,5 104820.33 4 state [Get Acc No] Number Input 01734000245 104820.33 4 path {01734000245} not found 104820.34 4 timer set 6 EV_TIMEOUT_ENTERDATA 104826.81 4 timer fired EV_TIMEOUT_ENTERDATA 104826.81 4 event EV_TIMEOUT_ENTERDATA, iCode=9006 state=1301 104826.83 4 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA 104826.84 4 path {EV_TIMEOUT_ENTERDATA} not found 104826.84 4 timer clear 104826.86 4 rv add [Get Acc No]{01734000245} 104826.86 4 path {01734000245} not found 104826.88 4 next module is [Varify A/C] (idx=128) 104826.89 4 rvns add [Get Acc No_PathTaken]{success} 104826.89 4 fn RunModule start [Database Query,[Varify A/C],128,,] 104826.91 4 timer clear 104826.92 4 state [Varify A/C] DB Query 104826.92 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 104826.97 4 rv replace start: [sELECT actnum FROM stlbas.stfacmas WHERE actnum='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3)] 104826.98 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:47:53 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:47:54 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:47:54 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{0173400025}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success} 104826.98 4 db About to execute a Retrieve type operation [sELECT actnum FROM stlbas.stfacmas WHERE actnum='01734000245' AND brancd=SUBSTR('01734000245',1,3)] 104827.00 4 db [Varify A/C] row count=1 104827.02 4 rv add [Varify A/C_RowCount]{1} 104827.03 4 db get RecordsetGetRowsMax 104827.03 4 db get 999 records. (row count=1) 104827.05 4 db update RVs 104827.05 4 db about to close dbDbqDatabase 104827.06 4 db going down path [True] 104827.08 4 next module is [Get PIN No] (idx=84) 104827.08 4 fn RunModule start [Get Numbers,[Get PIN No],84,,] 104827.09 4 timer clear 104827.11 4 state [Get PIN No] Number Input 104827.11 4 state [Get PIN No] Playing (Bangla Voice\4 digit PIN Code.wav) 104827.13 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\4 digit PIN Code.wav 104827.19 4 tw wav->vox convert end 531203,G:\TeleBanking System\Bangla Voice\4 digit PIN Code.vox,1,0,, 104827.20 4 play start ok, lPlayId=531265 104830.53 4 tw PlayEnd 4 531265 104830.55 4 play end id=531265, (current ID) 104830.55 4 event EV_PLAY_FINISHED, iCode=8001 state=1300 104830.56 4 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 104830.56 4 path {EV_PLAY_FINISHED} not found 104830.58 4 timer set 7 EV_TIMEOUT_REPLAYMSG 104830.59 4 tw DialogicEvent 129,TDX_PLAY,531265,0,0,,, 104830.59 4 event TDX_PLAY, iCode=129 state=1301 104830.61 4 LsGetNbrsRxDigits EV_UNKNOWN_129,TDX_PLAY 104830.63 4 path {TDX_PLAY} not found 104830.80 4 tw dtmf 3 (4,51,51) 104830.80 4 event 3, iCode=51 state=1301 104830.81 4 LsGetNbrsRxDigits 3,3 104830.83 4 state [Get PIN No] Number Input 3 104830.83 4 path {3} not found 104830.84 4 timer set 6 EV_TIMEOUT_ENTERDATA 104831.34 4 tw dtmf 8 (4,56,56) 104831.36 4 event 8, iCode=56 state=1301 104831.36 4 LsGetNbrsRxDigits 8,8 104831.38 4 state [Get PIN No] Number Input 38 104831.39 4 path {38} not found 104831.39 4 timer set 6 EV_TIMEOUT_ENTERDATA 104831.73 4 tw dtmf 0 (4,48,48) 104831.73 4 event 0, iCode=48 state=1301 104831.75 4 LsGetNbrsRxDigits 0,0 104831.77 4 state [Get PIN No] Number Input 380 104831.77 4 path {380} not found 104831.78 4 timer set 6 EV_TIMEOUT_ENTERDATA 104832.31 4 tw dtmf 4 (4,52,52) 104832.33 4 event 4, iCode=52 state=1301 104832.34 4 LsGetNbrsRxDigits 4,4 104832.34 4 state [Get PIN No] Number Input 3804 104832.36 4 path {3804} not found 104832.38 4 timer set 6 EV_TIMEOUT_ENTERDATA 104832.38 4 timer clear 104832.39 4 rv add [Get PIN No]{3804} 104832.41 4 path {3804} not found 104832.41 4 next module is [Varify A/C No] (idx=60) 104832.42 4 rvns add [Get PIN No_PathTaken]{success} 104832.42 4 fn RunModule start [Database Query,[Varify A/C No],60,,] 104832.44 4 timer clear 104832.45 4 state [Varify A/C No] DB Query 104832.45 4 db ODBC mode used name:[] connect:[ODBC;DSN=ORBBAS;UID=stlbas;PWD=stlbas2000;] 104832.50 4 rv replace start: [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM='$RV[Get Acc No]' AND brancd=SUBSTR('$RV[Get Acc No]',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('$RV[Get Acc No]','$RV[Get PIN No]') AND USRSTS='Y'] 104832.50 4 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{01/10/2007 10:47:53 AM}[$RV_DEVICEID]{4}[DlgcNetworkResource]{dxxxB1C4}[DlgcVoiceResource]{dxxxB1C4} $RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{G:\TeleBanking System\}[$RV_CIDNUMBER]{}[scriptEnd_Time]{01/10/2007 10:47:54 AM}[scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs}[scriptEnd_Goto_Module]{Get Bangla}[scriptStart_Time]{01/10/2007 10:47:54 AM}[scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs}[scriptStart_CalledFrom_Module]{Get Language}[scriptsPath]{G:\TeleBanking System\}[Get Language]{1}[Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"}[Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice}[DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice}{1}[Get Acc No]{0173400025}[Get Acc No]{01734000245}[Get Acc No_PathTaken]{success}[Varify A/C_RowCount]{1}[Varify A/C_1_1]{01734000245}[Get PIN No]{3804}[Get PIN No_PathTaken]{success} 104832.52 4 db About to execute a Retrieve type operation [sELECT PINCOD FROM STUSRMAS WHERE ACTNUM=01734000245' AND brancd=SUBSTR('01734000245',1,3) AND PINCOD=DFN_CREATE_PASSWORD_ENCRYPTED('01734000245','3804') AND USRSTS='Y] 104832.53 4 db [Varify A/C No] row count=1 104832.55 4 rv add [Varify A/C No_RowCount]{1} 104832.55 4 db get RecordsetGetRowsMax 104832.56 4 db get 999 records. (row count=1) 104832.56 4 db update RVs 104832.58 4 db about to close dbDbqDatabase 104832.59 4 db going down path [True] 104832.61 4 next module is (idx=83) 104832.61 4 fn RunModule start [Play,,83,,] 104832.63 4 timer clear 104832.63 4 Play Module start 104832.64 4 state Playing 104832.66 4 state Playing (Bangla Voice\Acc List.wav) 104832.66 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Acc List.wav 104832.72 4 tw wav->vox convert end 536734,G:\TeleBanking System\Bangla Voice\Acc List.vox,1,0,, 104832.75 4 play start ok, lPlayId=536812 104845.38 4 tw PlayEnd 4 536812 104845.39 4 play end id=536812, (current ID) 104845.39 4 event EV_PLAY_FINISHED, iCode=8001 state=1100 104845.41 4 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED 104845.41 4 path {EV_PLAY_FINISHED} not found 104845.42 4 timer set 7 EV_TIMEOUT_REPLAYMSG 104845.44 4 tw DialogicEvent 129,TDX_PLAY,536812,0,0,,, 104845.44 4 event TDX_PLAY, iCode=129 state=1101 104845.45 4 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY 104845.47 4 path {TDX_PLAY} not found 104847.67 4 tw dtmf 1 (4,49,49) 104847.67 4 event 1, iCode=49 state=1101 104847.69 4 LsPlayMsgFinished 1,1 104847.70 4 next module is [say Bal 1] (idx=129) 104847.70 4 rv add {1} 104847.72 4 fn RunModule start [say Numbers,[say Bal 1],129,,] 104847.72 4 timer clear 104847.73 4 state [say Bal 1] Say numbers: 125 as Number 104847.75 4 fn PlaySoundStartNumbers [C:\Program Files\VoiceGuide\system\Bangla Voice\16 digit Credit Card No.wav],[],[125],Number 104847.75 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 104847.77 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 104847.78 4 rv add [Hangup Time]{01/10/2007 10:48:47 AM} 104847.78 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 104847.80 4 HangupCall_Common hCall=4 104847.81 4 rec RecSoundStop ok 104847.81 4 play PlayStop ok 104847.83 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 104847.84 4 fnHangupCall end 104847.88 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 104847.89 4 event TDX_SETHOOK, iCode=135 state=900 104847.91 4 LsAwaitingCalls EV_UNKNOWN_135 104847.91 4 event callstate IDLE 4 1,0,0 104847.92 4 WorkingMode@Idle= 104847.94 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 104847.94 4 timer clear 104847.95 4 rec RecSoundStop ok 104847.97 4 play PlayStop ok 104847.97 4 rv add [CallEndTime]{01/10/2007 10:48:47 AM} 104848.00 4 on-hangup script:[] 104848.02 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 104848.03 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 104848.03 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 104848.05 4 init atidle reinit : start 104848.05 4 init atidle reinit iConferenceOtherLegLid=-1 104848.06 4 init atidle reinit : reset all LineState variables 104848.08 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 104848.08 4 state Waiting for a call... 104850.28 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 104850.28 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 104850.30 4 setting iDialoutReadyToDialout = 1 105142.83 0 btn Hangup on line 1 105142.84 1 event EV_TIMEOUT_HANGUP, iCode=9001 state=0 105204.95 0 vm loading VMB data begin 105204.97 0 vm loading VMB data - about to delete old entries 105204.98 0 vm loading VMB data - sorting/ordering 105205.00 0 vm loading VMB data end 105205.02 0 Loaded new voicemail configuration file (XML) 105301.33 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105301.34 MemStructVgs_ClearVgs [3] 105301.34 load end 105301.36 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105301.38 0 Erasing Script (new loaded) Id 1 105301.39 0 VgsScriptFree [1] 105301.39 MemStructVgs_ClearVgs [1] 105320.41 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105320.42 MemStructVgs_ClearVgs [1] 105320.42 load end 105320.44 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 105320.45 0 Erasing Script (new loaded) Id 3 105320.47 0 VgsScriptFree [3] 105320.47 MemStructVgs_ClearVgs [3] 105451.50 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105451.52 MemStructVgs_ClearVgs [3] 105451.52 load end 105451.53 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105451.55 0 Erasing Script (new loaded) Id 1 105451.55 0 VgsScriptFree [1] 105451.56 MemStructVgs_ClearVgs [1] 105458.58 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105458.58 MemStructVgs_ClearVgs [1] 105458.59 load end 105458.61 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 105458.63 0 Erasing Script (new loaded) Id 3 105458.63 0 VgsScriptFree [3] 105458.64 MemStructVgs_ClearVgs [3] 105506.08 4 event callstate OFFERING 4 2,0,0 105506.08 4 script interpretor: VgMulti v6.0.3243 105506.09 4 fired OFFERING event to listeners 105506.16 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 105506.16 4 cid CallerID vars set (in 'offering' event) [,,] 105506.17 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 105506.19 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 105506.19 4 tw ring 1 105506.20 4 ring time since last ring event (sec): 0.00 105506.20 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 105506.22 4 should answer as number of rings reached 105506.23 4 rv clear all 105506.23 4 init LineState ResetAtStartOfNewCall. 105506.25 4 answering the call (,,,0) 105506.27 4 timer clear 105506.28 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105506.28 4 event TDX_CST, iCode=134 state=6001 105506.30 4 LsModuleTransition : 134, [TDX_CST] 105506.91 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 105506.92 4 event TDX_SETHOOK, iCode=135 state=6001 105506.92 4 LsModuleTransition : 135, [TDX_SETHOOK] 105506.94 4 event callstate CONNECTED 4 256,0,0 105506.95 4 LineEvCallState_Connected hDevice=4 params=256,0,0 105506.95 4 WorkingModes tapi= script= LineState().iState=6001 105506.97 4 Inband detection not enabled 105506.98 4 StartLoadedVgs at 01/10/2007 10:55:06 AM (VgMulti v6.0.3243) 105506.98 4 set LineState().iVgsIdx=1 105507.00 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 105507.00 4 init StartLoadedVgs_InitLineState start 105507.02 4 rv add [$RV_STARTTIME]{01/10/2007 10:55:06 AM} 105507.03 4 rv add [$RV_DEVICEID]{4} 105507.03 4 rv add [DlgcNetworkResource]{dxxxB1C4} 105507.05 4 rv add [DlgcVoiceResource]{dxxxB1C4} 105507.06 4 rv add [$RV_CIDNAME]{} 105507.06 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 105507.08 4 rvns add [scriptsPath]{G:\TeleBanking System\} 105507.08 4 rv add [$RV_CIDNUMBER]{} 105507.09 4 fn RunModule start [Play,[Get Language],91,,] 105507.11 4 tw DialogicEvent 134,TDX_CST,37902,0,0,DE_LCON,, 105507.11 4 event TDX_CST, iCode=134 state=6001 105507.13 4 LsModuleTransition : 134, [TDX_CST] 105507.14 4 timer clear 105507.14 4 Play Module start 105507.16 4 state [Get Language] Playing 105507.17 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 105507.17 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 105507.19 4 tw wav->vox convert end 931250,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 105507.22 4 play start ok, lPlayId=931281 105507.80 4 tw dtmf 3 (4,51,51) 105507.80 4 event 3, iCode=51 state=1100 105507.81 4 LsPlayMsg 3,3 105507.83 4 next module is [say Bal 1] (idx=1) 105507.84 4 play PlayStop ok 105507.86 4 rv add [Get Language]{3} 105507.86 4 fn RunModule start [say Numbers,[say Bal 1],1,,] 105507.88 4 tw PlayEnd 4 931281 105507.88 4 play end id=931281, (current ID) 105507.89 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 105507.91 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 105507.91 4 tw DialogicEvent 129,TDX_PLAY,931281,0,0,,, 105507.92 4 event TDX_PLAY, iCode=129 state=6001 105507.94 4 LsModuleTransition : 129, [TDX_PLAY] 105507.94 4 timer clear 105507.95 4 state [say Bal 1] Say numbers: 200 as Number 105507.95 4 fn PlaySoundStartNumbers [],[],[200],Number 105507.97 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 105507.98 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 105507.98 4 rv add [Hangup Time]{01/10/2007 10:55:07 AM} 105508.00 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 105508.02 4 HangupCall_Common hCall=4 105508.02 4 rec RecSoundStop ok 105508.03 4 play PlayStop ok 105508.05 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 105508.05 4 fnHangupCall end 105508.86 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 105508.86 4 event TDX_SETHOOK, iCode=135 state=900 105508.88 4 LsAwaitingCalls EV_UNKNOWN_135 105508.89 4 event callstate IDLE 4 1,0,0 105508.89 4 WorkingMode@Idle= 105508.91 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 105508.92 4 timer clear 105508.92 4 rec RecSoundStop ok 105508.94 4 play PlayStop ok 105508.94 4 rv add [CallEndTime]{01/10/2007 10:55:08 AM} 105508.98 4 on-hangup script:[] 105508.98 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 105509.00 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 105509.00 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 105509.02 4 init atidle reinit : start 105509.03 4 init atidle reinit iConferenceOtherLegLid=-1 105509.03 4 init atidle reinit : reset all LineState variables 105509.05 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 105509.06 4 state Waiting for a call... 105511.25 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 105511.25 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 105511.27 4 setting iDialoutReadyToDialout = 1 105518.75 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105518.75 MemStructVgs_ClearVgs [3] 105518.77 load end 105518.78 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105518.80 0 Erasing Script (new loaded) Id 1 105518.80 0 VgsScriptFree [1] 105518.81 MemStructVgs_ClearVgs [1] 105623.84 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105623.84 MemStructVgs_ClearVgs [1] 105623.86 load end 105623.88 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 105623.89 0 Erasing Script (new loaded) Id 3 105623.89 0 VgsScriptFree [3] 105623.91 MemStructVgs_ClearVgs [3] 105635.92 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105635.94 MemStructVgs_ClearVgs [3] 105635.95 load end 105635.97 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105635.98 0 Erasing Script (new loaded) Id 1 105635.98 0 VgsScriptFree [1] 105636.00 MemStructVgs_ClearVgs [1] 105718.38 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105718.38 MemStructVgs_ClearVgs [1] 105718.39 load end 105718.41 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 105718.42 0 Erasing Script (new loaded) Id 3 105718.44 0 VgsScriptFree [3] 105718.44 MemStructVgs_ClearVgs [3] 105721.45 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105721.47 MemStructVgs_ClearVgs [3] 105721.48 load end 105721.50 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105721.50 0 Erasing Script (new loaded) Id 1 105721.52 0 VgsScriptFree [1] 105721.53 MemStructVgs_ClearVgs [1] 105725.55 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105725.55 MemStructVgs_ClearVgs [1] 105725.56 load end 105725.58 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 105725.59 0 Erasing Script (new loaded) Id 3 105725.59 0 VgsScriptFree [3] 105725.61 MemStructVgs_ClearVgs [3] 105736.78 4 event callstate OFFERING 4 2,0,0 105736.80 4 script interpretor: VgMulti v6.0.3243 105736.80 4 fired OFFERING event to listeners 105736.81 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 105736.83 4 cid CallerID vars set (in 'offering' event) [,,] 105736.83 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 105736.84 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 105736.86 4 tw ring 1 105736.86 4 ring time since last ring event (sec): 0.00 105736.88 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 105736.88 4 should answer as number of rings reached 105736.89 4 rv clear all 105736.91 4 init LineState ResetAtStartOfNewCall. 105736.91 4 answering the call (,,,0) 105736.92 4 timer clear 105736.94 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105736.94 4 event TDX_CST, iCode=134 state=6001 105736.95 4 LsModuleTransition : 134, [TDX_CST] 105737.56 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 105737.58 4 event TDX_SETHOOK, iCode=135 state=6001 105737.59 4 LsModuleTransition : 135, [TDX_SETHOOK] 105737.59 4 event callstate CONNECTED 4 256,0,0 105737.61 4 LineEvCallState_Connected hDevice=4 params=256,0,0 105737.61 4 WorkingModes tapi= script= LineState().iState=6001 105737.63 4 Inband detection not enabled 105737.64 4 StartLoadedVgs at 01/10/2007 10:57:37 AM (VgMulti v6.0.3243) 105737.64 4 set LineState().iVgsIdx=1 105737.66 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 105737.67 4 init StartLoadedVgs_InitLineState start 105737.67 4 rv add [$RV_STARTTIME]{01/10/2007 10:57:37 AM} 105737.69 4 rv add [$RV_DEVICEID]{4} 105737.70 4 rv add [DlgcNetworkResource]{dxxxB1C4} 105737.70 4 rv add [DlgcVoiceResource]{dxxxB1C4} 105737.72 4 rv add [$RV_CIDNAME]{} 105737.72 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 105737.73 4 rvns add [scriptsPath]{G:\TeleBanking System\} 105737.75 4 rv add [$RV_CIDNUMBER]{} 105737.75 4 fn RunModule start [Play,[Get Language],1,,] 105737.77 4 tw DialogicEvent 134,TDX_CST,14871,0,0,DE_LCON,, 105737.78 4 event TDX_CST, iCode=134 state=6001 105737.78 4 LsModuleTransition : 134, [TDX_CST] 105737.80 4 timer clear 105737.81 4 Play Module start 105737.81 4 state [Get Language] Playing 105737.83 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 105737.83 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 105737.86 4 tw wav->vox convert end 81906,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 105737.88 4 play start ok, lPlayId=81953 105739.64 4 tw dtmf 1 (4,49,49) 105739.66 4 event 1, iCode=49 state=1100 105739.66 4 LsPlayMsg 1,1 105739.67 4 rv add [scriptEnd_Time]{01/10/2007 10:57:39 AM} 105739.69 4 rv add [scriptEnd_Goto_Script]{G:\TeleBanking System\Tele Banking_Ban.vgs} 105739.69 4 rv add [scriptEnd_Goto_Module]{Get Bangla} 105739.72 4 rv add [scriptStart_Time]{01/10/2007 10:57:39 AM} 105739.73 4 rv add [scriptStart_CalledFrom_Script]{G:\TeleBanking System\Tele Banking_Main.vgs} 105739.75 4 rv add [scriptStart_CalledFrom_Module]{Get Language} 105739.75 4 FindFullPathToScript_VgsOrVgp start [G:\TeleBanking System\Tele Banking_Ban.vgs] 105739.77 0 LoadedVgs_Find G:\TeleBanking System\Tele Banking_Ban.vgs at idx=4 105739.78 4 rvns add [scriptsPath]{G:\TeleBanking System\} 105739.80 4 play PlayStop ok 105739.81 4 rv add [Get Language]{1} 105739.81 4 fn RunModule start [Evaluate,[Get Bangla],64,,] 105739.83 4 tw PlayEnd 4 81953 105739.84 4 play end id=81953, (current ID) 105739.84 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 105739.86 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 105739.86 4 tw DialogicEvent 129,TDX_PLAY,81953,0,0,,, 105739.88 4 event TDX_PLAY, iCode=129 state=6001 105739.89 4 LsModuleTransition : 129, [TDX_PLAY] 105739.89 4 timer clear 105739.91 4 state [Get Bangla] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 105739.92 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 105739.92 4 rvns add [Get Bangla_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 105739.94 4 rvns add [Get Bangla]{C:\Program Files\VoiceGuide\System\Bangla Voice} 105739.95 4 rvns add [DIRSYSTEMVOICE]{C:\Program Files\VoiceGuide\System\Bangla Voice} 105739.95 4 $RV[DIRSYSTEMVOICE] = [C:\Program Files\VoiceGuide\System\Bangla Voice\] 105739.97 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] stored in $RV[DIRSYSTEMVOICE] 105739.98 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 105739.98 4 matching path not found 105740.00 4 next module is (idx=63) 105740.00 4 matching path was found 105740.02 4 fn RunModule start [Play,,63,,] 105740.03 4 timer clear 105740.03 4 Play Module start 105740.05 4 state Playing 105740.06 4 state Playing (Bangla Voice\Service List.wav) 105740.06 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Service List.wav 105740.11 4 tw wav->vox convert end 84140,G:\TeleBanking System\Bangla Voice\Service List.vox,1,0,, 105740.13 4 play start ok, lPlayId=84187 105745.78 4 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,DISCONNECT_TAPI2, 105745.80 4 event DISCONNECT_TAPI2, iCode=134 state=1100 105745.81 4 LsPlayMsg EV_UNKNOWN_134,DISCONNECT_TAPI2 105745.81 4 path {DISCONNECT_TAPI2} not found 105745.83 4 HangupCall start (Default Handler 20: DISCONNECT_TAPI2) 105745.83 4 rv add [Hangup Time]{01/10/2007 10:57:45 AM} 105745.84 4 state Hanging up call... [Default Handler 20: DISCONNECT_TAPI2] 105745.86 4 HangupCall_Common hCall=4 105745.88 4 rec RecSoundStop ok 105745.89 4 play PlayStop ok 105745.91 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 105745.91 4 fnHangupCall end 105745.92 4 event TDX_CST, iCode=134 state=900 105745.94 4 LsAwaitingCalls EV_UNKNOWN_134 105745.94 4 tw PlayEnd 4 84187 105745.95 4 play end id=84187, (current ID) 105745.97 4 event EV_PLAY_FINISHED, iCode=8001 state=900 105745.97 4 LsAwaitingCalls EV_PLAY_FINISHED 105745.98 4 tw DialogicEvent 129,TDX_PLAY,84187,0,0,,, 105746.00 4 event TDX_PLAY, iCode=129 state=900 105746.00 4 LsAwaitingCalls EV_UNKNOWN_129 105746.02 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 105746.02 4 event TDX_SETHOOK, iCode=135 state=900 105746.03 4 LsAwaitingCalls EV_UNKNOWN_135 105746.05 4 event callstate IDLE 4 1,0,0 105746.05 4 WorkingMode@Idle= 105746.06 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 105746.08 4 timer clear 105746.08 4 rec RecSoundStop ok 105746.09 4 play PlayStop ok 105746.11 4 rv add [CallEndTime]{01/10/2007 10:57:46 AM} 105746.14 4 on-hangup script:[] 105746.14 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 105746.16 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 105746.17 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 105746.17 4 init atidle reinit : start 105746.19 4 init atidle reinit iConferenceOtherLegLid=-1 105746.20 4 init atidle reinit : reset all LineState variables 105746.20 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 105746.22 4 state Waiting for a call... 105748.42 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 105748.42 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 105748.44 4 setting iDialoutReadyToDialout = 1 105749.91 4 event callstate OFFERING 4 2,0,0 105749.92 4 script interpretor: VgMulti v6.0.3243 105749.92 4 fired OFFERING event to listeners 105749.94 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 105749.95 4 cid CallerID vars set (in 'offering' event) [,,] 105749.95 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 105749.97 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 105749.98 4 tw ring 1 105749.98 4 ring time since last ring event (sec): 0.00 105750.00 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 105750.00 4 should answer as number of rings reached 105750.02 4 rv clear all 105750.03 4 init LineState ResetAtStartOfNewCall. 105750.03 4 answering the call (,,,0) 105750.05 4 timer clear 105750.06 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 105750.08 4 event TDX_CST, iCode=134 state=6001 105750.08 4 LsModuleTransition : 134, [TDX_CST] 105750.69 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 105750.70 4 event TDX_SETHOOK, iCode=135 state=6001 105750.70 4 LsModuleTransition : 135, [TDX_SETHOOK] 105750.72 4 event callstate CONNECTED 4 256,0,0 105750.73 4 LineEvCallState_Connected hDevice=4 params=256,0,0 105750.73 4 WorkingModes tapi= script= LineState().iState=6001 105750.75 4 Inband detection not enabled 105750.77 4 StartLoadedVgs at 01/10/2007 10:57:50 AM (VgMulti v6.0.3243) 105750.77 4 set LineState().iVgsIdx=1 105750.78 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 105750.80 4 init StartLoadedVgs_InitLineState start 105750.80 4 rv add [$RV_STARTTIME]{01/10/2007 10:57:50 AM} 105750.81 4 rv add [$RV_DEVICEID]{4} 105750.81 4 rv add [DlgcNetworkResource]{dxxxB1C4} 105750.83 4 rv add [DlgcVoiceResource]{dxxxB1C4} 105750.84 4 rv add [$RV_CIDNAME]{} 105750.84 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 105750.86 4 rvns add [scriptsPath]{G:\TeleBanking System\} 105750.88 4 rv add [$RV_CIDNUMBER]{} 105750.88 4 fn RunModule start [Play,[Get Language],1,,] 105750.89 4 tw DialogicEvent 134,TDX_CST,473,0,0,DE_LCON,, 105750.89 4 event TDX_CST, iCode=134 state=6001 105750.91 4 LsModuleTransition : 134, [TDX_CST] 105750.92 4 timer clear 105750.92 4 Play Module start 105750.94 4 state [Get Language] Playing 105750.95 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 105750.95 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 105750.97 4 tw wav->vox convert end 95031,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 105750.98 4 play start ok, lPlayId=95062 105751.80 4 tw dtmf 3 (4,51,51) 105751.81 4 event 3, iCode=51 state=1100 105751.81 4 LsPlayMsg 3,3 105751.83 4 next module is [GetData] (idx=93) 105751.84 4 play PlayStop ok 105751.86 4 rv add [Get Language]{3} 105751.86 4 fn RunModule start [Evaluate,[GetData],93,,] 105751.88 4 tw PlayEnd 4 95062 105751.89 4 play end id=95062, (current ID) 105751.89 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 105751.91 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 105751.92 4 tw DialogicEvent 129,TDX_PLAY,95062,0,0,,, 105751.92 4 event TDX_PLAY, iCode=129 state=6001 105751.94 4 LsModuleTransition : 129, [TDX_PLAY] 105751.95 4 timer clear 105751.95 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 105751.97 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 105751.98 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 105751.98 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice} 105752.00 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] 105752.00 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 105752.02 4 matching path not found 105752.03 4 next module is [say Bal 1] (idx=91) 105752.03 4 matching path was found 105752.05 4 fn RunModule start [say Numbers,[say Bal 1],91,,] 105752.06 4 timer clear 105752.06 4 state [say Bal 1] Say numbers: 200 as Number 105752.08 4 fn PlaySoundStartNumbers [],[],[200],Number 105752.09 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 105752.09 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 105752.11 4 rv add [Hangup Time]{01/10/2007 10:57:52 AM} 105752.13 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 105752.13 4 HangupCall_Common hCall=4 105752.14 4 rec RecSoundStop ok 105752.16 4 play PlayStop ok 105752.16 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 105752.17 4 fnHangupCall end 105752.64 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 105752.66 4 event TDX_SETHOOK, iCode=135 state=900 105752.67 4 LsAwaitingCalls EV_UNKNOWN_135 105752.67 4 event callstate IDLE 4 1,0,0 105752.69 4 WorkingMode@Idle= 105752.69 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 105752.70 4 timer clear 105752.72 4 rec RecSoundStop ok 105752.73 4 play PlayStop ok 105752.73 4 rv add [CallEndTime]{01/10/2007 10:57:52 AM} 105752.77 4 on-hangup script:[] 105752.78 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 105752.78 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 105752.80 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 105752.81 4 init atidle reinit : start 105752.81 4 init atidle reinit iConferenceOtherLegLid=-1 105752.83 4 init atidle reinit : reset all LineState variables 105752.84 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 105752.84 4 state Waiting for a call... 105755.05 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 105755.05 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 105755.06 4 setting iDialoutReadyToDialout = 1 105844.23 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105844.23 MemStructVgs_ClearVgs [3] 105844.25 load end 105844.27 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105844.28 0 Erasing Script (new loaded) Id 1 105844.28 0 VgsScriptFree [1] 105844.30 MemStructVgs_ClearVgs [1] 105905.31 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105905.31 MemStructVgs_ClearVgs [1] 105905.33 load end 105905.34 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 105905.36 0 Erasing Script (new loaded) Id 3 105905.36 0 VgsScriptFree [3] 105905.38 MemStructVgs_ClearVgs [3] 105909.38 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105909.38 MemStructVgs_ClearVgs [3] 105909.39 load end 105909.41 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105909.42 0 Erasing Script (new loaded) Id 1 105909.42 0 VgsScriptFree [1] 105909.44 MemStructVgs_ClearVgs [1] 105913.44 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105913.44 MemStructVgs_ClearVgs [1] 105913.45 load end 105913.47 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 105913.48 0 Erasing Script (new loaded) Id 3 105913.48 0 VgsScriptFree [3] 105913.50 MemStructVgs_ClearVgs [3] 105915.52 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105915.52 MemStructVgs_ClearVgs [3] 105915.53 load end 105915.55 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105915.56 0 Erasing Script (new loaded) Id 1 105915.56 0 VgsScriptFree [1] 105915.58 MemStructVgs_ClearVgs [1] 105917.59 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105917.59 MemStructVgs_ClearVgs [1] 105917.61 load end 105917.63 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 105917.64 0 Erasing Script (new loaded) Id 3 105917.64 0 VgsScriptFree [3] 105917.66 MemStructVgs_ClearVgs [3] 105919.67 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105919.67 MemStructVgs_ClearVgs [3] 105919.69 load end 105919.70 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105919.72 0 Erasing Script (new loaded) Id 1 105919.72 0 VgsScriptFree [1] 105919.73 MemStructVgs_ClearVgs [1] 105922.73 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105922.73 MemStructVgs_ClearVgs [1] 105922.75 load end 105922.77 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 105922.77 0 Erasing Script (new loaded) Id 3 105922.78 0 VgsScriptFree [3] 105922.80 MemStructVgs_ClearVgs [3] 105926.80 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 105926.80 MemStructVgs_ClearVgs [3] 105926.81 load end 105926.83 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 105926.84 0 Erasing Script (new loaded) Id 1 105926.86 0 VgsScriptFree [1] 105926.86 MemStructVgs_ClearVgs [1] 110035.50 4 event callstate OFFERING 4 2,0,0 110035.52 4 script interpretor: VgMulti v6.0.3243 110035.52 4 fired OFFERING event to listeners 110035.53 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 110035.53 4 cid CallerID vars set (in 'offering' event) [,,] 110035.55 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 110035.56 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 110035.56 4 tw ring 1 110035.58 4 ring time since last ring event (sec): 0.00 110035.59 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 110035.59 4 should answer as number of rings reached 110035.61 4 rv clear all 110035.63 4 init LineState ResetAtStartOfNewCall. 110035.63 4 answering the call (,,,0) 110035.64 4 timer clear 110035.66 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110035.67 4 event TDX_CST, iCode=134 state=6001 110035.67 4 LsModuleTransition : 134, [TDX_CST] 110036.28 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 110036.30 4 event TDX_SETHOOK, iCode=135 state=6001 110036.31 4 LsModuleTransition : 135, [TDX_SETHOOK] 110036.31 4 event callstate CONNECTED 4 256,0,0 110036.33 4 LineEvCallState_Connected hDevice=4 params=256,0,0 110036.34 4 WorkingModes tapi= script= LineState().iState=6001 110036.34 4 Inband detection not enabled 110036.36 4 StartLoadedVgs at 01/10/2007 11:00:36 AM (VgMulti v6.0.3243) 110036.38 4 set LineState().iVgsIdx=3 110036.38 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 110036.39 4 init StartLoadedVgs_InitLineState start 110036.41 4 rv add [$RV_STARTTIME]{01/10/2007 11:00:36 AM} 110036.41 4 rv add [$RV_DEVICEID]{4} 110036.42 4 rv add [DlgcNetworkResource]{dxxxB1C4} 110036.42 4 rv add [DlgcVoiceResource]{dxxxB1C4} 110036.44 4 rv add [$RV_CIDNAME]{} 110036.45 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 110036.45 4 rvns add [scriptsPath]{G:\TeleBanking System\} 110036.47 4 rv add [$RV_CIDNUMBER]{} 110036.48 4 fn RunModule start [Play,[Get Language],89,,] 110036.48 4 tw DialogicEvent 134,TDX_CST,16364,0,0,DE_LCON,, 110036.50 4 event TDX_CST, iCode=134 state=6001 110036.52 4 LsModuleTransition : 134, [TDX_CST] 110036.53 4 timer clear 110036.53 4 Play Module start 110036.55 4 state [Get Language] Playing 110036.56 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 110036.56 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 110036.63 4 tw wav->vox convert end 260640,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 110036.64 4 play start ok, lPlayId=260718 110037.47 4 tw dtmf 3 (4,51,51) 110037.48 4 event 3, iCode=51 state=1100 110037.48 4 LsPlayMsg 3,3 110037.50 4 next module is [GetData] (idx=96) 110037.52 4 play PlayStop ok 110037.53 4 rv add [Get Language]{3} 110037.55 4 fn RunModule start [Evaluate,[GetData],96,,] 110037.55 4 tw PlayEnd 4 260718 110037.56 4 play end id=260718, (current ID) 110037.56 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 110037.58 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 110037.59 4 tw DialogicEvent 129,TDX_PLAY,260718,0,0,,, 110037.59 4 event TDX_PLAY, iCode=129 state=6001 110037.61 4 LsModuleTransition : 129, [TDX_PLAY] 110037.63 4 timer clear 110037.64 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 110037.66 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 110037.66 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 110037.67 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice} 110037.67 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] 110037.69 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 110037.70 4 matching path not found 110037.70 4 next module is [say Bal 1] (idx=94) 110037.72 4 matching path was found 110037.73 4 fn RunModule start [say Numbers,[say Bal 1],94,,] 110037.73 4 timer clear 110037.75 4 state [say Bal 1] Say numbers: 200 as Number 110037.77 4 fn PlaySoundStartNumbers [],[],[200],Number 110037.77 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 110037.78 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 110037.80 4 rv add [Hangup Time]{01/10/2007 11:00:37 AM} 110037.80 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 110037.81 4 HangupCall_Common hCall=4 110037.83 4 rec RecSoundStop ok 110037.83 4 play PlayStop ok 110037.84 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 110037.86 4 fnHangupCall end 110038.23 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 110038.25 4 event TDX_SETHOOK, iCode=135 state=900 110038.25 4 LsAwaitingCalls EV_UNKNOWN_135 110038.27 4 event callstate IDLE 4 1,0,0 110038.27 4 WorkingMode@Idle= 110038.28 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 110038.30 4 timer clear 110038.30 4 rec RecSoundStop ok 110038.31 4 play PlayStop ok 110038.33 4 rv add [CallEndTime]{01/10/2007 11:00:38 AM} 110038.36 4 on-hangup script:[] 110038.38 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 110038.38 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 110038.39 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 110038.41 4 init atidle reinit : start 110038.41 4 init atidle reinit iConferenceOtherLegLid=-1 110038.42 4 init atidle reinit : reset all LineState variables 110038.42 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 110038.44 4 state Waiting for a call... 110040.64 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 110040.64 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 110040.66 4 setting iDialoutReadyToDialout = 1 110145.19 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 110145.19 MemStructVgs_ClearVgs [1] 110145.20 load end 110145.22 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 110145.23 0 Erasing Script (new loaded) Id 3 110145.23 0 VgsScriptFree [3] 110145.25 MemStructVgs_ClearVgs [3] 110205.28 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 110205.28 MemStructVgs_ClearVgs [3] 110205.30 load end 110205.31 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 110205.33 0 Erasing Script (new loaded) Id 1 110205.33 0 VgsScriptFree [1] 110205.34 MemStructVgs_ClearVgs [1] 110212.34 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 110212.34 MemStructVgs_ClearVgs [1] 110212.36 load end 110212.38 loaded Script Id 1: G:\TeleBanking System\Tele Banking_Main.vgs 110212.39 0 Erasing Script (new loaded) Id 3 110212.41 0 VgsScriptFree [3] 110212.41 MemStructVgs_ClearVgs [3] 110219.69 4 event callstate OFFERING 4 2,0,0 110219.70 4 script interpretor: VgMulti v6.0.3243 110219.72 4 fired OFFERING event to listeners 110219.72 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 110219.73 4 cid CallerID vars set (in 'offering' event) [,,] 110219.75 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 110219.75 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 110219.77 4 tw ring 1 110219.78 4 ring time since last ring event (sec): 0.00 110219.78 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 110219.80 4 should answer as number of rings reached 110219.81 4 rv clear all 110219.81 4 init LineState ResetAtStartOfNewCall. 110219.83 4 answering the call (,,,0) 110219.83 4 timer clear 110219.84 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110219.86 4 event TDX_CST, iCode=134 state=6001 110219.88 4 LsModuleTransition : 134, [TDX_CST] 110220.48 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 110220.50 4 event TDX_SETHOOK, iCode=135 state=6001 110220.50 4 LsModuleTransition : 135, [TDX_SETHOOK] 110220.52 4 event callstate CONNECTED 4 256,0,0 110220.53 4 LineEvCallState_Connected hDevice=4 params=256,0,0 110220.53 4 WorkingModes tapi= script= LineState().iState=6001 110220.55 4 Inband detection not enabled 110220.56 4 StartLoadedVgs at 01/10/2007 11:02:20 AM (VgMulti v6.0.3243) 110220.56 4 set LineState().iVgsIdx=1 110220.58 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 110220.58 4 init StartLoadedVgs_InitLineState start 110220.59 4 rv add [$RV_STARTTIME]{01/10/2007 11:02:20 AM} 110220.61 4 rv add [$RV_DEVICEID]{4} 110220.61 4 rv add [DlgcNetworkResource]{dxxxB1C4} 110220.63 4 rv add [DlgcVoiceResource]{dxxxB1C4} 110220.64 4 rv add [$RV_CIDNAME]{} 110220.64 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 110220.66 4 rvns add [scriptsPath]{G:\TeleBanking System\} 110220.67 4 rv add [$RV_CIDNUMBER]{} 110220.67 4 fn RunModule start [Play,[Get Language],1,,] 110220.69 4 tw DialogicEvent 134,TDX_CST,10225,0,0,DE_LCON,, 110220.70 4 event TDX_CST, iCode=134 state=6001 110220.70 4 LsModuleTransition : 134, [TDX_CST] 110220.72 4 timer clear 110220.73 4 Play Module start 110220.73 4 state [Get Language] Playing 110220.75 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 110220.77 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 110220.78 4 tw wav->vox convert end 364843,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 110220.80 4 play start ok, lPlayId=364859 110221.98 4 tw dtmf 3 (4,51,51) 110221.98 4 event 3, iCode=51 state=1100 110222.00 4 LsPlayMsg 3,3 110222.02 4 next module is [GetData] (idx=93) 110222.03 4 play PlayStop ok 110222.03 4 rv add [Get Language]{3} 110222.05 4 fn RunModule start [Evaluate,[GetData],93,,] 110222.06 4 tw PlayEnd 4 364859 110222.06 4 play end id=364859, (current ID) 110222.08 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 110222.09 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 110222.09 4 tw DialogicEvent 129,TDX_PLAY,364859,0,0,,, 110222.11 4 event TDX_PLAY, iCode=129 state=6001 110222.13 4 LsModuleTransition : 129, [TDX_PLAY] 110222.14 4 timer clear 110222.14 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 110222.16 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 110222.17 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 110222.17 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice} 110222.19 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] 110222.20 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 110222.20 4 matching path not found 110222.22 4 next module is [say Bal 1] (idx=91) 110222.23 4 matching path was found 110222.23 4 fn RunModule start [say Numbers,[say Bal 1],91,,] 110222.25 4 timer clear 110222.27 4 state [say Bal 1] Say numbers: ARIF as Digits 110222.27 4 fn PlaySoundStartNumbers [],[],[ARIF],Digits 110222.28 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 110222.30 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 110222.30 4 rv add [Hangup Time]{01/10/2007 11:02:22 AM} 110222.31 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 110222.33 4 HangupCall_Common hCall=4 110222.33 4 rec RecSoundStop ok 110222.34 4 play PlayStop ok 110222.36 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 110222.36 4 fnHangupCall end 110222.44 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 110222.44 4 event TDX_SETHOOK, iCode=135 state=900 110222.45 4 LsAwaitingCalls EV_UNKNOWN_135 110222.47 4 event callstate IDLE 4 1,0,0 110222.47 4 WorkingMode@Idle= 110222.48 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 110222.50 4 timer clear 110222.50 4 rec RecSoundStop ok 110222.52 4 play PlayStop ok 110222.53 4 rv add [CallEndTime]{01/10/2007 11:02:22 AM} 110222.56 4 on-hangup script:[] 110222.58 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 110222.58 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 110222.59 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 110222.61 4 init atidle reinit : start 110222.61 4 init atidle reinit iConferenceOtherLegLid=-1 110222.63 4 init atidle reinit : reset all LineState variables 110222.63 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 110222.64 4 state Waiting for a call... 110224.84 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 110224.84 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 110224.86 4 setting iDialoutReadyToDialout = 1 110240.17 4 event callstate OFFERING 4 2,0,0 110240.19 4 script interpretor: VgMulti v6.0.3243 110240.20 4 fired OFFERING event to listeners 110240.20 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 110240.22 4 cid CallerID vars set (in 'offering' event) [,,] 110240.23 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 110240.23 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 110240.25 4 tw ring 1 110240.27 4 ring time since last ring event (sec): 0.00 110240.27 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 110240.28 4 should answer as number of rings reached 110240.30 4 rv clear all 110240.30 4 init LineState ResetAtStartOfNewCall. 110240.31 4 answering the call (,,,0) 110240.33 4 timer clear 110240.34 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110240.36 4 event TDX_CST, iCode=134 state=6001 110240.36 4 LsModuleTransition : 134, [TDX_CST] 110240.97 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 110240.98 4 event TDX_SETHOOK, iCode=135 state=6001 110240.98 4 LsModuleTransition : 135, [TDX_SETHOOK] 110241.00 4 event callstate CONNECTED 4 256,0,0 110241.02 4 LineEvCallState_Connected hDevice=4 params=256,0,0 110241.02 4 WorkingModes tapi= script= LineState().iState=6001 110241.03 4 Inband detection not enabled 110241.05 4 StartLoadedVgs at 01/10/2007 11:02:41 AM (VgMulti v6.0.3243) 110241.05 4 set LineState().iVgsIdx=1 110241.06 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 110241.08 4 init StartLoadedVgs_InitLineState start 110241.08 4 rv add [$RV_STARTTIME]{01/10/2007 11:02:41 AM} 110241.09 4 rv add [$RV_DEVICEID]{4} 110241.11 4 rv add [DlgcNetworkResource]{dxxxB1C4} 110241.11 4 rv add [DlgcVoiceResource]{dxxxB1C4} 110241.13 4 rv add [$RV_CIDNAME]{} 110241.14 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 110241.14 4 rvns add [scriptsPath]{G:\TeleBanking System\} 110241.16 4 rv add [$RV_CIDNUMBER]{} 110241.16 4 fn RunModule start [Play,[Get Language],1,,] 110241.17 4 tw DialogicEvent 134,TDX_CST,1854,0,0,DE_LCON,, 110241.19 4 event TDX_CST, iCode=134 state=6001 110241.19 4 LsModuleTransition : 134, [TDX_CST] 110241.22 4 timer clear 110241.22 4 Play Module start 110241.23 4 state [Get Language] Playing 110241.25 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 110241.25 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 110241.30 4 tw wav->vox convert end 385328,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 110241.31 4 play start ok, lPlayId=385375 110244.08 4 tw dtmf 3 (4,51,51) 110244.09 4 event 3, iCode=51 state=1100 110244.11 4 LsPlayMsg 3,3 110244.11 4 next module is [GetData] (idx=93) 110244.13 4 play PlayStop ok 110244.14 4 rv add [Get Language]{3} 110244.16 4 fn RunModule start [Evaluate,[GetData],93,,] 110244.16 4 tw PlayEnd 4 385375 110244.17 4 play end id=385375, (current ID) 110244.19 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 110244.19 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 110244.20 4 tw DialogicEvent 129,TDX_PLAY,385375,0,0,,, 110244.22 4 event TDX_PLAY, iCode=129 state=6001 110244.22 4 LsModuleTransition : 129, [TDX_PLAY] 110244.23 4 timer clear 110244.25 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 110244.27 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 110244.27 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 110244.28 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice} 110244.30 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] 110244.30 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 110244.31 4 matching path not found 110244.33 4 next module is [say Bal 1] (idx=91) 110244.33 4 matching path was found 110244.34 4 fn RunModule start [say Numbers,[say Bal 1],91,,] 110244.36 4 timer clear 110244.36 4 state [say Bal 1] Say numbers: ARIF as Digits 110244.38 4 fn PlaySoundStartNumbers [],[],[ARIF],Digits 110244.39 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide 110244.39 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 110244.41 4 rv add [Hangup Time]{01/10/2007 11:02:44 AM} 110244.42 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 110244.42 4 HangupCall_Common hCall=4 110244.44 4 rec RecSoundStop ok 110244.45 4 play PlayStop ok 110244.45 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 110244.47 4 fnHangupCall end 110244.52 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 110244.52 4 event TDX_SETHOOK, iCode=135 state=900 110244.53 4 LsAwaitingCalls EV_UNKNOWN_135 110244.55 4 event callstate IDLE 4 1,0,0 110244.55 4 WorkingMode@Idle= 110244.56 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 110244.58 4 timer clear 110244.58 4 rec RecSoundStop ok 110244.59 4 play PlayStop ok 110244.61 4 rv add [CallEndTime]{01/10/2007 11:02:44 AM} 110244.64 4 on-hangup script:[] 110244.64 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 110244.66 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 110244.67 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 110244.67 4 init atidle reinit : start 110244.69 4 init atidle reinit iConferenceOtherLegLid=-1 110244.70 4 init atidle reinit : reset all LineState variables 110244.70 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 110244.72 4 state Waiting for a call... 110246.92 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 110246.92 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 110246.94 4 setting iDialoutReadyToDialout = 1 110557.48 load start [G:\TeleBanking System\Tele Banking_Main.vgs] 110557.48 MemStructVgs_ClearVgs [3] 110557.50 load end 110557.52 loaded Script Id 3: G:\TeleBanking System\Tele Banking_Main.vgs 110557.53 0 Erasing Script (new loaded) Id 1 110557.55 0 VgsScriptFree [1] 110557.56 MemStructVgs_ClearVgs [1] 110604.17 4 event callstate OFFERING 4 2,0,0 110604.19 4 script interpretor: VgMulti v6.0.3243 110604.19 4 fired OFFERING event to listeners 110604.20 4 set LineState().hCall = 4 in LINECALLSTATE_OFFERING 110604.22 4 cid CallerID vars set (in 'offering' event) [,,] 110604.22 4 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING 110604.23 4 rings=0, min rings before answer=0 (iCallerIdHasArrived=0) 110604.25 4 tw ring 1 110604.25 4 ring time since last ring event (sec): 0.00 110604.27 4 rings=1, min rings before answer=0 (iCallerIdHasArrived=0) 110604.28 4 should answer as number of rings reached 110604.28 4 rv clear all 110604.30 4 init LineState ResetAtStartOfNewCall. 110604.31 4 answering the call (,,,0) 110604.31 4 timer clear 110604.33 4 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON, 110604.34 4 event TDX_CST, iCode=134 state=6001 110604.36 4 LsModuleTransition : 134, [TDX_CST] 110604.97 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND, 110604.97 4 event TDX_SETHOOK, iCode=135 state=6001 110604.98 4 LsModuleTransition : 135, [TDX_SETHOOK] 110605.00 4 event callstate CONNECTED 4 256,0,0 110605.02 4 LineEvCallState_Connected hDevice=4 params=256,0,0 110605.03 4 WorkingModes tapi= script= LineState().iState=6001 110605.03 4 Inband detection not enabled 110605.05 4 StartLoadedVgs at 01/10/2007 11:06:05 AM (VgMulti v6.0.3243) 110605.06 4 set LineState().iVgsIdx=3 110605.06 4 set sScriptToRunOnHangup=[] in StartLoadedVgs 110605.08 4 init StartLoadedVgs_InitLineState start 110605.09 4 rv add [$RV_STARTTIME]{01/10/2007 11:06:05 AM} 110605.09 4 rv add [$RV_DEVICEID]{4} 110605.11 4 rv add [DlgcNetworkResource]{dxxxB1C4} 110605.13 4 rv add [DlgcVoiceResource]{dxxxB1C4} 110605.13 4 rv add [$RV_CIDNAME]{} 110605.14 4 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 110605.16 4 rvns add [scriptsPath]{G:\TeleBanking System\} 110605.16 4 rv add [$RV_CIDNUMBER]{} 110605.17 4 fn RunModule start [Play,[Get Language],89,,] 110605.19 4 tw DialogicEvent 134,TDX_CST,20045,0,0,DE_LCON,, 110605.19 4 event TDX_CST, iCode=134 state=6001 110605.20 4 LsModuleTransition : 134, [TDX_CST] 110605.22 4 timer clear 110605.22 4 Play Module start 110605.23 4 state [Get Language] Playing 110605.25 4 state [Get Language] Playing (Bangla Voice\Welcome.wav) 110605.25 4 tw ConvertWav2Vox G:\TeleBanking System\Bangla Voice\Welcome.wav 110605.28 4 tw wav->vox convert end 589328,G:\TeleBanking System\Bangla Voice\Welcome.vox,1,0,, 110605.31 4 play start ok, lPlayId=589375 110606.52 4 tw dtmf 3 (4,51,51) 110606.53 4 event 3, iCode=51 state=1100 110606.53 4 LsPlayMsg 3,3 110606.55 4 next module is [GetData] (idx=96) 110606.58 4 play PlayStop ok 110606.58 4 rv add [Get Language]{3} 110606.59 4 fn RunModule start [Evaluate,[GetData],96,,] 110606.64 4 tw PlayEnd 4 589375 110606.66 4 play end id=589375, (current ID) 110606.66 4 event EV_PLAY_FINISHED, iCode=8001 state=6001 110606.67 4 LsModuleTransition : 8001, [EV_PLAY_FINISHED] 110606.69 4 tw DialogicEvent 129,TDX_PLAY,589375,0,0,,, 110606.69 4 event TDX_PLAY, iCode=129 state=6001 110606.70 4 LsModuleTransition : 129, [TDX_PLAY] 110606.72 4 timer clear 110606.73 4 state [GetData] Evaluate ["C:\Program Files\VoiceGuide\System\Bangla Voice"] 110606.73 4 eval[Cstr("C:\Program Files\VoiceGuide\System\Bangla Voice")] 110606.75 4 rvns add [GetData_Input]{"C:\Program Files\VoiceGuide\System\Bangla Voice"} 110606.77 4 rvns add [GetData]{C:\Program Files\VoiceGuide\System\Bangla Voice} 110606.77 4 Eval Expr result:[C:\Program Files\VoiceGuide\System\Bangla Voice] 110606.78 4 path {C:\Program Files\VoiceGuide\System\Bangla Voice} not found 110606.78 4 matching path not found 110606.80 4 next module is [say Bal 1] (idx=94) 110606.81 4 matching path was found 110606.81 4 fn RunModule start [say Numbers,[say Bal 1],94,,] 110606.83 4 timer clear 110606.84 4 state [say Bal 1] Say numbers: 200 as Number 110606.84 4 fn PlaySoundStartNumbers [],[],[200],Number 110606.88 4 ERROR 6.0.3243 PlaySoundStartNumbers line=1040, 5:Invalid procedure call or argument:VoiceGuide110606.89 4 HangupCall start (PlaySoundStartNumbers Error @ line 1040) 110606.89 4 rv add [Hangup Time]{01/10/2007 11:06:06 AM} 110606.91 4 state Hanging up call... [PlaySoundStartNumbers Error @ line 1040] 110606.92 4 HangupCall_Common hCall=4 110606.92 4 rec RecSoundStop ok 110606.94 4 play PlayStop ok 110606.95 4 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 110606.95 4 fnHangupCall end 110607.00 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,, 110607.02 4 event TDX_SETHOOK, iCode=135 state=900 110607.03 4 LsAwaitingCalls EV_UNKNOWN_135 110607.03 4 event callstate IDLE 4 1,0,0 110607.05 4 WorkingMode@Idle= 110607.06 4 set LineState().hCall = 0 LineEvCallState-LINECALLSTATE_IDLE 110607.06 4 timer clear 110607.08 4 rec RecSoundStop ok 110607.09 4 play PlayStop ok 110607.09 4 rv add [CallEndTime]{01/10/2007 11:06:07 AM} 110607.14 4 on-hangup script:[] 110607.14 4 timer set 0.1 EV_TIMEOUT_TIMETOREINITLINE 110607.16 4 timer fired EV_TIMEOUT_TIMETOREINITLINE 110607.17 4 event EV_TIMEOUT_TIMETOREINITLINE, iCode=9008 state=900 110607.17 4 init atidle reinit : start 110607.19 4 init atidle reinit iConferenceOtherLegLid=-1 110607.20 4 init atidle reinit : reset all LineState variables 110607.20 4 timer set 2 EV_TIMEOUT_AFTERIDLE_ALLOWOUT 110607.22 4 state Waiting for a call... 110609.42 4 timer fired EV_TIMEOUT_AFTERIDLE_ALLOWOUT 110609.42 4 event EV_TIMEOUT_AFTERIDLE_ALLOWOUT, iCode=9013 state=900 110609.44 4 setting iDialoutReadyToDialout = 1 Plz reply. 1001vgm.txt Share this post Link to post
SupportTeam Report post Posted 10/01/2007 10:33 PM Please do not post long traces as part of message. It makes the post hard to read. Trace shows that you are using v6.0.3243 of VoiceGuide. Please update to the latest v6 and see if you get better results with this newer version. Share this post Link to post
