Guest steertek Report post Posted 09/24/2007 12:25 PM Hi, I 've read a lot in the forum and help file. But VG still do not stop when caller hangs up during a play module. VG stops immediately the scripts when i unplug the phone line. I have a dialogic card, Enterprise 1 line VG version 6.0. Here are enclosed some files : config.xml, ConfigLine.xml, PbxSTEER_tones.tsf, disconnect_tone.wav. Can you tell me what's wrong ? PBXSTEER_Tones.zip PBXSTEER_Tones.zip Share this post Link to post
SupportTeam Report post Posted 09/25/2007 12:09 AM Try relaxing the Disconnect tone definition in ConfigLine.xml, to something like this: <Tone Name="Call progress Tone TID_DISCONNECT"> <Notes>STEER Settings</Notes> <ID>TID_DISCONNECT</ID> <Freq1>440</Freq1> <Freq1Dev>50</Freq1Dev> <Freq2>0</Freq2> <Freq2Dev>0</Freq2Dev> <On>50</On> <OnDev>10</OnDev> <Off>50</Off> <OffDev>10</OffDev> <Count>1</Count> </Tone> Share this post Link to post
Guest steertek Report post Posted 09/25/2007 05:18 PM I tried the definition you gave me. It does'nt work. what else can i do ? I enclosed VG.ini, log file, script file. I hang up in the "choixhopital" play module 0925vgmSTEER.zip Share this post Link to post
SupportTeam Report post Posted 09/25/2007 10:37 PM Which Dialogic card is used in this system? You could also try using the Dialogic's PBXpert application to perform a busy/disconnect/etc tone test and use the .TSF file that the PBXpert generates. The .TSF file is then specified in the Dialogic Config Manager. That approach has worked for some users. Another thing to look into would be whether the PBX/Telco who supplied the line can set this line to send a "Loop Current Drop" signal on that line when the call is ended. We'd need to see the "tw" trace to confirm if the Config.xml file is read correctly. The 'tw' trace shows the Dialogic card layer trace. Share this post Link to post
Guest steertek Report post Posted 09/26/2007 12:05 PM I use Windows XP SP2 uptodate, SR 5.1.1 SP1, Dialogic 4/EPCI. I used PBX expert. It only detects the disconnect tone(TSF enclosed in previous message). I set the .tsf file (TTSfilesupport and disconnect tone to YES) in the DCM without success. Here enclosed tw and log files. The user hangsup in the play module after the dialing his code (Welcode) 0926vgm.zip Share this post Link to post
SupportTeam Report post Posted 09/26/2007 12:13 PM No idea why it is not detecting it then. Probably best to see if the PBX/Switch can be configured to perform a Loop Current Drop on this line, or just wait for the script to timeout due to lack of user input and hangup... Share this post Link to post
Guest steertek Report post Posted 09/26/2007 03:12 PM can i use the SR 6 with the Dialogic D4/EPCI ? Share this post Link to post
SupportTeam Report post Posted 09/26/2007 08:48 PM Not sure. Best to check the SR6.0 Release Notes documentation. Share this post Link to post
