Loading Calls Into V5 Of VoiceGuide (with Voice Modem)
Selvan wrote:
I have downloaded 5.x for my voicemodem. Everything works well except when I tried to automate the outbound calls thru the OutdialQue.mdb approach. Our program schedules and inserts a record to make a call to a number. Nothing happens. The same info works well from phone loader.
Please post the OutdialQue.mdb after inserting data into if using both the VoiceGuide Phone Number Loader and your own added entries.
Looking at the different entries side by side will let us see what the differences are and what should be changed in the entry which you are loading.
Here is the parameters passed in each case:
1. Thru phone number loader:
I have attached the screenshot. Except in the first page, all other values are defaults.
2. Thru our program:
ID PhoneNumber ActivateTime DayTimeStart DayTimeStop DaysCallAllowed LineSelection Priority AnnounceMessage Script OnAnswerMachine RV AnswerTimeout CallRetriesLeft DelayBetweenRetries OnNotConnected EscalationCalls Options
2 +15103962953 0 0 0 <NULL> <NULL> 0 /mpura_wd/ivr/voiceguide/voice/anykeytostart.wav /mpura_wd/ivr/voiceguide/scripts/pay.vgs <NULL> <NULL> 0 0 0 <NULL> <NULL> <NULL>
Please let me know if you need more info.
phoneloader.doc
You should look a the .mdb (open it in MSAccess) file to see how the VoiceGuide Number Loader loads the new entries...
Then adjust your programs to load the entries in similar way...
