Call Transfer
Dear Sir
I also try Call Transfer but I fail. What is the problem in this system. I send Log file. Plz see this and reply.
From
Arif
Sorry I also send Config file. Plz see Config and Trace file
Config.zip
Trace shows that the script is doing a Monitored Hookflash Transfer (in module [Transfer Call 1]).
102035.58 4 state [Transfer Call 1] Monitored Hookflash Transfer to 107
About 3 seconds after dialing the destination extension (107) the busy signal is detected by the Dialogic card:
102038.13 4 Dial(107) ok
102041.22 4 event BUSY, iCode=133 state=1903
VoiceGuide then retrieves the call by issuing another hookflash:
102041.23 4 xfer dial [!] in Xfer_DialCmdCode_RetreiveOriginalCall
And looks if a "busy" path is defined in that module ([Transfer Call 1]):
102041.55 4 path {busy} not found
102041.55 4 path {disconnect} not found
102041.56 4 path {disconnected} not found
102041.56 4 False path not defined - hangup call (iXferType=12)
As no 'busy' or 'fail' path is defined VoiceGuide ends the call.
You may need to change the 'busy' tone definition in the ConfigLine.xml file if you think the busy tone is being falsely detected.
Please see: http://www.voiceguide.com/vghelp/source/ht...ctiondetect.htm
102035.58 4 dialing sTransferPrefix [!]
102035.84 4 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
102035.86 4 event TDX_DIAL, iCode=132 state=1902
102035.86 4 LsXfer_2_OnEndHook1PlayDestNbr 132,TDX_DIAL,0,0,0,,,
102035.88 4 VG.INI [PBX] Transfer_Prefix_PauseAfter = 2 sec
102035.88 4 timer set 2 EV_TIMEOUT_Transfer_Prefix_PauseAfter
102035.89 4 tw PlayEnd 4 0
102035.89 4 play end id=0, (current ID)
102035.91 4 event EV_PLAY_FINISHED, iCode=8001 state=1902
102035.91 4 LsXfer_2_OnEndHook1PlayDestNbr 8001,EV_PLAY_FINISHED,0,0,0,,,
102038.00 4 timer fired EV_TIMEOUT_Transfer_Prefix_PauseAfter
102038.00 4 event EV_TIMEOUT_Transfer_Prefix_PauseAfter, iCode=9030 state=1902
102038.02 4 LsXfer_2_OnEndHook1PlayDestNbr 9030,EV_TIMEOUT_Transfer_Prefix_PauseAfter,0,0,0,,,
102038.02 4 Dial(107, cp on) call
102038.13 4 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
102041.20 4 tw DialogicEvent 133,TDX_CALLP,7,0,0,CR_BUSY,,
102041.22 4 LsXfer_3_AfterDialDestNbrWaitForCallProgInfo 133,BUSY,7,0,0,CR_BUSY,,
102041.23 4 event CR_BUSY, iCode=133 state=1906
102041.25 4 LsXfer_5B : 133(EV_UNKNOWN_133),CR_BUSY,7,0,0,CR_BUSY,,
102041.27 4 event TDX_CALLP, iCode=133 state=1906
102041.27 4 LsXfer_5B : 133(EV_UNKNOWN_133),TDX_CALLP,7,0,0,CR_BUSY,,
102041.50 4 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
102041.50 4 event TDX_DIAL, iCode=132 state=1906
102041.52 4 LsXfer_5B : 132(EV_UNKNOWN_132),TDX_DIAL,0,0,0,,,
102041.52 4 sXferDialResult_SuccOrFail=
102041.53 4 XferGoDownSpecifiedPath iXferModule_PathsToTake_Max=3 (1)=busy (2)=disconnect (3)=disconnected
