Basic Questions About Accessing Callerid
Michael wrote:
I have some questions about your IVR technology
1) Can your application determine the address of an incoming call?
1a) If so, can the address information be exported to a file/database?
2) Can your application export/import information from a repository such as a database?
2a) If so, what databases does your software support?
3) Does your application allow the IVR modeler to manipulate data received from an incoming call? (For example, caller calls in, their address is determined by the IVR, the string of that address is then manipulated as required using the IVR or some sort of API from within the IVR and then exported to a database.)
Thank you.
Yes. CallerID is retrieved and is accessible throughout the script. This includes the CallerID/IP address supplied on VoIP calls.
Yes. Please see:
http://www.voiceguide.com/vghelp/source/ht...ltvariables.htm
http://www.voiceguide.com/vghelp/source/html/moddbquery.htm
http://www.voiceguide.com/vghelp/source/ht...drunprogram.htm
http://www.voiceguide.com/vghelp/source/html/modvbs.htm
Yes. Please see:
Pretty much every database is supported. As long as the database supports an ODBC interface then it can be used. Pretty much every database supports the ODBC interface.
Yes. Please see:
http://www.voiceguide.com/vghelp/source/html/modevalexpr.htm
Please post if you have any further questions.
