Scripted Voicemail
When using the scripted voicemail if a user checks there voice mail and then listens to all messages deleting as they go when they get to the last msg and delete it then try to delete again this same message as the system prompts that you can do i recieved a file not found vb script runtime error in line 95 char 3 of voiceguide\data\vbs_5.vbs
I'm running version 5.0a of the sotware in production.
Thank you for reporting this problem. The bug has now been found and to fix it on your system please update VoiceGuide's \system\vm\ directory with the attached file, allowing it to replace the existing file.
(the updated file is the VG script which is responsible for playing back the voicemail messages - it is part of VoiceGuide's Scripted Voicemail System)
vmLogin.vgs
