rodcrane Report post Posted 10/23/2007 06:56 PM Hi, I am trying to run voiceguide as a service using instsrv and srvany. The service starts and then fails. I have added the dependency Dialog to the voiceguide service and it shows up in the dependency box in the service management screen. VoiceGuide starts with no issue from a command line. VoiceGuide is registered using the Dialogic card information. The service is running using a system account. I set the VG log to 10, but no entries are made when launching the service. I have the same setup running on an XP server and verified the settings are the same for the service installation and registry settings. This new installation is a new 2003 server. Any help is appreciated. reg.txt Share this post Link to post
SupportTeam Report post Posted 10/23/2007 09:47 PM If you cannot get srvany to work for you then maybe you can try looking at other 'service wrapping' tools. eg: http://www.firedaemon.com/ Another option is to use v7 of VoiceGuide. VoiceGuide v7 runs natively as a Windows Service. Share this post Link to post
