Srvany Service Fails To Start
I am trying to run voiceguide as a service using instsrv and srvany. The service starts and then fails.
I have added the dependency Dialog to the voiceguide service and it shows up in the dependency box in the service management screen.
VoiceGuide starts with no issue from a command line.
VoiceGuide is registered using the Dialogic card information.
The service is running using a system account.
I set the VG log to 10, but no entries are made when launching the service.
I have the same setup running on an XP server and verified the settings are the same for the service installation and registry settings. This new installation is a new 2003 server.
Any help is appreciated.
reg.txt
If you cannot get srvany to work for you then maybe you can try looking at other 'service wrapping' tools. eg: http://www.firedaemon.com/
Another option is to use v7 of VoiceGuide. VoiceGuide v7 runs natively as a Windows Service.
