Run Program Fails
The traces show that the error is: "The system cannot find the file specified"
Can you try specifying the full path to the .exe file which you are trying to run?
I set the full path, but still get the error.
085423.171 4 1 Found result file: C:\Program Files\VoiceGuide\Scripts\PhoneTimeDPT\VGRUNRESULT_1.TXT
085423.171 4 1 ERROR v7.0.2848.35458 (Fri 19/10/2007 18:41:56.95) LsRunWaitTillFinished : Object reference not set to an instance of an object.
1031_0853_vgEngine.txt
VGRUNRESULT_1.TXT
Traces show the .exe was found and ran by VoiceGuide, but the result file generated by that program was not being read in properly.
Please update to this version of VoiceGuide:
[old link removed]
This newer version fixed the issue with the reading in of the result file.
You will still need to specify the full path to the .exe to get it started by the Run Program module.
