Dialogic D/41
Hi support team,
Is there any diffence bitween D/41ESC-PCI and a D/41E-PCI ? I was purcahsing this on ebay and was wondering if I have done the right bid .. bit confused .. :-)
tkx
mh
The older D/41E-PCI probably does not have the "SC" bus.
SC Bus allows calls to be bridged. This allows "Dial and Conference" type transfers etc.
ok thanks, when you talk about "Dial and Conference" , you mean between lines within the board itself ?
tkx
Mh
Both between the lines on the board itself and between the lines on the different cards.
