Guest sasha85 Report post Posted 11/05/2007 01:56 AM i need Telephony card that will be able to receive phone calls and to put callers through an automated menu, where they can choose various options by pressing their keypads and seving it to the server or pc... i want that all kind of phones will be able to call...from mobiles+cables and regular providers. i am is israel russia and ukraine...there is no much voip going on here:) i want to work with voiceguide but first i want to ask what kind of hardware do you recommend. hardware that will we best to my needs:) and i will be happy to read some tips about using voiceguide with my plan there Share this post Link to post
SupportTeam Report post Posted 11/05/2007 05:12 AM Quote i want to ask what kind of hardware do you recommend. Have you had a look at the "Recommend Hardware" page? You should look at using the Dialogic cards. They are available in versions which can accept the normal analog telephone lines, and there are versions which accept E1 or T1 lines. Sounds like you will be using normal analog telephone lines, so you should be looking at boards which are D/4PCIUF or D/120JCT etc. How many simultaneous calls would yon like the system to be able to handle? Share this post Link to post
Guest sasha85 Report post Posted 11/05/2007 06:07 AM well i saw this page there is lot of cards there...what cards fit my need best? if i will pick the analog tech that's mean that i wan't be able to take cable telephones? simultaneous maximum 10... Share this post Link to post
SupportTeam Report post Posted 11/05/2007 07:13 AM Have a look at the D/120JCT card. That card can handle 12 normal telephone lines. The 'analog' is a term used to describe the normal most commonly used telephone lines. Share this post Link to post
Guest sasha85 Report post Posted 11/05/2007 07:48 AM well...it is nice but, i ran a search in israel...had not found such card... do you got some more global cards which i can find easily? if this product is good i will buy it, got no cost prob...but i do want that the hardware will have a support center in the country it would serve...and this one i need in israel. Share this post Link to post
SupportTeam Report post Posted 11/05/2007 08:02 AM Dialogic brand is the most commonly used telephony card in the world. Go to: http://www.dialogic.com/purchase and select Israel. These two distributors come up: http://www.arrow-israel.co.il/ http://www.trekit.co.il/ Share this post Link to post
Guest sasha85 Report post Posted 11/05/2007 12:48 PM last question: why do i need 12 ports it is not that i need to build a net of phones extension i just need simultaneously few people would call that they will get answer... is there a way that the voiceguide devide somehow the transfers from one port? suppose there would be only one port and 10 people would get simultaneously an answer... ? Share this post Link to post
SupportTeam Report post Posted 11/05/2007 08:50 PM The number of lines/ports required depends on the number of calls you need to handle at the same time. One telphone line can only accept a connection form one caller at a time. You will need two lines to be able to handle two callers, and so on... Share this post Link to post
Guest sasha85 Report post Posted 11/05/2007 10:40 PM is that good for us http://store.digium.com/products.php?category_id=37 do i need to buy additional moduls exept this card? Share this post Link to post
SupportTeam Report post Posted 11/06/2007 01:05 AM The recommended hardware for use with VoiceGuide can be found on the Recommend Hardware page on our WWW. The cards which you linked to will not work with VoiceGuide. Share this post Link to post
Guest sasha85 Report post Posted 11/06/2007 03:44 AM well i searched but still not found those cards in israel, even called few big places...if they exist in israel than they got realy bad marketing...very bad one...and believe me i know...i am marketing manager myself. Share this post Link to post
SupportTeam Report post Posted 11/06/2007 04:32 AM Did you go to: http://www.dialogic.com/purchase ? Have you contacted either of the two distributors mentioned beforehand? http://www.arrow-israel.co.il/ http://www.trekit.co.il/ Share this post Link to post
Guest sasha85 Report post Posted 11/06/2007 04:59 AM both of them do not sell one card only... and besides they do not have those cards on their site... about http://www.dialogic.com/purchase well that would be my last option cause i do not want to order special shipment to israel... Share this post Link to post
SupportTeam Report post Posted 11/06/2007 05:47 AM Sounds like you may need to order the card from UK then. See http://www.postcti.co.uk or similar. Share this post Link to post
