Text To Speech Over D/240jct-t1
I am trying to run Text to Speech over D/240JCT-T1
but no success
on the following configuration:
Windows-XP SP2 with all the critical updates
Dialogic Ver 6.0
VoiceGuide Ver 6.0.3377 ( demo version )
Microsoft SAPI 5.1
looks like it is trying to generate a file tts_2_1.wav but it is only 1KB
I do have a success if I run the same script on D/41ESC
Windows-2000 Server SP4 with all the critical updates
Dialogic Ver 5.1.1
Microsoft SAPI 5.1
generated file tts_1_1.wav on the first try and played it no problem.
Is there anything special that needs to be set
for it to work with D/240JCT-T1 ISDN ???
Did I forget to set some parameters?
Which TTS engine are you using?
Have you read this Help file page: http://www.voiceguide.com/vghelp/source/html/config_tts.htm
Have you installed the SAPI SDK?
Are you able to use the demo apps to create TTS generated .WAV files? Use this app:
Start -> Programs -> Microsoft Speech SDK 5.1 -> Tools -> TTSApp
The select the TTS engine and press the "Save to .wav" button. Is the .WAV file created?
You may need to use v7 in order to be able to reliably select the TTS engine of choice. We have had reports that selecting the default TTS engine using the "Speech applet from the Windows Control Panel" approach recommended for v6 does not always work.
The default engine
Yes.
Yes.
Yes. I can use it OK.
Yes. It does create a file just fine, and I can play it back
Like I said in my previous message I have successfully execute everything on D/41ESC on Windows 2000
using VG ver 6, but the goal is to use D/240JCT, because of D240JCT I have to use Dialogic 6.0 and XP
there is probably something simple that needs to be set in VG configuration files
on D/41ESC configuration was just fine “out of the box” for D/240JCT I had to change to ISDN sample
Everything that I need works fine on D240JCT so far. Just the issue with playing Text to Speech,
or more like generating a file, since I see the file generated but it is only 1KB
[Log]
VoiceGuide=10
ktTel=10
ktTts=10
Please post the traces.
Please also include in the posted .ZIP the created .WAV file created by VoiceGuide.
NB. The TTS generation is done the same way regardless of whether the system is running on Digital or on Analog lines.
It was strange, must have been one of Windows Flukes...
I have uninstalled the Microsoft SDK 5.1 and installed it again. Nothing else was changed.
Now I have TTS working with D/240JCT setup.
Sorry to bother you with this nonsense
Thanks for letting us know that the TTS is working on this system now.
Please don't hesitate to let us know if you run into any problems in the future.
