Need Help With Rvget And Rvset
I assume that the VBS code below should produce a text box with the number 1, however the msgbox comes up with "$ProjectID"
Can you please let me know if I'm doing something wrong on this.
Thank you,
John
________________
Option Explicit
Dim vg, strTest
vg.RvSet $RV_LINEID, "ProjectID", "1"
strTest = vg.RvGet($RV_LINEID, "ProjectID")
msgbox strTest
Set vg = Nothing
Instead of:
Please try using:
strTest = vg.RvGet($RV_LINEID, "RV[ProjectID]")
From http://www.voiceguide.com/vghelp/source/html/com_rvget.htm :
sRv
Required. Result Variable who's value is to be returned. The leading dollar sign can be ommited. eg. in case of $RV[GetCardDetails] just the RV[GetCardDetails] can be specified, and in case of $RV_CALLLENGTH just the RV_CALLLENGTH can be specified.
Note that this lets RvGet retrieve multiple RVs embedded within a string, basically converting all RVs within a string expression. eg :
strTest = vg.RvGet($RV_LINEID, "RV[ProjectID]_RV[OtherInput]_myowntag")
Are you using v7 or v6 or VoiceGuide?
On version 6, dialogic 24 port.
I changed the code for that module to the following..
Dim vg, strtext
vg.RvSet $RV_LINEID, "RV[ProjectID]", "1"
strtext=vg.rvget($RV_LINEID, "RV[ProjectID]")
msgbox strtext
set vg = Nothing
Now the msgbox comes up blank. It just doesn't seem to want to take that number.
If you don't mind let me run a scenario by you real quick, you may have a better way to do what I'm trying.
Basically, I'm trying to make an int to hold the record line number for rewriting a reference to a query database module (ie., $RV[PTLoadData_6_INSERT INT HERE]. The intended function is to allow users to "scroll" through database lines having modules read back certain fields. If they're listening to record 1, and they press a key for next record, it should increase the int by 1, and start the same code over, but using the new line number so that it reads them back record 2 using the same modules that record 1 did.
Anything to help me out with that?
Thanks,
John
The line
is OK. no need to change it.
Only the RvGet line required changing.
The VBScript code should be:
msgbox strTest
Set vg = Nothing
You should be able to use RVs within the RV name. Try an expression like this:
$RV[PTLoadData_6_$RV[myIndex]]
or
RV[PTLoadData_6_RV[myIndex]]
v7 of VoiceGuide can definitely do the above.
Great, that change did it. Thanks for that.
Is it your recommendation to upgrade to 7? I know typically older versions can be a bit more stable (more time in the wild, patches, etc.) but you deal with this more that I do. Is it more stable?
If you have a link to a comparison chart, or feature summary for 7 that would be great.
Thanks again for the help!
John
We would recommend moving over to v7 for T1/E1 ISDN systems.
v7 has a better handling of ISDN error situations, runs natively as a Windows service, and can achieve better sound quality then v6.
It also uses less CPU then v6 when running T1/E1 ISDN systems.
