SupportTeam Report post Posted 11/21/2007 08:31 PM Luis wrote: Hi, I develop an IVR system under your VoiceGuide version 6, however I recently downloaded the version 7, but it gives me some errors with the TTS engine, even more it doesn’t let me initiate the Speech under Control Panel. I have installed the SDK SAPI 5, and it was working fine with the version 6, also I had a voice engine working fine, but with the version 7 it uses the Microsoft voice, and I’m not able to change it for the one I want to use. Share this post Link to post
SupportTeam Report post Posted 11/21/2007 08:31 PM Please Download the latest v7 from our WWW and then set the TTS engine to use in the VG.INI file, as described in this Help file page: http://www.voiceguide.com/vghelp/source/html/config_tts.htm Share this post Link to post
