Tts Engine Selection In V7
Luis wrote:
Hi, I develop an IVR system under your VoiceGuide version 6, however I recently downloaded the version 7, but it gives me some errors with the TTS engine, even more it doesn’t let me initiate the Speech under Control Panel. I have installed the SDK SAPI 5, and it was working fine with the version 6, also I had a voice engine working fine, but with the version 7 it uses the Microsoft voice, and I’m not able to change it for the one I want to use.
