Voiceguide V7 On Windows 2000 Advanced Server
I tried to upgrade our Voiceguide install from 6 to 7, and the setup on 7 won't finish because .NET 3.0 requires XP or later.
1) You may want to note this requirement on your System Requirements page (it currently states that VG will work with 2000, no comments there for V7).
2) Is there any workaround for this?
Thank you,
John
You will need to use Win2003 or WinXP to run VoiceGuide version 7.
Thanks for pointing out that the Recommended Hardware page does not mention this. We will have that updated.
