Guest mawogani Report post Posted 12/03/2007 02:35 PM I test VG with a Voice Modem and work fine, the next day it say that "wave driver is not install" and the day after it seems to be fine with the status "waitting for a call" and nver answer the call. here is my log trace: 102019.52 0 sys cleanup Start 102019.53 0 sys cleanup End Can you help me? Share this post Link to post
SupportTeam Report post Posted 12/03/2007 08:56 PM Many voice modems will have such problems. Reinstalling the modem’s wave drivers may fix such problems temporarily. If you want a reliable system then you should use a Dialogic card and v6 or v7 or VoiceGuide. Share this post Link to post
