Database Connect
Since I want to connect to a different file with each caller is it possible to use a variable like this for the Database or ODBC Data source?
c:\$rvPhone.dbf
Yes. You should be able to use an $RV as part of the database name or connect string.
The $RVs have a form of $RV[rvname] so the actual string specified in the database name field may look something like this:
c:\$RV[rvname].dbf
depends on what $RV[rvname] contains of course...
