Guest samet10 Report post Posted 12/24/2007 02:48 PM hi. ive installed the vg 6. trial version. becouse my i get errors when installing .net framework 3.0 is there a differance between the trial of the vg 6 and the 7? on the version 6 i never really get a chance to test the program since i get immidiatly a popup to register the program and i never have the oppertunity to test it for a complete hour like i was told by support. Share this post Link to post
SupportTeam Report post Posted 12/25/2007 11:30 AM All evaluation versions allow evaluation for an hour after each restart. The popup would only occur if software was running for more then one hour and a new call was placed into the system. Share this post Link to post
ktruk Report post Posted 12/31/2007 12:38 AM see: http://voiceguide.com/forums/index.php?showtopic=5322 VG eval version will timeout after 10 outbound calls and popup reg screen, as soon as 11th call made, even if less than one hour since restart. Share this post Link to post
Guest samet10 Report post Posted 01/01/2008 02:04 AM All evaluation versions allow evaluation for an hour after each restart. The popup would only occur if software was running for more then one hour and a new call was placed into the system. is there a 10 outbound call limit before the popup or can i try the software for an hour straight without interuption? Share this post Link to post
SupportTeam Report post Posted 01/01/2008 05:37 AM The outbound call limit kicks in as soon as that number of outbound calls are made. Share this post Link to post
Guest samet10 Report post Posted 01/01/2008 03:07 PM The outbound call limit kicks in as soon as that number of outbound calls are made. in that case i really dont have the oppertunity to try out the software. is there a way you can provide me with a trial that will alow me to test out the program for an hour or so without interuption? Share this post Link to post
SupportTeam Report post Posted 01/01/2008 09:53 PM The software will answer inbound calls for an hour without interruption, and the 10 call limit on outbound calls is enough to verify that the outbound calls and transfers can be made and the callflow/scripts run as expected. If the number of outbound calls were unlimitted over one hour in the evaluation version then this would allow the use of the evaluation verson of software for commercial tasks. Share this post Link to post
