Limitations On Sql Statements
hi
i want to know if there r any limitations on the sql statements i can use with voice guide .. because it doesnt work when it use a little bit complex statement(having more than one join) while it works well if i decreased the joins to one join .. knowing that i have tested the complex statement with the query analyser and it works properly.
regards
VoiceGuide does not do any interpretation on the SQL statement apart from replacing the $RV Result Variables. VG just passes the SQL to the database driver.
Which version of VG are you using?
Could you please post a copy of VoiceGuide's Trace Logs which captures the problem, this will allow us to see what happened.
[Log]
VoiceGuide=10
hi
i use version 6 .. and when i finish my ivr wish voice guide 6 .. i will do the whole thing again with a voice modem using voice guide 5.
attached my script and the file created in the log folder.
regards
script_and_log.zip
hi,
sorry i think i didnt attach the right log file
so here u r the script and log file again
by the way .. i have read the log file .. and it seems the problem is about using 2 successive INNER JOIN's .. it works good on sql query analyzer .. so i dont know what i should add here !!
script_and_log.zip
hey team
waste no time on ma question .. it works now .. i added some brackets and it worked .. thnx
regards
