SupportTeam Report post Posted 01/04/2008 09:52 PM Amy wrote: We don't start the program while we are in business. We don't want any voicemail up during business hours. However we want the program to automatically answer starting at 6:00 pm Monday-Friday and all day Sat & Sun. Any suggestions? Share this post Link to post
SupportTeam Report post Posted 01/04/2008 09:56 PM The script should be setup to "Start without answering the call", and then the first module should be a Time Switch module. Use the Time Switch module to rout calls to either the rest of the script (the part that does the voicemail etc) or route the call to a Hangup module. If you route the call to the hangup module the script will end without ever answering the call. See attached sample script which demonstrates the approach. AfterOfficeHours.vgs Share this post Link to post
