Guest manish Report post Posted 01/05/2008 09:16 AM Hi, I am using vg6.0 trial i want to know how i can play vox files with this in place of wav files. Share this post Link to post
SupportTeam Report post Posted 01/05/2008 11:21 AM Yes, you should be able to. The .vox file should be an 8kHz Dialogic format ADPCM file. Share this post Link to post
Guest manish Report post Posted 01/05/2008 02:21 PM Yes, you should be able to. The .vox file should be an 8kHz Dialogic format ADPCM file. But How? what configuration it requier to play vox file as i have vox file and i am unable to play in version 6 Share this post Link to post
SupportTeam Report post Posted 01/05/2008 09:08 PM Have you tried just specifying the .vox filename in the Play module? Which vesion of v6 are you using? Could you please post a copy of VoiceGuide's Trace Logs which captures the problem, this will allow us to see what happened. Enable logging by setting the log levels to 10 in VG.INI as per below: [Log] VoiceGuide=10 ktTel=10 Then restart VG and make a test call which demonstrates the problem. Trace files will be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
