Guest DiegoBellini Report post Posted 01/07/2008 03:23 AM Please, I need help with a VBS module that works making a "do while" reproduce then each of the recovered information. I don't understand because it does not work. For example, look at this VBS code: SQLConnStr = "$RV[ConnStr]" Conn.Open SQLConnStr StrSQL = "SELECT CodigoPago from telepago WHERE SocioNum = " & CustId Set Rs = Conn.execute(StrSQL) If Rs.Eof or Rs.Bof Then 'No codes availables Else NroReg = 0 Do while Not Rs.EOF NroReg = NroReg + 1 CodigoPago = Rs.fields("CodigoPago").Value StrSQL = "SELECT FileDeLectura from CodigoCuentas where CodigoPago = " & CodigoPago Set Rs2 = Conn.Execute(StrSQL) If Rs2.Eof or Rs2.Bof Then 'No data in this query Else Rs2.MoveFirst FileDeLectura = Rs2.Fields("FileDeLectura").Value vg.RvSet LineID,"FileDeLectura",FileDeLectura vg.Script_Goto iLineId,"","LeerCodigoConfirmacion","" 'This program ends here in abnormal form End If Rs.MoveNext Loop End If Share this post Link to post
SupportTeam Report post Posted 01/07/2008 04:00 AM If you could post the entire script then we can better answer your question, but I think the reason why you are having problem on line vg.Script_Goto iLineId,"","LeerCodigoConfirmacion","" 'This program ends here in abnormal form is because iLineId is not holding the actaul LineID value. Try: vg.Script_Goto $RV_LINEID,"","LeerCodigoConfirmacion","" Share this post Link to post
SupportTeam Report post Posted 01/07/2008 04:02 AM Also change: vg.RvSet LineID,"FileDeLectura",FileDeLectura to be vg.RvSet $RV_LINEID,"FileDeLectura",FileDeLectura Share this post Link to post
Guest DiegoBellini Report post Posted 01/07/2008 01:19 PM SupportTeam said: Also change: vg.RvSet LineID,"FileDeLectura",FileDeLectura to be vg.RvSet $RV_LINEID,"FileDeLectura",FileDeLectura I did the changes and they did not do effect, the program continues ending badly Thanks Share this post Link to post
SupportTeam Report post Posted 01/07/2008 04:49 PM Could you please post a copy of VoiceGuide's Trace Logs which captures the call, this will allow us to see what happened. Enable logging by setting the log levels to 10 in VG.INI as per below: Quote [Log] VoiceGuide=10 Then restart VG and make a test call which demonstrates the problem. Trace files will be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
