Vg Ivr Script Not Responding On Ring (urgent)
i am facing same problem which i was facing with Version 6.0.337 i.e. my dialogic is responding the demo program provieded by Dialogic but it's not responded the VG script. I have reinstalled dialogic and installed VG Version 7.0.4 trial version.
please find attached system infomation file and log file for same. I am in urgent need. So kindly help me how to solve the problem ASAP.
Expecting quick reply
Thanks in Advance.
0107vgm.zip
Are you using the latest SR6.0 drivers on this system?
VG v7 requires SR6.0 drivers installed.
If you are using SR6.0 drivers then can we get access to this system using logmein.com or similar to have a look at the system setup. Please forward login details to support@voiceguide.com along with a link to this forum thread.
please help in loction SR6.0 driver as i am unable to find it on dialogic not intel site. Can any provied me link for downloading Same.
Please also download the latest version of VG v7 that is available from our WWW now, and try with that version.
Please post traces as before if you still have problems.
please find system information and log file attached with this post. I am facing same problem as before. My dilogic is working fine with example but VG 7 is not ....
Please help me.
0108_1943_vgEngine.zip
Please help me.
Hello All,
My Spcl. thanks to all spcl. the support team for there prompt replies. I was able to play script of VG6.0 as i am short of time so i decieded not work with VG 7 for now.
Well i still have problem in playing Vox files please help me in this. I will also requier help in designing my script.
Presently i am using Demo version but within day or 2 support team will find me in there customers.
[Log]
VoiceGuide=10
ktTel=10
Please post your script design related questions in a new thread as it is a different topic.
