Guest kontoreXpress Report post Posted 08/25/2003 11:53 AM We are going to run a telemarketing app using VG Dialer on 4 lines attached to a Dialogic D/4PCI. How can we make it dial on all 4 lines simultaneously so it finishes the numbers-to-call-list more quickly? Thank you for responses. == LEVENT == Share this post Link to post
SupportTeam Report post Posted 08/26/2003 12:56 AM All lines which have "Allow VoiceGuide to dial out on this line" will be used by the dialer. (see "View"->"Line Device Config" menu) By default all lines are enabled for outbound dialing so you should see all 4 lines being used simultaneously - are you not seeing this? Share this post Link to post
