Run Multiple Scripts Within A Script
VG 5.2.5049
Hello guys, is there a way to switch between several scripts from another?
I have several scripts that do a function each, so I need to create another script as a main menu to choose what script to run.
Any idea?
Thanks in advance.
FM
Just specify the script's filename in the path to be taken.
From: http://www.voiceguide.com/vghelp/source/html/paths.htm :
Branching to other scripts and calling subscrips.
The Enterprise and Evaluation versions of VoiceGuide can call subscripts.
To branch (goto) to a script you can specify a path like this:
on {event} goto [script filename|module name]
eg: on {1} goto [c:\scripts\myscript.vgs|PlayWelcome]
To run a subscript (gosub) to a script you can specify a path:
on {event} gosub [script filename|module name]
eg: on {1} gosub [c:\scripts\myscript.vgs|PlayWelcome]
Oops, didn't read that part of the help.
It's great. Thanks a lot.
FM
