Double Bytes(chinese Word) Problem!
Hello,
I put a chinese word into VBscript file, when VoiceGuide ran to this VBscript file then VoiceGuide will hang up the line and break off whole procedures. Is it meaning the VoiceGuide doesn't support double bytes or chinese character set? The attached file is the VBscript file, please someone can help me to solve the problem. Thanks !
Paul
lib_num2wav.zip
Not sure if VBScript itself supports chinese characters. Have you tried creating a test VBScript file with chinese characters in it and running that VBScript using the wscript.exe or cscript.exe tools?
Would it be possible for you to work around using the chinese characters by writing the actual VBScript code in the Roman/Western letters?
We would need to see a trace from VoiceGuide to see what actually happened when the script was ran.
[Log]
VoiceGuide=10
The attached file is a copy of VoiceGuide's Trace Logs, thanks.
Paul
[Log]
VoiceGuide=10
0118vgm.zip
Traces show VoiceGuide started the VBScript, but looks like the VBScript with the chinese characters had problems running.
Suggest you do not use chinese characters in VBScript files.
