Guest fmonroy Report post Posted 01/21/2008 12:43 AM Hello guys, I'm trying to set up a test environment using trial version of the v7. I'm wondering if scripts are compatible to use them on v5 at production. Thanks in advance. FM. Share this post Link to post
SupportTeam Report post Posted 01/21/2008 01:02 AM Yes, the scripts are compatible. You should be able to take scripts from v5 and use them in v7. There are some changes in the some of the COM interface functions though, so if you are using the CO interface in your VBScripts then you may need to change a few functions calls. Share this post Link to post
Guest fmonroy Report post Posted 01/21/2008 01:03 AM Perfect, I'm not using those interfaces. Thanks a lot. Share this post Link to post
