jjohn Report post Posted 08/26/2003 02:01 AM Wth in my script there are several modules leading up to my voice mail boxs is there a way that after message is recorded it could loop back to the begging of the script . So that the client could run through the modules again to leave another message in another mail box Share this post Link to post
SupportTeam Report post Posted 08/26/2003 02:43 AM From VG Help file's "Paths" section: Returning from the Voicemail system If you would like the caller to go to a certain module after returning from the Voicemail system then you can specify a return module. The Path definition needs to be: On {Trigger} Goto [Voicemail System Module] Return [Module Title] The Current Paths settings will need to be edited by hand to specify such a path, the Add New Path help frame does not handle the Return option. Link to relevant page in the online version of Help file: http://VoiceGuide.com/vghelp/html/Paths.htm Share this post Link to post
